Hi. Recently i upgraded to Armbian_5.65_Orangepilite_Debian_stretch_next_4.14.78 and i have two problems. I can not read the thermal zones properly with neither of those:
cat /sys/class/thermal/thermal_zone0/temp
cat /sys/devices/virtual/thermal/thermal_zone0/temp
cat /etc/armbianmonitor/datasources/soctemp
because i have results like "30371". But when the system starts the correct temperature is displayed:
Welcome to ARMBIAN 5.73 stable Debian GNU/Linux 9 (stretch) 4.19.20-sunxi
System load:   0.07 0.15 0.10   Up time:       10 min
Memory usage:  29 % of 493MB    IP:            192.168.1.46
CPU temp:      33°C
Usage of /:    10% of 15G
and with armbianmonitor too:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
17:39:34: 1200MHz  0.06   3%   1%   1%   0%   0%   0% 34.6°C  0/15
17:39:39:  480MHz  0.06   1%   0%   0%   0%   0%   0% 31.5°C  0/15
17:39:45:  480MHz  0.13   4%   3%   0%   0%   0%   0% 31.8°C  0/15
My second problem is that my DS18B20 sonda does not work anymore. In /etc/modules-load.d/modules.conf i have:
w1-sunxi
w1-gpio
w1-therm
but there is nothing in /sys/bus/w1/devices/
is there any changes in this new version? I check the forum but i does not found anything. Any iddeas?
Thanks in advance.
You should not place any W1 driver in /etc/modules-load.d/modules.conf ...
You should rely on DT overlays : https://docs.armbian.com/User-Guide_Allwinner_overlays/
... and more specially to H3 W1-Bus overlay parameters : https://github.com/armbian/sunxi-DT-overlays/blob/master/sun8i-h3/README.sun8i-h3-overlays#L231,L250
Yes. Thank you martinayotte. If sombody needs that, i just have to add this lines to '/boot/armbianEnv.txt'
overlays=w1-gpio
param_w1_pin=PA20
param_w1_pin_int_pullup=1
and works like a charm! Thank you very much.
And, what about the strange readings in thermal_zones. My cpu give me 22.6ºC with armbianmonitor, but reading directly in any of the thermal zones with cat i have readings like '40898'.
What has changed from previous versions?
Than you in advance.
wow. I just realized that the CPU temperature in armbianmonitor is the same that the one i have reading the DS18B20 sonda ....
What is going on??
DS18B20 can't work for a long time
<code>
yaofei@opione2:~$ dmesg | grep w1
[    8.227238] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[   55.575200] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
[   55.579572] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[  114.185133] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
[  114.189866] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
yaofei@opione2:~$ uname -a
Linux opione2 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l armv7l armv7l GNU/Linux
yaofei@opione2:~$ ls /sys/bus/w1/
devices/           drivers/           drivers_autoprobe  drivers_probe      uevent
yaofei@opione2:~$ ls /sys/bus/w1/devices/
00-400000000000  00-800000000000  w1_bus_master1
yaofei@opione2:~$
</code>
my armbianEnv.txt:
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
rootdev=UUID=fc233414-8f78-4254-8d95-049158fc59da
rootfstype=ext4
overlays=uart1 usbhost0 w1-gpio #pps-gpio
param_w1_pin=PA10
an OrangePi One
yaofeideMac-Pro:~ yaofei$ ssh opione2.local
  ___                               ____  _    ___
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_)  / _ \ _ __   ___
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | '_ \ / _ \
| |_| | | | (_| | | | | (_| |  __/ |  __/| | | |_| | | | |  __/
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_|  \___/|_| |_|\___|
                       |___/
Welcome to ARMBIAN 5.73 stable Ubuntu 18.04.2 LTS 4.19.20-sunxi
System load:   1.18 0.26 0.09  	Up time:       0 min
Memory usage:  23 % of 493MB  	IP:            192.168.20.60
CPU temp:      46°C
Usage of /:    51% of 7.2G
Last login: Mon Mar  4 19:17:02 2019 from 192.168.20.40
what is the MIN_SPEED in /etc/default/cpufrequtils ? If it is too low, W1 may get into trouble, I´m usually set the MIN_SPEED to 480000 ...
see:
yaofei@opione2:~$ cat /etc/default/cpufrequtils
# WARNING: this file will be replaced on board support package (linux-root-...) upgrade
ENABLE=true
MIN_SPEED=408000
MAX_SPEED=1200000
GOVERNOR=ondemand
15 minutes ago, mantouboji said:
My OrangePi One and wires. Is it PA20 ?
As said in the other thread : In /boot/armbianEnv.txt, along with adding w1-gpio to overlays, did you provided W1 parameters, param_w1_pin and param_w1_pin_int_pullup ?
mantouboji,
  • you can give this command: cat /sys/kernel/debug/pinctrl/1c20800.pinctrl/pinmux-pins, and cat /sys/kernel/debug/pinctrl/pinctrl-maps
  • you should have the sensor connected to pin 37 and the PA20 in your armbianEnv.txt: instead there seems to be PA10.
  • can you put a photo of your sensor and how it is connected?
ps: the dupont connector in the photo at pin 37 does not appear to be securely attached:)
I chang to use PIN 4 to get 5V and PIN6 to get GND, it works. Thx .
But only works for a short time, now :
yaofei@opione2:~$ journalctl -fn | grep w1
3月 06 11:16:48 opione2 hass[808]: 2019-03-06 11:16:48 ERROR (SyncWorker_1) [homeassistant.components.sensor.onewire] No onewire sensor found. Check if dtoverlay=w1-gpio is in your /boot/config.txt. Check the mount_dir parameter if it's defined
3月 06 11:17:34 opione2 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
3月 06 11:17:34 opione2 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
3月 06 11:18:32 opione2 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
3月 06 11:18:32 opione2 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
Now I use another OrangePi One board to do some testing.
It runs an old version of Armbian
  ___                               ____  _    ___
                       |___/
Welcome to ARMBIAN 5.65 user-built Ubuntu 18.04.1 LTS 4.14.81-sunxi
System load:   0.86 0.21 0.07  	Up time:       0 min
Memory usage:  12 % of 493MB  	IP:            192.168.20.113
CPU temp:      33°C
Usage of /:    20% of 7.3G
I connect 3 18B20 heads to PA20.
It can't  find any of them.
so I upgrade to the latest version
Now it works.
So there must be some fix after 4.14.81 .
My configuration files are:
verbosity=1
logo=disabled
console=both
rootdev=UUID=8d2923b7-39e0-426b-82b6-476bc5af0db2
rootfstype=ext4
# UART1 for GPS
# PPS for GPS
# w1-gpio for DS18B20
overlays=w1-gpio pps-gpio uart1 usbhost0
param_w1_pin=PA20
param_pps_pin=PA7
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
the /etc/default/cpufrequtils file is the default one.
ENABLE=true
MIN_SPEED=408000
MAX_SPEED=1200000
GOVERNOR=ondemand
 The pull-up resistor must be 4.7K.
