Posted (edited)
Armbianmonitor:
Hello,
I am trying to communicate with a mcp2515 breakout (8Mhz oscillator) on an Orange Pi Pc+
I have modified the breakout following info on Raspberry Pi: HowTo/Quickstart MCP2515 to keep logic level @3v
I have two other nodes composed by two Arduinos, with same (not modified) breakout, one that transmits the other receives.
I have successfully tested the first breakout (used on OPi) with an Arduino (powered by 3.3v and 5v on TJA1050).
It lets me think that hardware is OK.
Below photos of wiring (nb: orange wire becomes red, is wired near TJA1050 = 5v):
Wiring Opi <-> mcp2515
It seems I have the same results with (edited) user_overlay and the compiled one provided in zador.blood.stained's post
dmesg| grep 'can\|mcp\|spi'
[    6.701431] mcp251x spi0.0 can0: MCP2515 successfully initialized.
[   28.455699] can: controller area network core (rev 20170425 abi 9)
[   28.471752] can: raw protocol (rev 20170425)
The controller seems well seen, I can bring up the can0 interface:
sudo ip link set can0 type can bitrate 125000 triple-sampling on
sudo ifconfig can0 up
ifconfig can0
can0: flags=193<UP,RUNNING,NOARP>  mtu 16
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
but candump is mute although the Arduino receiver displays messages from Arduino transmitter.
And cansend do not give error but I could not see this messages on Arduino receiver.
Does someone would have an idea of what I am missing ?
Edited by Jodaille
add link user overlay spi-mcp251x.dts
Do you have terminator register??
It's mine.
$ cat /boot/armbianEnv.txt
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
rootdev=UUID=4c260e6c-6b83-490b-9c33-a1c61c5840a5
rootfstype=ext4
overlays=i2c0 i2c1 i2c2 spi-spidev
extraargs=net.ifnames=0
##param_spidev_spi_bus=0
user_overlays=spi-mcp251x
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
$ dmesg| grep 'can\|mcp\|spi'
[    5.578413] mcp251x spi0.0 can0: MCP2515 successfully initialized.
[  137.204768] can: controller area network core (rev 20170425 abi 9)
[  137.219630] can: raw protocol (rev 20170425)
$ lsmod | grep can
can_dev                20480  1 mcp251x
$ ls /sys/bus/spi/devices/spi0.0
driver  modalias  net  of_node  power  statistics  subsystem  uevent
$ ls /sys/bus/spi/devices/spi0.0/net
can0
$ ls /sys/bus/spi/devices/spi0.0/net/can0
addr_assign_type    dev_id             link_mode         proto_down
address             dev_port           mtu               queues
addr_len            dormant            name_assign_type  speed
broadcast           duplex             netdev_group      statistics
carrier             flags              operstate         subsystem
carrier_changes     gro_flush_timeout  phys_port_id      tx_queue_len
carrier_down_count  ifalias            phys_port_name    type
carrier_up_count    ifindex            phys_switch_id    uevent
$ sudo ip link set can0 type can bitrate 125000 triple-sampling on
$ sudo ifconfig can0
can0: flags=128<NOARP>  mtu 16
$ sudo ifconfig can0 up
Hello,
sorry for the long long late reply.
I have abandoned this project for now, I think I am not (yet) clever enough to find a reason/solution.
Thank you @nopnop2002 for your help! :)
It's mine.
verbosity=1
logo=disabled
console=both
rootfstype=ext4
$ lsmod | grep can
can0
Expand
Well, I have same problem. Seems that everything is correct but I don't have any candump output
pasha@orangepipcplus:~$ sudo ifconfig can0
pasha@orangepipcplus:~$ lsmod | grep can
can_raw                20480  0
can                    20480  1 can_raw
pasha@orangepipcplus:~$ dmesg | grep "can\|mcp\|spi"
[    6.236392] can: controller area network core (rev 20170425 abi 9)
[    6.246062] can: raw protocol (rev 20170425)
[    7.585019] mcp251x spi0.0 can0: MCP2515 successfully initialized.
but:
pasha@orangepipcplus:~$ candump can0  - no output
resistor is OK, I connect Opi to existing can bus where one device sends data and second receive successfully
Also I wonder why I can't compile overlay from example
https://github.com/armbian/sunxi-DT-overlays/blob/master/examples/spi-mcp251x.dts
sudo armbian-add-overlay spi-mcp251x.dts
Compiling the overlay
dtc: livetree.c:521: get_node_by_phandle: Assertion `(phandle != 0) && (phandle != -1)' failed.
/usr/sbin/armbian-add-overlay: line 81:  2323 Aborted                 dtc -@ -q -I dts -O dtb -o ${temp_dir}/${fname}.dtbo $1
Error compiling the overlay
Device tree compiler is newest version (1.4.5-3)
thanks for help...
can_raw                20480  0
can                    20480  1 can_raw
but:
thanks for help...
For those who bump into the same problem. Change in the spi-mcp251x.dts file: from "clock-frequency = <8000000>;" to "clock-frequency = <16000000>;". (although the quartz on the can modul board is definitely 8Mhz)
Expand
My problem was on the latest system. According to dmesg, ifconfig everything OK but did not work at all until I changed the frequency.
 uname -a
Linux orangepione 5.4.45-sunxi #20.05.4 SMP Sun Jun 14 21:46:20 CEST 2020 armv7l armv7l armv7l GNU/Linux
