UnixOutlaw Posted February 1, 2019 Posted February 1, 2019 Banana Pi (original "model 1") A20 Was running flawlessly on Xenial - latest updates - almost everything worked (I run it on a LiPo battery to transport back and forth from work to keep my Resilio Sync data "in sync") Resilio seems to work fine - except in Bionic I can't use avahi to resolve names on my LAN... this worked in Xenial on the same hardware. The reason I decided to try out Bionic? Couldn't find a resource to upgrade from OpenSSH 7.2 to 7.3 or greater (I'm making heavy use of features not available in OpenSSH 7.2 on my other machines). I've tried tweaking my /etc/nsswitch.conf file to no avail... Sheesh - "avahi" just worked out of the box on Armbian Xenial - and it works out of the box on Bionic on x86_64... Works out of the box on Raspbian Stretch on my RPi 3B. Works out of the box on Armbian 5.6 (Xenial) on my Orange Pi+ 2E... Qualification : avahi works on the Banana in that other hosts can reach it (e.g. "ping ffrwchnedd.local" works from any other machine) - so it's announcing itself on my LAN, but it cannot use avahi to reach other hosts by hostname.local (no problem pining actual IP address of other devices). If I can't resolve this soon - I'll go back to Xenial and try and figure out how to do some version control on my ~/.ssh/config file(s) (I have a common one symlinked from my Resilio Sync folders). P.S. I didn't upgrade in place - I just booted from a fresh flashed SD card so I can backout to Armbian 5.6 Xenial without too much pain (other than re-syncing 130 GB of Resilio Sync folders - stored on 256 GB USB drive).
UnixOutlaw Posted February 2, 2019 Author Posted February 2, 2019 Update : it's not working on any of my Armbian machines... doesn't work on Xenial Armbian 5.7 on bananapi, or Xenial Armbian 5.6 on orangepi+ 2E... those machine names can be resolved from other hosts on the LAN, but they themselves are unable to resolve other machine names on my LAN. I could have sworn it was working previouisly. Close this topic - clearly not related to Armbian Bionic... I have no idea what's going on...
martinayotte Posted February 2, 2019 Posted February 2, 2019 I'm running Armbian Stretch on all my boards, and avahi-daemon is working on all of them, although default setting is "publish-workstation=no", I have to change to "yes" to make them visible in avahi-browse.
UnixOutlaw Posted February 4, 2019 Author Posted February 4, 2019 thanks for that info - the issue I have with Armbian, I can resolve the Armbian hosts on my LAN from other machines (all Linux), but from Armbian itself I can't resolve other host's names... Not 100% sure what "publish-workstation" does - but it kinda sounds like advertising itself on the LAN? Anyway I reset that to "yes" on a Linux laptop (x86_64) and on Armbian, and it's the same as before... I might try out stretch then... avahi works out of the box for me on Raspbian Stretch...
devman Posted February 4, 2019 Posted February 4, 2019 I had to change the entry in my /etc/nsswitch.conf to include "mdns4_minimal" in the "hosts: " line so it would resolve blahblah.local addresses
UnixOutlaw Posted February 5, 2019 Author Posted February 5, 2019 22 hours ago, devman said: I had to change the entry in my /etc/nsswitch.conf to include "mdns4_minimal" in the "hosts: " line so it would resolve blahblah.local addresses Already tried that - still won't resolve hostnames on my LAN (two different LANs - my home LAN and my work LAN)... NSSWITCH usually one of the first places I look (hangover from Solaris)... hosts: files mdns4_minimal dns myhostname Also - noticed some wildly different results from /sys/power/axp_pmu/battery/ output compared to Armbian Xenial on the same hardware... I don't know if that's because Bionic is drawing more power and battery never gets to 100%... but its always around 96% and always "discharging" ╰─➤ cat /sys/power/axp_pmu/battery/capacity 96 ╰─➤ cat /sys/power/axp_pmu/battery/charging 0
