wearyhacker Posted March 6, 2019 Share Posted March 6, 2019 H4 tcpdump seems to be missing from the repositories. Can anyone confirm this? Other than full source build can anyone suggest a quick fix. Roger Link to comment Share on other sites More sharing options...
lanefu Posted March 6, 2019 Share Posted March 6, 2019 Which distro? Is it part of a different package? Link to comment Share on other sites More sharing options...
wearyhacker Posted March 6, 2019 Author Share Posted March 6, 2019 Debian stretch for orange pi zero. Normal debian stretch distro has a package called tcpdump. Link to comment Share on other sites More sharing options...
martinayotte Posted March 6, 2019 Share Posted March 6, 2019 4 hours ago, wearyhacker said: tcpdump seems to be missing Did you tried "apt-get install tcpdump" ? Link to comment Share on other sites More sharing options...
wearyhacker Posted March 6, 2019 Author Share Posted March 6, 2019 Yes. It returns not found. Link to comment Share on other sites More sharing options...
martinayotte Posted March 6, 2019 Share Posted March 6, 2019 37 minutes ago, wearyhacker said: Yes. It returns not found. Strange ! You have probably networking issue : You can also download it manually from http://ftp.debian.org/debian/pool/main/t/tcpdump/tcpdump_4.9.2-1~deb8u1_armhf.deb ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN 5.76 user-built Debian GNU/Linux 9 (stretch) 4.20.12-sunxi System load: 0.14 0.13 0.09 Up time: 5 days Memory usage: 13 % of 493MB IP: 10.111.111.61 Usage of /: 9% of 15G [ 0 security updates available, 35 updates total: apt upgrade ] Last check: 2019-03-06 00:00Last login: Mon Mar 4 09:16:08 2019 from 10.111.111.11root@orangepizero:~# apt-get install tcpdump Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: tcpdump 0 upgraded, 1 newly installed, 0 to remove and 35 not upgraded. Need to get 396 kB of archives. After this operation, 864 kB of additional disk space will be used. Get:1 http://cdn-fastly.deb.debian.org/debian stretch/main armhf tcpdump armhf 4.9.2-1~deb9u1 [396 kB] Fetched 396 kB in 1s (202 kB/s) Selecting previously unselected package tcpdump. (Reading database ... 36429 files and directories currently installed.) Preparing to unpack .../tcpdump_4.9.2-1~deb9u1_armhf.deb ... Unpacking tcpdump (4.9.2-1~deb9u1) ... Setting up tcpdump (4.9.2-1~deb9u1) ... Processing triggers for man-db (2.7.6.1-2) ... root@orangepizero:~# Link to comment Share on other sites More sharing options...
wearyhacker Posted March 7, 2019 Author Share Posted March 7, 2019 What does your apt sources list look like. Mine looks like this. roger@wart:~$ cd /etc/apt roger@wart:/etc/apt$ cat sources.list roger@wart:/etc/apt$ cat sources.list.d/* deb http://apt.armbian.com stretch main stretch-utils stretch-desktop Top level file is empty. http://cdn-fastly.deb.debian.org/debian is not mentioned anywhere. Unusual that the top level file is empty. I doo not recall clearing it. Roger Link to comment Share on other sites More sharing options...
lanefu Posted March 7, 2019 Share Posted March 7, 2019 2 hours ago, wearyhacker said: What does your apt sources list look like. Mine looks like this. roger@wart:~$ cd /etc/apt roger@wart:/etc/apt$ cat sources.list roger@wart:/etc/apt$ cat sources.list.d/* deb http://apt.armbian.com stretch main stretch-utils stretch-desktop Top level file is empty. http://cdn-fastly.deb.debian.org/debian is not mentioned anywhere. Unusual that the top level file is empty. I doo not recall clearing it. Roger that's definitely odd that it got erased. The armbian repo just has armbian packages, so you'll need to recreate sources.list. see if this tool can help https://debgen.simplylinux.ch/ Link to comment Share on other sites More sharing options...
wearyhacker Posted March 7, 2019 Author Share Posted March 7, 2019 Thanks that fixed it. Link to comment Share on other sites More sharing options...
