  2. please provide the output of "apt policy armbian-bsp-cli-rock-5b" and "sudo cat /etc/apt/preferences.d/*"
  3. Chromium is not the best for playing videos. Try mplayer or mpv or something alike. I doubt you'll get great performance beyond 720p though. Might not even get it with 720p?
  4. If you can still return the item for a refund, go ahead and do so. If you can still leave a bad review for this bad seller, go ahead and do so. This person has quite the gall to take your money but send you to us for the costly support. Buy cheap, buy twice.
  5. @C127 I've been thinking... Are you using an M.2 disk as the root device? I only noticed the dropping to initramfs problem after removing my emmc. Maybe if you are using a M.2 disk that is masking the problem
  6. Hello and welcome to the Armbian community. I have a Banana Pi M2+ that I use as a small 24/7 home server.
  7. I am not entirely sure if those sensors are always accurate. In the case of my BPi M2+, I have some serious doubts.
  8. Today
  9. I have not personally modified armbianEnv.txt, I do not know how to. As I say I think the machine has been messed around with, i.e. it has been hacked.As I say I am trying to work out how to reenable /dev/mmcblk1.
  10. I don’t understand why playing videos with this board is a problem under Debian and not under Android for example. Thanks however. Denis
  11. The DRM / GPU patches are from mainline. I'm sure there are or will be some updates, hacks and tweaks that eventually come down the road. But that's beyond the scope of bringing up the board.
  12. Weird its doing it on all distros and builds have tried so far including Debian. I can only think it must be the boards firmware ?
  13. i also have issues to move the system to the nvme ssd 😞 my base is the Armbian 25.5.1 with 6.1.115 (vendor kernel) image .... "copied" (usbimager) it to the sdcard and its booting ... 🙂 so I upgraded the system on the sdcard, still running 🙂 I read some posts and advices .... so I partioned the nvme with one big partition (/dev/nvme0n1p1) running armbian-install choosing option 7, (loading/upgrading bootloader to mtd ) after this i choose option 4 (boot from mtd, system on sata, usb ... ) only possible selection was /dev/nvme0n1 ... looked ok said yes to everything no Error system goes to shutdown /power off removed power, removed sdcard plugin power again .... and ... no boot 😞 serial console saying: DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot10 ch1 ttot10 ch2 ttot10 ch3 ttot10 ch0 ttot18 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB ch1 ttot18 channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB ch2 ttot18 channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB ch3 ttot18 channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB Manufacturer ID:0xff DQS rds:h1,h1 CH0 RX Vref:27.1%, TX Vref:21.8%,22.8% DQ rds:h1 l0 h2 l0 h1 h5 l0 l0, l0 h3 l0 h3 h7 h2 l0 h1 DQS rds:l0,h1 CH1 RX Vref:28.5%, TX Vref:23.8%,23.8% DQ rds:h1 h2 h1 h3 h1 h3 l0 h1, h1 h4 h1 h4 h1 h3 l0 h4 DQS rds:l0,h1 CH2 RX Vref:27.5%, TX Vref:23.8%,22.8% DQ rds:h1 h3 h2 h1 h1 h6 h4 h1, h1 h2 h6 l0 h6 h2 h6 h3 DQS rds:h1,l0 CH3 RX Vref:29.7%, TX Vref:21.8%,20.8% DQ rds:h5 h3 h2 h1 h3 h2 h2 h2, h5 h2 h1 h2 h4 l0 l0 h5 stride=0x2, ddr_config=0x4 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0xa00 0x1400 0x2800 0x0, rank_mask0 0x401000 change to F1: 528MHz ch0 ttot10 ch1 ttot10 ch2 ttot10 ch3 ttot10 change to F2: 1068MHz ch0 ttot14 ch1 ttot14 ch2 ttot14 ch3 ttot14 change to F3: 1560MHz ch0 ttot16 ch1 ttot16 ch2 ttot16 ch3 ttot16 change to F0: 2112MHz ch0 ttot18 ch1 ttot18 ch2 ttot18 ch3 ttot18 out U-Boot SPL board init U-Boot SPL 2017.09-armbian-2017.09-S3e40-P187d-He5fc-Ve691-Bb703-R448a (May 30 2025 - 10:51:06) sfc cmd=03H(6BH-x4) Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MTD2 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(11a994b967...) + OK ## Checking fdt 0x00354c30 ... sha256(e3b0c44298...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 496.285/765.931 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> initcall sequence 00000000002d2af8 failed at call 00000000002c502c (err=-1) ### ERROR ### Please RESET the board ### if im boot with sdcard in the system and mount /dev/nvm0n1p1 there is the whole system .... inklusive /boot und boot/dtb ..... what didd I miss ? Does anyone hav a link to a working tutorial ?
  14. I would try the cma=256M argument anyway... this kernel argument eliminated my video glitches and dma errors. I don't know how a dtsi or dtbo parameter (loaded after linux is started) would override a kernel argument (given before the linux kernel is started).
  15. It exists and has been working for a long time , why does someone change it while it does't hinder you? Who changed it , and who should rollback, yes, we're community. Thank you.
  16. I need to make custom intro on my bigtreetech cb1 when i try plymouth some time give me error and sometimes the system startup normally as normal Plymouth without pics only 3dots in middle of screen i want examples or guidelines to make it and when i make update to initremfs files it’s give me error such as error to create hard link what I should i do
  17. You need this feature, we don't. This board is community supported, you are community. Thanks for understanding.
  18. Hi there, It's quite beginner question, so I started it here. Just got my OPi zero 3, for now I can connect it to my ethernet network (with DHCP), but have no monitor / mouse / keyboard for going through initial setup (root password, "normal" user name, full name and password. How can I prepare official SD image for such case? Laurent
  19. Please rollback and re-enable all PPS_ clients by yourself , thank you.
  20. You're right - the dtb is gxbb-p200. However, actual RAM is 1 GB total. Booting Emuelec 4.3 will show you that info. But that particular game-stick does not have an Android boot-loader so maybe that's why Armbian is unable to boot. 🤔
  21. Well other option is the upstream broke somehow. KDE neon is based on their testing branch so if there is a faulty package uploaded desktop breaks. Though we won't dive into this since KDE is no officially supported desktop environment by us. We mostly do GNOME and XFCE only. We don't have resources to deal with more while we wish we would/could.
  22. Hi, again, Once again, thanks for your help. Well, change to edge kernel, and no joy... Gonna try a vendor kernel... Don't know if the problem is kernel related or files, since this happened when i just received the update...
  23. Well yes and no. This depends in board family and how well support is matured. In case of rk3588 support is very basic. This is also an LTS kernel which means no new features will be available and only security fixes will be applied. Enhanced hdmi support is available in edge kernel and also in rockchip bsp which we call vendor. If the system is accessible via terminal or ssh, use armbian-config to switch kernels. Otherwise - if available - download an image matching DE and kernel or use the build framework to build your own.
  24. Hi, Thanks a lot for your help. 👍 Indeed i'm using 6.12... Where can i find vendor or edge kernel? In another PC's i use mainline kernels without problems, but i think that can't be used on arm system... Once again, many thanks
