Quantum Posted February 17, 2019 Posted February 17, 2019 Trying to reach a headless TinkerBoard with X2Go so I can set up wifi. SELinux is disabled. I can SSH in as my user just fine, with and without -i, but when setting the Pyhoca session to "Discover SSH Keys", I get "Not a valid EC private key file!" Ok, apparently it wants an elliptic curve key. It never used to accept anything but DSA and RSA. So I made an ecdsa keypair and ssh-copy-id to the TB. Same failure. I know that X2Go can't handle ed25519 unfortunately, so I don't even have that key for my user. When setting the Pyhoca session SSH key manually to /home/bill/.ssh/id_rsa or /home/bill/.ssh/id_ecdsa, I get, "Not a valid EC private key file!" When not setting the Pyhoca session SSH key either way, and password is allowed on the TB server, it comes up with a dialog box asking for password, and when I enter the correct one I get, "Authentication failed!" Needless to say, all three methods work on the commandline. Showstopper because I can't configure wifi without NetworkManager and NetworkManager requires a GUI, and this machine is headless. Researched this to the ends of the Earth, but the issues were X2Go from a Windows client (I'm CentOS), a permissions problem on keys or .ssh, or ssh_config forwarding was disabled. None apply here. #x2go irc is moribund, and the dev left to do the dishes.
martinayotte Posted February 17, 2019 Posted February 17, 2019 1 hour ago, Quantum said: Showstopper because I can't configure wifi without NetworkManager and NetworkManager requires a GUI, Workaround is to use "nmtui", it doesn't required any GUI, it is command line ...
Quantum Posted February 17, 2019 Author Posted February 17, 2019 I now remember discovering nmtui in the past two weeks and trying that too. I can add and set up the wifi interface just fine. But when I go to Activate it... it's not there. Stop/restart nmtui and the interface is still in Add... but only eth0 is in Activate. Maybe this Armbian is impractical/impossible. Why does everyone say that nmtui works for wifi when it doesn't? Or is it that it doesn't work on the current release?
martinayotte Posted February 17, 2019 Posted February 17, 2019 10 minutes ago, Quantum said: I can add and set up the wifi interface just fine. But when I go to Activate it... it's not there. Are you doing that with "sudo" ? If "nmtui" isn't working for unknown reason, you can also try to use "wpa_cli" ...
Quantum Posted February 17, 2019 Author Posted February 17, 2019 I always work as root for config. I've run Linux exclusively for 22 years. I ran Debian for 15 of those years, but packages weren't updated so I went to CentOS. Now it looks to me like Debian has descended into chaos. Thanks, but wpa_cli has 156 commands. I've already lost a week full-time tryin to set up this wifi interface using every other method that exists, each one failing in one way of another. Are you saying that nmtui will add a wifi WPA2 interface for you successfully? Have you tried this with the current Armbian saveset?
martinayotte Posted February 17, 2019 Posted February 17, 2019 11 minutes ago, Quantum said: but wpa_cli has 156 commands. This tutorial could help : https://wiki.archlinux.org/index.php/WPA_supplicant On my side, I'm an oldtimer guy, so I'm still using old way to setup WiFi directly in /etc/network/interface ...
Quantum Posted February 17, 2019 Author Posted February 17, 2019 I think it can't work because I have a TB S. And none of the rest of you has an S. So Armbian is busted with the TB S. Yes, and manual setup was what I fell back to after NetworkManager, connman, and nmtui failed. eth0 worked fine, but no matter how I set up wpa and wlan0 it would not associate. It would try, but fail with Reason 11. (regulatory not met) I manually copied regulatory.db and regulatory.db.t4k into /lib/firmware but boot still couldn't find it. With a clean install and then nmtui, eth0 gets the right static IP, but it is incommunicado with the rest of the network, even after reboot. This is a lost cause. I've wasted over a week on a fool's errand. I should have known better than to mess with Debian again, and just learned how to compile u-boot for Fed.
