  2. Please use a build that isn't 7 years old. https://www.armbian.com/amlogic-s9xx-tv-box Read the FAQ and the install instructions linked there
  3. moving to amlogic tv box forum
  4. here is the full log dtb/amlogic/meson-gxl-s805x-p241.dtb copied -u-boot-s905x-s912 u-boot.ext then renamed it as u-boot.ext manually booted from sd card , then installed to emmc sudo /root/install-aml.sh previously i could save bootcmd as env , after this ,i couldnot save env ,from u-boot now it gives this error gxl_p241_v1#saveenv Saving Environment to aml-storage... _find_partition_by_name()-198: do not find match in table env get partition info failed !! gxl_p241_v1## This saves all environment variables to eMMC/SD gxl_p241_v1#saveenv Saving Environment to aml-storage... _find_partition_by_name()-198: do not find match in table env get partition info failed !! ------------------------------------------------------------------------------------------------------------------------------------------------------------ is there any way to manually erase the default vendor , u-boot , and install armbian one ? Armbian_20.10_Arm-64_focal_current_5.9.0 this is the image i succesfully booted , -------------------------------------------------------------------------------------------------------- i tried to boot this image Armbian_community_26.2.0-trunk.385_Aml-s9xx-box_trixie_current_6.18.8_minimal it gives this error scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... init_part() 282: PART_TYPE_DOS 1 Storage Device(s) found reading zImage ** Unable to read file zImage ** reading dtb/amlogic/meson-gxl-s805x-p241.dtb 26728 bytes read in 57 ms (457 KiB/s) [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed Bad Linux ARM64 Image magic! gxl_p241_v1# --------------------------------------------------------------------------------------------------------------------------------------------------- vendor u-boot ,bootcmd u-boot default bootcmd gxl_p241_v1#printenv bootcmd bootcmd=run storeboot gxl_p241_v1#printenv storeboot storeboot=get_system_as_root_mode;echo system_mode: ${system_mode};if test ${system_mode} = 1; then setenv fs_type ro rootwait skip_initramfs;run storeargs;fi;get_valid_slot;get_avb_mode;echo active_slot: ${active_slot};if test ${active_slot} != normal; then setenv bootargs ${bootargs} androidboot.slot_suffix=${active_slot};fi;if test ${avb2} = 0; then if test ${active_slot} = _a; then setenv bootargs ${bootargs} root=/dev/mmcblk0p23;else if test ${active_slot} = _b; then setenv bootargs ${bootargs} root=/dev/mmcblk0p24;fi;fi;fi;if imgread kernel ${boot_part} ${loadaddr}; then bootm ${loadaddr}; fi;run update ------------------------------------------------------------------------------------------------------------------------------------------------------------ LOG After i installed armbin (Armbian_20.10_Arm-64_focal_current_5.9.0)to emmc , reboot gives this error [ OK ] Reached target Reboot. [ 650.054096] watchdog: watchdog0: watchdog did not stop! [ 650.541411] reboot: Restarting system bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. GXL:BL1:9ac50e:bb16dc;FEAT:BFFC39BE:100;POC:3;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;1.0;1.0;CHK:0; TE: 241336 BL2 Built : 10:47:34, Jan 14 2019. gxl g152d217 - guotai.shen@droid11-sz set vcck to 1120 mv set vddee to 1000 mv Board ID = 7 CPU clk: 984MHz DDR enable rdbi DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0 16bit @ 912MHz bist_test rank: 0 1b 00 37 27 0f 3f 1c 01 38 2b 11 45 27 27 27 27 27 27 27 27 27 27 27 27 693 - PASS Rank0: 1024MB-2T-13 AddrBus test pass! Set ddr ssc: ppm1000- eMMC boot @ 1 sw8 s emmc switch 3 ok BL2: rpmb counter: 0x00000020 emmc switch 1 ok OTP_ARB=00000001 Load FIP HDR from eMMC, src: 0x0000c200, des: 0x01700000, size: 0x00004000, part: 1 Load BL3x from eMMC, src: 0x00010200, des: 0x01704000, size: 0x000f4000, part: 1 NOTICE: BL3-1: v1.0(release):3bc3888 NOTICE: BL3-1: Built : 11:28:51, May 10 2019 [BL31]: GXL CPU setup! NOTICE: BL3-1: GXL secure boot! NOTICE: BL3-1: BL33 decompress pass mpu_config_enable:system pre init ok dmc sec lock MVN_1=0x01010100 MVN_2=0x01010000 [Image: gxl_v1.1.3375-8f9c8a7 2019-01-24 10:45:03 guotai.shen@droid11-sz] OPS=0x34 21 0d 34 00 25 ae dc 97 5b 00 83 fe 04 b3 53 02 [0.856523 Inits done] secure task start! high task start! low task start! INFO: BL3-2: ATOS-V2.4-238-g14a47cb #1 Tue Dec 3 07:25:46 UTC 2019 arm INFO: BL3-2: Chip: GXL Rev: D (21:D - 30:2) INFO: BL3-2: crypto engine DMA INFO: BL3-2: secure time TEE INFO: BL3-2: CONFIG_DEVICE_SECURE 0xb200000e U-Boot 2015.01-g186a540 (Mar 14 2020 - 17:11:46) DRAM: 1 GiB Relocation Offset is: 36e86000 register usb cfg[0][1] = 0000000037f51910 [CANVAS]canvas init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000033e866b0 aml_priv->desc_buf = 0x0000000033e889f0 SDIO Port B: 0, SDIO Port ๐Ÿ˜„ 1 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 40000000 [mmc_startup] mmc refix success init_part() 282: PART_TYPE_DOS [mmc_init] mmc init success check_valid_dts() 248: Decrypt dtb: Sig Check -2 get_partition_from_dts() 71: ret -249 get_partition_from_dts() 74: ret -249 get_ptbl_from_dtb()-269: get partition table from dts faild mmc_device_init()-1251: get partition table from dtb failed get_ptbl_rsv()-491: magic faild MPT, โ–’ื‹ mmc_device_init()-1278: dtb&rsv are not exist, no LPT source _find_partition_by_name()-198: do not find match in table env get partition info failed !! Using default environment In: serial Out: serial Err: serial reboot_mode=cold_boot itest - return true/false on integer compare Usage: itest [.b, .w, .l, .s] [*]value1 <op> [*]value2 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-2755: calc 79d92d6, store f26b0ab5 update_dtb_info()-2863: cpy 1 is not valid _verify_dtb_checksum()-2755: calc ab3aca1f, store f6004a13 update_dtb_info()-2863: cpy 0 is not valid dtb_read()-2972: total valid 0 emmc - EMMC sub system Usage: emmc dtb_read addr size emmc dtb_write addr size emmc erase dtb emmc erase key emmc fastboot_read addr size emmc fastboot_write addr size [store]decrypt dtb: Sig Check -2 vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 2 vpu: set clk: 200000000Hz, readback: 200000000Hz(0x501) vpu: vpu_clk_gate_init_off finish vpp: vpp_init hpd_state=0 vpp: vpp_matrix_update: 2 cvbs performance type = 6, table = 0 cvbs_config_hdmipll_gxl cvbs_set_vid2_clk Net: dwmac.c9410000[KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000 MACADDR:02:5b:97:dc:ae:25(from chipid) Warning: dwmac.c9410000 MAC addresses don't match: Address in SROM is 4a:f1:62:3d:0c:33 Address in environment is 02:5b:97:dc:ae:25 CONFIG_AVB2: avb2 Start read misc partition datas! _find_partition_by_name()-198: do not find match in table misc Cannot find dev. amlmmc cmd <NULL> failed store - STORE sub-system Usage: store init flag store read name addr off|partition size read 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store write name addr off|partition size write 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store rom_write add off size. write uboot to the boot device store erase boot/data: erase the area which is uboot or data store erase partition <partition_name>: erase the area which partition in u-boot store erase dtb store erase key store disprotect key store rom_protect on/off store scrub off|partition size scrub the area from offset and size store dtb iread/read/write addr <size> read/write dtb, size is optional store key read/write addr <size> read/write key, size is optional store mbr addr update mbr/partition table by dtb [burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store read misc 0x33e75090 0x0 0x820] failed to store read misc. info->magic = info->version_major = 0 info->version_minor = 0 info->slots[0].priority = 0 info->slots[0].tries_remaining = 0 info->slots[0].successful_boot = 0 info->slots[1].priority = 0 info->slots[1].tries_remaining = 0 info->slots[1].successful_boot = 0 info->crc32 = 0 Magic is incorrect. boot-info is invalid. Resetting. save boot-info info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 _find_partition_by_name()-198: do not find match in table misc Cannot find dev. amlmmc cmd <NULL> failed store - STORE sub-system Usage: store init flag store read name addr off|partition size read 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store write name addr off|partition size write 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store rom_write add off size. write uboot to the boot device store erase boot/data: erase the area which is uboot or data store erase partition <partition_name>: erase the area which partition in u-boot store erase dtb store erase key store disprotect key store rom_protect on/off store scrub off|partition size scrub the area from offset and size store dtb iread/read/write addr <size> read/write dtb, size is optional store key read/write addr <size> read/write key, size is optional store mbr addr update mbr/partition table by dtb [burnup]Err:store_write_ops,L110:cmd [store write misc 0x33e75090 0x0 0x820] failed active slot = 0 wipe_data=successful wipe_cache=successful upgrade_step=0 reboot_mode:::: cold_boot [KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000 [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]VPP_OFIFO_SIZE:0xfff00fff [CANVAS]addr=0x3d800000 width=3840, height=2160 _find_partition_by_name()-198: do not find match in table logo Cannot find dev. amlmmc cmd <NULL> failed store - STORE sub-system Usage: store init flag store read name addr off|partition size read 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store write name addr off|partition size write 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store rom_write add off size. write uboot to the boot device store erase boot/data: erase the area which is uboot or data store erase partition <partition_name>: erase the area which partition in u-boot store erase dtb store erase key store disprotect key store rom_protect on/off store scrub off|partition size scrub the area from offset and size store dtb iread/read/write addr <size> read/write dtb, size is optional store key read/write addr <size> read/write key, size is optional store mbr addr update mbr/partition table by dtb [burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store read logo 0x1080000 0x0 0x2000] Err imgread(L523):Fail to read 0x2000B from part[logo] at offset 0 There is no valid bmp file at the given address [OSD]osd_hw.free_dst_data: 0,719,0,575 [KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000 gpio: pin GPIOAO_2 (gpio 102) value is 1 Command: bcb uboot-command Start read misc partition datas! _find_partition_by_name()-198: do not find match in table misc Cannot find dev. amlmmc cmd <NULL> failed store - STORE sub-system Usage: store init flag store read name addr off|partition size read 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store write name addr off|partition size write 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store rom_write add off size. write uboot to the boot device store erase boot/data: erase the area which is uboot or data store erase partition <partition_name>: erase the area which partition in u-boot store erase dtb store erase key store disprotect key store rom_protect on/off store scrub off|partition size scrub the area from offset and size store dtb iread/read/write addr <size> read/write dtb, size is optional store key read/write addr <size> read/write key, size is optional store mbr addr update mbr/partition table by dtb [burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store read misc 0x33e75080 0x0 0x440] failed to store read misc. bcb - bcb Usage: bcb This command will run some commands which saved in misc partition by mark to decide whether execute command! Command format: bcb bcb_mark Example: /dev/block/misc partiton is saved some contents: uboot-command N/A setenv aa 11;setenv bb 22;setenv cc 33;saveenv; So you can execute command: bcb uboot-command [KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... init_part() 282: PART_TYPE_DOS 1 Storage Device(s) found fail in cmd [fatsize usb 0 factory_update_param.aml], rcode 1 File factory_update_param.aml not exist in Upan?? get upgrade version failed Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 CONFIG_SYSTEM_AS_ROOT: systemroot system_mode: 1 [KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000 Start read misc partition datas! _find_partition_by_name()-198: do not find match in table misc Cannot find dev. amlmmc cmd <NULL> failed store - STORE sub-system Usage: store init flag store read name addr off|partition size read 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store write name addr off|partition size write 'size' bytes starting at offset 'off' to/from memory address 'addr', skipping bad blocks. store rom_write add off size. write uboot to the boot device store erase boot/data: erase the area which is uboot or data store erase partition <partition_name>: erase the area which partition in u-boot store erase dtb store erase key store disprotect key store rom_protect on/off store scrub off|partition size scrub the area from offset and size store dtb iread/read/write addr <size> read/write dtb, size is optional store key read/write addr <size> read/write key, size is optional store mbr addr update mbr/partition table by dtb [burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store read misc 0x33e75090 0x0 0x820] failed to store read misc. info->magic = info->version_major = 0
  5. Hi, welcome. Syncing forums and tags with supported boards is (still) a manual job and from time to time I either cannot keep up or miss things. Like in this case. I'll fix this later and then move appropriately. Until then feel free to state your question in "Beginners" using the "other" tag. Cheers
  6. Today
  7. Hello to everyone. Being new around here I figured to drop one message here first... So, i have this Radxa Rock 4D SBC and i am quite impressed with it Me being me and SBC being what it is, yada... yada, i now have this hat+ from Waveshare - it is an dual SATA to PCIe adapter. It was designed for the Raspberry pi 5 obviously but Radxa has since started putting those FPC connectors on and i really would appreciate a 24/7 NAS with a SBC footprint... Long story short, it does not work out of the box - i have no doubt the product is okay it's just the HAT fails to initiate the OS and register. It reportedly has an eprom with data on it but my guess is it has to have a dtb overlay active and my rock 4D lacks anything in that regard (a "sata" in the overlay name) My issues? 1. Where is the Rock 4D forum or where do i post this issue best to?
  8. I tried Armbian_26.2.1_Nanopim4v2_trixie_current_6.18.8_minimal.img.xz, wrote it on TF card and it booted into Linux without any changes.
  9. device x92 android tv, amlogic s912, armbian file: Armbian_5.84_Aml-s905_Debian_stretch_default_5.1.0-rc1_20190507.img
  10. Hello, @Geoffrey F4FXLyou just saved me a lot of debugging time. I have multiple orange pi zero with h2+ and h3 and I had the same problem as you. With the reboot command, the sbc shutsdown but doesn't boot again, i need to reset the power for getting it booting again. On my side , this command extraargs=reboot=warm didn't worked but extraargs=reboot=watchdog worked perfectly. I just rebooted it 5 times in a row and it always rebooted well. My version : v25.11.2 for Orange Pi Zero running Armbian Linux 6.12.58-current-sunxi
  11. It is an h313 all winner box. But i can't point the RAM at all.
  12. Excelent! That works. I didn't, notice that pinctrl-rk805 was externalized and can't be loaded automatically. For now I've just add pinctrl-rk805 to /etc/initramfs-tools/modules and update-initramfs. Werner: device tree has no changes for a long time. Thanks!
  13. Which DTB did you use? I extracted the Android files and found a resource file named ENTRrk-kernel.dtb. The file began with "Rockchip RK3399 Excavator Board edp (Android)". Could it be possible that the device is compatible with this board?
  14. Hi Brent; YES! I did figure it out, finally. The issue is that almost all information on the web is for the older pipewire and wireplumber which works completely differently than the new versions. Bookworm used the "old way" and Trixie uses these new versions for which there isn't much info. Compounding the issue is that most information is regarding desktop versions of Linux, not headless like I run. So, when you use bluetooth on linux, wireplumber auto-creates profiles and pw nodes. Or at least it's supposed to. It wasn't creating these profiles because I was missing a conf file which is only needed when your NOT running on desktop, AFAICT. Add this file: /etc/wireplumber/wireplumber.conf.d/50-bluez-no-seat.conf wireplumber.profiles = { main = { monitor.bluez.seat-monitoring = disabled } } If you do that, all of sudden, bluetooth "just works". Took forever to find that stupid little piece of information.
  15. @sicxnull I ran into the same issue when flashing "Armbian-unofficial_26.02.0-trunk_Mxqpro_bookworm_current_6.12.65_minimal" (worked only in SD Card). The issue was gone when I switched to "Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_server" built by @Nick A
  16. Could you send me just the (short) list of packages you installed atop the base Armbian distro rather than a dump of every installed package? The goal is to provide me a simply procedure I can use to replicate the freeze you observe. You might also try running repeating the "free" command to monitor memory usage just after you start your tests. I expect you will see the swap usage steadily increasing. If you disable swap, the system will likely start killing processes.
  17. Have you gotten bluetooth working with trixie and pipewire on other Armbian devices? I gave up on pipewire after trying it a year or so ago. Too many little audio glitches and bugs. Maybe it's better now? Anyway, if this is unique to the RockPI-S, I'll investigate further.
  18. Hello everyone, I have a Lemfo H96 Max V56 (8GB RAM / 64GB eMMC). Board PCB Version: HCY RK3566 - 1X32 - V13 - 2021-03-27 I am relatively new to the Linux world. So far, the only image I have managed to flash and boot successfully is an old Linaro Debian 10 (vendor image from 2019). However, this version lacks hardware acceleration (it runs on llvmpipe), which makes it unusable for my specific needs. My Goal: I want to run a modern Linux with a Desktop environment to use PortMaster and RetroArch. For this, I critically need a system with working Panfrost/Mali GPU drivers. The Problem: I have read through this thread, but I am finding it quite confusing to pinpoint exactly where to start given the various methods (Legacy vs Mainline/Chainloader). Also, it seems some file links are dead or pointing to empty repositories. Request: Could someone please guide me to the correct/updated files for my specific 8GB board? The correct MiniLoader/SPL (.bin) for RKDevTool. A working Desktop Image (.img) (Armbian Bookworm or Ubuntu) that supports GPU acceleration. I am already comfortable using RKDevTool and putting the device into Maskrom mode, so I just need the correct file set to avoid bricking the device. Thanks in advance for any help!
  19. Yesterday
  20. Update on this box. Got wifi working fine. Everything works well with SD Boot. Installing to EMMC brings me to this error U-Boot SPL 2024.01_armbian-2024.01-S866c-Pa67d-H5afb-Vc88c-B2eb2-R448a (Feb 15 2026 - 18:20:18 -0500) DRAM base address is defined as 0x40000000 DRAM has 14 b/raw, 10 b/col, 4 B/width, 2 #rank and 8 #bank DRAM top address must be less than 0x40000000 DRAM: 1024 MiB Trying to boot from MMC2 MMC Device 1 not found spl: could not find mmc device 1. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Chasing down what could be causing this.
  21. I'm back at it, but this time I can boot by setting netplan wifi up. On reboot wifi never comes up. Do the following: Since end0 is reporting as "busy," let's see if forcing it back to eth0 helps udev clear the conflict. Edit /boot/armbianEnv.txt. Add or modify the extraargs line to include: extraargs=net.ifnames=0 biosdevname=0 Fix hash errors: # Remove the cached package lists that are causing the mismatch sudo rm -rf /var/lib/apt/lists/* # Create the partial directory again just in case sudo mkdir -p /var/lib/apt/lists/partial # Clean out the local repository of retrieved package files sudo apt clean # Update the package index again sudo apt update This is latest build.
  22. What Armbian image are you using? Full boot log would be helpful as well.
  23. BalenaEtcher has known issues and therefore not recommended. Use Armbian Imager or USBimager. Also verify that the downloaded image is good by utilizing the checksum. https://docs.armbian.com/User-Guide_Getting-Started/#download-and-verification https://github.com/armbian/imager https://bztsrc.gitlab.io/usbimager/
  24. Hello everyone, Iโ€™m trying to flash the following Armbian image, but Balena Etcher throws an error as soon as I load the image:
  25. Hello everyone, I successfully installed Armbian to eMMC on an Amlogic S805X (gxl_p241 / p241 board). The system boots correctly when I manually start it from U-Boot, but autoboot fails every time. I believe my bootloader / U-Boot environment is not properly configured. During flashing, I only selected the DTB, and I am not sure how the bootloader variables should be set for eMMC boot. if it didnt work ,how to manually install u-boot U-Boot log ----------------------------------------------------------------------------------- USB XHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... init_part() 282: PART_TYPE_DOS 1 Storage Device(s) found fail in cmd [fatsize usb 0 factory_update_param.aml], rcode 1 File factory_update_param.aml not exist in Upan?? get upgrade version failed Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 gxl_p241_v1#
  26. Which device? which armbian version? nobody here has a second sight. from the screenshot you aren't even using armbian or at least nothing official.
  27. Please help, I can't figure out this error for a month now. I've tried all the .dtb files, but nothing works.
ร—
ร—
