Baos Posted April 7, 2016 Posted April 7, 2016 My cubietruck mac address which I am assuming is auto generated is invalid. Though one would think it should work, other software on routers will not accept the mac as valid, and thus I can not add configurations to it. We probably need a layer somewhere to create 'valid' mac addresses. 02:C2:07:C0:B7:C7 is the generated mac that my cubietruck is currently using which software claims is invalid.
wahlm Posted April 7, 2016 Posted April 7, 2016 Hi Baos, the mac address is not invalid, but it is marked as a locally administered address. The mac addresses devices usually get from their manufacturer are universally administered addresses. So it seems the SW on your router doesn't like these perfectly valid addresses. I fear Igor doesn't have an Organizationally Unique Identifier (OUI) to create UAA mac addresses , so LAA is the correct way to go. Bye, wahlm 1
tkaiser Posted April 7, 2016 Posted April 7, 2016 My cubietruck mac address which I am assuming is auto generated is invalid. Based on the SoC's so called SID u-boot generates a unique and persistent locally administered MAC address. You should throw your router in the bin and should also start to think about the relevance of problems you're running into (since hundreds of thousands if not even millions of ARM devices get their MAC address this way) 1
Gravelrash Posted April 7, 2016 Posted April 7, 2016 +1 for what tkaiser said all my test routers branded and Openwrt based accept the LAA addresses. maybe you need to change or update firmwares on your routers etc
Baos Posted April 7, 2016 Author Posted April 7, 2016 Based on the SoC's so called SID u-boot generates a unique and persistent locally administered MAC address. You should throw your router in the bin and should also start to think about the relevance of problems you're running into (since hundreds of thousands if not even millions of ARM devices get their MAC address this way) Just threw my asus rt-ac87u in the bin because I got tired of it malfunctioning. I no longer like asus products. So, for the moment I had to turn my cable modem back into a gateway. That said, I found allwinner owns an OUI DC446D and applied it.
