  2. thread about video in case anyone is looking for it and a recent 'success story'
  3. I juste installed it, and it's pretty working 🥰 # wget https://armbian.lv.auroradev.org/beta/pool/main/l/linux-6.12.35/linux-image-current-sunxi_25.8.0-trunk.346_armhf__6.12.35-S783c-Dbdda-Pf7b7-C34a1Hf8af-HK01ba-V014b-Ba566-R448a.deb # apt install ./linux-image-current-sunxi_25.8.0-trunk.346_armhf__6.12.35-S783c-Dbdda-Pf7b7-C34a1Hf8af-HK01ba-V014b-Ba566-R448a.deb My dashboard is back ! Trying to update my arch with the latest kernel ... ps: in addition, if someone knows how to disable cursor blinking on this HDMI, it would be fine (I already disabled getty on it, but the cursor remain).
  4. Can someone tell me if Linux 6.14.8 or 6.15.4 supports this hardware acceleration? I can play 1080p H264, but with 100% CPU, with 6.14.8... and I get "unsuppoerted hwdec: drm" everytime I start mpv
  5. It is now half a year later, this SD-card was put back into the RPi4 and no issues there. The RPi4 has been upgraded from Bookworm to Trixie in-place (just latest pre-release) so gets quite some writes. It still has Bookworm Btrfs snapshot as well, total of about 9GB excluding 2GB swap partition and 512MB bootFAT. Avarage Btrfs scrub speed 41MB/s. The ROCK3A has no SD-card inserted anymore, running fine, except that in the last 40 days I see: root@rock3a:~# uname -a Linux rock3a 6.1.115-vendor-rk35xx #1 SMP Fri May 30 01:18:17 UTC 2025 aarch64 GNU/Linux root@rock3a:~# dmesg | grep "page allocation failure:" [ 527.016616] dmcrypt_write/2: page allocation failure: order:0, mode:0x800(GFP_NOWAIT), nodemask=(null),cpuset=/,mems_allowed=0 [2879228.441453] dec0:0:hevc_rkm: page allocation failure: order:5, mode:0x40dc0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO), nodemask=(null),cpuset=user.slice,mems_allowed=0 [2879523.127829] dec0:0:hevc_rkm: page allocation failure: order:5, mode:0x40dc0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO), nodemask=(null),cpuset=user.slice,mems_allowed=0 [3029341.482298] kworker/0:1: page allocation failure: order:0, mode:0x800(GFP_NOWAIT), nodemask=(null),cpuset=/,mems_allowed=0 The middle 2 is clear what source is, the others I do not know. I think I will first upgrade userspace to Trixie. I currently have no clue what the details w.r.t. page faults mean, so have to see and figure out what issue could be or maybe mitigate somehow.
  6. Does this happen with Bookworm or Noble? Plucky userspace is unsupported.
  7. Yes it is dead, that is why my comments between brackets. Start with http://beta.armbian.com then click with your mouse per sub object. Or wait until it is out of beta phase or modify your sources.list.d
  8. Currently using Armbian as a PiHole DNS server, it seems that after a few days the server just shuts itself down (Armbian 25.5.1 Noble 6.12). Not sure if it is a hardware related issue, I'll do some more tests and revert back to 25.2.2 Bookworm for now and see if the issue is replicated. Please note that my primary Armbian PiHole DNS does not encounter the same issue, though the version of it is Noble v25.2.3 / 6.12.30.
  9. @JuanEsf Yep, here it is a080ed7128c898bec1cad6ec68c57bae159169d2fa06fb18008100ad63e4445c
  10. You are right, this is a strange DTS issue. U-Boot is working, but the kernel can't initialize the SD card, which is why it drops to the initramfs shell. Unfortunately, I can't reproduce this specific error myself, but I agree with your analysis. I suspect this is the same reason why newer U-Boot versions initially failed to boot for me. I will start working on fixing the DTS next week. Thanks for finding this bug!
  11. @C127I just saw that @whywontitworkmessage and decided to try your image(0.3) directly in the sdcard ( emmc removed ) and that image does not boot. The UART is also stuck in starting kernel as mentioned by @whywontitwork, but I can get the HDMI output and the boot process drops to a initramfs shell because it can not find the root device. This is the console log. DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:h1,l0 CH0 RX Vref:24.6%, TX Vref:22.0%,22.0% DQ rds:h5 h2 h1 h2 h1 h4 l0 h7, h1 h1 h3 h3 h1 h1 h7 l0 DQS rds:l0,h2 CH1 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h4 l0 h2 h3 h6 l0 h7 l0, h7 h4 h4 h4 l1 h1 h6 h7 DQS rds:l0,h2 CH2 RX Vref:25.0%, TX Vref:21.0%,21.0% DQ rds:h1 l0 h2 l2 h1 h1 h5 h1, l1 h6 l1 h3 l2 h1 h1 h2 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:20.0%,20.0% DQ rds:h3 h1 h2 h1 h4 h1 h1 h1, h4 h7 h2 h2 h3 h5 l0 h5 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL 2024.04-armbian-2024.04-S2504-Pa35d-H29de-Vbf83-Bb703-R448a (Jul 02 2025 - 19:31:47 +0000) Trying to boot from MMC1 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK ## Checking hash(es) for Image atf-3 ... sha256+ OK INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: bypass memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 ns16550_serial serial@feb50000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.04-armbian-2024.04-S2504-Pa35d-H29de-Vbf83-Bb703-R448a (Jul 02 2025 - 19:31:47 +0000) Model: Xunlong Orange Pi 5 Pro DRAM: 16 GiB (effective 15.7 GiB) Core: 323 devices, 30 uclasses, devicetree: separate MMC: mmc@fe2c0000: 0 Loading Environment from nowhere... OK In: serial@feb50000 Out: serial@feb50000 Err: serial@feb50000 Model: Xunlong Orange Pi 5 Pro rockchip_dnl_key_pressed: no saradc device found Net: eth0: ethernet@fe1c0000 Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': No EFI system partition No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'mmc 0' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@fe2c0000.bootdev': 1 script ready mmc 1 mmc@fe2c0000.bootdev.part /boot/boot.scr ** Booting bootflow 'mmc@fe2c0000.bootdev.part_1' with script Boot script loaded from mmc 0:1 200 bytes read in 4 ms (48.8 KiB/s) 15754859 bytes read in 1321 ms (11.4 MiB/s) 39287296 bytes read in 3289 ms (11.4 MiB/s) 162018 bytes read in 28 ms (5.5 MiB/s) Working FDT set to 12000000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' ## Loading init Ramdisk from Legacy Image at 12180000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15754795 Bytes = 15 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Ramdisk to ebf92000, end ece9862b ... OK Loading Device Tree to 00000000ebf02000, end 00000000ebf91fff ... OK Working FDT set to ebf02000 Starting kernel ... Setting loglevel=8 and verbose=8 shows this is console: [ 2.028301] dwmmc_rockchip fe2d0000.mmc: IDMAC supports 32-bit address mode. [ 2.029020] dwmmc_rockchip fe2d0000.mmc: Using internal DMA controller. [ 2.029624] dwmmc_rockchip fe2d0000.mmc: Version ID is 270a [ 2.030163] dwmmc_rockchip fe2d0000.mmc: DW MMC controller at irq 84,32 bit host data width,256 deep fifo [ 2.031384] dwmmc_rockchip fe2d0000.mmc: allocated mmc-pwrseq [ 2.031921] mmc_host mmc2: card is non-removable. [ 2.217056] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 2.250531] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.376463] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ 2.409028] dwmmc_rockchip fe2d0000.mmc: Successfully tuned phase to 223 [ 2.423188] mmc2: new UHS-I speed SDR104 SDIO card at address 0001 [ 2.953845] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 2.991412] mmc0: error -110 whilst initialising SD card [ 3.527479] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 4.257059] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 4.271710] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0) [ 4.831481] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 5.560980] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 5.575632] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) [ 6.140278] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 6.869893] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
  12. Yes, it works correctly debian@orangepi5pro:~$ lsusb -t ... /: Bus 008.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 5000M |__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
  13. @C127I forgot to ask. Is USB3 port working for you in your kernel ?
  14. @Igor@amazingfate Can someone look at this issue please ? I am wondering if this is possibly affecting a large number targets or whether its just BananaPi-M7 / rockchip64 ? I have tried on another monitor also and am getting a black screen. On doing an `apt-get upgrade` on ssh terminal I happened to loose by HDMI display. AFAICT It looks like Ubuntu 'backgraded' gnome v46 (in Nobel release, and also in my older unofficial image) to v44. https://armbian.atlassian.net/jira/software/c/projects/AR/issues/AR-2702?jql=project %3D "AR" ORDER BY created DESC
  15. Sure. I am here to test it when you send. Next week I will be off for about 7 days, but we can test until that after that.
  16. You are right, I was too focused on the eMMC. The fact that sdio is used for WiFi/BT on this board suggests a more complex problem with the main SDHCI controller in U-Boot. This means my U-Boot patch is still in a very early stage, and I need to do a deeper analysis of how all these interfaces are powered and configured. I will continue working on it and will let you know when I have a new patch to test.
  17. Actually the 0.4 was trying to boot from MMC1 and the 0.5 from MMC2. is this expected ?
  18. @C127 Tested, same problem DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:h1,l0 CH0 RX Vref:24.6%, TX Vref:23.0%,22.0% DQ rds:h5 h2 h1 h2 h1 h5 l0 h7, h1 h1 h3 h3 h1 h1 h7 l0 DQS rds:l0,h2 CH1 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h5 l0 h2 h2 h6 l0 h7 l0, h7 h5 h4 h4 l1 h1 h6 h7 DQS rds:l0,h2 CH2 RX Vref:25.4%, TX Vref:22.0%,21.0% DQ rds:h1 l0 h2 l2 h1 h1 h5 h1, l1 h7 l2 h4 l2 h1 h1 h3 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h3 h1 h1 h1 h4 h1 h1 h1, h5 h6 h2 h2 h3 h5 l0 h5 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL 2024.04-armbian-2024.04-S2504-Pdd14-H29de-Vbf83-Bb703-R448a (Jul 11 2025 - 23:38:46 +0000) Trying to boot from MMC2 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
  19. Hello @salas, Thank you for the incredibly detailed testing and analysis! You are absolutely right, the problem is entirely aligned with U-Boot. Your observation that the kernel can see the eMMC after booting from the SD card is the key. It proves the hardware is fine and the kernel's eMMC driver is working correctly. The issue is that the U-Boot SPL (Secondary Program Loader) is not initializing the eMMC interface properly at boot time. Based on this, I've created a new patch (v0.5) that specifically targets this U-Boot initialization problem. I have adjusted the U-Boot device tree in an attempt to correctly enable the eMMC interface during the SPL phase. I have just updated the pre-compiled image in the "Releases" section of my build repository to v0.5. Thanks again for your amazing help!
  20. Yesterday
  21. Post not related to 0.4! Since yesterday I've been doing a few tests on your kernel patch against mainline kernel 6.16-rc5. here what I found out. I am testing against Johsua's ubuntu because this is my goal ( newer kernel on that image ) 1) Kernel compile and works , but I get a few warnings on the dtbs compilation DTC arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dts:235.3-13: Warning (reg_format): /mmc@fe2d0000/wifi@1:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (pci_device_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dts:233.17-241.4: Warning (avoid_default_addr_size): /mmc@fe2d0000/wifi@1: Relying on default #address-cells value arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dts:233.17-241.4: Warning (avoid_default_addr_size): /mmc@fe2d0000/wifi@1: Relying on default #size-cells value 2) Your patch works and makes the system bootable from the SDCARD. U-boot reads the /boot from the sdcard, since it can not find the EMMC, but after booting I can have to / on the EMMC and that works. 3) Curiously after the uboot handoff to the linux kernel, emmc is available but the sdcard fails to initialize emmc initialize just fine with the / [ 10.225763] mmc2: new HS400 Enhanced strobe MMC card at address 0001 [ 10.228424] mmcblk2: mmc2:0001 A3A564 233 GiB [ 10.233239] mmcblk2: p1 p2 [ 10.234373] mmcblk2boot0: mmc2:0001 A3A564 4.00 MiB [ 10.237884] mmcblk2boot1: mmc2:0001 A3A564 4.00 MiB So I basically have a working system but it requires the sdcard to boot and I can not mount the sdcard after boot root@pi5pro1:~# uname -r 6.16.0-rc5 root@pi5pro1:~# cat /etc/os-release PRETTY_NAME="Ubuntu 24.04.1 LTS" NAME="Ubuntu" VERSION_ID="24.04" VERSION="24.04.1 LTS (Noble Numbat)" VERSION_CODENAME=noble ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=noble LOGO=ubuntu-logo
  22. Hi, I'm facing the same issue with my BananaPI-M1 running ARMbian and I have another one bPI-M1 running ArchARM which is suffering exactly for the same issue (bPI is not supposed to be supported but it working pretty well but this HDMI issue and the miss of AXP209 exposition). I'm a bit lost about the current status : is the upstream 6.15 (or upcoming 6.16) already patched/corrected ? @eselarm The link seems dead 🙂
  23. @C127 0.4 output. Still no boot DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:h1,l0 CH0 RX Vref:24.6%, TX Vref:21.0%,21.0% DQ rds:h4 h2 h1 h2 h1 h5 l0 h7, h1 h1 h3 h3 h1 h1 h7 l0 DQS rds:l0,h2 CH1 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h4 l0 h2 h3 h7 l0 h7 l0, h6 h5 h4 h5 l1 h1 h6 h6 DQS rds:l0,h2 CH2 RX Vref:25.0%, TX Vref:21.0%,21.0% DQ rds:h1 l0 h2 l3 h1 h2 h5 h1, l1 h7 l1 h4 l2 h1 h1 h3 DQS rds:l0,h1 CH3 RX Vref:27.5%, TX Vref:21.0%,21.0% DQ rds:h3 h1 h2 h1 h4 h1 h1 h1, h5 h6 h2 h2 h4 h4 l0 h5 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL 2024.04-armbian-2024.04-S2504-P83ae-H29de-Vbf83-Bb703-R448a (Jul 03 2025 - 17:49:57 +0000) Trying to boot from MMC1 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
  24. I will flash the new image now and let you know what happens,
  25. I will gladly help you to test it. Just to let you know, on 0.3 apparently If i boot from the sdcard, after booting the emmc is available. So the kernel knows about it. just uboot does not ?
  26. Thanks, I'll pursue with the thread you mentioned.
  27. Managed to get RaspAP working on my OrangePi Zero 3 (OPZ3). At the time of writing, the RaspAP quick installer script did not support Ubuntu 24.04 on my OPZ3. So, I decided to try and install RaspAP manually, based on the manual installation step on the site. It mostly went smoothly, with some hiccups along the way. Some tweaks needed were around disabling wpa_supplicant and a missing library for isoquery. Some configuration details: OrangePi Zero 3 with 1GB ram Ubuntu 24.04 (6.12.23) server image downloaded from the Armbian site After all the apt upgrades and updates, the kernal was updated to 6.12.35 Attached below is the final consolidated script that was used. #!/bin/bash echo echo "######################################" read -p "Start installation - initial software - press Enter to start" sudo rfkill unblock wlan sudo apt-get install -y software-properties-common sudo add-apt-repository ppa:ondrej/php sudo apt-get install -y dhcpcd5 sudo apt-get install -y libjson-glib-dev echo echo "######################################" read -p "Installing isoquery - check result of the -v - press Enter to start" wget https://ftp.debian.org/debian/pool/main/i/isoquery/isoquery_3.3.4-1+b1_arm64.deb -P /tmp sudo dpkg -x /tmp/isoquery_3.3.4-1+b1_arm64.deb /tmp/isoquery/ sudo cp /tmp/isoquery/usr/bin/isoquery /usr/local/bin/ sudo chmod +x /usr/local/bin/isoquery isoquery -v echo echo "######################################" read -p "Stop resolved and add parms - press Enter to start" sudo systemctl stop systemd-resolved.service echo "DNS=9.9.9.9" | sudo tee -a /etc/systemd/resolved.conf echo "DNSStubListener=no" | sudo tee -a /etc/systemd/resolved.conf sudo ln -sf /run/systemd/resolve/resolv.conf /etc/resolv.conf echo echo "######################################" read -p "Install most of the software - press Enter to start" sudo apt-get install -y lighttpd git hostapd dnsmasq iptables-persistent vnstat qrencode php8.2-cgi jq isoquery echo echo "######################################" read -p "Enable php and start lighttpd - press Enter to start" sudo lighttpd-enable-mod fastcgi-php sudo service lighttpd force-reload sudo systemctl restart lighttpd.service echo echo "######################################" read -p "Pull the web application - press Enter to start" sudo rm -rf /var/www/html sudo git clone --recurse-submodules https://github.com/RaspAP/raspap-webgui /var/www/html sudo git -C /var/www/html submodule update --remote plugins WEBROOT="/var/www/html" CONFSRC="$WEBROOT/config/50-raspap-router.conf" LTROOT=$(grep "server.document-root" /etc/lighttpd/lighttpd.conf | awk -F '=' '{print $2}' | tr -d " \"") HTROOT=${WEBROOT/$LTROOT} HTROOT=$(echo "$HTROOT" | sed -e 's/\/$//') awk "{gsub(\"/REPLACE_ME\",\"$HTROOT\")}1" $CONFSRC > /tmp/50-raspap-router.conf sudo cp /tmp/50-raspap-router.conf /etc/lighttpd/conf-available/ sudo ln -s /etc/lighttpd/conf-available/50-raspap-router.conf /etc/lighttpd/conf-enabled/50-raspap-router.conf sudo systemctl restart lighttpd.service echo echo "######################################" read -p "Configure and setup software - press Enter to start" cd /var/www/html sudo cp installers/raspap.sudoers /etc/sudoers.d/090_raspap sudo mkdir /etc/raspap/ sudo mkdir /etc/raspap/backups sudo mkdir /etc/raspap/networking sudo mkdir /etc/raspap/hostapd sudo mkdir /etc/raspap/lighttpd sudo mkdir /etc/raspap/system sudo mkdir /etc/raspap/plugins sudo chown -R www-data:www-data /var/www/html sudo chown -R www-data:www-data /etc/raspap sudo mv installers/enablelog.sh /etc/raspap/hostapd sudo mv installers/disablelog.sh /etc/raspap/hostapd sudo mv installers/servicestart.sh /etc/raspap/hostapd sudo mv installers/debuglog.sh /etc/raspap/system sudo mv installers/plugin_helper.sh /etc/raspap/plugins sudo chown -c root:root /etc/raspap/hostapd/*.sh sudo chown -c root:root /etc/raspap/system/*.sh sudo chown -c root:root /etc/raspap/plugins/*.sh sudo chmod 750 /etc/raspap/hostapd/*.sh sudo chmod 750 /etc/raspap/system/*.sh sudo chmod 750 /etc/raspap/plugins/*.sh sudo cp installers/configport.sh /etc/raspap/lighttpd sudo chown -c root:root /etc/raspap/lighttpd/*.sh sudo mv installers/raspapd.service /lib/systemd/system sudo systemctl daemon-reload sudo systemctl enable raspapd.service echo echo "######################################" read -p "Install default configuration - press Enter to start" sudo mv /etc/default/hostapd ~/default_hostapd.old sudo cp /etc/hostapd/hostapd.conf ~/hostapd.conf.old sudo cp config/hostapd.conf /etc/hostapd/hostapd.conf sudo cp config/090_raspap.conf /etc/dnsmasq.d/090_raspap.conf sudo cp config/090_wlan0.conf /etc/dnsmasq.d/090_wlan0.conf sudo cp config/dhcpcd.conf /etc/dhcpcd.conf sudo cp config/config.php /var/www/html/includes/ sudo cp config/defaults.json /etc/raspap/networking/ echo echo "######################################" read -p "Disable systemd-networkd - press Enter to start" sudo systemctl stop systemd-networkd sudo systemctl disable systemd-networkd sudo cp config/raspap-bridge-br0.netdev /etc/systemd/network/raspap-bridge-br0.netdev sudo cp config/raspap-br0-member-eth0.network /etc/systemd/network/raspap-br0-member-eth0.network echo echo "######################################" read -p "ip4 forwarding and MASQ - press Enter to start" echo "net.ipv4.ip_forward=1" | sudo tee /etc/sysctl.d/90_raspap.conf > /dev/null sudo sysctl -p /etc/sysctl.d/90_raspap.conf sudo /etc/init.d/procps restart sudo iptables -t nat -A POSTROUTING -j MASQUERADE sudo iptables -t nat -A POSTROUTING -s 192.168.50.0/24 ! -d 192.168.50.0/24 -j MASQUERADE sudo iptables-save | sudo tee /etc/iptables/rules.v4 echo echo "######################################" read -p "Start hostapd - press Enter to start" sudo systemctl unmask hostapd.service sudo systemctl enable hostapd.service echo echo "######################################" read -p "Install OpenVPN - press Enter to start" sudo apt-get install -y openvpn sudo sed -i "s/\('RASPI_OPENVPN_ENABLED', \)false/\1true/g" /var/www/html/includes/config.php sudo systemctl enable openvpn-client@client echo echo "######################################" read -p "Install Wireguard - press Enter to start" sudo apt-get install -y wireguard sudo sed -i "s/\('RASPI_WIREGUARD_ENABLED', \)false/\1true/g" /var/www/html/includes/config.php sudo systemctl enable wg-quick@wg echo echo "######################################" read -p "Install adblock - press Enter to start" sudo mkdir /etc/raspap/adblock wget https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts -O /tmp/hostnames.txt wget https://big.oisd.nl/dnsmasq -O /tmp/domains.txt sudo cp /tmp/hostnames.txt /etc/raspap/adblock sudo cp /tmp/domains.txt /etc/raspap/adblock sudo cp installers/update_blocklist.sh /etc/raspap/adblock/ sudo chown -c root:www-data /etc/raspap/adblock/*.* sudo chmod 750 /etc/raspap/adblock/*.sh sudo touch /etc/dnsmasq.d/090_adblock.conf echo "conf-file=/etc/raspap/adblock/domains.txt" | sudo tee -a /etc/dnsmasq.d/090_adblock.conf > /dev/null echo "addn-hosts=/etc/raspap/adblock/hostnames.txt" | sudo tee -a /etc/dnsmasq.d/090_adblock.conf > /dev/null sudo sed -i '/dhcp-option=6/d' /etc/dnsmasq.d/090_raspap.conf sudo sed -i "s/\('RASPI_ADBLOCK_ENABLED', \)false/\1true/g" includes/config.php echo echo "######################################" read -p "Stop and disable wpa_supplicant - press Enter to start" sudo systemctl stop wpa_supplicant.service sudo systemctl disable wpa_supplicant.service sudo systemctl mask wpa_supplicant.service echo echo "######################################" read -p "Stop NetworkManager managing wlan0 - press Enter to start" echo "[keyfile]" | sudo tee -a /etc/NetworkManager/conf.d/99-unmanaged-devices.conf echo "unmanaged-devices=interface-name:wlan0" | sudo tee -a /etc/NetworkManager/conf.d/99-unmanaged-devices.conf echo echo "######################################" read -p "Rebooting - Good Luck!!! - press Enter to start" sudo systemctl reboot Post Installation - Notes Do change the default SSID password (RaspAP/ChangeMe) Do change the default admin password of the Web GUI (admin/secret) Do install the kludge for the 2GB error in 1GB models Do configure the DNS servers in the Web GUI or clients may not get DNS server entries Other Stuff If you really want the Dashboard pictures to show the 2.4/5GHz, highlight the ethernet port and show number of wifi client connections, you’ll have to change the /var/www/html/src/RaspAP/UI/Dashboard.php file Edit the getConnectionType function include end0[0-9] in the matching Rewrite the getWirelessClients function to use ip n to determine number of wireless clients iw does not return the correct information for number of wireless clients on the OPZ3 Rewrite the getFrequencyBand function to look at hostapd.conf to determine the whether 2.4 or 5Ghz iw does not return the frequency used by the wifi on the OPZ3 public function getConnectionType(): string { // get the interface associated with the default route $interface = trim(shell_exec("ip route show default | head -1 | awk '{print $5}'")); if (empty($interface)) { return 'unknown'; } // classify interface type if (preg_match('/^eth0|enp\d+s\d+|ens\d+s\d+|end[0-9]|enx[0-9a-f]*/', $interface)) { return 'ethernet'; } if (preg_match('/^wlan\d+|wlp\d+s\d+|wlx[0-9a-f]*/', $interface)) { return 'wireless'; } if (preg_match('/^usb\d+|^eth[1-9]\d*/', $interface)) { return 'tethering'; } if (preg_match('/^ppp\d+|wwan\d+|wwp\d+s\d+/', $interface)) { return 'cellular'; } // if none match, return the interface name as a fallback return "other ($interface)"; } public function getWirelessClients($interface): int { $cmd = 'ip n | grep '. escapeshellarg($interface) .' | egrep \'DELAY|REACHABLE|PROBE\''; exec($cmd, $output, $status); if ($status !== 0) { return 0; } // enumerate 'station' entries (each represents a wireless client) $clientCount = 0; foreach ($output as $line) { $clientCount++; } return $clientCount; } public function getFrequencyBand(string $interface): ?string { $output = shell_exec("cat /etc/hostapd/hostapd.conf | grep channel= | awk 'BEGIN{FS=\"=\"}{ print $2 }'"); if (!$output) { return null; } $frequency = (int)$output; if ($frequency < 15 ) { return "2.4"; } return "5"; } References Manual installation steps on the RaspAP docs site Notes on disabling WPA and excluding WLAN0 Additional library to install for RaspAP Completely disable a service This post on my blog
