  2. Hi @Igor, all, Made some updates, see here (including some minor corrections). Tested it with a built image (bookworm-minimal) and it seems to work: I will see how i can change U-Boot configuration to allow for `setexpr` to work, as using `setexpr` will make sure this does not need constant changing whenever kernel grows in size. As this is my first pull request, not sure what to do next? Please have a look-see, Groetjes,
  3. Is there anybody, who can help me with wifi module ..? or.. any utility to test / check gpios or. help me with gpio mapping in dts ..?? when I use dtb for meson8m2-mxiii-plus.dtb "Tronsmart MXIII Plus" tv box, wifi works fine... but, when I can replicate it on "my" dts for sencor (meson8b-sencor.dts) I have no success (two attached files for compare) Thanks.... meson8m2-mxiii-plus.dts meson8b-sencor.dts
  4. @eas07027 That install guide is for x86. dpkg -i os-agent_1.7.2_linux_x86_64.deb Try this https://community.home-assistant.io/t/installing-home-assistant-supervised-on-a-raspberry-pi-using-debian-12/247116 I haven’t installed home assistant before so I can’t help much. If home assistant is using docker you need to run these commands.
  5. Today
  6. Hi @Zzzz, @Zaf9670, After it fails to boot, can you type the following in the U-Boot monitor prompt and share the ouput: echo $fdt_addr_r echo $kernel_addr_r echo $ramdisk_addr_r setexpr abc 1 + 1 echo "abc=x${abc}x" fdt header fdt header get def totalsize echo "def=x${def}x" Thanks, Groetjes,
  7. @RaptorSDS, it do not boot from sdcard or flash usb, i think this box is die, only enter in Mask mode, but do not working any rkdeveloptool commands to rescue it! I rememeber now, to be a emcp so the ram memory is the same chip, i do not remove it, this go to junk! Thank you by help-me!
  8. @Rodrigo Campos the patch is less then three months old. If you need secure boot i have the steps here. You just need to edit the defconfig patch for the board you are using.
  9. Hi @Nick A, sorry my late answer. I can't directly use your image, because my box is that boot-secure. I need to compile it every time I want to update, so my last build have about 4 months, but I think that time it just have a "new patch for dram" unless have a other new dram patch. Anyway, I'll try to build it again to try. If you have any additional tip to this, I'll appreciate. Thanks again for all your efforts.
  10. @Alfi ciio, did you try to change the PRETTY_NAME on os-release file? It should be "Debian GNU/Linux 12 (bookworm)" to install HA Supervisor
  11. https://www.loverpi.com/collections/le-potato It says open-source support. Free software is software you may use, share, modify and redistribute. Can le potato run entirely on free software, such that there is no piece of non free software on the computer? If so are the armbian le potato images free software images? https://www.armbian.com/lepotato/ Thank you.
  12. This may or not be the case. Looking through the Ubuntu bug tracker, I find a lot of similarly failed upgrades. But at least ports.ubuntu.com was not disabled in the past: https://launchpadlibrarian.net/757026143/VarLogDistupgradeMainlog.txt from https://bugs.launchpad.net/ubuntu/+bug/2086530
  13. The home assistant is installed perfectly, but it does not load on emmc.
  14. @Zaf9670 Please run "armbianmonitor -u" on the board and share the link
  15. Sounds like an error with X. @ALL above: Did you recently update any packages? Please pastebin or attach the content of the ~/.xsession-errors file. Go and search for it if necessary "sudo find / -name .xsession-errors*"
  16. With this, I will use the box to run a simple file synchronization service. I want to use the internal eMMc, what is the best way to use it?
  17. updating so far, i installed arch linux on tv box @RaptorSDS I really want to learn how to do this, where are these pins? What adapter is this? Is this adapter the common one for reading electronic chips? I will love to help you with the information, in return I receive the knowledge Also, eMMC is unstable, I install and configure armbian normally, but when trying to update armbian, every now and then it freezes during the update and after restarting it no longer enters the system. After reporting the system crash here on the forum recently, I found myself on a mission to install a system that I feel comfortable with, Archlinux. With the idea of using the sdcard, with the command dd if=armbian-blabla.img of=device bs=1M oflag=direct status=progress I installed Armbian on the sdcard. With that, I already installed U-Boot and the Armbian boot, I just had to download the armv7 rootfs from archlinuxarm.org I had problems with the root password and file permissions. After copying the arch rootfs to the card, I discovered after trial and error that the files were corrupted. The solution was to redo the entire process. Now the system starts correctly, however, ssh would not start with the boot, and my board is an R29, I do not have HDMI access (and I suspect that not even the USB gadgets work, but I have not tested it yet). The solution was simple. With Armbian on the internal eMMC, I mounted the sdcard along with the dev, proc, sys and run partitions, and in chroot with the sdcard I configured ssh, pacman with pacman-key --init and pacman-key --populate archlinuxarm, and installed sudo to be able to do the basics. In addition, it was necessary to manually configure fstab and copy network settings (to make things easier) from armbian to arch.
  18. A quick google search seems to suggest that the Orange Pi Lite is prone to overheat. Obvious question that you did not mention in your original question: Do you have a heatsink installed? Is there sufficient airflow? In general, are you sure you want to use this board with a mate environment? Even if you get to work around the heat issues. RAM and CPU are likely to cause this to be a bit of an underwhelming experience.
  19. Same here, also with an OrangePi 5+. It used to work with autologin at startup but after some updates it didn't work anymore. When I start the board I get a graphical login screen and although I enter the password correctly, the login screen closes and then it appears again prompting to enter the password. The only way to log in is to switch to the text console (ctrl+alt+f3) and log in text mode and then run startx; I tried enabling/disabling auto login from armbian-config but it doesn't seem to do anything. user@orangepi5-plus:~$ cat /etc/issue Armbian 25.2.3 noble \l user@orangepi5-plus:~$ uname -r 6.1.99-vendor-rk35xx Does anybody have any ideas about this issue?
  20. Thanks Nick A!!! wifi worked, immediately upon loading it offered to choose a network name. all that's left is to find a usb-hab and it can be used as a children's PC. thanks to everyone who helped with advice and action, thanks for being understanding.
  21. you have to log at the bord direct for the pins or soldering point , than solder wire and connect to uart usb adapter , than you can get a log, you say yyou can boot from emmc but its not stable ? or complete dead emmc this are cheap box , there is not many to speed up maybe use one box for one task is the goal than
  22. yes put armbian image like multiboot on a sdcard and than boot maybe you have to put another boot partionion on emmc but not more , you dont need to remove emmc for this
  23. Hi @Vaclav Rada, You can also disable the systemd 'predictable naming convention' of interface naming by adding: net.ifnames=0 to your kernel commandline. This can be done in armbianEnv.txt by adding them to the extraargs variable as follows: extraargs=net.ifnames=0 Would be better to adjust your armbianEnv.txt instead of changing on-disk systemd service unit files, as they will be overwritten whenever an update comes along. I have not seen a situation myself where using the 'new' naming convention for network interfaces would work out better. But perhaps my use cases are not as flashy as other's 🙂 Groetjes,
  24. @atleta I've been seeing that it's a bad idea, it has 8g and I didn't want to completely waste its use, I wanted to help the system's processing or speed in some way but I think it's difficult lol
  25. Which build are you using? Is your internal emmc detected on boot?
  26. Hi, i have a R29_5G_LP3_V1.2 that i brick it, tried reduce the partition from internal emmc, i used rkdeveloptool to fix it, and dont worked! Can i remove the emmc chip and this can work just sdcard boot? Thanks
  27. Yesterday
  28. I was facing the same issue on armbian 24.11., kernel 6.6.62. If you look at the service: cat /etc/systemd/system/helios64-heartbeat-led.service Below, see that the device_name to trigger the led activity is "eth0". [Unit] Description=Enable heartbeat & network activity led on Helios64 After=getty.target [Service] Type=oneshot ExecStart=bash -c 'echo heartbeat | tee /sys/class/leds/helios64\\:\\:status/trigger' ExecStart=bash -c 'echo netdev | tee /sys/class/leds/helios64\\:blue\\:net/trigger' ExecStart=bash -c 'echo eth0 | tee /sys/class/leds/helios64\\:blue\\:net/device_name' ExecStart=bash -c 'echo 1 | tee /sys/class/leds/helios64\\:blue\\:net/link' ExecStart=bash -c 'echo 1 | tee /sys/class/leds/helios64\\:blue\\:net/rx' ExecStart=bash -c 'echo 1 | tee /sys/class/leds/helios64\\:blue\\:net/tx' [Install] WantedBy=multi-user.target But, the ethernet interfaces have different names: ifconfig end0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 ... enx646266d00c69: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ... I wanted the led to follow the activity of 1GbE interface, which, in this case, is the "end0". So, adjusting the line in the service file From: ExecStart=bash -c 'echo eth0 | tee /sys/class/leds/helios64\\:blue\\:net/device_name' To: ExecStart=bash -c 'echo end0 | tee /sys/class/leds/helios64\\:blue\\:net/device_name' And then restarting the service did the trick. systemctl daemon-reload systemctl restart helios64-heartbeat-led # systemctl enable helios64-heartbeat-led # the service should be already enabled to start on startup automatically Hope this helps.
