Has anyone had any luck with the Radxa Cubie a5e and Armbian?
Meestor_X replied to Meestor_X's topic in Allwinner sunxi
While attempting, using AI, to see if there were DTS changes that could help this (spoiler: there aren't), it came up with some DTB changes that it claims need to be made for the board's stability. Maybe someone who understands these things can see if they got it right? Also, does the new allwinner update for armbian help/fix any of the cubie's USB/Power issues? https://github.com/armbian/build/pull/9381 a5e-armbian-DTS.patch - Today
I finally managed to boot in Maskrom mode by shorting the clock pin (red circle on the picture) to ground, then loading the loader (rk3528_spl_loader_v1.07.104.bin) and u-boot with rkdeveloptool.
Is the NanoPC-T6 Plus compatible with the NanoPC T6 LTS image ?
magic_sam replied to magic_sam's topic in NanoPC T6 LTS
Dear @Werner , I have just created an issue on Github to keep track of this discussion: https://github.com/armbian/build/issues/9446 Is it safe to try possibly unsupported images on the NanoPC-T6 Plus ? It's a relatively expensive piece of kit and I'd rather not take any chances (new LPDDR5 RAM: possibly new memory timings, etc.) Best regards, Samuel -
Timezone for Iceland
Igor replied to Björn Eiríksson's topic in Framework and userspace feature requests
... problem is elsewhere. This is running: sudo dpkg-reconfigure tzdata in CLI (Armbian Noble), choosing region Atlantic, then: -
bedna, see - i tried your way on a raspi 3B+ with the last minimal armbian and it worked like your case like a charm - on my Win11 with putty. If you look a bit back to my post with the attached "ssh_debian.txt" - that is what I get when I use a debian as ssh client! ssh client and the odroid ssh server cannot agree on how to connect UNLESS I dumb it down as seen in the command line - and then "1234" is not accepted.. So - armbian "odroid XU4" does not behave like "raspi"!
So I need to know what I have to do to get MIDI messages into my music app that I'm working on. I developed a cli synth app on Manjaro using SDL3 and Jack. Jack I used to connect to MIDI aka 'MIDI-Bridge' or MIDI Through and an external program to produce MIDI messages sent to MIDI Through. I am currently trying to do the same on the actual device I wish to use which is the OrangePi 4 LTS I have spare with just bare bones Armbian Server, no desktop. I have audio working through Pipewire. I am used to Jack just being available because Pipewire intercepts and handles the calls behind the scenes. I noticed that on Armbian I think I have to use the 'pw-jack' program or jack-play goes into an eternal and uninterruptible error loop (I have to kill it through another terminal). Note: I am developing this program in Zig. Am I doing all of this the wrong way? Is there some system process I have to start? Or something I haven't installed?
geoW replied to Björn Eiríksson's topic in Framework and userspace feature requests
Armbian config is just a wrapper to system tools that are dealing with this. We only change hardware related packages, the rest is stock Debian / Ubuntu. Is this problem solved somehow in Ubuntu? Probably the core of issue is originating from here: https://www.iana.org/ "Time zone of Iceland in Africa?" https://lists.iana.org/hyperkitty/list/tz@iana.org/message/QKQ27H23CTLFGJAQXJ24IVLRLQXHRLUA/ Interesting problem ... -
Clarification on GPL 2.0 License Applicability
Clark McCauley replied to Clark McCauley's topic in Off-topic
Thank you for the resources, and you're right, I should probably be asking a lawyer. That said, the thing that's been throwing me off is that the GPL FAQ specifically states that and uses GCC as an example. Using GCC to build a binary does not make the binary subject to GPL. It seems like there's a similarity here to armbian/build which is a tool that produces an artifact and the code within customize-image.sh is my own code. This question really came up for me when I was modifying a DTS file to disable a peripheral on my device and was investigating whether that change would need to be open sourced. I found that the parent DTS file that I was patching was licensed under GPL 2.0 OR MIT, so if I'm reading everything correctly, it seems like neither the customize-image.sh script nor my DTS patches need to published and licensed under GPL 2.0. But I'm posing here in case I've egregiously misunderstood something. If there's nuance and subtlety here, where my assumptions above might be correct, or might not be depending on other factors, then I may need to get an attorney involved. -
@Ryzer pcduino definitely works fine with dwc2. I cannot get OTG to work without it. I am not qulified to make any comments on whether this makes sense or is a coincidence, but if I don't load the module, it's doesn't work. For some reason, the mass storage gadget is still a little unstable in Windows (sometimes the File Explorer window shuts down for no reason), but on a Linux laptop, it is rock stable. It has also been running for two days in my car and doesn't seem to miss a beat there either (Linux host).
I'm putting together a build for a 3D printer, rk3308b-s board that has no ethernet, just a Fn-link wifi chip that is a knock-off of an rtl8192fs. I pulled the OEM dts and it describes the chip as an rtl8192cs. I'm pretty sure this is an out of kernel driver and my searches indicate I put source in userpatches. What do I need to add in the board/*.csc file to build to an image with the kernel module(s)? I do have a ralink ra2400, a mt7201 and some supported realtek dongles and If connected, I could git the code build and moprobe the module to test. Ideally, I would like to incorporate the driver via dkms in a armbian build. Can someone point me to the process?
I found a solution: downgrade the kernel to version 5.10.218 on SD-card_images by Johang Gunarsson in sweden. I used his Bookworm image. It does require a bit of work: Rsync is often broken on his images for pcduino (it looks for a libcryto.1 module but that module is obsolete), so you may need to downoad and compile rsync if you need it. The wifi is also unstable with the main line driver. I fixed the issue by installing morrownr's driver, but it takes ages to compile on the old lady (about 45 mins). I took the kernel and headers from this archive: https://archive.debian.org/debian/pool/main/l/linux/ Apparently, the big change between kernel 5 and 6 wrt OTG is usb-role-switch. Pcduino can support this new requirement, but someone with the right knowledge needs to take the time to update the device tree, and since the board is old, this may take time, or at this stage, may never happen.
Basically it has 1 gb ROM 8gb ram h3 chip and I HAVE put many img files on SD card NONE of them boot and as soon as I take the SD card out it boots into android perfectly fine... I'm lost on words and what to do I have also tried FEL mode on linux but the request times out with error -7 power supply is 5v 2a which is fine for this so not that and I'm using a 256gb a1 rated SD card. This is from a generic Chinese tv box called meecom and it has ADX-H-V1.0 written on it. I also changed the dtb files a lot but it still gave no display or sign that it was booted into armbian idk what to do help ( btw I repasted it that's why it has no thermal putty on it)
It really is as simple as possible on Armbian. Pretty good documentation too, I posted it before, but here you go again: https://docs.armbian.com/ All you have to do is to login as root from an ssh client following standards. I do not have access to a windows installation where I can confirm if what you say is true, that the ssh client does not let you login with "ssh root@xxx.xxx.xxx.xxx", so maybe you are correct, but it sounds very unlikely to me. But what I can guarantee is using an ssh client from another unix system will definitely let you connect. So use a mac or a linux computer to access. Or install wsl on windows and do it from there. https://learn.microsoft.com/en-us/windows/wsl/install Edit: I actually forgot, but I had putty installed on my system. I used it to check colors in a script I maintain and it exists in the extras repo on arch. Downloaded latest minimal image for rpi (so not same hardware as you) and... No settings changed in putty, just a standard root@192.168.99.60 that I added into the "Host Name (or IP address)" field and clicked "open". Name : putty Version : 0.83-1 So I don't know what to tell you...
tparys replied to Clark McCauley's topic in Off-topic
This seems like an excellent question for a lawyer. That said, the Armbian Build system is GPL v2, which Wikipedia has an excellent Article on, and has the following to say: That said, even if you're not distributing modifications of the build system, the final image still has GPL components. -
GTA V OG on Orange Pi 5+ 1080p Low DXVK / PanVK / Debian13 - Yesterday
I haven't got my head around what the differences are with -copy options. I'm able to use drm-copy but it produces a small stutter when watching 1080p hevc content whereas drm is very smooth. As previously mentioned, drm-copy does allow mpv to display videos with problematic file widths instead of just a black screen. I don't understand it all enough to know why that is.
I think building a new image is probably beyond me at the moment. I uninstalled the existing headers, rebooted and installed the updated headers and rebooted. The issue persists. I'm just going to give up on it. I don't really need to LCD display to work. I just wanted confirmation I wasn't missing something stupid. Thanks.
hm yes. I am not a Linux guru and would have liked to get a base for an up-to-date omv8. For me to just burn a recent armbian image on a Odroid hc2 - what a schmuck can do based on simple how-to's - this is not it. I see that you would have to modify the sd card up-front with either a key entrance to ssh or with another user. Console is "out" for a headless install and I do not have an XU4 so that you could do console/hmi supported install first steps. I think I call it a day. Thanks for all the support.
The patches that were available out-of-tree for a long time were a kind of hack using the DRM subsystem for decoding. For inclusion in mainline, they were further developed into a more correct request method. It is hwdec=v4l2request-copy in fact, because the stateless decoder is an m2m device and the scan-out is still carried out via the DRM subsystem. However, the copy is cheap because it is executed via dmabuf as zero copy.
Orange Pi Zero 3 WiFi Issues (unisoc_wifi Driver)
ValdikSS replied to Thomas Waterfall's topic in Allwinner sunxi
I found a workaround: disabling BSS transition management from AP to STA seems to work. There won't be roaming on AP's request obviously. wpa_cli set disable_btm 1 or in Debian's interfaces configuration file: iface wlan0 inet dhcp wpa-ssid YourSSIDJere wpa-psk blablabla post-up wpa_cli set disable_btm 1 Regular roaming (device-initiated) still works fine. -
For the longest time I have struggled with Timezone for Iceland in Armbian. The initial Armbian config has Europe -> and then places in Europe, in this list then it even has exotic places like Jan Mayen and or Swalbard (I forgot which ?). But it does not have Iceland at all. I know at this point in time (at initial install you can manually enter in some time zone format also). If you go in Armbian Config after it has been installed then the Armbian Config tool only displays Cities, so at this point in time you have missed the chance to enter it in the time zone format. Iceland uses UTC / GMT0, as in same time as London half of the year, but differs by one hour the other half since we do not have daylight savings like they have. I guess what I am asking for is something equal to this in the setup windows both in intial setup and in the Armbian Config sudo timedatectl set-timezone Atlantic/Reykjavik
how about armbian 26.2.1 but still using vendor kernel? did we still have this problem?
xsetiadi replied to jondowd's topic in Orange Pi 5
how do you solve this man? im also have this issue using v25.11.2 for Orange Pi 5 running Armbian Linux 6.1.115-vendor-rk35xx im using official power adapter. so i guess nothing wrong with my power. can we fix this without reinstalling the entire os? i have several running container and services.
