  2. @NicoD Hi! "FarmingSimulator 17" okay, I will try it.
  3. @marcosdsdba I would compile this on the box. Install kernel headers. Post the errors you are getting. https://github.com/NickAlilovic/build/releases/download/20250306/linux-headers-edge-sunxi64_25.05.0-trunk_arm64__6.12.11-S62b2-Da873-P8a5c-C1abcH02eb-HK01ba-Vc222-B9bbb-R448a.deb
  4. marcosdsdba
    marcosdsdba
  5. Today
  6. @Nick A Is it possible to create an image using the driver that Kevin posted? Because I tried to compile it and couldn't, several errors with .h file paths and C language function errors. Even importing the include linux/timer.h, etc., several errors occurred and I couldn't compile it on the SD card running Armbian. I don't know if I did something wrong or if I need to do it differently.
  7. Yesterday
  8. The Radxa bullseye image looks to boot fine, but Armbian forky does not boot at all.
  9. DTB extracted. Thanks! I should have some time this weekend to dig into getting wifi to work. @Nick A mentioned it might only work on kernel 4 so im unsure now but will see what i can do
  10. @sicxnull I'm uploading it now and it will soon be available on my Google Drive at this link: https://drive.google.com/drive/folders/14Imqiz3u0qjLbLyDGkB0ratNn7k7-p6Z?usp=sharing
  11. boot up armbian. check the /dev partition You will see mmcblk0 mmcblk2,etc The android image likely has many partitions. so you will see mmcblk2-9 etc, thats what we want Go ahead and dump the first 250mb (probably more than needed but just in case) into an image file and upload it, i can extract the dtb from that assuming mmcblk2 is what we want, you would run sudo dd if=/dev/mmcblk2 of=mmcblk2-first250mb.img bs=1M count=250 status=progress then upload that.
  12. @Jain Ziad Try this: https://forum.armbian.com/topic/57960-sv6256p-wifi-now-working-on-linux-6x-armbian-tested/
  13. sven-ola
    @brunorro What a read! That's cool stuff - hopefully those guys'n'gals visit the next station on their journey soon: from TH1520, via JH7110, then (hopefully) X1. At least that mailbox communication sounds similar with the SpacemiT SoC: power management via extra rCPU is also a thing here. Thank you for the link // Sven-Ola
  14. sven-ola
    @cal5582 Hav you plugged in your Oculink/Intel Arc combination to a standard PC's M.2 slot? Just to make sure, it's not the power supply for our power hungry graphical friends. If it is not the power supply (5V, 12V) then there is one difference from PC to OpiRV2: the OpiRV2's M.2 slot has only 2 PCIe lanes connected, while a standard PC has M.2/M-key connectors with 4 lanes normally. A graphics card may be used to a high number of lanes, so not only hungry for power but also for lanes. Also: there seems to exist Oculink adapters with an optical link between PC/board and card. In that case, I would expect an extra PCIe bridge to be shown with lspci.
  15. I'm trying to enable UART6, UART7, and UART10 via overlays on a sige5 board. UART6 AND UART7 are working fine but I'm not seeing UART10 in the /dev directory. Could someone help me debug this?
  16. @KhanhDTPHi. First off, great job with all these games. Would it be possible to test FarmingSimulator 17 please? I got the game working, but the image is offset a lot. Mouse also. I needed to set wine to win7 and use the x86 FarmingSimulator2017.exe in the x86 folder. I've got no clue how to fix this issue, maybe you have more tips and tricks. In windowed mode I can see everything, but mouse goes out of the window and stops working. Otherwise it looks playable if it was outputting correctly. Cheers, NicoD
  17. @gabriel_altoe Try this: https://brandolamarck.substack.com/p/como-extrair-e-decompilar-a-device. I'll take some time to try and follow the tips. I'll post any updates here.
  18. @sicxnull Yes, I can try to extract the DBT. How can I do that?
  19. @Nick A Thank you very much, I'll try using it and get back to you if everything is okay.
  20. brunorro
    Thank you, @sven-ola , your work is amazing About the GPU, I suppose that spacemit can do something like what this guy did to make work the BXM-4-64 on the TH1520 https://mwilczynski.dev/posts/riscv-gpu-zink/ Anyways, my hardware knowledge is way far away from this...
  21. cal5582
    nvme drive is in the bottom slot, oculink adapter going to a powered external pci-e adapter in the top nvme slot. i was able to plug a non-gpu in it and get a device to detect. just both my intel arc gpus failed to detect. edit, new discovery, when the fpga device is active on the 2nd nvme slot i can no longer see my original nvme drive if booting off the sd card. very strange. almost like its a lane bifrucation issue. ignore that, misconfig on my end.
  22. maxsub
    You mean the M.2 PCIe slot? My RV2 board has no oculink slot, only 2 PCIe slots, one for NVMe and one for SSD.
  23. cal5582
    not sure if this is the right place to ask, but i was able to get it to recompile the kernel with the xe driver flag turned on, and got a working booting 6.18.9 image, which is amazing, i have never been able to get anything newer than the 6.6 kernel the manufacturer provided working. so thank you so much for all your hard work. theres only one problem, when i do the lspci command, i dont see anything attached to that slot. i tried two different intel arc gpus, an arc 350 and an arc 310 neither detects. so i pulled out an ibm fpga card and plugged it into the same powered oculink adapter, and lo and behold the fpga card detected, so my pcie adapter setup is good. is there any advice you could offer besides enabling the xe2 driver in kernel that i may have to persue? i know this is kind of off topic, id just like to get hardware accelerated graphics working on this device.
  24. Last week
  25. While reviewing the system logs, I noticed several ftrace warnings appearing in dmesg. After investigating the root cause, I have applied the necessary configuration updates to eliminate these logs. The driver is now running cleanly without any ftrace-related noise.
  26. Hi, did you resolve this? I'm having trouble with the same thing and this seems to be the only forum where this is mentioned. It seems to be a watchdog issue?
  27. @Kevin su I just bought a TV Box with SV6256P and planned to port the driver and in my first search I found your post. Excellent work!
  28. Board: MKS-Klipad50 Images: * Armbian_26.2.1_Mksklipad50_noble_current_6.18.8_minimal.img.xz * Armbian_26.2.1_Mksklipad50_trixie_current_6.18.8_minimal.img.xz Passed tests: * gpg and sha checksum files * boot from emmc, leds, display, touch, usb, internal wifi * initial setup, uboot-console, full klipper/klipperscreen install, reboot Result: All expected images do exist, verify and work properly.
