Or you could do this. Quick Google search and this worked like a charm for me The Radxa Dragon Q6A on Armbian may lose Wi‑Fi after a kernel upgrade because the AIC8800 Wi‑Fi/BT module's DKMS driver fails to rebuild automatically; users report manually running sudo dpkg-reconfigure aic8800-usb-dkms can restore Wi‑Fi until the next kernel update. After it was done I just did a quick reboot and Wireless and Bluetooth were back.
I wanted to play with: kernel on ubifs or perhaps DAX on erofs. Btw, Amlogic's boy did "job secure". The bootloader must be signed with aml-enc, a x86 binary, differently for SD and NOR flash. Anyways, it makes x00kb of trice encrypted and signed 0s.
I tried different overlays, reduced max-frequency, set rx-(-tx)-bus-width and different mode settings indepently. Is it perhaps driven by gpio regulator instead of fixed 3v3? With a vcc-supply property one line (warning) goes away.
https://github.com/radxa-pkg/u-boot-aw2501 This is the radxa u-boot build. The important build scripts are in the Makefile.local and the ones in the main directory. I believe the patch directory is in the Debian folder. https://github.com/radxa-pkg/u-boot-aw2501/blob/main/.github/local/Makefile.local https://docs.radxa.com/en/cubie/a7a/low-level-dev/build-system/u-boot Use AI to help you figure it out. My armbian build downloads the official uboot deb package. But I also added a directory for custom uboot packages that overrides the official package.
How can we acces the SPI NOR Flash on Odroid HC4? The usual error seems to be the driver, not a thing we can overlay device tree? Id for xt25f128b is implemented. meson-spifc ffd14000.spi: registered host spi0 spi spi0.0: setup mode 0, 8 bits/w, 1000000 Hz max --> 0 spi-nor spi0.0: supply vcc not found, using dummy regulator spi-nor spi0.0: error -95 reading JEDEC ID spi-nor spi0.0: probe with driver spi-nor failed with error -95 meson-spifc ffd14000.spi: registered child spi0.0
Looks like I'm stupid. I can’t figure out which _defconfig is used to compile u-boot for cubie-A7A. I understand that 2022.07 is used as the source, but there is no necessary _defconfig in the configs folder. Accordingly, I don’t understand which file to write a patch for, or which patch to make changes to. I ask for help in writing the required patch.
In case you're interested I’ve uploaded my experiments with the current and edge kernels for my board (X88pro13, RK3528) to GitHub x88pro. LAN and USB are working; HDMI is not. Wifi only in current with aic8800 chip. Device Tree for my Board : userpatches/kernel/archive/rockchip64-.../dt/x88pro.dts might interest you.
This week's work centers on board portfolio expansion, kernel and U-Boot version bumps, and CI and infrastructure hardening across the build and documentation pipelines. Board support saw notable growth with the introduction of the SpacemiT K3 Pico-ITX and Luckfox Nova (RK3308B), alongside a new generic uefi-arm64-dt family and board intended to standardize UEFI device-tree targets. Qualcomm enablement advanced through Radxa Dragon Q6A and Q8B work, including UFS provisioning for Kodiak, EDL-based UFS flashing in the imager, and audioreach topology firmware for sc8280xp. Catalog assets were extended for the MaaXBoard 8ULP, Mellow Fly C5, Xiaomi Sheng, and the new Radxa and SpacemiT boards. On the kernel and bootloader front, rockchip64, meson64, and rpi4b edge branches were promoted to the stable 7.1 series, with the rtl8192eu driver rebuilt and re-enabled against the new tree. U-Boot was refreshed on cm3588-nas, nanopik2-s905, and the Luckfox Nova, while updated DDR, BL31, and BL32 blobs landed for RK3528 and new SPL loaders were published for RV1103, RV1106, and RK3506. Targeted kernel-config work restored md/RAID modules on sunxi, enabled MIPI DBI panels on sunxi64, and added CPUFreq support for the SpacemiT K1. Infrastructure changes focused on resilience and resource control. The git-trees workflow gained bounded retries, escalating timeouts, and Google mirror fallbacks; Docker base-image pulls now retry transient GHCR failures and split host dependencies into per-group apt layers. Image compression caps xz memory and thread usage, the info-gatherer no longer exhausts file descriptors, and a new CI policy enforces transparent backgrounds and object-size limits for board and vendor logos, with offending assets re-cropped. #Armbian #EmbeddedLinux #UBoot #Qualcomm #Rockchip ChangesActions: Disable debugsym builds. by @vidplace7 in armbian/MorseMicro-DKMS#7Add Board & Vendor logo for the Mellow Fly C5. by @deece in armbian/armbian.github.io#324Add board SpacemiT K3 Pico-ITX. by @pyavitz in armbian/build#10001Add board: Luckfox Nova (RK3308B). by @crackerjacques in armbian/build#9985Add K3 Pico ITX. by @igorpecovnik in armbian/armbian.github.io#341Add Luckfox Nova board image. by @crackerjacques in armbian/armbian.github.io#332Add MaaXBoard 8ULP board image and Avnet vendor logo. by @govindsi in armbian/armbian.github.io#340Add Radxa Dragon Q8B board image. by @SuperKali in armbian/armbian.github.io#342Add spl_loader bins for RV1103, RV1106, RK3506. by @vidplace7 in armbian/rkbin#46Add Xiaomi Sheng board image. by @code002-2 in armbian/armbian.github.io#337armbian-install: fix boot on UEFI systems. by @EvilOlaf in armbian/build#9945armbian-upgrade: use apt-get to silence apt CLI-warning noise. by @igorpecovnik in armbian/build#9998artifact-uboot: opt-in cache-bust via UBOOT_HASH_EXTRA for prebuilt blobs. by @igorpecovnik in armbian/build#9995board assets: fix 10 board-image dimensions + square the Huawei logo. by @igorpecovnik in armbian/armbian.github.io#334ci: board-asset validation — transparent background + object-size + full monthly scan. by @igorpecovnik in armbian/armbian.github.io#333ci: bound each retry attempt with a 10-minute timeout. by @rpardini in armbian/shallow#8ci: double retry timeout each attempt; fetch from Google mirrors. by @rpardini in armbian/shallow#9ci: enforce MAX_OBJECT_PCT=50 + re-crop the two over-limit board images. by @igorpecovnik in armbian/armbian.github.io#335ci: make git-trees workflow resilient to network failures. by @rpardini in armbian/shallow#7ci: push image-info data branch direct to github (bypass git cache proxy). by @igorpecovnik in armbian/armbian.github.io#338ci: vendor logos must be transparent + ≤80% object fill (+ fix the 6 opaque ones). by @igorpecovnik in armbian/armbian.github.io#336cm3588-nas: u-boot: bump to v2026.07-rc3. by @rpardini in armbian/build#9975docker: retry transient ghcr base-image pulls; guard the auto-pull cronjob. by @igorpecovnik in armbian/build#10006docker: split host deps into per-group apt layers in generated Dockerfile. by @rpardini in armbian/build#9999Feature/sunxi mainline stmmac ac300. by @deece in armbian/build#9952fix(images): hide UFS images from the catalog. by @SuperKali in armbian/imager#157fix(profiles): keep the flash profile picker in sync with Settings. by @SuperKali in armbian/imager#156Flash UFS images to Qualcomm boards over EDL. by @SuperKali in armbian/imager#158image: cap xz compression memory and lower the thread cap. by @igorpecovnik in armbian/build#10005info-gatherer: fix 'Too many open files' from cpu*4 parallel workers. by @igorpecovnik in armbian/build#10014introduce new family uefidt and new board uefi-arm64-dt. by @amazingfate in armbian/build#9923Kodiak: add Radxa Dragon Q6A UFS provisioning XML. by @SuperKali in armbian/qcombin#2luckfox-rk3308b-nova: bump U-Boot to v2026.07-rc4. by @crackerjacques in armbian/build#10010meson64: bleedingedge: enable CONFIG_GPIO_CDEV_V1. by @adeepn in armbian/build#9979nanopik2-s905: bump u-boot to v2026.04. by @igorpecovnik in armbian/build#9989PocketBeagle 2 - Fix NCM Networking w/ACM for Serial. by @Grippy98 in armbian/build#10007qcom/qcs6490: replace Radxa Dragon Q6A adsp/cdsp with linux-firmware. by @SuperKali in armbian/firmware#129qcom/sc8280xp: add Radxa Dragon Q8B audioreach topology. by @SuperKali in armbian/firmware#128radxa-cubie-a5e: tidy BOARD_NAME to "Cubie A5E". by @igorpecovnik in armbian/build#9990remove bleedingedge from all boards. by @EvilOlaf in armbian/build#10016rk3528: updated rkbins ddr/bl31/bl32 for rk3528. by @rpardini in armbian/rkbin#47rockchip64 & meson64: bump edge to stable 7.1. by @EvilOlaf in armbian/build#9980rpi4b: bump edge to 7.1.y. by @EvilOlaf in armbian/build#9982rtl8192eu: fix build against 7.1 and re-enable. by @EvilOlaf in armbian/build#10009SpacemiT K1: Update CPUFreq support EDGE. by @pyavitz in armbian/build#9981sunxi64: Enable CONFIG_DRM_PANEL_MIPI_DBI=m for current and edge configs. by @d93921012 in armbian/build#9984sunxi: restore md modules (software raid modules). by @k-popov in armbian/build#9992Update MorseMicro suite to 1.17.9. by @vidplace7 in armbian/MorseMicro-DKMS#8Update odroidxu4-current to 6.6.143. by @belegdol in armbian/build#10018View the full article
NVMe not recognized on OrangePi 5 Pro with Armbian
eselarm replied to Folaht Pjehrsohmehj's topic in Beginners
This is not NVME, but SATA. No surprise it does not work. It might be that the M.2 slot of the OPi5pro is such that with an overlay, you could map SATA signals to that slot and then it should work. Look in rockchip overlays folder for any .dtbo file with name like *rk3588*sata* But you should check HW circuit diagram maybe first, might also be that this is only for the normal OPi5 Maybe search a bit, I found Is old topic, but the principles are still the same. -
Folaht Pjehrsohmehj replied to Folaht Pjehrsohmehj's topic in Beginners
Power supply: WNB-0504000 5V 4A 20W USB-C. SSD: Intenso Top Performance M.2 128GB SATA-600 I'm gonna buy a new power supply. Looks like I'm needing a 5A one. -
ubuntu nor gnome is not relevant what matters is u-boot and kernel (and powersupply and type of nvme ssd ) u-boot logs can be seen via serial console cable -
I've tried Ubuntu-gnome. Still no SSD recognition. -
SATA hard drives on Odroid-HC4 (OpenMediaVault works!)
BigHeadMode replied to BigHeadMode's topic in Odroid C4
I am 95% sure this happens even on a plain Armbian install. I'll double check. Some news: - it does not happen on all SATA devices (booted fine with 1 SSD) - power supply seems fine; marked 4.0 A There is a workaround! press any key to interrupt boot (be fast, 2 second timer) scsi scan # wait under 2 minutes boot # similar output to "failed" boots # but after under 2 minutes, it will continue into the boot process Does anyone know how I could put these steps into the boot process automatically? -
Hello everybody, With 6.18.10-current-rockchip64 and rk3399-kobol-helios64.dtb-6.18.18-opp dtb file, Ok With 6.18.35-current-rockchip64 and overlay helios64 patch with armbian-config, Ko With 6.18.35-current-rockchip64 and k3399-kobol-helios64.dtb-6.18.18-opp dtb file, Ko The crash is random... sometime crash: - At the boot with red system light blinking - At the opening of my LUKS ciffers drives - At a high cpu load - With nothing special, all led are blue, system blinking but network and ssh is Ko Is it possible to explain me how to see the problem or how to have log because I am in blind to have more details ? Is it possible to explain me how to pass to the last 6.18.36 kernel to seen if it is better than 6.18.35 ? Thanks a lot.
Werner replied to BigHeadMode's topic in Odroid C4
I suggest to ask at dietpi forums, since we cannot help with 3rd party os/scripts. -
Thank you, bro. I'll try it this evening after work. I'll post the results.
William Bulchi replied to SteeMan's topic in FAQ
I want to install an image from the sd card to the internal memory in x96q tv box, it boots perfectly from sd card, without having to press anything, and everything works ok, even bluetooth adapter and video reproduction, my question is "do i still need to modify boot files to install in emmc or is not necessary? thanks in advance.... -
armbian not booting TV BOX TX9Pro sun50iw9 H616
Nick A replied to Роман Логинов's topic in Allwinner CPU Boxes
You can find everything you need here. H616 is similar to H618. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/ you can use this tool to extract your dram settings. https://github.com/apritzel/sunxi-fw -
@flintduvaд secure boot might be similar to older Allwinner SOCs. https://forum.armbian.com/topic/58803-i-need-secure-image-x98h-pro/#comment-235213
I have an Odroid HC4 I've used as a NAS. Back around 2021, it worked fine. I think I installed plain armbian back then and installed openmediavault on top of it. Then I did all kinds of updates to it. I believe it's now on a hybrid of Debian Bookworm and Debian Trixie - don't ask. The update mechanism is not super clear. I wanted to run a fresh, plain Armbian and install dietpi. But there is a well documented flaw where Armbian cannot exit boot in some cases. In my case, it happens only when SATA drives are attached. I have two WD Red drives that it can't boot with those attached. It seems like the bootloader code was changed over time, which let prior builds boot but not current builds. Admittedly, these drives fail SMART, so they could be reporting bad data. Errors: Scanning bus for devices... [SATA stuff] timeout exit! fs_devread read error - block [SATA stuff - size is off by about 10x - says 700 GB, actually 6 TB] Device 0: [SATA stuff] ... is now current device timeout exit! timeout exit! timeout exit! [etc.] I tried setting the code in /boot to only attempt to boot from emmc0 and emmc1. The farthest I got was this, but I think updating to trixie via armbian-config again broke the boot code: installed old armbian minimal apt install armbian-config # the keys are old and fail with the sha1 ban recently implemented. this fixes that wget https://apt.armbian.com/armbian.key gpg --dearmor < armbian.key | sudo tee /usr/share/keyrings/armbian.gpg > /dev/null armbian-config: disable firmware update (also disables kernel updates) distro full upgrade from armbian-config got: Description: Armbian 26.5.1 trixie Release: 13 https://dietpi.com/docs/hardware/#make-your-own-distribution noticed this in the install script running, i'm worried it will wipe the good old firmware and replace with new bad: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. [ OK ] DietPi-Installer | APT install linux-image-current-meson64 linux-u-boot-odroidhc4-current [ OK ] DietPi-Installer | rm -f /boot/uImage /boot/uInitrd /boot/uInitrd-6.18.34-current-meson64 [ OK ] DietPi-Installer | rm /boot/.next [ OK ] DietPi-Installer | rm /boot/armbianEnv.txt [ OK ] DietPi-Installer | mkimage -C none -A arm64 -T script -d /boot/boot.cmd /boot/boot.scr [ SUB1 ] DietPi-Set_hardware > flash-u-boot-mmc (/dev/mmcblk0) 442+0 records in 442+0 records out 442 bytes copied, 0.00430629 s, 103 kB/s 2626+1 records in 2626+1 records out 1344880 bytes (1.3 MB, 1.3 MiB) copied, 0.162507 s, 8.3 MB/s [ OK ] flash-u-boot-mmc (/dev/mmcblk0) | Completed [ INFO ] DietPi-Installer | Preventing needless kernel and initramfs symlink generation [ OK ] DietPi-Installer | eval echo 'do_symlinks=0' > /etc/kernel-img.conf [ OK ] DietPi-Installer | rm -f /initrd.img /initrd.img.old /vmlinuz /vmlinuz.old [ INFO ] DietPi-Installer | Generating list of minimal packages, required for DietPi installation [ OK ] DietPi-Installer | Marking required packages as manually installed [ OK ] DietPi-Installer | Unhold all packages [ INFO ] DietPi-Installer | APT autopurge gawk original-awk, please wait... Reading package lists... Ideas: - try booting with just one SATA - try another SATA drive - try with petitboot (older / manufacturer boot code) instead of uboot - compare working /boot folder on working microsd with failed /boot folder (I did this, far too many differences to list). I did try copying key differences and recompiling the boot, didn't seem to fix it. - hotswap / hot install the drives after boot (apparently works) related: https://dietpi.com/forum/t/error-on-updating-ombi/25096 https://dietpi.com/forum/t/dietpi-os-apt-update-warnings/24923/31?page=2 https://forum.openmediavault.org/index.php?thread/43298-install-omv-on-odroid-hc4-some-questions-from-a-newbie/ https://dietpi.com/forum/t/odroid-hc4-sata-drives-not-recognized/4795 https://dietpi.com/forum/t/odroid-c2-doesnt-boot-up/6489/14 https://dietpi.com/forum/t/orange-pi-5-boot-from-sata-m-2-ssd/17884/51?page=2 https://github.com/MichaIng/DietPi/issues/7601
Update on 0.7: Led Display works perfectly Wifi works perfectly after reboot (i would suggest it on screen after the driver is built) Unable to test USB3 at the moment Installed Kodi, unable to get video acceleration (it says llvmpipe with CPU at almost 100%, clearly is running software rendering) @serovan did you reboot after first boot? But yes, probably your revision has different pinout for the peripherals (wifi and PHY)
Роман Логинов replied to Роман Логинов's topic in Allwinner CPU Boxes
Could you please tell me how to configure my own UBOOT so that the console boots from a flash drive? Is there any wiki information on this? When I loaded various Armbian versions onto the flash drive, the memory wouldn't initialize... U-Boot SPL 2025.04 (Apr 19 2026 - 19:49:57 +0200) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.04 (Apr 19 2026 - 19:49:57 +0200) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.04 (Apr 19 2026 - 19:49:57 +0200) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.04 (Apr 19 2026 - 19:49:57 +0200) DRAM:This DRAM setup is currently not supported. resetting ... Category Parameter Log Value What it is and what it's for Processor (SoC) Model sun50iw9 This is an Allwinner H616. Specified in the build configuration. Memory (DRAM) DRAM Type 3 (DDR3) Memory type. DRAM SIZE 2048 MB Memory capacity. DRAM CLK 600 MHZ Memory frequency. para1 30fb Key timing parameter. para2 8000000 Key configuration parameter. dram_tpr13 6041 Another timing parameter. Power Management Unit (PMU) PMU AXP1530 Critical for stability! Requires driver or compatibility with AXP313. Integrated Memory MMC MMC 5.0, 15032 MB eMMC type and size. Ethernet No ethernet found No Ethernet. We work only via Wi-Fi. U-Boot SPL 2024.01-armbian-2024.01-S866c-P6135-Ha9af-V6d37-Bda0a-R448a (Sep 19 2024 - 19:48:11 -0400) This DRAM setup is currently not supported. resetting ... U-Boot SPL 2024.01-armbian-2024.01-S866c-P6135-Ha9af-V6d37-Bda0a-R448a (Sep 19 2024 - 19:48:11 -0400) This DRAM setup is currently not supported. resetting ... U-Boot SPL 2024.01-armbian-2024.01-S866c-P6135-Ha9af-V6d37-Bda0a-R448a (Sep 19 2024 - 19:48:11 -0400) This DRAM setup is currently not supported. resetting ... -
Hello friends. I ask for help in creating firmware with TOC0. Unfortunately, I once launched Android firmware from a Teclast tablet on my A7A board, and apparently eFuse burned out. Now standard firmware with eGON.BT0 will not run on this board. Or tell me where to fix it so that the firmware from the sources is compiled with TOC0.
IMX708/ Pi Cam 3 not initializing on Pi Zero 2W
eselarm replied to Stuart Watt's topic in Raspberry Pi
What is your plan with that camera? My latest try with raspbian (armv6) trixie based failed w.r.t. V4L2. So that is with start.elf, not start_x.elf. The latter works fine on bookworm based raspbian for camara v1. Camera v3 never worked with legacy firmware mode (start_x=1), so needs libcamera. For easy handling, the latest RPL variant of libcamera named rpicam should work, but then you'll be essentially back to RaspberryPiOS. If you have standard Debian Trixie based, all that modified libcamera is not there and more important, you will have other firmware files (bootcode.bin start.elf fixup.dat). Armbian takes the version from Ubuntu AFAIK, Debian is yet another version as is the latest from RaspberryPiOS (64-bit patched Debian or 32-bit patched and re-compiled Raspbian). The package name is raspi-frmware, check which versions there are with sudo apt list -a raspi-frmware and in addition, the 3 files themselves, I did timestamp or suffix them with sha256sum in the past on order to keep track of the various ones delivered for various OSses and images. I assume the Armbian kernel is compiled from same RPi kernel tree as RaspberryPiOS, so overlays for the v3 camera should be there and functionally the same. I currently have 1 camera v1 base RPI3B+ running, still bookworm, but I might boot it with Debian Trixie/Sid and see what mainline libcamera does. Probably then Armbian bcm2711 edge kernel, at least something that provides overlays as Debian kernels have almost none, at least not for camera sensors.
