Jodaille Posted March 18, 2019 Posted March 18, 2019 (edited) Armbianmonitor: http://ix.io/1DR9 Hello, I am trying to communicate with a mcp2515 breakout (8Mhz oscillator) on an Orange Pi Pc+ I have modified the breakout following info on Raspberry Pi: HowTo/Quickstart MCP2515 to keep logic level @3v I have two other nodes composed by two Arduinos, with same (not modified) breakout, one that transmits the other receives. I have successfully tested the first breakout (used on OPi) with an Arduino (powered by 3.3v and 5v on TJA1050). It lets me think that hardware is OK. Below photos of wiring (nb: orange wire becomes red, is wired near TJA1050 = 5v): It seems I have the same results with (edited) user_overlay and the compiled one provided in zador.blood.stained's post dmesg| grep 'can\|mcp\|spi' [ 6.701431] mcp251x spi0.0 can0: MCP2515 successfully initialized. [ 28.455699] can: controller area network core (rev 20170425 abi 9) [ 28.471752] can: raw protocol (rev 20170425) The controller seems well seen, I can bring up the can0 interface: sudo ip link set can0 type can bitrate 125000 triple-sampling on sudo ifconfig can0 up ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 but candump is mute although the Arduino receiver displays messages from Arduino transmitter. And cansend do not give error but I could not see this messages on Arduino receiver. Does someone would have an idea of what I am missing ? Edited March 19, 2019 by Jodaille add link user overlay spi-mcp251x.dts
nopnop2002 Posted March 31, 2019 Posted March 31, 2019 Do you have terminator register?? It's mine. $ cat /boot/armbianEnv.txt verbosity=1 logo=disabled console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootdev=UUID=4c260e6c-6b83-490b-9c33-a1c61c5840a5 rootfstype=ext4 overlays=i2c0 i2c1 i2c2 spi-spidev extraargs=net.ifnames=0 ##param_spidev_spi_bus=0 user_overlays=spi-mcp251x usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u $ dmesg| grep 'can\|mcp\|spi' [ 5.578413] mcp251x spi0.0 can0: MCP2515 successfully initialized. [ 137.204768] can: controller area network core (rev 20170425 abi 9) [ 137.219630] can: raw protocol (rev 20170425) $ lsmod | grep can can_dev 20480 1 mcp251x $ ls /sys/bus/spi/devices/spi0.0 driver modalias net of_node power statistics subsystem uevent $ ls /sys/bus/spi/devices/spi0.0/net can0 $ ls /sys/bus/spi/devices/spi0.0/net/can0 addr_assign_type dev_id link_mode proto_down address dev_port mtu queues addr_len dormant name_assign_type speed broadcast duplex netdev_group statistics carrier flags operstate subsystem carrier_changes gro_flush_timeout phys_port_id tx_queue_len carrier_down_count ifalias phys_port_name type carrier_up_count ifindex phys_switch_id uevent $ sudo ip link set can0 type can bitrate 125000 triple-sampling on $ sudo ifconfig can0 can0: flags=128<NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 $ sudo ifconfig can0 up $ sudo ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Jodaille Posted September 7, 2019 Author Posted September 7, 2019 Hello, sorry for the long long late reply. I have abandoned this project for now, I think I am not (yet) clever enough to find a reason/solution. Thank you @nopnop2002 for your help!
svd93 Posted April 25, 2020 Posted April 25, 2020 On 3/31/2019 at 9:41 AM, nopnop2002 said: Do you have terminator register?? It's mine. $ cat /boot/armbianEnv.txt verbosity=1 logo=disabled console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootdev=UUID=4c260e6c-6b83-490b-9c33-a1c61c5840a5 rootfstype=ext4 overlays=i2c0 i2c1 i2c2 spi-spidev extraargs=net.ifnames=0 ##param_spidev_spi_bus=0 user_overlays=spi-mcp251x usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u $ dmesg| grep 'can\|mcp\|spi' [ 5.578413] mcp251x spi0.0 can0: MCP2515 successfully initialized. [ 137.204768] can: controller area network core (rev 20170425 abi 9) [ 137.219630] can: raw protocol (rev 20170425) $ lsmod | grep can can_dev 20480 1 mcp251x $ ls /sys/bus/spi/devices/spi0.0 driver modalias net of_node power statistics subsystem uevent $ ls /sys/bus/spi/devices/spi0.0/net can0 $ ls /sys/bus/spi/devices/spi0.0/net/can0 addr_assign_type dev_id link_mode proto_down address dev_port mtu queues addr_len dormant name_assign_type speed broadcast duplex netdev_group statistics carrier flags operstate subsystem carrier_changes gro_flush_timeout phys_port_id tx_queue_len carrier_down_count ifalias phys_port_name type carrier_up_count ifindex phys_switch_id uevent $ sudo ip link set can0 type can bitrate 125000 triple-sampling on $ sudo ifconfig can0 can0: flags=128<NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 $ sudo ifconfig can0 up $ sudo ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Well, I have same problem. Seems that everything is correct but I don't have any candump output pasha@orangepipcplus:~$ sudo ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 pasha@orangepipcplus:~$ sudo ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 pasha@orangepipcplus:~$ lsmod | grep can can_raw 20480 0 can_dev 20480 1 mcp251x can 20480 1 can_raw pasha@orangepipcplus:~$ dmesg | grep "can\|mcp\|spi" [ 6.236392] can: controller area network core (rev 20170425 abi 9) [ 6.246062] can: raw protocol (rev 20170425) [ 7.585019] mcp251x spi0.0 can0: MCP2515 successfully initialized. pasha@orangepipcplus:~$ but: pasha@orangepipcplus:~$ candump can0 - no output resistor is OK, I connect Opi to existing can bus where one device sends data and second receive successfully Also I wonder why I can't compile overlay from example https://github.com/armbian/sunxi-DT-overlays/blob/master/examples/spi-mcp251x.dts sudo armbian-add-overlay spi-mcp251x.dts Compiling the overlay dtc: livetree.c:521: get_node_by_phandle: Assertion `(phandle != 0) && (phandle != -1)' failed. /usr/sbin/armbian-add-overlay: line 81: 2323 Aborted dtc -@ -q -I dts -O dtb -o ${temp_dir}/${fname}.dtbo $1 Error compiling the overlay Device tree compiler is newest version (1.4.5-3) thanks for help...
lowag Posted August 3, 2020 Posted August 3, 2020 On 4/25/2020 at 7:00 PM, svd93 said: Well, I have same problem. Seems that everything is correct but I don't have any candump output pasha@orangepipcplus:~$ sudo ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 pasha@orangepipcplus:~$ sudo ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 pasha@orangepipcplus:~$ lsmod | grep can can_raw 20480 0 can_dev 20480 1 mcp251x can 20480 1 can_raw pasha@orangepipcplus:~$ dmesg | grep "can\|mcp\|spi" [ 6.236392] can: controller area network core (rev 20170425 abi 9) [ 6.246062] can: raw protocol (rev 20170425) [ 7.585019] mcp251x spi0.0 can0: MCP2515 successfully initialized. pasha@orangepipcplus:~$ but: pasha@orangepipcplus:~$ candump can0 - no output resistor is OK, I connect Opi to existing can bus where one device sends data and second receive successfully Also I wonder why I can't compile overlay from example https://github.com/armbian/sunxi-DT-overlays/blob/master/examples/spi-mcp251x.dts sudo armbian-add-overlay spi-mcp251x.dts Compiling the overlay dtc: livetree.c:521: get_node_by_phandle: Assertion `(phandle != 0) && (phandle != -1)' failed. /usr/sbin/armbian-add-overlay: line 81: 2323 Aborted dtc -@ -q -I dts -O dtb -o ${temp_dir}/${fname}.dtbo $1 Error compiling the overlay Device tree compiler is newest version (1.4.5-3) thanks for help... For those who bump into the same problem. Change in the spi-mcp251x.dts file: from "clock-frequency = <8000000>;" to "clock-frequency = <16000000>;". (although the quartz on the can modul board is definitely 8Mhz)
martinayotte Posted August 3, 2020 Posted August 3, 2020 26 minutes ago, lowag said: Device tree compiler is newest version (1.4.5-3) This version is far from been the newest, and I doubt it is supporting the "-@" option for symbols. Download at least the 1.4.7 from 2018, from http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/
lowag Posted August 3, 2020 Posted August 3, 2020 My problem was on the latest system. According to dmesg, ifconfig everything OK but did not work at all until I changed the frequency. uname -a Linux orangepione 5.4.45-sunxi #20.05.4 SMP Sun Jun 14 21:46:20 CEST 2020 armv7l armv7l armv7l GNU/Linux
