Orange Pi Zero 3 to Banana Pi M4 Zero Hardware Update
c0rnelius replied to SUPA's topic in Banana Pi M4 Zero
U-Boot SPL 2025.07-armbian-2025.07-Se37d-P526e-H8869-V8e92-Bb703-R448a (Aug 19 2025 - 04:10:01 +0000) DRAM: 4096 MiB Trying to boot from MMC2 NOTICE: BL31: v2.12.5(debug):armbian NOTICE: BL31: Built : 04:09:39, Aug 19 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b5100, model: BananaPi BPI-M4-Zero INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: Probing for PMIC on I2C: INFO: PMIC: found AXP313 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.07-armbian-2025.07-Se37d-P526e-H8869-V8e92-Bb703-R448a (Aug 19 2025 - 04:10:01 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: BananaPi BPI-M4-Zero DRAM: 4 GiB Core: 65 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Allwinner mUSB OTG (Peripheral) Net: using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready eth0: usb_ether starting USB... USB EHCI 1.00 USB OHCI 1.0 Bus usb@5311000: 1 USB Device(s) found Bus usb@5311400: 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 1 ms (4.4 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 280 bytes read in 0 ms Load fdt: /boot/dtb/allwinner/sun50i-h618-bananapi-m4-zero.dtb MMC: no card present ** Bad device specification mmc 0 ** 43728 bytes read in 4 ms (10.4 MiB/s) Working FDT set to 4fa00000 1358 bytes read in 3 ms (441.4 KiB/s) Applying kernel provided DT overlay sun50i-h616-bananapi-m4-sdio-wifi-bt.dtbo 4203 bytes read in 2 ms (2 MiB/s) Applying kernel provided DT fixup script (sun50i-h616-fixup.scr) ## Executing script at 45000000 17177939 bytes read in 543 ms (30.2 MiB/s) 38219784 bytes read in 1207 ms (30.2 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42760000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 17177875 Bytes = 16.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 48f9e000, end 49fffd13 ... OK Loading Device Tree to 0000000048f2a000, end 0000000048f9dfff ... OK Working FDT set to 48f2a000 Starting kernel ... Armbian 25.8.1 Trixie ttyS0 bananapim4zero login: root Password: _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.8.1 for BananaPi BPI-M4-Zero running Armbian Linux 6.12.35-current-sunxi64 Packages: Debian stable (trixie) Updates: Kernel upgrade enabled and 6 packages available for upgrade IPv4: (LAN) xx.xx.xx.xx (WAN) xx.xx.xx.xx Performance: Load: 16% Uptime: 0 min Memory usage: 4% of 3.83G CPU temp: 46°C Usage of /: 5% of 29G Commands: Configuration : armbian-config Upgrade : armbian-upgrade Monitoring : htop root@bananapim4zero:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk2 179:0 0 29.1G 0 disk └─mmcblk2p1 179:1 0 28.8G 0 part /var/log.hdd / mmcblk2boot0 179:32 0 4M 1 disk mmcblk2boot1 179:64 0 4M 1 disk zram0 252:0 0 1.9G 0 disk [SWAP] zram1 252:1 0 50M 0 disk zram2 252:2 0 0B 0 disk root@bananapim4zero:~# https://www.armbian.com/bananapi-m4-zero/ Seems fine to me? -
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 ed9827920 (https://ryanfortner.github.io/box64-debs/) + ge-proton10-29 (https://github.com/GloriousEggroll/proton-ge-custom/releases/tag/GE-Proton10-29) (GE-proton is more likely to be segment fault-proof than other wine-proton versions) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v2.7.1 ~30fps@720p (high settings - the lowest settings in game) box64 environment variables: Crysis 2 Maximum Edition -
Good day. We have a medical device project. We always wanted to have bananapi m4 zero hardware on our main board, with armbian as an OS seeing as it is up to date and fit for purpose. However, our Hardware supplier has not been able to solve the full hardware stack. We currently are able to boot the orangepi zero 3 image... and as far as I understand the hardware chips are very close to each other. We also have emmc on the board. But not working. We desperately need hardware development help so we can get banana pi m4 zero armbian supported OS working. Any advise please. We have 2GB RAM , allwinner h618, axp313. All the same as orangepi zero 3. Please help. Desperate help needed.
@jock Than you for the hints. If I measure on all (except GND) UART Pin 3.3V is not indicate that all resistor in place? Regarding the rk3399 schematic design, there should be some 100 ohm resistors there. To be honest for me was also very difficult to find the MaskRom pins, search something what is not there is a bit challenging. I measure all black SMD item (far as I know they are resistors), but non of them 100 ohm. (The board other side I do not see any missing resistor) Could you please advise me what I need to look? There is 3 point where possible to solder resistor, how to identify which one I need?
SteeMan replied to marfalk's topic in Amlogic CPU Boxes
You would just burn your downloaded image file to any USB storage, just like you would to an SD card (i.e. plug the USB storage into another device and burn the image to the storage) -
I've setup an Armbian build environment that was able to build a Rock-S0, trixie, minimal image. Using the patch for the Rock-S0 also rk3308b based, as a basis, I would like to create a sv06-Ace patch using the rk-kernel.dts that I managed to pull from the OEM SV06 Ace firmware. If I get a working Armbian image for the SV06, Mainline klipper should be doable. Can someone point me to the documentation on howto do this. rk-kernel.dts
marfalk replied to marfalk's topic in Amlogic CPU Boxes
Thank you. I have managed to successfully boot Armbian from SD card. Android is preserved. Now I am trying to install (move) Armbian (the "/root" partition) to an external USB drive. I run "armbian-config", then I pick "System" --> "Storage", but no "Install" (Copy the running Armbian system to another device) option is listied (according to the documentation here). I get only the following items: Download a fresh, official Armbian OS image and write it to a device Enable read only filesystem Enable Network filesystem (NFS) support etc... I have tried also in Terminal: "armbian-config --cmd STO001" but I get an error. In the instructions for TV boxes here it says: "running the shell script in the /root directory: install-aml.sh" But it refers to installing (moving) Armbian to the internal eMMC, if I am not mistaken. Is it possible to install it either to an external USB HDD or internal SATA HDD? -
@BigDi I was able flash the Image Armbian_26.2.1_Nanopim4v2_trixie_current_6.18.8_minimal.img.xz to the emmc and start Armbian on the device. Interesting that Wifi (Realtek RTL8821CU) is work well but Ethernet not.
With a lot of trial and error I figured out the issue but not the cause. This seems to only effect HEVC (x265) videos when drm is successfully enabled with MPV from this repository. If I try a different player, they play fine but no hardware acceleration. If I encode the videos to x264 they play but hardware acceleration fails with the following error [ffmpeg/video] h264: v4l2_request_probe_video_device: set controls failed. Invalid argument (22) The issue is the width of the video. Outside of certain ranges it will display a black video (audio works). It doesn't seem to matter what the height is set to. Eg) 704x480, 704x960 image is displayed. 706x480, 706x960 black screen The ranges go for 14 pixels and each range is separated by 50 pixels. eg) widths in the range of 690 to 704 display an image. Widths between 706 and 752 display a black screen. 754 to 768 display an image. It's a strange one.... Here is a list of ranges that work. Any widths outside of these ranges produces a black screen. It only goes up to 1984 but I'm sure the same rules would apply above this value.
to get 32768 clk from GPIO1 D4 on RK3328
tparys replied to emresensoy's topic in Advanced users - Development
PREEMPT_RT is fully merged in mainline Linux as of 2024 (https://en.wikipedia.org/wiki/PREEMPT_RT). - Yesterday
Here is the updated image with Wifi and EMMC boot https://github.com/sicXnull/armbian-build/releases/download/mxqpro/Armbian-unofficial_26.02.0-trunk_Mxqpro-h313_trixie_current_6.12.74_cinnamon_desktop.img.xz
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 ed9827920 (https://ryanfortner.github.io/box64-debs/) + ge-proton10-29 (https://github.com/GloriousEggroll/proton-ge-custom/releases/tag/GE-Proton10-29) (GE-proton is more likely to be segment fault-proof than other wine-proton versions) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v2.5.3 30~40fps@720p (low settings, texture high) box64 environment variables: RESIDENT EVIL 6 -
Is the NanoPC-T6 Plus compatible with the NanoPC T6 LTS image ?
Werner replied to magic_sam's topic in NanoPC T6 LTS
I don't know, perhaps the author knows. Try. If it doesn't work, then fe's wiki is misleading. -
magic_sam replied to magic_sam's topic in NanoPC T6 LTS
Dear @Werner , Thank you very much for your quick reply, and sorry for the delay on my end (I started a new job last week). If this board is not yet compatible with Armbian, then why this article ? EDIT: FriendlyElec's Wiki seems to imply that the board is compatible with Armbian's M6 / T6 and R6 images... https://wiki.friendlyelec.com/wiki/index.php/NanoPC-T6_Plus#Install_OS Best regards, Samuel -
Please read the FAQ and installation instructions linked on the download page. https://www.armbian.com/amlogic-s9xx-tv-box/
hi @spaceship we 'need to start working on it', what that means is that if you search around sufficiently, it is likely u-boot (the bootloader) and linux already supported A733. the task is 'system integration' to build that into Armbian. But as with all things, it means work, to spend hours / days figuring out how to do that and to do so and send a pull request for Armbian to include it. The challenges in life is such that most of us (including me) has very little fragmented time / energy to work on it. Perhaps that if more users 'request' it and support Armbian by way of donations, maybe they'd try to put it together and complete this work. The initial integration is one thing, the trouble is that linux keeps moving and linux 7.0 is about to drop. Hence, say you take what is there now integrate it, and no sooner 7.0 is out, you need to keep maintaining it. Hence, for a more sustainable setup, perhaps is for the community to fund Armbian to do so with donations, and efforts from the side. it is good for the community to support this effort both finanically and efforts from the side, this is to ensure that there is no "influence from a controlling (3rd) party" (possibly including a govt) i.e. no conflict of interest, e.g. to try to embed exploits in it for the govt's or 3rd party purpose, as in that the project is truly open source and inspected to prevent such exploits. but for what is worth, what it takes is a 'project' to get from here to integration e.g. in an 'edge' 7.0 kernel. --- off-topic but related, the security situation affecting commonly used commodity devices sold globally is *bad* https://www.kaspersky.com/about/press-releases/kaspersky-discovers-keenadu-a-multifaceted-android-malware-that-can-come-preinstalled-on-new-devices https://securelist.com/keenadu-android-backdoor/118913/ https://www.tomsguide.com/computing/malware-adware/dangerous-new-keenadu-malware-found-pre-installed-on-cheap-android-phones-and-tablets-how-to-stay-safe https://www.forbes.com/sites/daveywinder/2026/02/17/android-backdoor-pre-installed-on-devices---thousands-already-infected/
Hello NickA, fire-hound from discord here ... You do a tremendous service for us all, keep it up buddy! I loaded your recent build from here: https://github.com/NickAlilovic/build/releases and can confirm it works on my A7A. It correctly detected my Pimorony NVME Base lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mtdblock0 31:0 0 8M 0 disk mmcblk0 179:0 0 29.2G 0 disk ├─mmcblk0p1 179:1 0 256M 0 part /boot └─mmcblk0p2 179:2 0 28.6G 0 part /var/lib/containers/storage/overlay /var/log.hdd / zram0 254:0 0 3.9G 0 disk [SWAP] zram1 254:1 0 50M 0 disk /var/log zram2 254:2 0 0B 0 disk nvme0n1 259:0 0 238.5G 0 disk └─nvme0n1p1 259:1 0 238.5G 0 part /srv/dev-disk-by-uuid-b28b2f5c-ee2e-4ded-959e-22bc63051b1d and: screenfetch _,met$$$$$gg. root@radxa-cubie-a7a ,g$$$$$$$$$$$$$$$P. OS: Debian 13 trixie ,g$$P"" """Y$$.". Kernel: aarch64 Linux 6.6.98-vendor-sun60iw2 ,$$P' `$$$. Uptime: 11h 14m ',$$P ,ggs. `$$b: Packages: 661 `d$$' ,$P"' . $$$ Shell: bash 5.2.37 $$P d$' , $$P Disk: 4.9G / 271G (2%) $$: $$. - ,d$$' CPU: ARM Cortex-A55 Cortex-A76 @ 8x 1.794GHz $$\; Y$b._ _,d$P' RAM: 534MiB / 7928MiB Y$$. `.`"Y$$$$P"' `$$b "-.__ `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `"""" So far so good The issues: 1. The typical Armbian image has a module in the armbian-config and radxa's rsetup where one can set up the two leds conveiently to other than full on and heartbeat for the green and blue gpio leds respectively. I find it to be a nuisance to dig for that manually 2. The Ovralys module in armbian-config is returning an error - when entering DTO001 module (Device Tree Overlays) saying: Invalid overlay_prefix that might require deeper digging into the issue i guess? What works: Open Media Vault registers the NVME nicely as additional storage. I suspect booting off that NVME would work for an updated SPI bootloader i could test that if you want me to? If you need any other info or output I stand at Your disposal 😁
You should also consider the bootloader (type and version), in principle you do not need the dtb- package as the dtb files are also in the kernel package (enough when doing own extlinux). U-Boot philosophy is to provide just enough so that the kernel/initrd/DTB can load and started. Audio is not part of that I think. LE certainly used other bootloader and as you already showed has more non-upstreamed patches. See my experience:
@ag123 what does that mean exactly? I can't stand custom GNU/Linux builds from Orange Pi's company. I have a OPi Zero 3 and few OPi zero 2w, they're awesome with armbian, no issues at all. But now using the OPi Zero 3 as an hostap, i'm noticing that the throughput regarding network io seems to be a bottleneck, i was looking for something cheap and came accross this OPi 4 Pro. Thank you for doing this research.
Looking for help porting to an RK3328-based device
Soupborsh Proton replied to QwertyChouskie's topic in Rockchip CPU Boxes
Hello, I would like to use Armbian on control hub too but without disassembling it. I tried latest renegade image and usb and internet were not working. What is exactly everything I need to change in the image to make the usb at least work? I tried enabling the rk3318-box-led-conf3 in some file I forgot but it did not work, maybe else more needed or I did it wrong. I would be very grateful if you could write what I need to change! I do not want to disassemble since it's legality in FTC rules is ambigous for me.
