  2. Dear @brentr, It seems to be a common bug that keeps reappearing. And as far as I understand, it's a fix that needs to be applied to the kernel because otherwise, it won't work. Isn't there a way to make an external fix, which the user can install if needed and which can be applied to any kernel? If this bug is hardcoded, I imagine it's impossible and must be modified every time the kernel is compiled... I'm sorry I can't help much except by reporting the bug. Thank you for your contribution and the work you do, both to you and the community.
  4. Hi, In Gnome settings-> power there should be a "Automatic Screen Blank" toggle which you can switch to disabled. I checked this in a quite new Gnome version (48), not sure what version you have.
  5. Hello, I'm trying to connect hw125 to orange pi r1, but nothing happens. I searched both on the internet and through gpt. The kernel is the latest, I compiled it myself.
  6. hey , i almost gave up installing armbian , thank you for your support , for last time , im gonna try this ,i can understand dtb stuffs but, could you please tell me what armbian image i should download ? or could you please share me the link , i think whole time i downloaded wrong image ,
  7. Loading a kernel module has nothing to do with enabling a device tree overlay.
  8. Turning it on using armbian-config works and is easy (overlay).
  9. Tell me what external WiFi2. 4g, 5g USB to buy that is not expensive but supports armbian.
  10. You should of course monitor the temperatures now to see if the board becomes abnormally hot (use your hand or the programs sensors or btop, for example). That being said, a quick web search suggests to me that you are simply seeing a software problem AKA bug. I suggest you open a bug ticket on the Armbian bug tracker and patiently wait for the board maintainer to have a look into the issue. https://www.armbian.com/nanopi-neo-2/ lists https://github.com/spendist as the maintainer for your board. Maybe you can send an e-mail? sources: https://forum.armbian.com/topic/9501-opzero-h5-after-update-41917-the-cpu-temperature-is-wrong/ https://community.nxp.com/t5/i-MX-Processors/IMX8MP-not-able-to-read-Thermal-zone0-temperature/m-p/1655665 https://community.nxp.com/t5/QorIQ/Temperature-is-not-available-at-sys-class-thermal-thermal-zoneX/m-p/1343009
  11. The breakage occurred between Armbian 25.2.1 and Armbian 25.2.2
  12. Great choice! TBH not many people asked for add this at first run - probably as many use cases are headless / servers and people are used to just run command on their own. But agree, its one of those "nice to have". This is open source world. Anyone can contribute a feature, fix a bug. Donations are here for things that you already have. If you want feature to be fixed or added, line is very long - most of this forum is seeking for something. And there is just a few people on the other side, willing to pay with their private time for the common software maintenance. Donations, what people are willing to pay / contribute, cover less then 1% of the costs. Its a beer, not trade money. End users would destroy the project in no time, if we accept donations as a payment for the work. It is impossible to cover remaining 99%. Here and there yes, long term, no.
  13. I just verified that the arecord command fails also with kernel 6.12.15 So, we now know the breakage occurred between 6.12.12 and 6.12.15
  14. Thank you for that information. Indeed, you have partially upgraded to noble by now. It appears, though, as if you also have some packages that predate even jammy, like clang-10 and crda and possibly others. Did you originally install this board with a release before jammy? I see you do have armbian-focal-desktop-xfce installed, for example. For housekeeping, I suggest you do the following now before anything else. "sudo apt update;sudo apt upgrade" to make sure all packages are up-to-date in jammy. You might run into trouble because some of your packages are already from the noble pocket. Let me know if there were any issues. Next, try to simplify your package set by marking as many packages as automatically installed as possible to make the dist-upgrade path easier. Try to trim the output of "apt-mark showmanual" down to the minimum by marking them via "sudo apt-mark auto $pkg". Specifically, I think all your obsolete packages should be marked as automatically installed. # these look like clear candidates for removal unless some other package depends on them sudo apt-mark auto fonts-ubuntu-font-family-conso libhogweed5 libicu66 libjson-c4 libmpdec2 libnettle7 libpcre2-posix2 libpython3.8-minimal libsepol1 libssl1.1 libssl3t64 libwebp6 numix-blue-gtk-theme perl-modules-5.30 python3.8-minimal systemd-resolved ttf-ubuntu-font-family # these should be clear as well, but have a closer look if you want sudo apt-mark auto armbian-focal-desktop-xfce crda hddtemp Periodically, while trimming down the list of explicitly installed packages, check with "sudo apt autoremove --dry-run" before "sudo apt autoremove" to trim down on the installed packages. Then show me the output of "aptitude search '~i !~M' " once you are done. With regards to your filesystem issue, indeed it seems to be less complicated than I feared. I suggest you boot into your computer, umount sda1 and fsck it. That should take care of it. Monitor the drive if errors come back and if so, consider replacing it.
  15. I was able to duplicate this problem. Audio output appears to be working in both edge and current branches. But, The "arecord: set_params:1416: unable to install hw params" error occurs in the current branch as well. This is running kernel 6.12.28 the example arecord command you gave appears to work in kernel 6.12.12. So, the breakage occurred between 6.12.12 and 6.12.28
  16. https://zuckerbude.org/armbian-using-kernel-config/ https://www.google.com/search?q=google+how+to+load+linux+kernel+modules
  17. Ok, I think I got it. Tomorrow I will give a try, thanks. Mi box is the Transpeed M98 Plus by the way.
  18. Does anyone know if the spi-cpol and spi-cpha parameters are applicable in the ads7846 part of the DTS? I have seen cpol in an LCD discussion here: https://forum.armbian.com/topic/38896-orange-pi-lite-problem-with-latest-firmware/#findComment-191293 I am running out of ideas to try to make touch work... I can also try using gpio-spi.ko I need to check that the IRQ pin is changing from 3.3 to 0V... if I connect a LED to it, will it be a 0.0V pulse or held low while I press my finger? I learnt that /proc/interrupts can tell me if the IRQ input is seeing something... and I can see the number increase each time I press my finger on the screen: (see the line that ends with ads7846) https://forums.raspberrypi.com/viewtopic.php?t=187023&start=25 Is there any way to debug the ads7846 kernel module? I have seen this J1jumper mentioned here: https://forum.arduino.cc/t/solved-3-5-tft-not-stable-at-power-up/684536/19 "if you jumper J1, you feed it with 3.3V" I power it with 3.3V and the J1 contacts are disconnected... so maybe the 7846 is undervolted... does anyone have experience with this?
  19. Yesterday
  20. @jockThanks Jock, I know that and I agree with you. I could also take an Rpi4 with an SSD, but it is also for the fun of tinkering and checking if I still have "green fingers" The app is not critical as it's for displaying the welcome book and appliance manuals in some holiday rentals on the guests's phone from a QR code.
  21. @fabiobassa @jock you both are master-gods with the power of every god from all the mythologies known by the human kind! Next step for me now is to install it to the eMMC (if that's not possible, I will stick with SD boot only, no problem). I heard that there is the armbian-install command, so I will try it since the provided image is a XFCE Desktop one and I want a minimum image to free up resources since I just need a headless machine... Any suggestions for guides/documentations to install a minimal enviroment to emmc from the SD desktop enviroment?
  22. @Vinicius Guastala @jock indeed is a semi-god on those boxes 😅 ✋
  23. please ignore my previous comment. THE EXPERIMENTAL IMAGE DID BOOTED FROM SD CARD! IT WORKED I have forgotten to erase the flash on the first time... After I erased, it booted from the SD Card. I cannot thank you guys enough!!!! <3 <3 <3
  24. @fabiobassa and @jock, thanks for your quick responses! You are true heroes for this community. The suggested experimental image have not worked for me unfortunately. Same behavior, no Video and no Leds. However, a little progress on the UART search... Connecting my RX adapter pin to the SD Card 4th pin gave me the biggest console output so far, even though its just garbage, I see it as a little progress... Please see the attachment. Also, I think I was able to identify that the Samsung chip is a 1gb/8GB one from the "rkdeveloptool rfi" command... see it below with some more output from the rkdeveloptooll... [2025-05-12 18:49:03] viny182@desktop-mint ~> sudo rkdeveloptool list DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=302 Loader [2025-05-12 18:49:17] viny182@desktop-mint ~> sudo rkdeveloptool list-partitions Not found any partition table! [2025-05-12 18:49:46] viny182@desktop-mint ~ [1]> sudo rkdeveloptool test-device Test Device OK. [2025-05-12 18:49:58] viny182@desktop-mint ~> sudo rkdeveloptool rfi Flash Info: Manufacturer: SAMSUNG, value=00 Flash Size: 7456 MB Flash Size: 15269888 Sectors Block Size: 512 KB Page Size: 2 KB ECC Bits: 0 Access Time: 40 Flash CS: Flash<0> [2025-05-12 18:50:19] viny182@desktop-mint ~> sudo rkdeveloptool read-flash-id Flash ID: 45 4D 4D 43 20 [2025-05-12 18:50:26] viny182@desktop-mint ~> sudo rkdeveloptool read-chip-info Chip Info: 41 32 32 33 0 0 0 0 0 0 0 0 0 0 0 0 [2025-05-12 18:50:41] viny182@desktop-mint ~> sudo rkdeveloptool read-capability Reading capabilities failed
  25. Everything is good, thanks for the help and sorry for confusion, I only should to change PiRogue default interface after installation, this is PiRogue interface detection problem...
  26. @Vinicius Guastala I agree with @fabiobassa, thanks for the very detailed post of your board and broad description of the behaviour. I would suggest you to erase the internal flash and try to boot from sdcard with this armbian image. It is an "experimental" image with opensource Trust OS; many recent boards are having issues with proprietary trust os, possibly yours has similar issues, so you could give a shot to this. By the way, the serial log output would be indeed very handy if you have the chance to find the serial port. Beware also that armbian (and multitool) use 115200bps baud rate for the serial, while proprietary software uses 1.5Mbps baud rate!
  27. @gurzixo much better to steer to an officially supported SBC from armbian, if you need something reliable: https://www.armbian.com/download/?device_support=Platinum support&arch=aarch64
  28. @Vinicius Guastala first of all thank you for so much detailled infos and your efforts to find any relevant pin on your board. Yes china manufacturers are well known to use the first avaible chip they have unused on desk so I am not at all surprised to have this frankstein model of a 322x Unfortunately I don't own such board, so really at the moment I have few clues to point you on the right direction. Mine are generic considerations: 1) no separate chips apart from cpu, just one big big chip = ECMP usually 8 giga rom, 1 giga ram ( good for you if it is 16/2 but i doubt) 2) to me looks more interesting the FGHI part for uart, REMEMBER that uart speed is 1500000 ( yes!!!!! one million 500000) but follow the tracks for any missing resistor/missing short that stop the uart signal from CPU to pads 3) if you have a radio-aficionado or a tv technician that owns an oscilloscope finding the uart pads will be easier Sorry if I am not any further useful for your case, cannot buy every single new board that comes out on market, but if for you is important feel free to send me one sample for study and development EDIT : I just remebered that if you are lucky because not all boards have enabled. you'll find a uart on the sd card reader, starting from most right pins and counting 4 . Let me be more clear : two small and two big, from right....on the 4 you will have a uart at 1.500.000 Of course if you put the sd in you will lose this signal, but at least confirm you have any readable character on that pin )
