  2. Sure, no worries. You will notice once its fixed. as this is not something you should adjust on the APT client side. You didn't and won't loose anything except current updating mechanism is broken.
  4. Thanks Nick. In the meanwhile, would dtbo overlay, setting up CSI taken from radxa a733 work with kernel/u-boot of your image? Is there a way I can manually alter boot files to get this dtbo loaded? This is of course for the experiment - radxa's a733 image seems to still have a problem with ISP processor (or dtbo file affecting data formatting), as the resulting picture from the camera seems to be in a wrong color space (by the look, but I'm not an expert). I've reported the issue at https://forum.radxa.com/t/radxa-cubie-a7a-radxa-13m-214-camera/29717/7 for anyone interested.
  5. duplicate
  6. Igor, I understand the issue is complex, as you say, but for now I can only report that this didn't work. However, if I manage to resolve it, please let me know what we should do next, as I don't want to lose the work I've done on the image I downloaded. I also understand that these are BETA test images.
  7. Today when I run: apt clean and rm -rf /var/lib/apt/lists/* apt update Ign:10 http://beta.armbian.com trixie/trixie-utils all Packages Err:8 http://beta.armbian.com trixie/trixie-utils armhf Packages File has unexpected size (10351 != 8303). Mirror sync in progress? [IP: 23.186.113.5 80] Ign:11 http://beta.armbian.com trixie/trixie-desktop armhf Packages 0% [7 InRelease 30.1 kB/47.3 kB 64%]Error: Transaction http://beta.armbian.com/dists/trixie/InRelease was already aborted and is aborted again Err:10 http://beta.armbian.com trixie/trixie-utils all Packages File has unexpected size (3562 != 3343). Mirror sync in progress? [IP: 23.186.113.5 80] Get:12 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB] Get:13 http://deb.debian.org/debian trixie/main armhf Packages [12.7 MB] Get:14 http://deb.debian.org/debian trixie/non-free armhf Packages [69.9 kB] Get:15 http://deb.debian.org/debian trixie/non-free-firmware armhf Packages [6,685 B] Get:16 http://deb.debian.org/debian trixie/contrib armhf Packages [50.6 kB] Get:17 http://deb.debian.org/debian trixie-updates/main armhf Packages [5,144 B] Get:18 http://deb.debian.org/debian trixie-backports/non-free-firmware armhf Packages [3,856 B] Get:19 http://deb.debian.org/debian trixie-backports/non-free armhf Packages [1,520 B] Get:20 http://deb.debian.org/debian trixie-backports/main armhf Packages [132 kB] Get:21 http://deb.debian.org/debian trixie-backports/contrib armhf Packages [4,364 B] Error: Transaction http://beta.armbian.com/dists/trixie/InRelease was already aborted and is aborted again
  8. I spent practically whole holidays to rework repository management and there are still some problems, even it was tested on and on before going into production. But beta repository, which you are having troubles with, was never tested. Only stable. Motive: https://github.com/armbian/build/pull/9150 Affected: https://github.com/armbian/armbian.github.io/blob/main/.github/workflows/infrastructure-repository-update.yml https://github.com/armbian/armbian.github.io/blob/main/.github/workflows/infrastructure-download-external.yml https://github.com/armbian/armbian.github.io/blob/main/scripts/sync-repository.sh https://github.com/armbian/armbian.github.io/blob/main/scripts/copy-kernel-packages.sh https://github.com/armbian/build/blob/main/tools/repository/extract-repo.sh https://github.com/armbian/build/blob/main/tools/repository/repo.sh ... so you might get an idea on the problem complexity
  9. The update from the "armbian.com/beta" repository has not been working for quite some time now. Repositories are broken, sizes in InRelease do not match sizes in subbranches. Mirror synchronization has been going on for about a week now?!
  10. I confirm that the update has not been working for several days. Your repositories are broken, sizes in InRelease do not match sizes in subbranches. The file has an unexpected size (10351 != 8303). Perhaps the mirror is synchronizing? [IP: 65.21.120.247 80] Mirror synchronization has been going on for about a week now!?
  11. This isn't a DMA problem. There are too many inconsistencies in the audio driver. The driver needs to be fixed first.
  12. Unfortunately, after multiple tries the image provided didn't work. Here is the outputs of the commands asked to be runned with there respective tested images: dmesg | grep -iE "stmmac|sun8i|dwmac|emac|phy|mdio|motorcomm|yt8531" dmesg | grep -i "registered.*phy\|phy.*connect" ls -l /sys/bus/mdio_bus/devices/ cat /sys/bus/mdio_bus/*/phy_id 2>/dev/null find /sys/class/net -name "end0" -o -name "eth0" | head -1 | xargs -I {} cat {}/phys_switch_id 2>/dev/null ls /sys/firmware/devicetree/base/soc/ethernet*/mdio/ Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img [NOT WORKING] https://pastebin.com/v4bqxkeU Armbian_community_26.2.0-trunk.100_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/fG0YKepz Armbian_community_26.2.0-trunk.151_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/4eEC9mMg Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_current_6.12.63_minimal_phy-io-supply.img [NOT WORKING] https://pastebin.com/DnRgP4k5 Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_edge_6.18.2_minimal.img [WORKING] https://pastebin.com/8qp2X9wC armbianmonitor -U Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img [NOT WORKING] https://pastebin.com/iUKFu1u0 Armbian_community_26.2.0-trunk.100_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/SUDx7yme Armbian_community_26.2.0-trunk.151_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/QVU9q2La Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_current_6.12.63_minimal_phy-io-supply.img [NOT WORKING] https://pastebin.com/qiE4u2PQ Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_edge_6.18.2_minimal.img [WORKING] https://pastebin.com/2iWbYgqK For some reason, Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img stopped working when it did before. I tested it 5 times, and none of those boots worked. I don't know if the times I tested it before worked because of the small chance of booting with an ethernet connection, but it stopped working after booting. Anyway, I just want to clarify the inconsistency, but Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_edge_6.18.2_minimal.img is still consistently working after numerous boots. Also, while testing the images to provide the outputs, I realized something interesting, which for some reason I didn't notice before. After booting for the first time, the images downloaded from the official place, https://www.armbian.com/orangepi3-lts/, showed a message that explains that the image used is a “Developer Preview Build” and that it should not be used for production. I don't know if this is expected or is a mistake in publicizing the incorrect images, but now that I realized it, I felt that I needed to disclose it. Maybe that is the reason the Ethernet connection is not working. Armbian_community_26.2.0-trunk.151_Orangepi3-lts_trixie_current_6.12.63_minimal.img Welcome to Armbian_community! Documentation: https://docs.armbian.com | Community support: https://community.armbian.com/ IP address: Network connection timeout! Create root password: **** Repeat root password: **** Developer Preview Build This Armbian image was generated automatically for development and testing purpose. It may include unfinished features or unstable components. If you are not here to report issues or just test it, please do not use this image in production. Expect things to change - or even break - as improvements are made. Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your first name):_ Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img Welcome to Armbian_community! Documentation: https://docs.armbian.com | Community support: https://community.armbian.com/ IP address: Network connection timeout! Create root password: **** Repeat root password: **** WARNING! You are using an automated build meant only for developers to provide construtive feedback to improve build system, OS settings or UX. If this does not apply to you, STOP NOW! Especially don't use this image for production since things might not work as expected or at all. They may break anytime with next update. Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your first name):_
  13. A quite easy workaround until it's resolved up-upstream is to install and enable the Cinnamenu applet and disable the "vanilla" menu applet. Right-click on the taskbar/panel, choose "Applets" and the rest is straightforward. To place the Cinnamenu in the bottom left corner, right click on the taskbar/panel and enter Edit mode to be able to move stuff around, finish Edit mode and you're all set.
  14. moved to off-topic since op is not using Armbian.
  15. I'm sorry, but I don't really understand what a microSD card has to do with the problem above to perform system updates?
  16. Hello, i'm trying to make Arch work on my H3, it boots to uboot, loads fine and says RAM size and reads /boot/boot.scr, but when it tries to ext4load something it gives a error of ` ** fs_devread read error - block` and ` ** No partition table - mmc 0`, everything after `321 bytes read in 24 ms (33.2 KiB/s)` loads by arrays of pixels, i never seen these before on Armbian, H3Droid or any other img file. [ EDIT ] Turns out, U-Boot defaults to 400000hz on SD card while saying its mode is SD High Speed (50MHz), i still cant fix the issue...
  17. I see that this configuration is a kernel build feature, not an armbian-developed function: https://cateee.net/lkddb/web-lkddb/INITRAMFS_SOURCE.html https://unix.stackexchange.com/questions/479415/how-does-linux-know-where-the-rootfs-is So, you can post your question in many more linux discussion places. I hope you get the answer (and share here). Have you ever got this INITRAMFS_SOURCE configuration work, outside of Armbian... for example building the kernel from source by itself?
  18. Thanks @robertoj as a matter of fact this is my own custom initial ramdisk. I've been running it as a standalone file for some time and it works great but now I want to integrate it inside the kernel itself. for this I need to set CONFIG_INITRAMFS_SOURCE during the make process.
  19. Yesterday
  20. Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ?
  21. I solved the issue ! I flashed the latest armbian release raw image to the sdcard and plugged it in the TV box. It magically booted from the SDCard and now I have mmcblk2 as a block device. Now I can run armbian-install command to get everything going correctly.
  22. sven-ola
    All clear for the PCIe MSI: it is something with that Intel 7260 card. Today, I got two other M.2 Wifis: MT7922 and RTL8822ce, both seem to work on current and also on edge. Thus, I consider this as a success. Here's some screen blurb. // Sven-Ola
  23. Try a different microSD card, and always start with a serial-USB connection to your laptop. After first boot, run htop and if you see the CPU high usage, wait until it is done. Then reboot the orange pi.
  24. I don't know about customizing the initrd during the armbian build process. But this is the way to customize it AFTER you get armbian running in your board https://forum.armbian.com/topic/53568-how-to-add-a-specific-single-file-in-the-initrdimg-ideally-automatically-with-update-initramfs/#comment-221767 I know it is not YOUR OWN INITRD, but maybe you can work with it. Large language models are more useful when the answer exists somewhere in a popular website. If no human has written about it, ChatGPT or Gemini will not give you the answer. Have you tried replacing the uImage file in the /boot folder, with your own initrd, converted to uinitrd?
  25. hello! I need to create my own initial ramdisk during the armbian build process by supplying a value to this kernel tag:- grep CONFIG_INITRAMFS_SOURCE /home/andrew/armbian/build/cache/sources/linux-kernel-worktree/6.18__sunxi__armhf/.config CONFIG_INITRAMFS_SOURCE="usr/sideinitrd.cpio" my build runs under docker, and no matter where i place the CPIO file, i get this error: [🐳|🔨] make[3]: *** No rule to make target 'usr/sideinitrd.cpio', needed by 'usr/initramfs_inc_data'. Stop. [🐳|🔨] make[2]: *** [scripts/Makefile.build:556: usr] Error 2 [🐳|🔨] make[2]: *** Waiting for unfinished jobs.... just speculating, but maybe the armbian build cannot find my CPIO file in my compile tree known to docker:- pwd /home/andrew/armbian/build andrew@my-vps:~/armbian/build$ ls CONTRIBUTING.md Dockerfile README.md action.yml buildarmbian2.txt compile.sh extensions output patch shell.nix userpatches CREDITS.md LICENSE VERSION buildarmbian1.txt cache config lib packages requirements.txt tools chatGPT and gemini have wasted days on bogus suggestions on where to place it relative to my compile tree. i have tried many locations without success. EXPLANATION FROM GEMINI:- Armbian’s build process is designed to be "clean." When you run it inside Docker, it follows a strict sequence: Step A: It prepares the environment. Step B: It runs a "cleanup" on the kernel source to ensure no "junk" from previous builds exists (this deletes your .cpio file). Step 😄 It checks your .config and starts the make command. Because Step B happens every time you start the build, any file you manually copy into the kernel tree gets deleted seconds before the compiler actually looks for it. That is why you kept seeing No rule to make target. i am wondering if anyone has already done this before and how they got it going? latest log attached. help! andrew. buildarmbian2.txt.gz
  26. Minor update, I hardcoded usage of uboot debugging option and removed cache to force compiling uboot. But output from bootloader remained the same: U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Ha5c2-Vcc17-Bf389-R448a (Jan 08 2026 - 10:33:14 +0000) DRAM: 512 MiB Trying to boot from MMC1 Maybe detailed logging was already enabled? But it still does not give me any hints. Especially my board does not contain any additional slots like emmc, only for micro sd card (I don't understand why bootloader tries to use mmc1) UPD: I find out question with a little bit similar problem (hang out on mmc1) but need time to understand the reason, maybe it has similar issue
  27. Thank you reply, brentr. I add some info. passmark run command param is -r 2 ,means only run memory test.By the way ,I rename "PerformanceTest_Linux_ARM64" to passmark.Which you can download from "https://www.passmark.com/products/pt_linux/download.php" or "https://www.passmark.com/downloads/PerformanceTest_Linux_ARM64.zip" The only reason ,I install xterm,is I need use resize command to resize serial console.And I install it at 4.4 kernel also. pi@Pi-s:~$ apt list --installed 7zip/stable,now 25.01+dfsg-1~deb13u1 arm64 [installed,automatic] adbd/stable,now 34.0.5-12 arm64 [installed] adduser/stable,now 3.152 all [installed,automatic] adwaita-icon-theme/stable,now 48.1-1 all [installed,automatic] alsa-utils/stable,now 1.2.14-1 arm64 [installed] android-libbase/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-libboringssl/stable,now 14.0.0+r45-2 arm64 [installed,automatic] android-libcutils/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-liblog/stable,now 1:34.0.5-12 arm64 [installed,automatic] apt-utils/stable,now 3.0.3 arm64 [installed] apt/stable,now 3.0.3 arm64 [installed] armbian-bsp-cli-rockpi-s-current/now 25.11.2 arm64 [installed,local] armbian-config/unknown,now 26.2.0-trunk.126.1225.000141 all [installed] armbian-firmware/now 25.11.2 all [installed,local] at-spi2-common/stable,now 2.56.2-1 all [installed,automatic] avahi-daemon/stable,now 0.8-16 arm64 [installed,automatic] avahi-utils/stable,now 0.8-16 arm64 [installed] base-files/now 25.11.2-13.8+deb13u2-trixie arm64 [installed,local] base-passwd/stable,now 3.6.7 arm64 [installed] bash-completion/stable,now 1:2.16.0-7 all [installed] bash/stable,now 5.2.37-2+b5 arm64 [installed] bc/stable,now 1.07.1-4+b1 arm64 [installed] binutils-aarch64-linux-gnu/stable,now 2.44-3 arm64 [installed,automatic] binutils-common/stable,now 2.44-3 arm64 [installed,automatic] binutils/stable,now 2.44-3 arm64 [installed,automatic] bsdextrautils/stable,now 2.41-5 arm64 [installed,automatic] bsdutils/stable,now 1:2.41-5 arm64 [installed] btop/stable,now 1.3.2-0.1 arm64 [installed] btrfs-progs/stable,now 6.14-1 arm64 [installed] build-essential/stable,now 12.12 arm64 [installed] bzip2/stable,now 1.0.8-6 arm64 [installed,automatic] ca-certificates/stable,now 20250419 all [installed] console-setup-linux/stable,now 1.242~deb13u1 all [installed,automatic] console-setup/stable,now 1.242~deb13u1 all [installed] coreutils/stable,now 9.7-3 arm64 [installed] cpio/stable,now 2.15+dfsg-2 arm64 [installed,automatic] cpp-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-14/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] cpp/stable,now 4:14.2.0-1 arm64 [installed,automatic] cron-daemon-common/stable,now 3.0pl1-197 all [installed,automatic] cron/stable,now 3.0pl1-197 arm64 [installed] curl/stable,now 8.14.1-2+deb13u2 arm64 [installed] cutecom/stable,now 0.51.0-1+b3 arm64 [installed] dash/stable,now 0.5.12-12 arm64 [installed] dbus-bin/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-daemon/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-session-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-system-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-user-session/stable,now 1.16.2-2 arm64 [installed] dbus/stable,now 1.16.2-2 arm64 [installed,automatic] dconf-gsettings-backend/stable,now 0.40.0-5 arm64 [installed,automatic] dconf-service/stable,now 0.40.0-5 arm64 [installed,automatic] debconf-utils/stable,now 1.5.91 all [installed] debconf/stable,now 1.5.91 all [installed] debian-archive-keyring/stable,now 2025.1 all [installed,automatic] debianutils/stable,now 5.23.2 arm64 [installed] debsums/stable,now 3.0.2.3 all [installed] device-tree-compiler/stable,now 1.7.2-2+b1 arm64 [installed] dialog/stable,now 1.3-20250116-1 arm64 [installed] diffutils/stable,now 1:3.10-4 arm64 [installed] dmidecode/stable,now 3.6-2 arm64 [installed] dmsetup/stable,now 2:1.02.205-2 arm64 [installed,automatic] dosfstools/stable,now 4.2-1.2 arm64 [installed] dpkg-dev/stable,now 1.22.21 all [installed,automatic] dpkg/stable,now 1.22.21 arm64 [installed] dracut-install/stable,now 106-6 arm64 [installed,automatic] e2fsprogs/stable,now 1.47.2-3+b3 arm64 [installed] ethtool/stable,now 1:6.14.2-1 arm64 [installed] fake-hwclock/stable,now 0.14 all [installed] fdisk/stable,now 2.41-5 arm64 [installed] figlet/stable,now 2.2.5-3+b2 arm64 [installed] file/stable,now 1:5.46-5 arm64 [installed] findutils/stable,now 4.10.0-3 arm64 [installed] fontconfig-config/stable,now 2.15.0-2.3 arm64 [installed,automatic] fontconfig/stable,now 2.15.0-2.3 arm64 [installed,automatic] fonts-dejavu-core/stable,now 2.37-8 all [installed,automatic] fonts-dejavu-mono/stable,now 2.37-8 all [installed,automatic] fping/stable,now 5.1-1+b1 arm64 [installed,automatic] g++-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] g++-14/stable,now 14.2.0-19 arm64 [installed,automatic] g++-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] g++/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-14-base/stable,now 14.2.0-19 arm64 [installed] gcc-14/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc/stable,now 4:14.2.0-1 arm64 [installed,automatic] gensio-bin/stable,now 2.8.13-7 arm64 [installed] git-man/stable,now 1:2.47.3-0+deb13u1 all [installed,automatic] git/stable,now 1:2.47.3-0+deb13u1 arm64 [installed] gpg/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgconf/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgv/stable,now 2.4.7-21+b3 arm64 [installed] gpiod/stable,now 2.2.1-2+deb13u1 arm64 [installed] grep/stable,now 3.11-4+b1 arm64 [installed] groff-base/stable,now 1.23.0-9 arm64 [installed,automatic] gtk-update-icon-cache/stable,now 4.18.6+ds-2 arm64 [installed,automatic] gzip/stable,now 1.13-1 arm64 [installed] hicolor-icon-theme/stable,now 0.18-2 all [installed,automatic] hostname/stable,now 3.25 arm64 [installed] htop/stable,now 3.4.1-5 arm64 [installed] iftop/stable,now 1.0~pre4-9+b2 arm64 [installed] inetutils-telnet/stable,now 2:2.6-3 arm64 [installed,automatic] inetutils-traceroute/stable,now 2:2.6-3 arm64 [installed] init-system-helpers/stable,now 1.69~deb13u1 all [installed] init/stable,now 1.69~deb13u1 arm64 [installed] initramfs-tools-bin/stable,now 0.148.3 arm64 [installed,automatic] initramfs-tools-core/stable,now 0.148.3 all [installed,automatic] initramfs-tools/stable,now 0.148.3 all [installed] iproute2/stable,now 6.15.0-1 arm64 [installed] iputils-ping/stable,now 3:20240905-3 arm64 [installed] iw/stable,now 6.9-1+b1 arm64 [installed] jq/stable,now 1.7.1-6+deb13u1 arm64 [installed] kbd/stable,now 2.7.1-2 arm64 [installed,automatic] keyboard-configuration/stable,now 1.242~deb13u1 all [installed,automatic] klibc-utils/stable,now 2.0.14-1 arm64 [installed,automatic] kmod/stable,now 34.2-2 arm64 [installed,automatic] less/stable,now 668-1 arm64 [installed] libacl1/stable,now 2.3.2-2+b1 arm64 [installed] libaio1t64/stable,now 0.3.113-8+b1 arm64 [installed,automatic] libapparmor1/stable,now 4.1.0-1 arm64 [installed,automatic] libapt-pkg7.0/stable,now 3.0.3 arm64 [installed,automatic] libasan8/stable,now 14.2.0-19 arm64 [installed,automatic] libasound2-data/stable,now 1.2.14-1 all [installed,automatic] libasound2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libassuan9/stable,now 3.0.2-2 arm64 [installed,automatic] libatk-bridge2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatk1.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatomic1/stable,now 14.2.0-19 arm64 [installed,automatic] libatopology2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libatspi2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libattr1/stable,now 1:2.5.2-3 arm64 [installed] libaudit-common/stable,now 1:4.0.2-2 all [installed] libaudit1/stable,now 1:4.0.2-2+b2 arm64 [installed] libavahi-client3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common-data/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-core7/stable,now 0.8-16 arm64 [installed,automatic] libbinutils/stable,now 2.44-3 arm64 [installed,automatic] libblkid1/stable,now 2.41-5 arm64 [installed] libbpf1/stable,now 1:1.5.0-3 arm64 [installed,automatic] libbrotli1/stable,now 1.1.0-2+b7 arm64 [installed,automatic] libbsd0/stable,now 0.12.2-2 arm64 [installed,automatic] libbz2-1.0/stable,now 1.0.8-6 arm64 [installed] libc-bin/stable,now 2.41-12 arm64 [installed] libc-dev-bin/stable,now 2.41-12 arm64 [installed,automatic] libc-l10n/stable,now 2.41-12 all [installed,automatic] libc6-dev/stable,now 2.41-12 arm64 [installed,automatic] libc6/stable,now 2.41-12 arm64 [installed] libcaca0/stable,now 0.99.beta20-5 arm64 [installed,automatic] libcairo-gobject2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcairo2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcap-ng0/stable,now 0.8.5-4+b1 arm64 [installed] libcap2-bin/stable,now 1:2.75-10+b1 arm64 [installed,automatic] libcap2/stable,now 1:2.75-10+b1 arm64 [installed] libcbor0.10/stable,now 0.10.2-2 arm64 [installed,automatic] libcc1-0/stable,now 14.2.0-19 arm64 [installed,automatic] libcloudproviders0/stable,now 0.3.6-2 arm64 [installed,automatic] libcolord2/stable,now 1.4.7-3 arm64 [installed,automatic] libcom-err2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libcrypt-dev/stable,now 1:4.4.38-1 arm64 [installed,automatic] libcrypt1/stable,now 1:4.4.38-1 arm64 [installed] libctf-nobfd0/stable,now 2.44-3 arm64 [installed,automatic] libctf0/stable,now 2.44-3 arm64 [installed,automatic] libcups2t64/stable,now 2.4.10-3+deb13u2 arm64 [installed,automatic] libcurl3t64-gnutls/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libcurl4t64/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libdaemon0/stable,now 0.14-7.1+b3 arm64 [installed,automatic] libdatrie1/stable,now 0.2.13-3+b1 arm64 [installed,automatic] libdb5.3t64/stable,now 5.3.28+dfsg2-9 arm64 [installed] libdbus-1-3/stable,now 1.16.2-2 arm64 [installed,automatic] libdconf1/stable,now 0.40.0-5 arm64 [installed,automatic] libdebconfclient0/stable,now 0.280 arm64 [installed] libdeflate0/stable,now 1.23-2 arm64 [installed,automatic] libdevmapper1.02.1/stable,now 2:1.02.205-2 arm64 [installed,automatic] libdialog15/stable,now 1.3-20250116-1 arm64 [installed,automatic] libdouble-conversion3/stable,now 3.3.1-1 arm64 [installed,automatic] libdpkg-perl/stable,now 1.22.21 all [installed,automatic] libdrm-amdgpu1/stable,now 2.4.124-2 arm64 [installed,automatic] libdrm-common/stable,now 2.4.124-2 all [installed,automatic] libdrm2/stable,now 2.4.124-2 arm64 [installed,automatic] libedit2/stable,now 3.1-20250104-1 arm64 [installed,automatic] libegl-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libegl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libelf1t64/stable,now 0.192-4 arm64 [installed,automatic] libepoxy0/stable,now 1.5.10-2 arm64 [installed,automatic] liberror-perl/stable,now 0.17030-1 all [installed,automatic] libestr0/stable,now 0.1.11-2 arm64 [installed,automatic] libevdev2/stable,now 1.13.4+dfsg-1 arm64 [installed,automatic] libexpat1/stable,now 2.7.1-2 arm64 [installed,automatic] libext2fs2t64/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libfastjson4/stable,now 1.2304.0-2 arm64 [installed,automatic] libfdisk1/stable,now 2.41-5 arm64 [installed,automatic] libfdt1/stable,now 1.7.2-2+b1 arm64 [installed,automatic] libffi8/stable,now 3.4.8-2 arm64 [installed,automatic] libfftw3-single3/stable,now 3.3.10-2+b1 arm64 [installed,automatic] libfido2-1/stable,now 1.15.0-1+b1 arm64 [installed,automatic] libfile-fnmatch-perl/stable,now 0.02-3+b4 arm64 [installed,automatic] libfontconfig1/stable,now 2.15.0-2.3 arm64 [installed,automatic] libfreetype6/stable,now 2.13.3+dfsg-1 arm64 [installed,automatic] libfribidi0/stable,now 1.0.16-1 arm64 [installed,automatic] libgbm1/stable,now 25.0.7-2 arm64 [installed,automatic] libgcc-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libgcc-s1/stable,now 14.2.0-19 arm64 [installed] libgcrypt20/stable,now 1.11.0-7 arm64 [installed,automatic] libgdbm-compat4t64/stable,now 1.24-2 arm64 [installed,automatic] libgdbm6t64/stable,now 1.24-2 arm64 [installed,automatic] libgdk-pixbuf-2.0-0/stable,now 2.42.12+dfsg-4 arm64 [installed,automatic] libgdk-pixbuf2.0-common/stable,now 2.42.12+dfsg-4 all [installed,automatic] libgensio6t64/stable,now 2.8.13-7 arm64 [installed,automatic] libgl1-mesa-dri/stable,now 25.0.7-2 arm64 [installed,automatic] libgl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglib2.0-0t64/stable,now 2.84.4-3~deb13u1 arm64 [installed,automatic] libglvnd0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglx-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libglx0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libgmp10/stable,now 2:6.3.0+dfsg-3 arm64 [installed] libgnutls30t64/stable,now 3.8.9-3 arm64 [installed,automatic] libgomp1/stable,now 14.2.0-19 arm64 [installed,automatic] libgpg-error0/stable,now 1.51-4 arm64 [installed,automatic] libgpiod3/stable,now 2.2.1-2+deb13u1 arm64 [installed,automatic] libgpm2/stable,now 1.20.7-11+b2 arm64 [installed,automatic] libgprofng0/stable,now 2.44-3 arm64 [installed,automatic] libgraphite2-3/stable,now 1.3.14-2+b1 arm64 [installed,automatic] libgssapi-krb5-2/stable,now 1.21.3-5 arm64 [installed,automatic] libgtk-3-0t64/stable,now 3.24.49-3 arm64 [installed,automatic] libgtk-3-common/stable,now 3.24.49-3 all [installed,automatic] libgudev-1.0-0/stable,now 238-6 arm64 [installed,automatic] libharfbuzz0b/stable,now 10.2.0-1+b1 arm64 [installed,automatic] libhogweed6t64/stable,now 3.10.1-1 arm64 [installed,automatic] libhwasan0/stable,now 14.2.0-19 arm64 [installed,automatic] libice6/stable,now 2:1.1.1-1 arm64 [installed,automatic] libicu76/stable,now 76.1-4 arm64 [installed,automatic] libidn2-0/stable,now 2.3.8-2 arm64 [installed,automatic] libiniparser4/stable,now 4.2.6-1 arm64 [installed,automatic] libinput-bin/stable,now 1.28.1-1 arm64 [installed,automatic] libinput10/stable,now 1.28.1-1 arm64 [installed,automatic] libisl23/stable,now 0.27-1 arm64 [installed,automatic] libitm1/stable,now 14.2.0-19 arm64 [installed,automatic] libjansson4/stable,now 2.14-2+b3 arm64 [installed,automatic] libjbig0/stable,now 2.1-6.1+b2 arm64 [installed,automatic] libjpeg62-turbo/stable,now 1:2.1.5-4 arm64 [installed,automatic] libjq1/stable,now 1.7.1-6+deb13u1 arm64 [installed,automatic] libk5crypto3/stable,now 1.21.3-5 arm64 [installed,automatic] libkeyutils1/stable,now 1.6.3-6 arm64 [installed,automatic] libklibc/stable,now 2.0.14-1 arm64 [installed,automatic] libkmod2/stable,now 34.2-2 arm64 [installed,automatic] libkrb5-3/stable,now 1.21.3-5 arm64 [installed,automatic] libkrb5support0/stable,now 1.21.3-5 arm64 [installed,automatic] libksba8/stable,now 1.6.7-2+b1 arm64 [installed,automatic] liblastlog2-2/stable,now 2.41-5 arm64 [installed] liblcms2-2/stable,now 2.16-2 arm64 [installed,automatic] libldap2/stable,now 2.6.10+dfsg-1 arm64 [installed,automatic] liblerc4/stable,now 4.0.0+ds-5 arm64 [installed,automatic] libllvm19/stable,now 1:19.1.7-3+b1 arm64 [installed,automatic] liblocale-gettext-perl/stable,now 1.07-7+b1 arm64 [installed,automatic] liblognorm5/stable,now 2.0.6-5 arm64 [installed,automatic] liblsan0/stable,now 14.2.0-19 arm64 [installed,automatic] liblsof0/stable,now 4.99.4+dfsg-2 arm64 [installed,automatic] liblua5.4-0/stable,now 5.4.7-1+b2 arm64 [installed,automatic] libluajit-5.1-2/stable,now 2.1.0+openresty20250117-2 arm64 [installed,automatic] libluajit-5.1-common/stable,now 2.1.0+openresty20250117-2 all [installed,automa> liblz1/stable,now 1.15-3 arm64 [installed,automatic] liblz4-1/stable,now 1.10.0-4 arm64 [installed,automatic] liblzma5/stable,now 5.8.1-1 arm64 [installed] liblzo2-2/stable,now 2.10-3+b1 arm64 [installed,automatic] libmagic-mgc/stable,now 1:5.46-5 arm64 [installed,automatic] libmagic1t64/stable,now 1:5.46-5 arm64 [installed,automatic] libmariadb3/stable,now 1:11.8.3-0+deb13u1 arm64 [installed,automatic] libmd0/stable,now 1.1.0-2+b1 arm64 [installed] libmd4c0/stable,now 0.5.2-2+b1 arm64 [installed,automatic] libmnl0/stable,now 1.0.5-3 arm64 [installed,automatic] libmount1/stable,now 2.41-5 arm64 [installed] libmpc3/stable,now 1.3.1-1+b3 arm64 [installed,automatic] libmpfr6/stable,now 4.2.2-1 arm64 [installed,automatic] libmtdev1t64/stable,now 1.1.7-1 arm64 [installed,automatic] libncurses5/now 6.4-4 arm64 [installed,local] libncurses6/stable,now 6.5+20250216-2 arm64 [installed] libncursesw6/stable,now 6.5+20250216-2 arm64 [installed,automatic] libnetplan1/stable,now 1.1.2-7 arm64 [installed,automatic] libnettle8t64/stable,now 3.10.1-1 arm64 [installed,automatic] libnewt0.52/stable,now 0.52.25-1 arm64 [installed,automatic] libnghttp2-14/stable,now 1.64.0-1.1 arm64 [installed,automatic] libnghttp3-9/stable,now 1.8.0-1 arm64 [installed,automatic] libngtcp2-16/stable,now 1.11.0-1 arm64 [installed,automatic] libngtcp2-crypto-gnutls8/stable,now 1.11.0-1 arm64 [installed,automatic] libnl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-genl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-route-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnpth0t64/stable,now 1.8-3 arm64 [installed,automatic] libnss-mdns/stable,now 0.15.1-4+b1 arm64 [installed] libonig5/stable,now 6.9.9-1+b1 arm64 [installed,automatic] libopenipmi0t64/stable,now 2.0.37-1 arm64 [installed,automatic] libp11-kit0/stable,now 0.25.5-3 arm64 [installed,automatic] libpam-modules-bin/stable,now 1.7.0-5 arm64 [installed] libpam-modules/stable,now 1.7.0-5 arm64 [installed] libpam-runtime/stable,now 1.7.0-5 all [installed] libpam-systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libpam0g/stable,now 1.7.0-5 arm64 [installed] libpango-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangocairo-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangoft2-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libparted2t64/stable,now 3.6-5 arm64 [installed,automatic] libpcap0.8t64/stable,now 1.10.5-2 arm64 [installed,automatic] libpci3/stable,now 1:3.13.0-2 arm64 [installed,automatic] libpcre2-16-0/stable,now 10.46-1~deb13u1 arm64 [installed,automatic] libpcre2-8-0/stable,now 10.46-1~deb13u1 arm64 [installed] libpcsclite1/stable,now 2.3.3-1 arm64 [installed,automatic] libperl5.40/stable,now 5.40.1-6 arm64 [installed,automatic] libpipeline1/stable,now 1.5.8-1 arm64 [installed,automatic] libpixman-1-0/stable,now 0.44.0-3 arm64 [installed,automatic] libpng16-16t64/stable-security,now 1.6.48-1+deb13u1 arm64 [installed,automatic] libpopt0/stable,now 1.19+dfsg-2 arm64 [installed,automatic] libpq5/stable,now 17.6-0+deb13u1 arm64 [installed,automatic] libproc2-0/stable,now 2:4.0.4-9 arm64 [installed,automatic] libprotobuf32t64/stable,now 3.21.12-11 arm64 [installed,automatic] libproxychains4/stable,now 4.17-3 arm64 [installed,automatic] libpsl5t64/stable,now 0.21.2-1.1+b1 arm64 [installed,automatic] libpython3-stdlib/stable,now 3.13.5-1 arm64 [installed,automatic] libpython3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13-stdlib/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13/stable,now 3.13.5-2 arm64 [installed,automatic] libqt5core5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5dbus5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5gui5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5network5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5serialport5/stable,now 5.15.15-2 arm64 [installed,automatic] libqt5widgets5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libreadline8t64/stable,now 8.2-6 arm64 [installed,automatic] libreiserfscore0t64/stable,now 1:3.6.27-9 arm64 [installed,automatic] librtmp1/stable,now 2.4+20151223.gitfa8646d.1-2+b5 arm64 [installed,automatic] libsamplerate0/stable,now 0.2.2-4+b2 arm64 [installed,automatic] libsasl2-2/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsasl2-modules-db/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsctp1/stable,now 1.0.21+dfsg-1 arm64 [installed,automatic] libseccomp2/stable,now 2.6.0-2 arm64 [installed,automatic] libselinux1/stable,now 3.8.1-1 arm64 [installed] libsemanage-common/stable,now 3.8.1-1 all [installed,automatic] libsemanage2/stable,now 3.8.1-1 arm64 [installed,automatic] libsensors-config/stable,now 1:3.6.2-2 all [installed,automatic] libsensors5/stable,now 1:3.6.2-2 arm64 [installed,automatic] libsepol2/stable,now 3.8.1-1 arm64 [installed,automatic] libsframe1/stable,now 2.44-3 arm64 [installed,automatic] libsharpyuv0/stable,now 1.5.0-0.1 arm64 [installed,automatic] libslang2/stable,now 2.3.3-5+b2 arm64 [installed,automatic] libsm6/stable,now 2:1.2.6-1 arm64 [installed,automatic] libsmartcols1/stable,now 2.41-5 arm64 [installed] libsqlite3-0/stable,now 3.46.1-7 arm64 [installed] libss2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libssh2-1t64/stable,now 1.11.1-1 arm64 [installed,automatic] libssl3t64/stable,now 3.5.4-1~deb13u1 arm64 [installed] libstdc++-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libstdc++6/stable,now 14.2.0-19 arm64 [installed,automatic] libsystemd-shared/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libsystemd0/stable,now 257.9-1~deb13u1 arm64 [installed] libtasn1-6/stable,now 4.20.0-2 arm64 [installed,automatic] libtext-charwidth-perl/stable,now 0.04-11+b4 arm64 [installed,automatic] libtext-iconv-perl/stable,now 1.7-8+b4 arm64 [installed,automatic] libtext-wrapi18n-perl/stable,now 0.06-10 all [installed,automatic] libthai-data/stable,now 0.1.29-2 all [installed,automatic] libthai0/stable,now 0.1.29-2+b1 arm64 [installed,automatic] libtiff6/stable,stable-security,now 4.7.0-3+deb13u1 arm64 [installed,automatic] libtinfo5/now 6.4-4 arm64 [installed,local] libtinfo6/stable,now 6.5+20250216-2 arm64 [installed] libtirpc-common/stable,now 1.3.6+ds-1 all [installed,automatic] libtirpc3t64/stable,now 1.3.6+ds-1 arm64 [installed,automatic] libtsan2/stable,now 14.2.0-19 arm64 [installed,automatic] libubsan1/stable,now 14.2.0-19 arm64 [installed,automatic] libuchardet0/stable,now 0.0.8-1+b2 arm64 [installed,automatic] libudev1/stable,now 257.9-1~deb13u1 arm64 [installed] libunistring5/stable,now 1.3-2 arm64 [installed,automatic] libusb-1.0-0/stable,now 2:1.0.28-1 arm64 [installed,automatic] libutempter0/stable,now 1.2.1-4 arm64 [installed,automatic] libuuid1/stable,now 2.41-5 arm64 [installed] libvulkan1/stable,now 1.4.309.0-1 arm64 [installed,automatic] libwacom-common/stable,now 2.14.0-1 all [installed,automatic] libwacom9/stable,now 2.14.0-1 arm64 [installed,automatic] libwayland-client0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-cursor0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-egl1/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-server0/stable,now 1.23.1-3 arm64 [installed,automatic] libwebp7/stable,now 1.5.0-0.1 arm64 [installed,automatic] libwrap0/stable,now 7.6.q-36 arm64 [installed,automatic] libwtmpdb0/stable,now 0.73.0-3+deb13u1 arm64 [installed,automatic] libx11-6/stable,now 2:1.8.12-1 arm64 [installed,automatic] libx11-data/stable,now 2:1.8.12-1 all [installed,automatic] libx11-xcb1/stable,now 2:1.8.12-1 arm64 [installed,automatic] libxau6/stable,now 1:1.0.11-1 arm64 [installed,automatic] libxaw7/stable,now 2:1.0.16-1 arm64 [installed,automatic] libxcb-dri3-0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-glx0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-icccm4/stable,now 0.4.2-1 arm64 [installed,automatic] libxcb-image0/stable,now 0.4.0-2+b2 arm64 [installed,automatic] libxcb-keysyms1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-present0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-randr0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-render-util0/stable,now 0.3.10-1 arm64 [installed,automatic] libxcb-render0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shape0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shm0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-sync1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-util1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-xfixes0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinerama0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinput0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xkb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcomposite1/stable,now 1:0.4.6-1 arm64 [installed,automatic] libxcursor1/stable,now 1:1.2.3-1 arm64 [installed,automatic] libxdamage1/stable,now 1:1.1.6-1+b2 arm64 [installed,automatic] libxdmcp6/stable,now 1:1.1.5-1 arm64 [installed,automatic] libxext6/stable,now 2:1.3.4-1+b3 arm64 [installed,automatic] libxfixes3/stable,now 1:6.0.0-2+b4 arm64 [installed,automatic] libxft2/stable,now 2.3.6-1+b4 arm64 [installed,automatic] libxi6/stable,now 2:1.8.2-1 arm64 [installed,automatic] libxinerama1/stable,now 2:1.1.4-3+b4 arm64 [installed,automatic] libxkbcommon-x11-0/stable,now 1.7.0-2 arm64 [installed,automatic] libxkbcommon0/stable,now 1.7.0-2 arm64 [installed,automatic] libxml2/stable,now 2.12.7+dfsg+really2.9.14-2.1+deb13u2 arm64 [installed,automa> libxmu6/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxmuu1/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxpm4/stable,now 1:3.5.17-1+b3 arm64 [installed,automatic] libxrandr2/stable,now 2:1.5.4-1+b3 arm64 [installed,automatic] libxrender1/stable,now 1:0.9.12-1 arm64 [installed,automatic] libxshmfence1/stable,now 1.3.3-1 arm64 [installed,automatic] libxt6t64/stable,now 1:1.2.1-1.2+b2 arm64 [installed,automatic] libxtables12/stable,now 1.8.11-2 arm64 [installed,automatic] libxxf86vm1/stable,now 1:1.1.4-1+b4 arm64 [installed,automatic] libxxhash0/stable,now 0.8.3-2 arm64 [installed,automatic] libyaml-0-2/stable,now 0.2.5-2 arm64 [installed,automatic] libz3-4/stable,now 4.13.3-1 arm64 [installed,automatic] libzstd1/stable,now 1.5.7+dfsg-1 arm64 [installed] links/stable,now 2.29-2+b3 arm64 [installed] linux-base/stable,now 4.12 all [installed] linux-dtb-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-image-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-libc-dev/stable,now 6.12.57-1 all [installed,automatic] linux-u-boot-rockpi-s-current/now 25.11.2 arm64 [installed,local] lm-sensors/stable,now 1:3.6.2-2 arm64 [installed] lmbench/stable,now 3.0-a9+debian.1-9 arm64 [installed] locales/stable,now 2.41-12 all [installed] login.defs/stable,now 1:4.17.4-2 all [installed] login/stable,now 1:4.16.0-2+really2.41-5 arm64 [installed] logrotate/stable,now 3.22.0-1+b2 arm64 [installed] logsave/stable,now 1.47.2-3+b3 arm64 [installed,automatic] lsb-release/stable,now 12.1-1 all [installed,automatic] lshw/stable,now 02.19.git.2021.06.19.996aaad9c7-2.1 arm64 [installed] lsof/stable,now 4.99.4+dfsg-2 arm64 [installed] make/stable,now 4.4.1-2 arm64 [installed,automatic] man-db/stable,now 2.13.1-1 arm64 [installed] mariadb-common/stable,now 1:11.8.3-0+deb13u1 all [installed,automatic] mawk/stable,now 1.3.4.20250131-1 arm64 [installed] media-types/stable,now 13.0.0 all [installed,automatic] mesa-libgallium/stable,now 25.0.7-2 arm64 [installed,automatic] minicom/stable,now 2.10-1 arm64 [installed] mmc-utils/stable,now 0+git20240329.f757f413-1+b1 arm64 [installed] mount/stable,now 2.41-5 arm64 [installed] mtd-utils/stable,now 1:2.3.0-1 arm64 [installed] mysql-common/stable,now 5.8+1.1.1 all [installed,automatic] nano/stable,now 8.4-1 arm64 [installed] ncurses-base/stable,now 6.5+20250216-2 all [installed] ncurses-bin/stable,now 6.5+20250216-2 arm64 [installed] ncurses-term/stable,now 6.5+20250216-2 all [installed] netbase/stable,now 6.5 all [installed,automatic] netplan-generator/stable,now 1.1.2-7 arm64 [installed,automatic] netplan.io/stable,now 1.1.2-7 arm64 [installed] openssh-client/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssh-server/stable,now 1:10.0p1-7 arm64 [installed] openssh-sftp-server/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssl-provider-legacy/stable,now 3.5.4-1~deb13u1 arm64 [installed] openssl/stable,now 3.5.4-1~deb13u1 arm64 [installed,automatic] p7zip-full/stable,now 16.02+transitional.1 all [installed] parted/stable,now 3.6-5 arm64 [installed] passwd/stable,now 1:4.17.4-2 arm64 [installed] patch/stable,now 2.8-2 arm64 [installed,automatic] pci.ids/stable,now 0.0~2025.06.09-1 all [installed,automatic] perl-base/stable,now 5.40.1-6 arm64 [installed] perl-modules-5.40/stable,now 5.40.1-6 all [installed,automatic] perl/stable,now 5.40.1-6 arm64 [installed,automatic] picocom/stable,now 3.1-4+b1 arm64 [installed] powertop/stable,now 2.15-4 arm64 [installed] procps/stable,now 2:4.0.4-9 arm64 [installed,automatic] proxychains4/stable,now 4.17-3 arm64 [installed] psmisc/stable,now 23.7-2 arm64 [installed] putty-tools/stable,now 0.83-3 arm64 [installed,automatic] putty/stable,now 0.83-3 arm64 [installed] pv/stable,now 1.9.31-1 arm64 [installed,automatic] python3-cffi-backend/stable,now 1.17.1-3 arm64 [installed,automatic] python3-minimal/stable,now 3.13.5-1 arm64 [installed,automatic] python3-netplan/stable,now 1.1.2-7 arm64 [installed,automatic] python3-psutil/stable,now 7.0.0-2 arm64 [installed,automatic] python3-typing-extensions/stable,now 4.13.2-1 all [installed,automatic] python3-urwid/stable,now 2.6.16-1 arm64 [installed,automatic] python3-wcwidth/stable,now 0.2.13+dfsg1-1 all [installed,automatic] python3-yaml/stable,now 6.0.2-1+b2 arm64 [installed,automatic] python3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] python3.13/stable,now 3.13.5-2 arm64 [installed,automatic] python3/stable,now 3.13.5-1 arm64 [installed,automatic] readline-common/stable,now 8.2-6 all [installed,automatic] rfkill/stable,now 2.41-5 arm64 [installed] rockusb/stable,now 0.2.0-2+b2 arm64 [installed] rpcsvc-proto/stable,now 1.4.3-1+b1 arm64 [installed,automatic] rsync/stable,now 3.4.1+ds1-5 arm64 [installed] rsyslog/stable,now 8.2504.0-1 arm64 [installed] runit-helper/stable,now 2.16.4 all [installed,automatic] s-tui/stable,now 1.1.6-1.2 all [installed] sed/stable,now 4.9-2+b1 arm64 [installed] sensible-utils/stable,now 0.0.25 all [installed,automatic] ser2net/stable,now 4.6.4-1 arm64 [installed] shared-mime-info/stable,now 2.4-5+b2 arm64 [installed,automatic] sqv/stable,now 1.3.0-3 arm64 [installed,automatic] stress/stable,now 1.0.7-1+b1 arm64 [installed] sudo/stable,now 1.9.16p2-3 arm64 [installed] sysbench/stable,now 1.0.20+ds-7+b1 arm64 [installed] sysstat/stable,now 12.7.5-2+b2 arm64 [installed] systemd-resolved/stable,now 257.9-1~deb13u1 arm64 [installed] systemd-sysv/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] systemd-timesyncd/stable,now 257.9-1~deb13u1 arm64 [installed] systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] sysvinit-utils/stable,now 3.14-4 arm64 [installed] tar/stable,now 1.35+dfsg-3.1 arm64 [installed] telnet/stable,now 0.17+2.6-3 all [installed] tio/stable,now 3.9-1 arm64 [installed] toilet-fonts/stable,now 0.3-3 all [installed,automatic] toilet/stable,now 0.3-3 arm64 [installed] tree/stable,now 2.2.1-1 arm64 [installed] tzdata/stable,now 2025b-4+deb13u1 all [installed] u-boot-tools/stable,now 2025.01-3 arm64 [installed] ucf/stable,now 3.0052 all [installed,automatic] udev/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] usbutils/stable,now 1:018-2 arm64 [installed] util-linux/stable,now 2.41-5 arm64 [installed] wavemon/stable,now 0.9.1-1+b1 arm64 [installed] wget/stable,now 1.25.0-2 arm64 [installed] whiptail/stable,now 0.52.25-1 arm64 [installed,automatic] wireguard-tools/stable,now 1.0.20210914-3 arm64 [installed] wireless-regdb/stable,now 2025.07.10-1 all [installed] wpasupplicant/stable,now 2:2.10-24 arm64 [installed] x11-common/stable,now 1:7.7+24+deb13u1 all [installed,automatic] xauth/stable,now 1:1.1.2-1.1 arm64 [installed] xbitmaps/stable,now 1.1.1-2.2 all [installed,automatic] xkb-data/stable,now 2.42-1 all [installed,automatic] xterm/stable,now 398-1 arm64 [installed] xz-utils/stable,now 5.8.1-1 arm64 [installed,automatic] zlib1g/stable,now 1:1.3.dfsg+really1.3.1-1+b1 arm64 [installed] pi@Pi-s:~$ pi@Pi-s:~$ lsmod Module Size Used by 8723ds 1327104 0 hci_uart 135168 0 btqca 20480 1 hci_uart btrtl 28672 1 hci_uart snd_soc_rk3308 65536 1 crct10dif_ce 12288 1 btintel 49152 1 hci_uart snd_soc_rockchip_i2s_tdm 24576 2 snd_soc_simple_card 20480 0 btbcm 20480 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card bluetooth 671744 6 btrtl,btqca,btintel,hci_uart,btbcm snd_soc_core 204800 4 snd_soc_rockchip_i2s_tdm,snd_soc_rk3308,snd_soc_simple_card_utils,snd_soc_simple_card snd_compress 24576 1 snd_soc_core snd_pcm_dmaengine 12288 1 snd_soc_core snd_pcm 106496 4 snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine snd_timer 36864 1 snd_pcm snd 77824 4 snd_timer,snd_compress,snd_soc_core,snd_pcm soundcore 12288 1 snd cpufreq_dt 16384 0 cfg80211 815104 1 8723ds rfkill 24576 4 bluetooth,cfg80211 zram 36864 2 842_decompress 16384 1 zram 842_compress 20480 1 zram binfmt_misc 20480 1 usb_f_acm 16384 1 u_serial 28672 1 usb_f_acm g_serial 12288 0 libcomposite 65536 2 g_serial,usb_f_acm nfnetlink 16384 2 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 45056 2 realtek 40960 1 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 28672 1 stmmac pi@Pi-s:~$
  28. I'm trying to start sound. The device is created, but the error is "Write error: -5,Input/output error." The logs show the entry [ 7.411495] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743313] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743325] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan1 busy [ 20.743391] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743400] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan1 busy [ 20.743409] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan2 busy Why is it busy? # speaker-test -Dhw:2 -r48000 -c2 -tsine -f1000 speaker-test 1.2.14 Playback device is hw:2 Stream parameters are 48000Hz, S16_LE, 2 channels Sine wave rate is 1000.0000Hz Rate set to 48000Hz (requested 48000Hz) Buffer size range from 32 to 131072 Period size ra[ 194.914904] sun6i-dma 7121000.dma-controller: vchan 0000000060790fd8: txd 00000000925572c7[2]: submitted [194.914931] dma dma1chan2: vchan 0000000060790fd8: issued [ 194.914968] sun6i-dma 7121000.dma-controller: pchan 0: alloc vchan 0000000060790fd8 [194.914980] dma dma1chan2: [ 194.914980] desc: p - 0x00000000a9840060 v - 0x00000000be392dcf [ 194.914980] c - 0x03820481 s - 0xa9a00000 d - 0x07116020 [ 194.914980] l - 0x0000bb80 p - 0x00000008 n - 0xa9840040 [ 194.914998] sun6i-dma 7121000.dma-controller: Common register: [ 194.914998] mask0(0000): 0x00000002 [ 194.914998] mask1(0004): 0x00000000 [ 194.914998] pend0(0010): 0x00000000 [ 194.914998] pend1(0014): 0x00000000 [ 194.914998] stats(0030): 0x00000001 [194.915015] sun6i-dma 7121000.dma-controller: Chan 0 reg: [ 194.915015] ___en(0000): 0x00000001 [ 194.915015] pause(0004): 0x00000000 [ 194.915015] start(0008): 0xa9840060 [ 194.915015] __cfg(000c): 0x00000000 [ 194.915015] __src(0010): 0x00000000 [ 194.915015] __dst(0014): 0x00000000 [194.915015] count(0018): 0x00000000 [ 194.915015] _para(001c): 0x00000000 [194.915015] nge from 16 to 65536 Periods = 4 was set period_size = 12000 was set buffer_size = 48000 0 - Front Left Write error: -5,Input/output error xrun_recovery failed: -5,Input/output error Transfer failed: Input/output error
