moved
I need to make custom intro on my bigtreetech cb1 when i try plymouth some time give me error and sometimes the system startup normally as normal Plymouth without pics only 3dots in middle of screen i want examples or guidelines to make it and when i make update to initremfs files it’s give me error such as error to create hard link what I should i do
You need this feature, we don't. This board is community supported, you are community. Thanks for understanding.
Hi there, It's quite beginner question, so I started it here. Just got my OPi zero 3, for now I can connect it to my ethernet network (with DHCP), but have no monitor / mouse / keyboard for going through initial setup (root password, "normal" user name, full name and password. How can I prepare official SD image for such case? Laurent
Please rollback and re-enable all PPS_ clients by yourself , thank you.
Well other option is the upstream broke somehow. KDE neon is based on their testing branch so if there is a faulty package uploaded desktop breaks. Though we won't dive into this since KDE is no officially supported desktop environment by us. We mostly do GNOME and XFCE only. We don't have resources to deal with more while we wish we would/could.
Well yes and no. This depends in board family and how well support is matured. In case of rk3588 support is very basic. This is also an LTS kernel which means no new features will be available and only security fixes will be applied. Enhanced hdmi support is available in edge kernel and also in rockchip bsp which we call vendor. If the system is accessible via terminal or ssh, use armbian-config to switch kernels. Otherwise - if available - download an image matching DE and kernel or use the build framework to build your own.
NanoPi R6S wrong network interface naming
Radu Stefan Ciubotaru replied to Afritic Group's topic in NanoPi R6S/R6C
Hello, I have a NanoPi R6S and have just attempted the presented adjustment on my Armbian Install but it looks like udev fails to rename the interfaces at boot due to the fact that the kernel is doing that before ? I don't really have a lot of experience here but becaus of this the NetworkManager vlan mapping and IP addresses get mangled up thus resulting in my device not working as intended. Could there be something that I am doing wrong ? -
Hi there I'm using Ubuntu 24.04 (Noble) KDE Neon image from may 26, 2025. After download this image and installing it, Wayland was working fine, not problems at all. Then, after a system upgrade, if i choose Wayland from session manager, the system freezes and i can't boot with Wayland, only X11... Before the update, the system was smooth, now it's really laggy....Like i said, i'm using Desktop image with Armbian Linux v6.12 KDE Neon (Ubuntu 24.04) There's something wrong with the update Anyone knows why is this happening, and any turnaround to use Wayland again?
Thank you very much @c0rnelius, using your image and (for France) I'm almost good. The only errors in the dmesg are the HDMI audio errors but it works... However loading GPU overlay or not, I have a problem decoding videos. To reproduce: - download this mp4 video test file (https://www.sample-videos.com/video321/mp4/720/big_buck_bunny_720p_30mb.mp4) ) open in chromium, make it full-screen. Denis
I didn't have that much time to look at my Orange Pi board. On work, i have to deal with similar issues, but regarding another Soc (imx8mp with vivante GPU). But on work i have support from other people / offices. Meanwhile the grafik looks like to work, but also with lot of kernel patches and fixing involved (we have a yocto based build, and even Qt is somehow patched to work with our yocto base, wtf) on my orange pi board testet out some kernels. tried the official debian / ubuntu kernels (from orangepi.org) the version 5.10 kernels versions are booting (from sd) but no Grafik support ... the version 6.1.43 kernels are not even booting .... wtf 😞 i tried a SPI flushing, no change the armbian Kernels are booting !!! yay ! but : Armbian 25.5.1 with 6.1.115 (vendor kernel) looks like it has gpu support ! yay ! at least glxinfo shows the gpu string 🙂 but no emmc support 😞 even with booting from sd the kernel does not find /dev/mmcblk0 (mmcblk1 is detected as the sd card) 😞 Desktop images with Armbian Linux v6.12: it detects the emmc, so booth /dev/mmcblk0 and /dev/mmcblk1 are present, yay ! 🙂 but no grafik card support 😞 what do Im missing ? on the newer kernel Im need the device tree overlay for panthor (gpu_panthor) right? But didnt manage to get the gpu up ... mesa always fail to create the context and than switching back to the software renderer (regarding glxinfo logs) So im stuck atm .... and yes, its frustrating!
@mantouboji recently there was a substantial change to the build flags for the entire sunxi64 platform in this PR: https://github.com/armbian/build/pull/8368 Looking at the diff (https://github.com/armbian/build/pull/8368/files#diff-003c7426ff865cb4e5d2d17e324129fe9de266da1f83a11e290670929e55036dL1105-L1106), it seems PPS client (whatever that is, sorry, not familiar with it) flags have been removed. Maybe this can help you raise an appropriate "bring this back" issue.
Hi all, Sorry for such a kiddy question but I couldn’t find the answer. I have a bit another device than expected. I have Banana Pi 3 device with Armbian-bpi-SpacemiT 24.5.0-trunk Noble and i'm trying to install a new kernel to it. I've installed linux-allwinner kernel 6.8.0-60.63.1 and all the stuff with it. linux-allwinner/noble-security,noble-updates,now 6.8.0-60.63.1 riscv64 [installed] linux-headers-allwinner/noble-security,noble-updates,now 6.8.0-60.63.1 riscv64 [installed,automatic] linux-image-allwinner/noble-security,noble-updates,now 6.8.0-60.63.1 riscv64 [installed,automatic] linux-tools-allwinner/noble-security,noble-updates,now 6.8.0-60.63.1 riscv64 [installed] And current boot kernel looks like ``` # mkimage -l /boot/Image FIT description: Linux 6.1.15-legacy-k1 Created: Wed May 1 17:17:59 2024 Image 0 (kernel) Description: Linux 6.1.15-legacy-k1 Created: Wed May 1 17:17:59 2024 Type: Kernel Image Compression: uncompressed Data Size: 32397312 Bytes = 31638.00 KiB = 30.90 MiB Architecture: RISC-V OS: Linux Load Address: 0x01400000 Entry Point: 0x01400000 Hash algo: crc32 Hash value: f571b82e Default Configuration: 'conf-default' Configuration 0 (conf-default) Description: Generic Linux kernel Kernel: kernel ``` The question is - How to make from vmlinuz-6.8.0-60-generic a kernel with the same format like above ? When I try to make it like this `mkimage -A riscv -O linux -T kernel -C none -a 0x01400000 -e 0x01400000 -d /boot/vmlinuz-6.8.0-60-generic /tmp/Image` I have another kernel format. ``` Created: Fri Jul 18 15:49:58 2025 Image Type: RISC-V Linux Kernel Image (uncompressed) Data Size: 38608384 Bytes = 37703.50 KiB = 36.82 MiB Load Address: 01400000 Entry Point: 01400000 ```
- 189 replies
- MangoPi MQ Pro
- Sipeed Nezha
(and 1 more)
Tagged with:
I don't think that there was an intentional removal. Feel free to re-enable, test and send a PR.
Who in charge of the SUNXI64 edge kernel config ? Why removed all PPS device support in 6.15.4 kernel?
I see. The logs show that you have setup armbianEnv.txt to boot from a filesystem that the later logs show is an EXT4 filesystem, located on the first partition of first namespace of the first found NVMe device. The logs do not show any blockdevice for mmc1 (which appears to be the driver linked to the SD card). No logging usually means that there is no device detected. Do note that things will indeed not be simple if you change your setup after gathering diagnostics logs. People are willing to help, but correct diagnostics information is needed for people to actually help you. Grt,
@djurny No, its not a simple as that, its acutally not on the install on NVMe anymore.
I got a radxa rock 5t and trying to install armbian(https://www.armbian.com/radxa-rock-5t), arimbian NOT boot and I can see the indicator light on the board is showing a steady green light. I boot with the official image https://docs.radxa.com/en/rock5/rock5t/low-level-dev/maskrom/linux and insert the sd card(with armbian img), and run such command, then I can boot armbian from SD card sudo dd if=/dev/mmcblk0 of=working_idbloader.img bs=512 skip=64 count=8000 sudo dd if=/dev/mmcblk0 of=working_u-boot.itb bs=512 skip=16384 count=8000 sudo dd if=working_idbloader.img of=/dev/mmcblk1 bs=512 seek=64 conv=notrunc sudo dd if=working_u-boot.itb of=/dev/mmcblk1 bs=512 seek=16384 conv=notrunc BTW, it seems there's no rock-5t tag, so I selected the 5b one
moved to off-topic since not about Armbian but 3rd party img.
