lukaszertel Posted February 20, 2019 Posted February 20, 2019 Armbianmonitor: http://ix.io/1BCH Dear Armbian friends, I have question about add DS18B20 temp sensor at RPi-Monitor (web based interface). Can somebody paste working config of this sensor? On internet I found many tutorials but with DHT sensors. On this page (Xavier is an author of RPi-Monitor I think) is described DS18B20 but in status "Working in progress". I tried this but without luck. https://xavierberger.github.io/RPi-Monitor-docs/32_sensors.html?highlight=ds18b20 Cheers, Lucas
martinayotte Posted February 20, 2019 Posted February 20, 2019 5 minutes ago, lukaszertel said: I tried this but without luck. Is the DS18B20 driver working fine from command line using "cat /sys/bus/w1/devices/28-000004fe1847/w1_slave" ? In the link you've provided, it is mention that you only have to add a reg_expr, but there is also a note : Quote Note: In version 1.x of RPi-Monitor it is prohibited to use = in regular expression.
lukaszertel Posted February 20, 2019 Author Posted February 20, 2019 Working like a charm :-) root@orangepizero:/etc/rpimonitor# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave 6a 01 55 05 7f 7e 81 66 1d : crc=1d YES 6a 01 55 05 7f 7e 81 66 1d t=22625 I've lastest available version of RPi-Monitor on my Orange Pi Zero: Version: 2.12-r0 by Xavier Berger I tested both values: t.(d+)$ and t=(d+)$ Those values are used in conf file, in my case custo.conf witch is mentioned in main config file /etc/rpimonitor/data.conf Of course, after each change I restart service with command: service rpimonitor restart ====== Edited: ====== I found that this two sections are only important for drawing temperature stats: dynamic.18.name=045 dynamic.18.source=/sys/bus/w1/devices/28-020b92459bc7/w1_slave dynamic.18.regexp=t.(d+)$ dynamic.18.postprocess=sprintf("%.2f", $1/1000) dynamic.18.rrd=GAUGE web.statistics.1.content.18.name=045 web.statistics.1.content.18.graph.1=045 web.statistics.1.content.18.ds_graph_options.045.label=045 (°C) What I'm not sure is regular expression, can someone tell me how to extract only temperature value from this command? cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave
FRANK333 Posted March 4, 2019 Posted March 4, 2019 hi lukaszertel, To create the sensor graph you have to decomment include=/etc/rpimonitor/template/dht11.conf in the file /etc/rpimonitor/data.conf Then go with nano /etc/rpimonitor/template/dht11.conf and modify the temperature sensor code you can comment on the humidity parameters to not see them anymore. Below here, there is the modified dh11 file for your external sensor Spoiler cat /etc/rpimonitor/template/dht11.conf ######################################################################## # Extract temperature and humidity from DHT11/DHT22 # Page: 2 # Information Status Statistics # - tempetature - yes - yes # - humidity - yes - yes ####################################################################### # Add new pages (number 2) web.status.2.name=Living room web.statistics.2.name=Living room # Get dynamic data dynamic.1.name=living_room_temp dynamic.1.source=/sys/devices/w1_bus_master1/28-020b92459bc7/w1_slave dynamic.1.regexp=t=(\d+)$ dynamic.1.postprocess=$1/1000 dynamic.1.rrd=GAUGE dynamic.2.name=humidity dynamic.2.source=Adafruit_DHT 11 27 dynamic.2.regexp=Hum = (\S+) dynamic.2.postprocess= dynamic.2.rrd=GAUGE # Add a line of status in page number 2 web.status.2.content.1.name=Temperature web.status.2.content.1.icon=cpu_temp.png web.status.2.content.1.line.1="Ambient Temperature: <b>"+data.living_room_temp+"°C</b>" web.status.2.content.1.line.2="Ambient Humidity: <b>"+data.humidity+"%</b>" # Add a statistic graph (with 2 curves suing separate scales) in page number 2 web.statistics.2.content.1.name=Temperature web.statistics.2.content.1.graph.1=living_room_temp web.statistics.2.content.1.graph.2=humidity web.statistics.2.content.1.ds_graph_options.living_room_temp.label=Ambient temp. (deg C) web.statistics.2.content.1.ds_graph_options.humidity.label=Humidity (%) web.statistics.2.content.1.ds_graph_options.humidity.yaxis=2 #web.statistics.2.content.1.graph_options.legend= { position: "sw"} web.statistics.2.content.1.graph_options.y2axis={ position: "right", min: 0, max: 100 } Spoiler
lukaszertel Posted March 4, 2019 Author Posted March 4, 2019 Thank You Frank, I will check it at friday. At the moment I don't have access to my Orange Pi. And of couse I will write down my results. Cheers! ================= --------Edited-------- ================= It works! I only commented out humidity parameters - rest is as You suggested. Thank You once again for help FRANK333 :-) One additional question: I messed up a little bit with setting correct time on my Orange Pi Zero. I changed it and now it's correct, but not on stats graph. On browser tab with Statistics there is still incorrect time displayed. ================= --------Edited-------- ================= SOLVED! To solve issue with incorrect hours on stats page graph I found rrd file in /var/lib/rpimonitor/stat directory. Simply remove and restart RPi Monitor did the trick. Cheers!
