  2. moved to off-topic since op is not using Armbian.
  3. I'm sorry, but I don't really understand what a microSD card has to do with the problem above to perform system updates?
  4. Hello, i'm trying to make Arch work on my H3, it boots to uboot, loads fine and says RAM size and reads /boot/boot.scr, but when it tries to ext4load something it gives a error of ` ** fs_devread read error - block` and ` ** No partition table - mmc 0`, everything after `321 bytes read in 24 ms (33.2 KiB/s)` loads by arrays of pixels, i never seen these before on Armbian, H3Droid or any other img file.
  5. I see that this configuration is a kernel build feature, not an armbian-developed function: https://cateee.net/lkddb/web-lkddb/INITRAMFS_SOURCE.html https://unix.stackexchange.com/questions/479415/how-does-linux-know-where-the-rootfs-is So, you can post your question in many more linux discussion places. I hope you get the answer (and share here). Have you ever got this INITRAMFS_SOURCE configuration work, outside of Armbian... for example building the kernel from source by itself?
  6. Thanks @robertoj as a matter of fact this is my own custom initial ramdisk. I've been running it as a standalone file for some time and it works great but now I want to integrate it inside the kernel itself. for this I need to set CONFIG_INITRAMFS_SOURCE during the make process.
  7. Yesterday
  8. Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ?
  9. I solved the issue ! I flashed the latest armbian release raw image to the sdcard and plugged it in the TV box. It magically booted from the SDCard and now I have mmcblk2 as a block device. Now I can run armbian-install command to get everything going correctly.
  10. sven-ola
    All clear for the PCIe MSI: it is something with that Intel 7260 card. Today, I got two other M.2 Wifis: MT7922 and RTL8822ce, both seem to work on current and also on edge. Thus, I consider this as a success. Here's some screen blurb. // Sven-Ola
  11. Try a different microSD card, and always start with a serial-USB connection to your laptop. After first boot, run htop and if you see the CPU high usage, wait until it is done. Then reboot the orange pi.
  12. I don't know about customizing the initrd during the armbian build process. But this is the way to customize it AFTER you get armbian running in your board https://forum.armbian.com/topic/53568-how-to-add-a-specific-single-file-in-the-initrdimg-ideally-automatically-with-update-initramfs/#comment-221767 I know it is not YOUR OWN INITRD, but maybe you can work with it. Large language models are more useful when the answer exists somewhere in a popular website. If no human has written about it, ChatGPT or Gemini will not give you the answer. Have you tried replacing the uImage file in the /boot folder, with your own initrd, converted to uinitrd?
  13. hello! I need to create my own initial ramdisk during the armbian build process by supplying a value to this kernel tag:- grep CONFIG_INITRAMFS_SOURCE /home/andrew/armbian/build/cache/sources/linux-kernel-worktree/6.18__sunxi__armhf/.config CONFIG_INITRAMFS_SOURCE="usr/sideinitrd.cpio" my build runs under docker, and no matter where i place the CPIO file, i get this error: [🐳|🔨] make[3]: *** No rule to make target 'usr/sideinitrd.cpio', needed by 'usr/initramfs_inc_data'. Stop. [🐳|🔨] make[2]: *** [scripts/Makefile.build:556: usr] Error 2 [🐳|🔨] make[2]: *** Waiting for unfinished jobs.... just speculating, but maybe the armbian build cannot find my CPIO file in my compile tree known to docker:- pwd /home/andrew/armbian/build andrew@my-vps:~/armbian/build$ ls CONTRIBUTING.md Dockerfile README.md action.yml buildarmbian2.txt compile.sh extensions output patch shell.nix userpatches CREDITS.md LICENSE VERSION buildarmbian1.txt cache config lib packages requirements.txt tools chatGPT and gemini have wasted days on bogus suggestions on where to place it relative to my compile tree. i have tried many locations without success. EXPLANATION FROM GEMINI:- Armbian’s build process is designed to be "clean." When you run it inside Docker, it follows a strict sequence: Step A: It prepares the environment. Step B: It runs a "cleanup" on the kernel source to ensure no "junk" from previous builds exists (this deletes your .cpio file). Step 😄 It checks your .config and starts the make command. Because Step B happens every time you start the build, any file you manually copy into the kernel tree gets deleted seconds before the compiler actually looks for it. That is why you kept seeing No rule to make target. i am wondering if anyone has already done this before and how they got it going? latest log attached. help! andrew. buildarmbian2.txt.gz
  14. Minor update, I hardcoded usage of uboot debugging option and removed cache to force compiling uboot. But output from bootloader remained the same: U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Ha5c2-Vcc17-Bf389-R448a (Jan 08 2026 - 10:33:14 +0000) DRAM: 512 MiB Trying to boot from MMC1 Maybe detailed logging was already enabled? But it still does not give me any hints. Especially my board does not contain any additional slots like emmc, only for micro sd card (I don't understand why bootloader tries to use mmc1) UPD: I find out question with a little bit similar problem (hang out on mmc1) but need time to understand the reason, maybe it has similar issue
  15. Thank you reply, brentr. I add some info. passmark run command param is -r 2 ,means only run memory test.By the way ,I rename "PerformanceTest_Linux_ARM64" to passmark.Which you can download from "https://www.passmark.com/products/pt_linux/download.php" or "https://www.passmark.com/downloads/PerformanceTest_Linux_ARM64.zip" The only reason ,I install xterm,is I need use resize command to resize serial console.And I install it at 4.4 kernel also. pi@Pi-s:~$ apt list --installed 7zip/stable,now 25.01+dfsg-1~deb13u1 arm64 [installed,automatic] adbd/stable,now 34.0.5-12 arm64 [installed] adduser/stable,now 3.152 all [installed,automatic] adwaita-icon-theme/stable,now 48.1-1 all [installed,automatic] alsa-utils/stable,now 1.2.14-1 arm64 [installed] android-libbase/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-libboringssl/stable,now 14.0.0+r45-2 arm64 [installed,automatic] android-libcutils/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-liblog/stable,now 1:34.0.5-12 arm64 [installed,automatic] apt-utils/stable,now 3.0.3 arm64 [installed] apt/stable,now 3.0.3 arm64 [installed] armbian-bsp-cli-rockpi-s-current/now 25.11.2 arm64 [installed,local] armbian-config/unknown,now 26.2.0-trunk.126.1225.000141 all [installed] armbian-firmware/now 25.11.2 all [installed,local] at-spi2-common/stable,now 2.56.2-1 all [installed,automatic] avahi-daemon/stable,now 0.8-16 arm64 [installed,automatic] avahi-utils/stable,now 0.8-16 arm64 [installed] base-files/now 25.11.2-13.8+deb13u2-trixie arm64 [installed,local] base-passwd/stable,now 3.6.7 arm64 [installed] bash-completion/stable,now 1:2.16.0-7 all [installed] bash/stable,now 5.2.37-2+b5 arm64 [installed] bc/stable,now 1.07.1-4+b1 arm64 [installed] binutils-aarch64-linux-gnu/stable,now 2.44-3 arm64 [installed,automatic] binutils-common/stable,now 2.44-3 arm64 [installed,automatic] binutils/stable,now 2.44-3 arm64 [installed,automatic] bsdextrautils/stable,now 2.41-5 arm64 [installed,automatic] bsdutils/stable,now 1:2.41-5 arm64 [installed] btop/stable,now 1.3.2-0.1 arm64 [installed] btrfs-progs/stable,now 6.14-1 arm64 [installed] build-essential/stable,now 12.12 arm64 [installed] bzip2/stable,now 1.0.8-6 arm64 [installed,automatic] ca-certificates/stable,now 20250419 all [installed] console-setup-linux/stable,now 1.242~deb13u1 all [installed,automatic] console-setup/stable,now 1.242~deb13u1 all [installed] coreutils/stable,now 9.7-3 arm64 [installed] cpio/stable,now 2.15+dfsg-2 arm64 [installed,automatic] cpp-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-14/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] cpp/stable,now 4:14.2.0-1 arm64 [installed,automatic] cron-daemon-common/stable,now 3.0pl1-197 all [installed,automatic] cron/stable,now 3.0pl1-197 arm64 [installed] curl/stable,now 8.14.1-2+deb13u2 arm64 [installed] cutecom/stable,now 0.51.0-1+b3 arm64 [installed] dash/stable,now 0.5.12-12 arm64 [installed] dbus-bin/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-daemon/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-session-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-system-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-user-session/stable,now 1.16.2-2 arm64 [installed] dbus/stable,now 1.16.2-2 arm64 [installed,automatic] dconf-gsettings-backend/stable,now 0.40.0-5 arm64 [installed,automatic] dconf-service/stable,now 0.40.0-5 arm64 [installed,automatic] debconf-utils/stable,now 1.5.91 all [installed] debconf/stable,now 1.5.91 all [installed] debian-archive-keyring/stable,now 2025.1 all [installed,automatic] debianutils/stable,now 5.23.2 arm64 [installed] debsums/stable,now 3.0.2.3 all [installed] device-tree-compiler/stable,now 1.7.2-2+b1 arm64 [installed] dialog/stable,now 1.3-20250116-1 arm64 [installed] diffutils/stable,now 1:3.10-4 arm64 [installed] dmidecode/stable,now 3.6-2 arm64 [installed] dmsetup/stable,now 2:1.02.205-2 arm64 [installed,automatic] dosfstools/stable,now 4.2-1.2 arm64 [installed] dpkg-dev/stable,now 1.22.21 all [installed,automatic] dpkg/stable,now 1.22.21 arm64 [installed] dracut-install/stable,now 106-6 arm64 [installed,automatic] e2fsprogs/stable,now 1.47.2-3+b3 arm64 [installed] ethtool/stable,now 1:6.14.2-1 arm64 [installed] fake-hwclock/stable,now 0.14 all [installed] fdisk/stable,now 2.41-5 arm64 [installed] figlet/stable,now 2.2.5-3+b2 arm64 [installed] file/stable,now 1:5.46-5 arm64 [installed] findutils/stable,now 4.10.0-3 arm64 [installed] fontconfig-config/stable,now 2.15.0-2.3 arm64 [installed,automatic] fontconfig/stable,now 2.15.0-2.3 arm64 [installed,automatic] fonts-dejavu-core/stable,now 2.37-8 all [installed,automatic] fonts-dejavu-mono/stable,now 2.37-8 all [installed,automatic] fping/stable,now 5.1-1+b1 arm64 [installed,automatic] g++-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] g++-14/stable,now 14.2.0-19 arm64 [installed,automatic] g++-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] g++/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-14-base/stable,now 14.2.0-19 arm64 [installed] gcc-14/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc/stable,now 4:14.2.0-1 arm64 [installed,automatic] gensio-bin/stable,now 2.8.13-7 arm64 [installed] git-man/stable,now 1:2.47.3-0+deb13u1 all [installed,automatic] git/stable,now 1:2.47.3-0+deb13u1 arm64 [installed] gpg/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgconf/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgv/stable,now 2.4.7-21+b3 arm64 [installed] gpiod/stable,now 2.2.1-2+deb13u1 arm64 [installed] grep/stable,now 3.11-4+b1 arm64 [installed] groff-base/stable,now 1.23.0-9 arm64 [installed,automatic] gtk-update-icon-cache/stable,now 4.18.6+ds-2 arm64 [installed,automatic] gzip/stable,now 1.13-1 arm64 [installed] hicolor-icon-theme/stable,now 0.18-2 all [installed,automatic] hostname/stable,now 3.25 arm64 [installed] htop/stable,now 3.4.1-5 arm64 [installed] iftop/stable,now 1.0~pre4-9+b2 arm64 [installed] inetutils-telnet/stable,now 2:2.6-3 arm64 [installed,automatic] inetutils-traceroute/stable,now 2:2.6-3 arm64 [installed] init-system-helpers/stable,now 1.69~deb13u1 all [installed] init/stable,now 1.69~deb13u1 arm64 [installed] initramfs-tools-bin/stable,now 0.148.3 arm64 [installed,automatic] initramfs-tools-core/stable,now 0.148.3 all [installed,automatic] initramfs-tools/stable,now 0.148.3 all [installed] iproute2/stable,now 6.15.0-1 arm64 [installed] iputils-ping/stable,now 3:20240905-3 arm64 [installed] iw/stable,now 6.9-1+b1 arm64 [installed] jq/stable,now 1.7.1-6+deb13u1 arm64 [installed] kbd/stable,now 2.7.1-2 arm64 [installed,automatic] keyboard-configuration/stable,now 1.242~deb13u1 all [installed,automatic] klibc-utils/stable,now 2.0.14-1 arm64 [installed,automatic] kmod/stable,now 34.2-2 arm64 [installed,automatic] less/stable,now 668-1 arm64 [installed] libacl1/stable,now 2.3.2-2+b1 arm64 [installed] libaio1t64/stable,now 0.3.113-8+b1 arm64 [installed,automatic] libapparmor1/stable,now 4.1.0-1 arm64 [installed,automatic] libapt-pkg7.0/stable,now 3.0.3 arm64 [installed,automatic] libasan8/stable,now 14.2.0-19 arm64 [installed,automatic] libasound2-data/stable,now 1.2.14-1 all [installed,automatic] libasound2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libassuan9/stable,now 3.0.2-2 arm64 [installed,automatic] libatk-bridge2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatk1.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatomic1/stable,now 14.2.0-19 arm64 [installed,automatic] libatopology2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libatspi2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libattr1/stable,now 1:2.5.2-3 arm64 [installed] libaudit-common/stable,now 1:4.0.2-2 all [installed] libaudit1/stable,now 1:4.0.2-2+b2 arm64 [installed] libavahi-client3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common-data/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-core7/stable,now 0.8-16 arm64 [installed,automatic] libbinutils/stable,now 2.44-3 arm64 [installed,automatic] libblkid1/stable,now 2.41-5 arm64 [installed] libbpf1/stable,now 1:1.5.0-3 arm64 [installed,automatic] libbrotli1/stable,now 1.1.0-2+b7 arm64 [installed,automatic] libbsd0/stable,now 0.12.2-2 arm64 [installed,automatic] libbz2-1.0/stable,now 1.0.8-6 arm64 [installed] libc-bin/stable,now 2.41-12 arm64 [installed] libc-dev-bin/stable,now 2.41-12 arm64 [installed,automatic] libc-l10n/stable,now 2.41-12 all [installed,automatic] libc6-dev/stable,now 2.41-12 arm64 [installed,automatic] libc6/stable,now 2.41-12 arm64 [installed] libcaca0/stable,now 0.99.beta20-5 arm64 [installed,automatic] libcairo-gobject2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcairo2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcap-ng0/stable,now 0.8.5-4+b1 arm64 [installed] libcap2-bin/stable,now 1:2.75-10+b1 arm64 [installed,automatic] libcap2/stable,now 1:2.75-10+b1 arm64 [installed] libcbor0.10/stable,now 0.10.2-2 arm64 [installed,automatic] libcc1-0/stable,now 14.2.0-19 arm64 [installed,automatic] libcloudproviders0/stable,now 0.3.6-2 arm64 [installed,automatic] libcolord2/stable,now 1.4.7-3 arm64 [installed,automatic] libcom-err2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libcrypt-dev/stable,now 1:4.4.38-1 arm64 [installed,automatic] libcrypt1/stable,now 1:4.4.38-1 arm64 [installed] libctf-nobfd0/stable,now 2.44-3 arm64 [installed,automatic] libctf0/stable,now 2.44-3 arm64 [installed,automatic] libcups2t64/stable,now 2.4.10-3+deb13u2 arm64 [installed,automatic] libcurl3t64-gnutls/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libcurl4t64/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libdaemon0/stable,now 0.14-7.1+b3 arm64 [installed,automatic] libdatrie1/stable,now 0.2.13-3+b1 arm64 [installed,automatic] libdb5.3t64/stable,now 5.3.28+dfsg2-9 arm64 [installed] libdbus-1-3/stable,now 1.16.2-2 arm64 [installed,automatic] libdconf1/stable,now 0.40.0-5 arm64 [installed,automatic] libdebconfclient0/stable,now 0.280 arm64 [installed] libdeflate0/stable,now 1.23-2 arm64 [installed,automatic] libdevmapper1.02.1/stable,now 2:1.02.205-2 arm64 [installed,automatic] libdialog15/stable,now 1.3-20250116-1 arm64 [installed,automatic] libdouble-conversion3/stable,now 3.3.1-1 arm64 [installed,automatic] libdpkg-perl/stable,now 1.22.21 all [installed,automatic] libdrm-amdgpu1/stable,now 2.4.124-2 arm64 [installed,automatic] libdrm-common/stable,now 2.4.124-2 all [installed,automatic] libdrm2/stable,now 2.4.124-2 arm64 [installed,automatic] libedit2/stable,now 3.1-20250104-1 arm64 [installed,automatic] libegl-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libegl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libelf1t64/stable,now 0.192-4 arm64 [installed,automatic] libepoxy0/stable,now 1.5.10-2 arm64 [installed,automatic] liberror-perl/stable,now 0.17030-1 all [installed,automatic] libestr0/stable,now 0.1.11-2 arm64 [installed,automatic] libevdev2/stable,now 1.13.4+dfsg-1 arm64 [installed,automatic] libexpat1/stable,now 2.7.1-2 arm64 [installed,automatic] libext2fs2t64/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libfastjson4/stable,now 1.2304.0-2 arm64 [installed,automatic] libfdisk1/stable,now 2.41-5 arm64 [installed,automatic] libfdt1/stable,now 1.7.2-2+b1 arm64 [installed,automatic] libffi8/stable,now 3.4.8-2 arm64 [installed,automatic] libfftw3-single3/stable,now 3.3.10-2+b1 arm64 [installed,automatic] libfido2-1/stable,now 1.15.0-1+b1 arm64 [installed,automatic] libfile-fnmatch-perl/stable,now 0.02-3+b4 arm64 [installed,automatic] libfontconfig1/stable,now 2.15.0-2.3 arm64 [installed,automatic] libfreetype6/stable,now 2.13.3+dfsg-1 arm64 [installed,automatic] libfribidi0/stable,now 1.0.16-1 arm64 [installed,automatic] libgbm1/stable,now 25.0.7-2 arm64 [installed,automatic] libgcc-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libgcc-s1/stable,now 14.2.0-19 arm64 [installed] libgcrypt20/stable,now 1.11.0-7 arm64 [installed,automatic] libgdbm-compat4t64/stable,now 1.24-2 arm64 [installed,automatic] libgdbm6t64/stable,now 1.24-2 arm64 [installed,automatic] libgdk-pixbuf-2.0-0/stable,now 2.42.12+dfsg-4 arm64 [installed,automatic] libgdk-pixbuf2.0-common/stable,now 2.42.12+dfsg-4 all [installed,automatic] libgensio6t64/stable,now 2.8.13-7 arm64 [installed,automatic] libgl1-mesa-dri/stable,now 25.0.7-2 arm64 [installed,automatic] libgl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglib2.0-0t64/stable,now 2.84.4-3~deb13u1 arm64 [installed,automatic] libglvnd0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglx-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libglx0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libgmp10/stable,now 2:6.3.0+dfsg-3 arm64 [installed] libgnutls30t64/stable,now 3.8.9-3 arm64 [installed,automatic] libgomp1/stable,now 14.2.0-19 arm64 [installed,automatic] libgpg-error0/stable,now 1.51-4 arm64 [installed,automatic] libgpiod3/stable,now 2.2.1-2+deb13u1 arm64 [installed,automatic] libgpm2/stable,now 1.20.7-11+b2 arm64 [installed,automatic] libgprofng0/stable,now 2.44-3 arm64 [installed,automatic] libgraphite2-3/stable,now 1.3.14-2+b1 arm64 [installed,automatic] libgssapi-krb5-2/stable,now 1.21.3-5 arm64 [installed,automatic] libgtk-3-0t64/stable,now 3.24.49-3 arm64 [installed,automatic] libgtk-3-common/stable,now 3.24.49-3 all [installed,automatic] libgudev-1.0-0/stable,now 238-6 arm64 [installed,automatic] libharfbuzz0b/stable,now 10.2.0-1+b1 arm64 [installed,automatic] libhogweed6t64/stable,now 3.10.1-1 arm64 [installed,automatic] libhwasan0/stable,now 14.2.0-19 arm64 [installed,automatic] libice6/stable,now 2:1.1.1-1 arm64 [installed,automatic] libicu76/stable,now 76.1-4 arm64 [installed,automatic] libidn2-0/stable,now 2.3.8-2 arm64 [installed,automatic] libiniparser4/stable,now 4.2.6-1 arm64 [installed,automatic] libinput-bin/stable,now 1.28.1-1 arm64 [installed,automatic] libinput10/stable,now 1.28.1-1 arm64 [installed,automatic] libisl23/stable,now 0.27-1 arm64 [installed,automatic] libitm1/stable,now 14.2.0-19 arm64 [installed,automatic] libjansson4/stable,now 2.14-2+b3 arm64 [installed,automatic] libjbig0/stable,now 2.1-6.1+b2 arm64 [installed,automatic] libjpeg62-turbo/stable,now 1:2.1.5-4 arm64 [installed,automatic] libjq1/stable,now 1.7.1-6+deb13u1 arm64 [installed,automatic] libk5crypto3/stable,now 1.21.3-5 arm64 [installed,automatic] libkeyutils1/stable,now 1.6.3-6 arm64 [installed,automatic] libklibc/stable,now 2.0.14-1 arm64 [installed,automatic] libkmod2/stable,now 34.2-2 arm64 [installed,automatic] libkrb5-3/stable,now 1.21.3-5 arm64 [installed,automatic] libkrb5support0/stable,now 1.21.3-5 arm64 [installed,automatic] libksba8/stable,now 1.6.7-2+b1 arm64 [installed,automatic] liblastlog2-2/stable,now 2.41-5 arm64 [installed] liblcms2-2/stable,now 2.16-2 arm64 [installed,automatic] libldap2/stable,now 2.6.10+dfsg-1 arm64 [installed,automatic] liblerc4/stable,now 4.0.0+ds-5 arm64 [installed,automatic] libllvm19/stable,now 1:19.1.7-3+b1 arm64 [installed,automatic] liblocale-gettext-perl/stable,now 1.07-7+b1 arm64 [installed,automatic] liblognorm5/stable,now 2.0.6-5 arm64 [installed,automatic] liblsan0/stable,now 14.2.0-19 arm64 [installed,automatic] liblsof0/stable,now 4.99.4+dfsg-2 arm64 [installed,automatic] liblua5.4-0/stable,now 5.4.7-1+b2 arm64 [installed,automatic] libluajit-5.1-2/stable,now 2.1.0+openresty20250117-2 arm64 [installed,automatic] libluajit-5.1-common/stable,now 2.1.0+openresty20250117-2 all [installed,automa> liblz1/stable,now 1.15-3 arm64 [installed,automatic] liblz4-1/stable,now 1.10.0-4 arm64 [installed,automatic] liblzma5/stable,now 5.8.1-1 arm64 [installed] liblzo2-2/stable,now 2.10-3+b1 arm64 [installed,automatic] libmagic-mgc/stable,now 1:5.46-5 arm64 [installed,automatic] libmagic1t64/stable,now 1:5.46-5 arm64 [installed,automatic] libmariadb3/stable,now 1:11.8.3-0+deb13u1 arm64 [installed,automatic] libmd0/stable,now 1.1.0-2+b1 arm64 [installed] libmd4c0/stable,now 0.5.2-2+b1 arm64 [installed,automatic] libmnl0/stable,now 1.0.5-3 arm64 [installed,automatic] libmount1/stable,now 2.41-5 arm64 [installed] libmpc3/stable,now 1.3.1-1+b3 arm64 [installed,automatic] libmpfr6/stable,now 4.2.2-1 arm64 [installed,automatic] libmtdev1t64/stable,now 1.1.7-1 arm64 [installed,automatic] libncurses5/now 6.4-4 arm64 [installed,local] libncurses6/stable,now 6.5+20250216-2 arm64 [installed] libncursesw6/stable,now 6.5+20250216-2 arm64 [installed,automatic] libnetplan1/stable,now 1.1.2-7 arm64 [installed,automatic] libnettle8t64/stable,now 3.10.1-1 arm64 [installed,automatic] libnewt0.52/stable,now 0.52.25-1 arm64 [installed,automatic] libnghttp2-14/stable,now 1.64.0-1.1 arm64 [installed,automatic] libnghttp3-9/stable,now 1.8.0-1 arm64 [installed,automatic] libngtcp2-16/stable,now 1.11.0-1 arm64 [installed,automatic] libngtcp2-crypto-gnutls8/stable,now 1.11.0-1 arm64 [installed,automatic] libnl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-genl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-route-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnpth0t64/stable,now 1.8-3 arm64 [installed,automatic] libnss-mdns/stable,now 0.15.1-4+b1 arm64 [installed] libonig5/stable,now 6.9.9-1+b1 arm64 [installed,automatic] libopenipmi0t64/stable,now 2.0.37-1 arm64 [installed,automatic] libp11-kit0/stable,now 0.25.5-3 arm64 [installed,automatic] libpam-modules-bin/stable,now 1.7.0-5 arm64 [installed] libpam-modules/stable,now 1.7.0-5 arm64 [installed] libpam-runtime/stable,now 1.7.0-5 all [installed] libpam-systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libpam0g/stable,now 1.7.0-5 arm64 [installed] libpango-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangocairo-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangoft2-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libparted2t64/stable,now 3.6-5 arm64 [installed,automatic] libpcap0.8t64/stable,now 1.10.5-2 arm64 [installed,automatic] libpci3/stable,now 1:3.13.0-2 arm64 [installed,automatic] libpcre2-16-0/stable,now 10.46-1~deb13u1 arm64 [installed,automatic] libpcre2-8-0/stable,now 10.46-1~deb13u1 arm64 [installed] libpcsclite1/stable,now 2.3.3-1 arm64 [installed,automatic] libperl5.40/stable,now 5.40.1-6 arm64 [installed,automatic] libpipeline1/stable,now 1.5.8-1 arm64 [installed,automatic] libpixman-1-0/stable,now 0.44.0-3 arm64 [installed,automatic] libpng16-16t64/stable-security,now 1.6.48-1+deb13u1 arm64 [installed,automatic] libpopt0/stable,now 1.19+dfsg-2 arm64 [installed,automatic] libpq5/stable,now 17.6-0+deb13u1 arm64 [installed,automatic] libproc2-0/stable,now 2:4.0.4-9 arm64 [installed,automatic] libprotobuf32t64/stable,now 3.21.12-11 arm64 [installed,automatic] libproxychains4/stable,now 4.17-3 arm64 [installed,automatic] libpsl5t64/stable,now 0.21.2-1.1+b1 arm64 [installed,automatic] libpython3-stdlib/stable,now 3.13.5-1 arm64 [installed,automatic] libpython3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13-stdlib/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13/stable,now 3.13.5-2 arm64 [installed,automatic] libqt5core5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5dbus5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5gui5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5network5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5serialport5/stable,now 5.15.15-2 arm64 [installed,automatic] libqt5widgets5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libreadline8t64/stable,now 8.2-6 arm64 [installed,automatic] libreiserfscore0t64/stable,now 1:3.6.27-9 arm64 [installed,automatic] librtmp1/stable,now 2.4+20151223.gitfa8646d.1-2+b5 arm64 [installed,automatic] libsamplerate0/stable,now 0.2.2-4+b2 arm64 [installed,automatic] libsasl2-2/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsasl2-modules-db/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsctp1/stable,now 1.0.21+dfsg-1 arm64 [installed,automatic] libseccomp2/stable,now 2.6.0-2 arm64 [installed,automatic] libselinux1/stable,now 3.8.1-1 arm64 [installed] libsemanage-common/stable,now 3.8.1-1 all [installed,automatic] libsemanage2/stable,now 3.8.1-1 arm64 [installed,automatic] libsensors-config/stable,now 1:3.6.2-2 all [installed,automatic] libsensors5/stable,now 1:3.6.2-2 arm64 [installed,automatic] libsepol2/stable,now 3.8.1-1 arm64 [installed,automatic] libsframe1/stable,now 2.44-3 arm64 [installed,automatic] libsharpyuv0/stable,now 1.5.0-0.1 arm64 [installed,automatic] libslang2/stable,now 2.3.3-5+b2 arm64 [installed,automatic] libsm6/stable,now 2:1.2.6-1 arm64 [installed,automatic] libsmartcols1/stable,now 2.41-5 arm64 [installed] libsqlite3-0/stable,now 3.46.1-7 arm64 [installed] libss2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libssh2-1t64/stable,now 1.11.1-1 arm64 [installed,automatic] libssl3t64/stable,now 3.5.4-1~deb13u1 arm64 [installed] libstdc++-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libstdc++6/stable,now 14.2.0-19 arm64 [installed,automatic] libsystemd-shared/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libsystemd0/stable,now 257.9-1~deb13u1 arm64 [installed] libtasn1-6/stable,now 4.20.0-2 arm64 [installed,automatic] libtext-charwidth-perl/stable,now 0.04-11+b4 arm64 [installed,automatic] libtext-iconv-perl/stable,now 1.7-8+b4 arm64 [installed,automatic] libtext-wrapi18n-perl/stable,now 0.06-10 all [installed,automatic] libthai-data/stable,now 0.1.29-2 all [installed,automatic] libthai0/stable,now 0.1.29-2+b1 arm64 [installed,automatic] libtiff6/stable,stable-security,now 4.7.0-3+deb13u1 arm64 [installed,automatic] libtinfo5/now 6.4-4 arm64 [installed,local] libtinfo6/stable,now 6.5+20250216-2 arm64 [installed] libtirpc-common/stable,now 1.3.6+ds-1 all [installed,automatic] libtirpc3t64/stable,now 1.3.6+ds-1 arm64 [installed,automatic] libtsan2/stable,now 14.2.0-19 arm64 [installed,automatic] libubsan1/stable,now 14.2.0-19 arm64 [installed,automatic] libuchardet0/stable,now 0.0.8-1+b2 arm64 [installed,automatic] libudev1/stable,now 257.9-1~deb13u1 arm64 [installed] libunistring5/stable,now 1.3-2 arm64 [installed,automatic] libusb-1.0-0/stable,now 2:1.0.28-1 arm64 [installed,automatic] libutempter0/stable,now 1.2.1-4 arm64 [installed,automatic] libuuid1/stable,now 2.41-5 arm64 [installed] libvulkan1/stable,now 1.4.309.0-1 arm64 [installed,automatic] libwacom-common/stable,now 2.14.0-1 all [installed,automatic] libwacom9/stable,now 2.14.0-1 arm64 [installed,automatic] libwayland-client0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-cursor0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-egl1/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-server0/stable,now 1.23.1-3 arm64 [installed,automatic] libwebp7/stable,now 1.5.0-0.1 arm64 [installed,automatic] libwrap0/stable,now 7.6.q-36 arm64 [installed,automatic] libwtmpdb0/stable,now 0.73.0-3+deb13u1 arm64 [installed,automatic] libx11-6/stable,now 2:1.8.12-1 arm64 [installed,automatic] libx11-data/stable,now 2:1.8.12-1 all [installed,automatic] libx11-xcb1/stable,now 2:1.8.12-1 arm64 [installed,automatic] libxau6/stable,now 1:1.0.11-1 arm64 [installed,automatic] libxaw7/stable,now 2:1.0.16-1 arm64 [installed,automatic] libxcb-dri3-0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-glx0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-icccm4/stable,now 0.4.2-1 arm64 [installed,automatic] libxcb-image0/stable,now 0.4.0-2+b2 arm64 [installed,automatic] libxcb-keysyms1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-present0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-randr0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-render-util0/stable,now 0.3.10-1 arm64 [installed,automatic] libxcb-render0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shape0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shm0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-sync1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-util1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-xfixes0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinerama0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinput0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xkb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcomposite1/stable,now 1:0.4.6-1 arm64 [installed,automatic] libxcursor1/stable,now 1:1.2.3-1 arm64 [installed,automatic] libxdamage1/stable,now 1:1.1.6-1+b2 arm64 [installed,automatic] libxdmcp6/stable,now 1:1.1.5-1 arm64 [installed,automatic] libxext6/stable,now 2:1.3.4-1+b3 arm64 [installed,automatic] libxfixes3/stable,now 1:6.0.0-2+b4 arm64 [installed,automatic] libxft2/stable,now 2.3.6-1+b4 arm64 [installed,automatic] libxi6/stable,now 2:1.8.2-1 arm64 [installed,automatic] libxinerama1/stable,now 2:1.1.4-3+b4 arm64 [installed,automatic] libxkbcommon-x11-0/stable,now 1.7.0-2 arm64 [installed,automatic] libxkbcommon0/stable,now 1.7.0-2 arm64 [installed,automatic] libxml2/stable,now 2.12.7+dfsg+really2.9.14-2.1+deb13u2 arm64 [installed,automa> libxmu6/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxmuu1/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxpm4/stable,now 1:3.5.17-1+b3 arm64 [installed,automatic] libxrandr2/stable,now 2:1.5.4-1+b3 arm64 [installed,automatic] libxrender1/stable,now 1:0.9.12-1 arm64 [installed,automatic] libxshmfence1/stable,now 1.3.3-1 arm64 [installed,automatic] libxt6t64/stable,now 1:1.2.1-1.2+b2 arm64 [installed,automatic] libxtables12/stable,now 1.8.11-2 arm64 [installed,automatic] libxxf86vm1/stable,now 1:1.1.4-1+b4 arm64 [installed,automatic] libxxhash0/stable,now 0.8.3-2 arm64 [installed,automatic] libyaml-0-2/stable,now 0.2.5-2 arm64 [installed,automatic] libz3-4/stable,now 4.13.3-1 arm64 [installed,automatic] libzstd1/stable,now 1.5.7+dfsg-1 arm64 [installed] links/stable,now 2.29-2+b3 arm64 [installed] linux-base/stable,now 4.12 all [installed] linux-dtb-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-image-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-libc-dev/stable,now 6.12.57-1 all [installed,automatic] linux-u-boot-rockpi-s-current/now 25.11.2 arm64 [installed,local] lm-sensors/stable,now 1:3.6.2-2 arm64 [installed] lmbench/stable,now 3.0-a9+debian.1-9 arm64 [installed] locales/stable,now 2.41-12 all [installed] login.defs/stable,now 1:4.17.4-2 all [installed] login/stable,now 1:4.16.0-2+really2.41-5 arm64 [installed] logrotate/stable,now 3.22.0-1+b2 arm64 [installed] logsave/stable,now 1.47.2-3+b3 arm64 [installed,automatic] lsb-release/stable,now 12.1-1 all [installed,automatic] lshw/stable,now 02.19.git.2021.06.19.996aaad9c7-2.1 arm64 [installed] lsof/stable,now 4.99.4+dfsg-2 arm64 [installed] make/stable,now 4.4.1-2 arm64 [installed,automatic] man-db/stable,now 2.13.1-1 arm64 [installed] mariadb-common/stable,now 1:11.8.3-0+deb13u1 all [installed,automatic] mawk/stable,now 1.3.4.20250131-1 arm64 [installed] media-types/stable,now 13.0.0 all [installed,automatic] mesa-libgallium/stable,now 25.0.7-2 arm64 [installed,automatic] minicom/stable,now 2.10-1 arm64 [installed] mmc-utils/stable,now 0+git20240329.f757f413-1+b1 arm64 [installed] mount/stable,now 2.41-5 arm64 [installed] mtd-utils/stable,now 1:2.3.0-1 arm64 [installed] mysql-common/stable,now 5.8+1.1.1 all [installed,automatic] nano/stable,now 8.4-1 arm64 [installed] ncurses-base/stable,now 6.5+20250216-2 all [installed] ncurses-bin/stable,now 6.5+20250216-2 arm64 [installed] ncurses-term/stable,now 6.5+20250216-2 all [installed] netbase/stable,now 6.5 all [installed,automatic] netplan-generator/stable,now 1.1.2-7 arm64 [installed,automatic] netplan.io/stable,now 1.1.2-7 arm64 [installed] openssh-client/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssh-server/stable,now 1:10.0p1-7 arm64 [installed] openssh-sftp-server/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssl-provider-legacy/stable,now 3.5.4-1~deb13u1 arm64 [installed] openssl/stable,now 3.5.4-1~deb13u1 arm64 [installed,automatic] p7zip-full/stable,now 16.02+transitional.1 all [installed] parted/stable,now 3.6-5 arm64 [installed] passwd/stable,now 1:4.17.4-2 arm64 [installed] patch/stable,now 2.8-2 arm64 [installed,automatic] pci.ids/stable,now 0.0~2025.06.09-1 all [installed,automatic] perl-base/stable,now 5.40.1-6 arm64 [installed] perl-modules-5.40/stable,now 5.40.1-6 all [installed,automatic] perl/stable,now 5.40.1-6 arm64 [installed,automatic] picocom/stable,now 3.1-4+b1 arm64 [installed] powertop/stable,now 2.15-4 arm64 [installed] procps/stable,now 2:4.0.4-9 arm64 [installed,automatic] proxychains4/stable,now 4.17-3 arm64 [installed] psmisc/stable,now 23.7-2 arm64 [installed] putty-tools/stable,now 0.83-3 arm64 [installed,automatic] putty/stable,now 0.83-3 arm64 [installed] pv/stable,now 1.9.31-1 arm64 [installed,automatic] python3-cffi-backend/stable,now 1.17.1-3 arm64 [installed,automatic] python3-minimal/stable,now 3.13.5-1 arm64 [installed,automatic] python3-netplan/stable,now 1.1.2-7 arm64 [installed,automatic] python3-psutil/stable,now 7.0.0-2 arm64 [installed,automatic] python3-typing-extensions/stable,now 4.13.2-1 all [installed,automatic] python3-urwid/stable,now 2.6.16-1 arm64 [installed,automatic] python3-wcwidth/stable,now 0.2.13+dfsg1-1 all [installed,automatic] python3-yaml/stable,now 6.0.2-1+b2 arm64 [installed,automatic] python3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] python3.13/stable,now 3.13.5-2 arm64 [installed,automatic] python3/stable,now 3.13.5-1 arm64 [installed,automatic] readline-common/stable,now 8.2-6 all [installed,automatic] rfkill/stable,now 2.41-5 arm64 [installed] rockusb/stable,now 0.2.0-2+b2 arm64 [installed] rpcsvc-proto/stable,now 1.4.3-1+b1 arm64 [installed,automatic] rsync/stable,now 3.4.1+ds1-5 arm64 [installed] rsyslog/stable,now 8.2504.0-1 arm64 [installed] runit-helper/stable,now 2.16.4 all [installed,automatic] s-tui/stable,now 1.1.6-1.2 all [installed] sed/stable,now 4.9-2+b1 arm64 [installed] sensible-utils/stable,now 0.0.25 all [installed,automatic] ser2net/stable,now 4.6.4-1 arm64 [installed] shared-mime-info/stable,now 2.4-5+b2 arm64 [installed,automatic] sqv/stable,now 1.3.0-3 arm64 [installed,automatic] stress/stable,now 1.0.7-1+b1 arm64 [installed] sudo/stable,now 1.9.16p2-3 arm64 [installed] sysbench/stable,now 1.0.20+ds-7+b1 arm64 [installed] sysstat/stable,now 12.7.5-2+b2 arm64 [installed] systemd-resolved/stable,now 257.9-1~deb13u1 arm64 [installed] systemd-sysv/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] systemd-timesyncd/stable,now 257.9-1~deb13u1 arm64 [installed] systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] sysvinit-utils/stable,now 3.14-4 arm64 [installed] tar/stable,now 1.35+dfsg-3.1 arm64 [installed] telnet/stable,now 0.17+2.6-3 all [installed] tio/stable,now 3.9-1 arm64 [installed] toilet-fonts/stable,now 0.3-3 all [installed,automatic] toilet/stable,now 0.3-3 arm64 [installed] tree/stable,now 2.2.1-1 arm64 [installed] tzdata/stable,now 2025b-4+deb13u1 all [installed] u-boot-tools/stable,now 2025.01-3 arm64 [installed] ucf/stable,now 3.0052 all [installed,automatic] udev/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] usbutils/stable,now 1:018-2 arm64 [installed] util-linux/stable,now 2.41-5 arm64 [installed] wavemon/stable,now 0.9.1-1+b1 arm64 [installed] wget/stable,now 1.25.0-2 arm64 [installed] whiptail/stable,now 0.52.25-1 arm64 [installed,automatic] wireguard-tools/stable,now 1.0.20210914-3 arm64 [installed] wireless-regdb/stable,now 2025.07.10-1 all [installed] wpasupplicant/stable,now 2:2.10-24 arm64 [installed] x11-common/stable,now 1:7.7+24+deb13u1 all [installed,automatic] xauth/stable,now 1:1.1.2-1.1 arm64 [installed] xbitmaps/stable,now 1.1.1-2.2 all [installed,automatic] xkb-data/stable,now 2.42-1 all [installed,automatic] xterm/stable,now 398-1 arm64 [installed] xz-utils/stable,now 5.8.1-1 arm64 [installed,automatic] zlib1g/stable,now 1:1.3.dfsg+really1.3.1-1+b1 arm64 [installed] pi@Pi-s:~$ pi@Pi-s:~$ lsmod Module Size Used by 8723ds 1327104 0 hci_uart 135168 0 btqca 20480 1 hci_uart btrtl 28672 1 hci_uart snd_soc_rk3308 65536 1 crct10dif_ce 12288 1 btintel 49152 1 hci_uart snd_soc_rockchip_i2s_tdm 24576 2 snd_soc_simple_card 20480 0 btbcm 20480 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card bluetooth 671744 6 btrtl,btqca,btintel,hci_uart,btbcm snd_soc_core 204800 4 snd_soc_rockchip_i2s_tdm,snd_soc_rk3308,snd_soc_simple_card_utils,snd_soc_simple_card snd_compress 24576 1 snd_soc_core snd_pcm_dmaengine 12288 1 snd_soc_core snd_pcm 106496 4 snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine snd_timer 36864 1 snd_pcm snd 77824 4 snd_timer,snd_compress,snd_soc_core,snd_pcm soundcore 12288 1 snd cpufreq_dt 16384 0 cfg80211 815104 1 8723ds rfkill 24576 4 bluetooth,cfg80211 zram 36864 2 842_decompress 16384 1 zram 842_compress 20480 1 zram binfmt_misc 20480 1 usb_f_acm 16384 1 u_serial 28672 1 usb_f_acm g_serial 12288 0 libcomposite 65536 2 g_serial,usb_f_acm nfnetlink 16384 2 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 45056 2 realtek 40960 1 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 28672 1 stmmac pi@Pi-s:~$
  16. I'm trying to start sound. The device is created, but the error is "Write error: -5,Input/output error." The logs show the entry [ 7.411495] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743313] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743325] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan1 busy [ 20.743391] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743400] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan1 busy [ 20.743409] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan2 busy Why is it busy? # speaker-test -Dhw:2 -r48000 -c2 -tsine -f1000 speaker-test 1.2.14 Playback device is hw:2 Stream parameters are 48000Hz, S16_LE, 2 channels Sine wave rate is 1000.0000Hz Rate set to 48000Hz (requested 48000Hz) Buffer size range from 32 to 131072 Period size ra[ 194.914904] sun6i-dma 7121000.dma-controller: vchan 0000000060790fd8: txd 00000000925572c7[2]: submitted [194.914931] dma dma1chan2: vchan 0000000060790fd8: issued [ 194.914968] sun6i-dma 7121000.dma-controller: pchan 0: alloc vchan 0000000060790fd8 [194.914980] dma dma1chan2: [ 194.914980] desc: p - 0x00000000a9840060 v - 0x00000000be392dcf [ 194.914980] c - 0x03820481 s - 0xa9a00000 d - 0x07116020 [ 194.914980] l - 0x0000bb80 p - 0x00000008 n - 0xa9840040 [ 194.914998] sun6i-dma 7121000.dma-controller: Common register: [ 194.914998] mask0(0000): 0x00000002 [ 194.914998] mask1(0004): 0x00000000 [ 194.914998] pend0(0010): 0x00000000 [ 194.914998] pend1(0014): 0x00000000 [ 194.914998] stats(0030): 0x00000001 [194.915015] sun6i-dma 7121000.dma-controller: Chan 0 reg: [ 194.915015] ___en(0000): 0x00000001 [ 194.915015] pause(0004): 0x00000000 [ 194.915015] start(0008): 0xa9840060 [ 194.915015] __cfg(000c): 0x00000000 [ 194.915015] __src(0010): 0x00000000 [ 194.915015] __dst(0014): 0x00000000 [194.915015] count(0018): 0x00000000 [ 194.915015] _para(001c): 0x00000000 [194.915015] nge from 16 to 65536 Periods = 4 was set period_size = 12000 was set buffer_size = 48000 0 - Front Left Write error: -5,Input/output error xrun_recovery failed: -5,Input/output error Transfer failed: Input/output error
  17. I use etckeeper on my ODroid-N2. he sends me changes to my /etc/once a day. And regularly I get this change: armbian-leds.conf | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) diff --git a/armbian-leds.conf b/armbian-leds.conf index 8108230..537ea6f 100644 --- a/armbian-leds.conf +++ b/armbian-leds.conf @@ -5,5 +5,5 @@ invert=0 [/sys/class/leds/rtw88-1-1.1:1.0] trigger=phy0tpt -brightness=1 +brightness=0 What is this mess? What is it for?
  18. If anyone wants to make an image for the v1.1 board I dumped the bootloader from the v1.1 board which can be found here: https://www.mediafire.com/file/v41ojct50vqnbbp/bootloader-dump.bin/file
  19. update armbian dts ,Give to those in need use sudo armbian-add-overlay ***.dts this dts can avaible rtl8211f on h618 /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h618"; fragment@0 { target = <&mmc1>; __overlay__ { status = "disabled"; }; }; fragment@1 { target = <&emac1>; __overlay__ { status = "disabled"; }; }; fragment@2 { target = <&pio>; __overlay__ { x98h_rgmii_pins: x98h-rgmii-pins { pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15"; function = "emac0"; drive-strength = <40>; }; }; }; /* 3. 配置千兆网卡 */ fragment@3 { target = <&emac0>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&x98h_rgmii_pins>; phy-mode = "rgmii"; phy-handle = <&rgmii_phy>; phy-io-supply = <&reg_aldo1>; allwinner,tx-delay-ps = <700>; allwinner,rx-delay-ps = <3100>; status = "okay"; mdio { rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; reset-gpios = <&pio 8 16 1>; reset-assert-us = <30000>; reset-deassert-us = <150000>; }; }; }; }; };
  20. https://drive.google.com/drive/folders/1dx0TApPAEjFDz24Rm22J4jgtIbJrYYHC?usp=drive_link build log: url for test...
  21. Hi @Nick A, I seem to have the same x96q v5.1 board as @Trauma. He reported some time ago that your x98h image runs as intended on the x96q v5.1 board if the following patch is applied: https://github.com/sicXnull/armbian-build/blob/333e462466670e9a8609771ccd05977b87800881/patch/u-boot/u-boot-sunxi/board_x96q-v5-1/sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch Although the v5.1 image from @sicxnull does work as well including ethernet and wifi, I would also prefer the more recent armbian version. Can you briefly explain the steps necessary to build a corresponding image for the x96q v5.1? Thank you
  22. Last week
  23. This looks like normal OOM behavior to me. If you want me to replicate, please provide a list of packages to apt install and the commands I need to run to start the passmark benchmark as you did.
  24. When running PassMark on my Rock Pi S running Armbian 25.11, the system completely freezes, including the serial console. The blue TF card read/write LED stays lit, and OOM events are visible on the serial console. This freeze typically lasts over half an hour before the system recovers as the blue LED turns off. OOM events also occur on the stock kernel 4.4 system, but it doesn't freeze. I really don't want to use the 4.4 kernel system, but how can I optimize it? Below is my system configuration and log output: Translated with DeepL.com (free version) pi@Pi-s:~$ uname -a Linux Pi-s 6.12.58-current-rockchip64 #3 SMP PREEMPT Thu Nov 13 20:34:41 UTC 2025 aarch64 GNU/Linux pi@Pi-s:~$ cat /etc/os-release PRETTY_NAME="Armbian 25.11.2 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.2 ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 25.11.2 trixie" pi@Pi-s:~$ cat /sys/class/leds/rockpis\:blue\:user/trigger none usb-gadget usb-host kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock disk-activity disk-read disk-write mtd nand-disk heartbeat cpu cpu0 cpu1 cpu2 cpu3 activity default-on panic usbport [mmc1] mmc2 mmc0 rfkill-any rfkill-none stmmac-0:01:link stmmac-0:01:100Mbps stmmac-0:01:10Mbps bluetooth-power rfkill0 hci0-power rfkill1 ===befor run passmark======== pi@Pi-s:~$ free -h total used free shared buff/cache available Mem: 466Mi 116Mi 145Mi 328Ki 215Mi 350Mi Swap: 233Mi 20Mi 212Mi ==running passmark========== pi@Pi-s:~$ [ 672.734497] systemd-journal invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=-250 [ 672.735618] CPU: 2 UID: 0 PID: 388 Comm: systemd-journal Not tainted 6.12.58-current-rockchip64 #3 [ 672.735638] Hardware name: Radxa ROCK Pi S (DT) [ 672.735645] Call trace: [ 672.735650] dump_backtrace+0x94/0x114 [ 672.735670] show_stack+0x18/0x24 [ 672.735679] dump_stack_lvl+0x78/0x90 [ 672.735692] dump_stack+0x18/0x24 [ 672.735700] dump_header+0x40/0x1a8 [ 672.735715] oom_kill_process+0x130/0x358 [ 672.735727] out_of_memory+0xdc/0x568 [ 672.735738] __alloc_pages_noprof+0xcbc/0xdcc [ 672.735752] alloc_pages_mpol_noprof+0x88/0x23c [ 672.735762] alloc_pages_noprof+0x48/0xc0 [ 672.735770] folio_alloc_noprof+0x14/0x64 [ 672.735778] filemap_alloc_folio_noprof+0x140/0x154 [ 672.735789] __filemap_get_folio+0x208/0x394 [ 672.735799] filemap_fault+0x54c/0x858 [ 672.735809] __do_fault+0x3c/0x134 [ 672.735821] __handle_mm_fault+0x9e4/0x17cc [ 672.735831] handle_mm_fault+0xe8/0x2e4 [ 672.735839] do_page_fault+0x100/0x58c [ 672.735851] do_translation_fault+0xac/0xc8 [ 672.735860] do_mem_abort+0x44/0x94 [ 672.735873] el0_da+0x2c/0x9c [ 672.735883] el0t_64_sync_handler+0xe4/0x158 [ 672.735893] el0t_64_sync+0x190/0x194 [ 672.735904] Mem-Info: [ 672.745515] active_anon:9385 inactive_anon:40818 isolated_anon:0 [ 672.745515] active_file:662 inactive_file:777 isolated_file:0 [ 672.745515] unevictable:0 dirty:0 writeback:0 [ 672.745515] slab_reclaimable:3237 slab_unreclaimable:8655 [ 672.745515] mapped:65 shmem:7 pagetables:779 [ 672.745515] sec_pagetables:0 bounce:0 [ 672.745515] kernel_misc_reclaimable:0 [ 672.745515] free:1597 free_pcp:34 free_cma:1 [ 672.748854] Node 0 active_anon:123756kB inactive_anon:77056kB active_file:2736kB inactive_file:2428kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:260kB dirty:0kB writeback:0kB shmem:28kB shmem_thp:0kB shmem_pmdmapped:0kB anon_thp:0kB writeback_tmp:0kB kernel_stack:2144kB pagetables:3116kB sec_pagetables:0kB all_unreclaimable? no [ 672.751655] Node 0 DMA free:6336kB boost:0kB min:2684kB low:3352kB high:4020kB reserved_highatomic:0KB active_anon:38576kB inactive_anon:162236kB active_file:3244kB inactive_file:2308kB unevictable:0kB writepending:0kB present:522240kB managed:477808kB mlocked:0kB bounce:0kB free_pcp:436kB local_pcp:0kB free_cma:68kB [ 672.754668] lowmem_reserve[]: 0 0 0 0 [ 672.755060] Node 0 DMA: 653*4kB (UMEC) 164*8kB (UMEC) 90*16kB (UE) 13*32kB (UE) 5*64kB (E) 4*128kB (E) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 6612kB [ 672.756372] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB [ 672.757147] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=32768kB [ 672.758033] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB [ 672.758825] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=64kB [ 672.759562] 1693 total pagecache pages [ 672.762567] 243 pages in swap cache [ 672.762925] Free swap = 212kB [ 672.763223] Total swap = 238900kB [ 672.763550] 130560 pages RAM [ 672.763816] 0 pages HighMem/MovableOnly [ 672.764163] 11108 pages reserved [ 672.764453] 4096 pages cma reserved [ 672.764770] Tasks state (memory values in pages): [ 672.768270] [ pid ] uid tgid total_vm rss rss_anon rss_file rss_shmem pgtables_bytes swapents oom_score_adj name [ 672.769454] [ 233] 990 233 5947 81 32 49 0 94208 640 0 systemd-resolve [ 672.770505] [ 234] 988 234 23067 16 0 16 0 81920 256 0 systemd-timesyn [ 672.771532] [ 242] 0 242 8746 96 32 64 0 86016 512 -1000 systemd-udevd [ 672.772547] [ 264] 998 264 6903 236 64 172 0 90112 320 0 systemd-network [ 672.773662] [ 369] 0 369 4570 32 32 0 0 77824 384 0 wpa_supplicant [ 672.774698] [ 388] 0 388 6833 67 32 0 35 81920 256 -250 systemd-journal [ 672.775746] [ 484] 100 484 1445 92 32 60 0 53248 32 0 avahi-daemon [ 672.776772] [ 488] 0 488 2520 32 32 0 0 49152 32 0 cron [ 672.777768] [ 491] 996 491 2064 93 32 61 0 53248 160 -900 dbus-daemon [ 672.778778] [ 518] 0 518 55049 180 96 84 0 73728 96 0 rsyslogd [ 672.779770] [ 519] 0 519 4682 38 32 6 0 81920 256 0 systemd-logind [ 672.780831] [ 544] 100 544 1414 50 6 44 0 53248 32 0 avahi-daemon [ 672.787179] [ 735] 0 735 4358 114 64 50 0 77824 224 0 wpa_supplicant [ 672.788241] [ 787] 0 787 2701 62 0 62 0 49152 32 0 agetty [ 672.789295] [ 788] 0 788 3775 58 0 58 0 65536 128 0 login [ 672.790457] [ 797] 0 797 2863 115 64 51 0 57344 224 -1000 sshd [ 672.793417] [ 1322] 1000 1322 5625 72 32 40 0 81920 512 100 systemd [ 672.794428] [ 1324] 1000 1324 5942 63 2 61 0 77824 384 100 (sd-pam) [ 672.795407] [ 1333] 1000 1333 3109 422 416 6 0 61440 288 0 bash [ 672.796355] [ 1510] 0 1510 5345 186 128 58 0 90112 288 0 sshd-session [ 672.798743] [ 1514] 0 1514 5346 466 416 50 0 77824 32 0 sshd-session [ 672.804912] [ 1928] 1000 1928 5375 211 164 47 0 90112 352 0 sshd-session [ 672.806021] [ 1929] 1000 1929 5410 449 359 90 0 81920 128 0 sshd-session [ 672.813315] [ 1930] 1000 1930 605 75 0 75 0 45056 32 0 sftp-server [ 672.814361] [ 1931] 1000 1931 3042 103 32 71 0 53248 544 0 bash [ 672.815311] [ 2008] 1000 2008 8691 64 64 0 0 106496 384 0 passmark [ 672.816290] [ 2023] 1000 2023 35734 15887 15887 0 0 315392 11584 0 passmark [ 672.827360] [ 2024] 1000 2024 31575 7416 7416 0 0 278528 15904 0 passmark [ 672.828805] [ 2025] 1000 2025 35734 17441 17441 0 0 315392 10016 0 passmark [ 672.831389] [ 2026] 1000 2026 31839 7873 7864 9 0 282624 15680 0 passmark [ 672.832430] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-8.scope,task=passmark,pid=2023,uid=1000 [ 672.834281] Out of memory: Killed process 2023 (passmark) total-vm:142936kB, anon-rss:63548kB, file-rss:0kB, shmem-rss:0kB, UID:1000 pgtables:308kB oom_score_adj:0 [ 673.170919] systemd-journald[388]: Under memory pressure, flushing caches. pi@Pi-s:~$ pi@Pi-s:~$ pi@Pi-s:~$ [ 1406.871962] systemd-journald[388]: Under memory pressure, flushing caches. pi@Pi-s:~$ [ 1686.724826] systemd-journald[388]: Under memory pressure, flushing caches. [ 2073.973035] systemd-resolve invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0 [ 2073.975522] CPU: 2 UID: 990 PID: 233 Comm: systemd-resolve Not tainted 6.12.58-current-rockchip64 #3 [ 2073.975558] Hardware name: Radxa ROCK Pi S (DT) [ 2073.975564] Call trace: [ 2073.975569] dump_backtrace+0x94/0x114 [ 2073.975591] show_stack+0x18/0x24 [ 2073.975600] dump_stack_lvl+0x78/0x90 [ 2073.975612] dump_stack+0x18/0x24 [ 2073.975620] dump_header+0x40/0x1a8 [ 2073.975634] oom_kill_process+0x130/0x358 [ 2073.975645] out_of_memory+0xdc/0x568 [ 2073.975656] __alloc_pages_noprof+0xcbc/0xdcc [ 2073.975671] alloc_pages_mpol_noprof+0x88/0x23c [ 2073.975681] alloc_pages_noprof+0x48/0xc0 [ 2073.975689] folio_alloc_noprof+0x14/0x64 [ 2073.975697] filemap_alloc_folio_noprof+0x140/0x154 [ 2073.975707] __filemap_get_folio+0x208/0x394 [ 2073.975717] filemap_fault+0x54c/0x858 [ 2073.975727] __do_fault+0x3c/0x134 [ 2073.975740] __handle_mm_fault+0x9e4/0x17cc [ 2073.975749] handle_mm_fault+0xe8/0x2e4 [ 2073.975758] do_page_fault+0x100/0x58c [ 2073.975769] do_translation_fault+0xac/0xc8 [ 2073.975778] do_mem_abort+0x44/0x94 [ 2073.975790] el0_da+0x2c/0x9c [ 2073.975800] el0t_64_sync_handler+0xe4/0x158 [ 2073.975809] el0t_64_sync+0x190/0x194 [ 2073.975821] Mem-Info: [ 2073.988269] active_anon:20576 inactive_anon:36197 isolated_anon:0 [ 2073.988269] active_file:35 inactive_file:317 isolated_file:0 [ 2073.988269] unevictable:0 dirty:0 writeback:0 [ 2073.988269] slab_reclaimable:3159 slab_unreclaimable:8656 [ 2073.988269] mapped:132 shmem:61 pagetables:814 [ 2073.988269] sec_pagetables:0 bounce:0 [ 2073.988269] kernel_misc_reclaimable:0 [ 2073.988269] free:2209 free_pcp:8 free_cma:0 [ 2073.995887] Node 0 active_anon:147140kB inactive_anon:79952kB active_file:328kB inactive_file:1060kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:524kB dirty:0kB writeback:0kB shmem:244kB shmem_thp:0kB shmem_pmdmapped:0kB anon_thp:0kB writeback_tmp:0kB kernel_stack:2208kB pagetables:3256kB sec_pagetables:0kB all_unreclaimable? no [ 2073.999317] Node 0 DMA free:8424kB boost:0kB min:2684kB low:3352kB high:4020kB reserved_highatomic:0KB active_anon:146860kB inactive_anon:80232kB active_file:100kB inactive_file:1224kB unevictable:0kB writepending:0kB present:522240kB managed:477808kB mlocked:0kB bounce:0kB free_pcp:492kB local_pcp:64kB free_cma:72kB [ 2074.004391] lowmem_reserve[]: 0 0 0 0 [ 2074.004781] Node 0 DMA: 8*4kB (U) 282*8kB (UE) 137*16kB (UE) 57*32kB (UE) 16*64kB (UE) 4*128kB (E) 1*256kB (E) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 8096kB [ 2074.006154] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB [ 2074.006944] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=32768kB [ 2074.007692] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB [ 2074.008434] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=64kB [ 2074.009158] 1165 total pagecache pages [ 2074.009493] 727 pages in swap cache [ 2074.010642] Free swap = 232kB [ 2074.010949] Total swap = 238900kB [ 2074.011247] 130560 pages RAM [ 2074.011508] 0 pages HighMem/MovableOnly [ 2074.011847] 11108 pages reserved [ 2074.012135] 4096 pages cma reserved [ 2074.012444] Tasks state (memory values in pages): [ 2074.012859] [ pid ] uid tgid total_vm rss rss_anon rss_file rss_shmem pgtables_bytes swapents oom_score_adj name [ 2074.015540] [ 233] 990 233 5918 65 64 1 0 94208 640 0 systemd-resolve [ 2074.016593] [ 234] 988 234 23036 23 0 23 0 81920 256 0 systemd-timesyn [ 2074.017652] [ 242] 0 242 8713 162 128 34 0 86016 370 -1000 systemd-udevd [ 2074.018665] [ 264] 998 264 6903 174 64 110 0 90112 320 0 systemd-network [ 2074.019686] [ 369] 0 369 4570 39 32 7 0 77824 384 0 wpa_supplicant [ 2074.020739] [ 388] 0 388 6793 176 96 13 67 81920 192 -250 systemd-journal [ 2074.021841] [ 484] 100 484 1445 52 32 20 0 53248 32 0 avahi-daemon [ 2074.022857] [ 488] 0 488 2520 32 32 0 0 49152 32 0 cron [ 2074.023800] [ 491] 996 491 2064 110 64 46 0 53248 128 -900 dbus-daemon [ 2074.024797] [ 518] 0 518 55049 115 96 19 0 73728 96 0 rsyslogd [ 2074.025805] [ 519] 0 519 4642 65 32 33 0 77824 224 0 systemd-logind [ 2074.026837] [ 544] 100 544 1414 50 6 44 0 53248 32 0 avahi-daemon [ 2074.027842] [ 735] 0 735 4358 64 64 0 0 77824 224 0 wpa_supplicant [ 2074.028858] [ 787] 0 787 2701 62 0 62 0 49152 32 0 agetty [ 2074.031960] [ 788] 0 788 3775 58 0 58 0 65536 128 0 login [ 2074.033044] [ 797] 0 797 2863 115 64 51 0 57344 224 -1000 sshd [ 2074.034056] [ 1322] 1000 1322 5625 72 32 40 0 81920 512 100 systemd [ 2074.035032] [ 1324] 1000 1324 5942 63 2 61 0 77824 384 100 (sd-pam) [ 2074.035999] [ 1333] 1000 1333 3109 453 416 37 0 61440 288 0 bash [ 2074.036933] [ 1510] 0 1510 5345 90 32 58 0 90112 352 0 sshd-session [ 2074.038232] [ 1514] 0 1514 5346 466 416 50 0 77824 32 0 sshd-session [ 2074.039257] [ 1928] 1000 1928 5375 115 68 47 0 90112 416 0 sshd-session [ 2074.040253] [ 1929] 1000 1929 5410 449 359 90 0 81920 128 0 sshd-session [ 2074.041245] [ 1930] 1000 1930 605 75 0 75 0 45056 32 0 sftp-server [ 2074.042259] [ 1931] 1000 1931 3042 103 32 71 0 53248 544 0 bash [ 2074.043190] [ 2008] 1000 2008 8691 78 64 14 0 106496 384 0 passmark [ 2074.044364] [ 2024] 1000 2024 41346 18840 18840 0 0 360448 14272 0 passmark [ 2074.045725] [ 2025] 1000 2025 47783 14691 14657 34 0 413696 24832 0 passmark [ 2074.047090] [ 2026] 1000 2026 43327 20702 20664 38 0 376832 14400 0 passmark [ 2074.048376] [ 2036] 0 2036 2632 63 32 31 0 49152 37 0 cron [ 2074.049351] [ 2044] 0 2044 2632 2 0 2 0 49152 37 0 cron [ 2074.050395] [ 2053] 0 2053 2520 47 0 47 0 45056 37 0 cron [ 2074.051675] [ 2054] 0 2054 2520 1 0 1 0 45056 37 0 cron [ 2074.052650] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-8.scope,task=passmark,pid=2025,uid=1000 [ 2074.054345] Out of memory: Killed process 2025 (passmark) total-vm:191132kB, anon-rss:58628kB, file-rss:136kB, shmem-rss:0kB, UID:1000 pgtables:404kB oom_score_adj:0 [ 2074.573529] systemd-journald[388]: Under memory pressure, flushing caches. ==== passmark frozen also (run from ssh)========== PassMark PerformanceTest Linux (11.0.1004) Radxa ROCK Pi S Cortex-A35 (aarch64) 4 cores @ 1296 MHz | 466 MiB RAM Number of Processes: 4 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------------- CPU Mark: Incomplete Integer Math 0.0 Million Operations/s Floating Point Math 0.0 Million Operations/s Prime Numbers 0.0 Million Primes/s Sorting 0.0 Thousand Strings/s Encryption 0.0 MB/s Compression 0.0 KB/s CPU Single Threaded 0.0 Million Operations/s Physics 0.0 Frames/s Extended Instructions (NEON) 0.0 Million Matrices/s Memory Mark: Incomplete Database Operations Running (1/1) Memory Read Cached Queued Memory Read Uncached Queued Memory Write Queued Available RAM Queued Memory Latency Queued Memory Threaded Queued -------------------------------------------------------------------------------- Results not submitted Use ESC or CTRL-C to exit A: Run All Tests 😄 Run CPU Tests M: Run Memory Tests U: Upload Test Results
  25. I've been trying to update the system for 2 days but I can't: sudo apt update Get:1 http://deb.debian.org/debian trixie InRelease [140 kB] Get:2 http://security.debian.org trixie-security InRelease [43.4 kB] Get:4 http://security.debian.org trixie-security/main armhf Packages [88.5 kB] Get:5 https://github.armbian.com/configng stable InRelease [5,467 B] Get:6 https://github.armbian.com/configng stable/main armhf Packages [434 B] Get:3 http://armbian.lv.auroradev.org/beta trixie InRelease [39.4 kB] Get:7 http://armbian.lv.auroradev.org/beta trixie/trixie-desktop all Packages [731 B] Get:8 http://armbian.lv.auroradev.org/beta trixie/trixie-desktop armhf Packages [2,250 B] Get:9 http://armbian.lv.auroradev.org/beta trixie/trixie-utils armhf Packages [8,303 B] Ign:9 http://armbian.lv.auroradev.org/beta trixie/trixie-utils armhf Packages Err:9 http://beta.armbian.com trixie/trixie-utils armhf Packages File has unexpected size (10737 != 8303). Mirror sync in progress? [IP: 23.186.113.5 80] Get:10 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Get:11 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB] Err:9 http://beta.armbian.com trixie/trixie-utils armhf Packages File has unexpected size (10737 != 8303). Mirror sync in progress? [IP: 23.186.113.5 80] Get:12 http://armbian.lv.auroradev.org/beta trixie/trixie-utils all Packages [3,343 B] Ign:12 http://armbian.lv.auroradev.org/beta trixie/trixie-utils all Packages Get:13 http://deb.debian.org/debian trixie/main armhf Packages [12.7 MB] Err:9 http://beta.armbian.com trixie/trixie-utils armhf Packages File has unexpected size (10737 != 8303). Mirror sync in progress? [IP: 23.186.113.5 80] Ign:12 http://beta.armbian.com trixie/trixie-utils all Packages Get:14 http://deb.debian.org/debian trixie/non-free armhf Packages [69.9 kB] Get:15 http://deb.debian.org/debian trixie/contrib armhf Packages [50.6 kB] Get:16 http://deb.debian.org/debian trixie/non-free-firmware armhf Packages [6,685 B] Get:17 http://deb.debian.org/debian trixie-updates/main armhf Packages [5,144 B] Get:18 http://deb.debian.org/debian trixie-backports/non-free armhf Packages [1,520 B] Get:19 http://deb.debian.org/debian trixie-backports/contrib armhf Packages [4,348 B] Get:20 http://deb.debian.org/debian trixie-backports/non-free-firmware armhf Packages [3,856 B] Get:21 http://deb.debian.org/debian trixie-backports/main armhf Packages [130 kB] Fetched 13.4 MB in 18s (754 kB/s) Error: Failed to fetch http://beta.armbian.com/dists/trixie/trixie-utils/binary-armhf/Packages File has unexpected size (10737 != 8303). Mirror sync in progress? [IP: 23.186.113.5 80] Error: Failed to fetch http://beta.armbian.com/dists/trixie/trixie-utils/binary-all/Packages.bz2 File has unexpected size (3942 != 3343). Mirror sync in progress? [IP: 23.186.113.5 80] Error: Some index files failed to download. They have been ignored, or old ones used instead.
  26. Has anyone figured out an image for a v1.1 box yet?
  27. sven-ola
    PCIe MSI is not working. At least with an Intel iwlwifi M.2 card. For that reason, I investigated the differences between the Xunlong KY tree and the Armbian Spacemit Tree. B/c loading the "official" 552kb esos.elf seems to work (even if the Ky version is only 104kb) on the OrangePi RV2, I started to backport Xunlong changes to Armbian/Spacemit family. Newer kernel, but no luck with that MSI. There should be a DMA-transfer-complete interrupt at the end of the firmware upload. Card is working in my PC. MSI is working on OpiRV2 with NVME. Current status: board runs with spacemit-family kernel, but some minor Does-Not-Work yet: LED, onboard Wifi+BT and I need to check that special RTL eth... LG // Sven-Ola Edit: Pic it or it didn't happen. RV2 underside with WIfi card.
  28. Hi, Just wanted to provide more info on this. When I try to load the beagle Y AI official debian image it works fine, just wondering whether the dtb is inline with the Beagle Y AI official dtb or any changes where made related to the usb host. Any help would be appreciated. Thanks!
