laurentppol Posted February 18, 2019 Share Posted February 18, 2019 Armbianmonitor: http://ix.io/1Bqx Hi there, after a recent apt upgrade I have problem with WiFi. I CAN connect to one WiFi, WPA2, static IP. However I CAN'T connect to another one, WPA2, tried with static and dynamic IP. I am using NetworkManager. Searched forum, deleted /etc/networks/interfaces. Information in /etc/NetworkManager/"network name" seems to be correct. Almost the same as for working net. (except uuid & IP info) CAN also connect from laptop. wpa_supplicant line from ps: /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant What should I check else? Link to comment Share on other sites More sharing options...
laurentppol Posted February 18, 2019 Author Share Posted February 18, 2019 6 minutes ago, laurentppol said: Armbianmonitor: http://ix.io/1Bqx Hi there, after a recent apt upgrade I have problem with WiFi. I CAN connect to one WiFi, WPA2, static IP. However I CAN'T connect to another one, WPA2, tried with static and dynamic IP. I am using NetworkManager. But same problem with wicd. It accepts password, then LONG "working" icon, then same password dialog box. With wicd it simply does not connect. Searched forum, deleted /etc/networks/interfaces. Information in /etc/NetworkManager/"network name" seems to be correct. Almost the same as for working net. (except uuid & IP info) CAN also connect from laptop. wpa_supplicant line from ps: /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant What should I check else? Link to comment Share on other sites More sharing options...
