H4
tcpdump seems to be missing from the repositories. Can anyone confirm this?
Other than full source build   can anyone suggest a quick fix.
Roger
37 minutes ago, wearyhacker said:
Yes. It returns not found.
Strange ! You have probably networking issue :
You can also download it manually from http://ftp.debian.org/debian/pool/main/t/tcpdump/tcpdump_4.9.2-1~deb8u1_armhf.deb
  ___                               ____  _   _____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |__  /___ _ __ ___
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |   / // _ \ '__/ _ \
| |_| | | | (_| | | | | (_| |  __/ |  __/| |  / /|  __/ | | (_) |
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| /____\___|_|  \___/
                       |___/
Welcome to ARMBIAN 5.76 user-built Debian GNU/Linux 9 (stretch) 4.20.12-sunxi
System load:   0.14 0.13 0.09      Up time:       5 days
Memory usage:  13 % of 493MB      IP:            10.111.111.61
Usage of /:    9% of 15G
[ 0 security updates available, 35 updates total: apt upgrade ]
Last check: 2019-03-06 00:00
Last login: Mon Mar  4 09:16:08 2019 from 10.111.111.11
root@orangepizero:~# apt-get install tcpdump
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  tcpdump
0 upgraded, 1 newly installed, 0 to remove and 35 not upgraded.
Need to get 396 kB of archives.
After this operation, 864 kB of additional disk space will be used.
Get:1 http://cdn-fastly.deb.debian.org/debian stretch/main armhf tcpdump armhf 4.9.2-1~deb9u1 [396 kB]
Fetched 396 kB in 1s (202 kB/s)
Selecting previously unselected package tcpdump.
(Reading database ... 36429 files and directories currently installed.)
Preparing to unpack .../tcpdump_4.9.2-1~deb9u1_armhf.deb ...
Unpacking tcpdump (4.9.2-1~deb9u1) ...
Setting up tcpdump (4.9.2-1~deb9u1) ...
Processing triggers for man-db (2.7.6.1-2) ...
What does your apt sources list look like.
Mine looks like this.
roger@wart:~$ cd /etc/apt
roger@wart:/etc/apt$ cat sources.list
roger@wart:/etc/apt$ cat sources.list.d/*
deb http://apt.armbian.com stretch main stretch-utils stretch-desktop
Top level file is empty.
http://cdn-fastly.deb.debian.org/debian is not mentioned anywhere. Unusual that the top level file is empty. I doo not recall clearing it.
Roger
Roger
that's definitely odd that it got erased.     The armbian repo just has armbian packages, so you'll need to recreate sources.list.
see if this tool can help https://debgen.simplylinux.ch/
