  2. Ethernet is supposedly broken by design. While Xunlong is working on a hw revision of this board it is to be expected that it will be released under the same name which will then ultimately contribute to users confusion why on some boards eth works and on others not. Therefore get rid of this one altogether. https://github.com/armbian/build/issues/6587 View the full article
  3. Unfortunately, my programming knowledge is low and knowledge of DTS Overlays + source code of w1-gpio linux kernel does not allow me to find the source of the problem [ 4.997793] sun50i-h616-pinctrl 300b000.pinctrl: pin PC10 already requested by onewire@0; cannot claim for 300b000.pinctrl:74
  4. rk35xx: drop vendor-boogie-panthor BRANCH; it has been integrated into vendor rk35xx: drop vendor-boogie-panthor BRANCH; it has been integrated into vendor This reverts commit 5f59fe63f19391eea3f1d7f99e62db9bbc9c961f View the full article
  5. multiple boards: fixes for board file syntax / missing vars (fixing JSON matrix prepare) multiple boards: fixes for board file syntax / missing vars (fixing JSON matrix prepare) BOARD_MAINTAINER must exist Every board file needs some variables defined, since they're parsed directly (and sources/includes are not resolved) View the full article
  6. Description Same as #6588 for v24.05 branch View the full article
  7. thanks for replying @Stephen Graf. I rather want to try using the older armbian-firmware package and keep the newer kernel, since the problem only shows up after I upgrade the firmware. currently it still hangs after 15-20 hours. can I extract the firmware from and image? the post from @ER Samson mention vnstat. I do not use it, and the package is not installed. i did use htop to check what's using the cpu. but nothing extensive. I haven't check the governor prior the deletion of firmware. currently is "on-demand"
  8. Ha, interesting ... I have put in armbianEnv.txt instead pc10 now param_w1_pin=gpio71 where gpio71 is number line for PC7 which is not connected DS18B20 🙂 at current is nothing connected and working w1-gpio with info log where is show PC10/gpio-74 [ 4.957396] Driver for 1-wire Dallas network protocol. [ 4.960325] w1-gpio onewire@0: there is not valid maps for state default [ 4.960433] gpio-74 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file [ 4.986579] w1_master_driver w1_bus_master1: Attaching one wire slave 28.03165129ecff crc 24 cat /sys/bus/w1/devices/28-03165129ecff/w1_slave 5f 01 4b 46 7f ff 0c 10 12 : crc=12 YES 5f 01 4b 46 7f ff 0c 10 12 t=21937 I can not understand this
  9. I would not use ZFS with this kernel if I were you. This kernel is provided by hw vendor, by people / business that only cares about (selling) hardware features to work. Everything else is unmaintained and open source community (not just Armbian) developers are not even thinking to maintain this kernel outside that as its concorde fallacy. FYI - it is highly possible ZFS implementation is affected, but you are FREE to do whatever. 90% of solutions, not workarounds, Armbian team (a few people) is unable to integrate into OS with their private resources, public (thousands of you) are simply not there. I can estimate, we could integrate about 30% of resolved suggestions this community generate with few full time engineers. Which costs money. Until you are satisfied with reporting problems only, until you don't care that a lot of value is wasted, there is nothing we can do but keep trying to provide "best effort" support with what we have and explaining this situation. Users perspective will always be like we refuse to help ... but people that are working on / helping Armbian are already long maxed out in efforts of helping everyone, even our competitors. Also. Hardware vendors have exploit of open source community build into their business model. If it happens that you are using hardware with terrible vendors reputation, bugs can be written, but are last to be resolved, some bugs are never resolved ... If you really wanna help everyone, start here: https://github.com/armbian/os/wiki/Import-3rd-party-packages Study and implement a solution. We also have automated dependency testing, which should prevent this problem in first place, but ain't working well and it wouldn't help much in this case. ZFS package is imported from Trixie and yes I understand that upstream package dependency has been recently changed. Until a month ago, we didn't have this problem, everything was working right and now, there is little we can do except disabling importing (which will also delete packages from repository). We don't compile those packages on our own and I am aware that this is not the best way. There are more workarounds - like using Trixie or Noble user space ... Its sadly under-powered, too small. Math is simple - I would very much like to help, but costs are the one that are killing us. Imagine that fixing a problem costs 1000 USD. You are willing to pay 5 USD (or not even that), which is fair if there would be more people contributes their share that you cover all costs. This never happens. They come with another and another problem for 1000 USD (often a lot more, sometimes a lot less) instead. Then its expected that we pay the rest, 995 USD for costs of resolving community software problem, this is simply not sustainable way of cooperation. Even the bug was made by us. I am trying to keep ZFS available. Do you have any idea how much time loss this service already caused with no benefits whatsoever? There are thousands of bugs in open source software and most of people pin everything on us after they download "Armbian image" and images that are produced by copycats as they claim "its Armbian". This particular problem was introduced by us, yes, but alternatively would be not providing ZFS that is capable of working with recent kernels. Which touches to the core of embedded Linux experience and logic. Often we can't match user space and kernel like this is done on 1st class x86 desktop / server / hw Linux world. Even they, often breaks critical things too, even with thousands of full time employees (Redhat). We can't provide that level of services with close to nothing from your side.
  10. Summary, In all examples to use w1-gpio in Armbian in armbinaEnv.txt always is name of gpio is write in capital letters for example PC10 param_w1_pin=PC10 but when we use PC10 w1-gpio not works and in log is message: [ 4.997793] sun50i-h616-pinctrl 300b000.pinctrl: pin PC10 already requested by onewire@0; cannot claim for 300b000.pinctrl:74 command cat /sys/kernel/debug/gpio did not show that gpio 74 / PC10 is used command but when we use name gpio in lowercase letters pc10 w1-gpio works and show data from DS18B20 but show message in log [ 9.366246] w1-gpio onewire@0: there is not valid maps for state default command cat /sys/kernel/debug/gpio show gpiochip0: GPIOs 0-287, parent: platform/300b000.pinctrl, 300b000.pinctrl: gpio-74 ( |onewire@0 ) out hi and we can see data from DS18B20 cat /sys/bus/w1/devices/28-03165129ecff/w1_slave 53 01 4b 46 7f ff 0c 10 2d : crc=2d YES 53 01 4b 46 7f ff 0c 10 2d t=21187 for me, it is bug or in kernel 6.6.30 or overlay for Ornage Pi Zreo v3
  11. Description Set correct video firmware based on the device being used. Fixes - https://forum.khadas.com/t/ffmpeg-and-hardware-h264-decode/19033/24 How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [X] Checked that the preload service starts correctly on vim4 and video_code.bin file points to correct firmware file. Checklist: Please delete options that are not relevant. [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
  12. I have checked what hapen when on Ornage Pi Zero v1 with kernel 6.1.63 in armbianEnv.txt use pa14 instead PA14 in log I see [ 9.358693] Driver for 1-wire Dallas network protocol. [ 9.366246] w1-gpio onewire@0: there is not valid maps for state default [ 9.368019] gpio-110 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file and w1-gpio not working and no files in /sys/bus/w1/devices/ but we see marked in red the same information that I have on OZPI v3 when I use pc10 instead of PC10 but on OZPI v3 DS18B20 works and on OZPI v1 it doesn't work when I use the lower case name gpio This looks like some kind of bug in kernel 6.6.30 on OZPI v3
  13. hello luis , try this :https://drive.google.com/drive/folders/1ls4jTIl00CJ3UFQipGdOYmrN0XBnfJlS?usp=sharing
  14. hi wulfy23, the problem is that you cannot use the console because the operating system no longer starts. If I extract the sd card and read it from the computer though, I can see all the OS files.
  15. dts overlay aren't 'perfect' https://elinux.org/Device_Tree_Source_Undocumented#:~:text=Node can be deleted with,%2Fdelete-property%2F directive.&text=If a delete is specified,with the overlay source file. If a delete is specified in an overlay source file, the delete only impacts the files compiled in association with the overlay source file. The delete does not result in an opcode in the resulting .dtb, thus applying the overlay will not delete the node or property in the base tree. and it may take using those 'hacks' described at that page to attempt a 'fix' hence, you may like to just note that those messages are 'benign' and w1-gpio works normally.
  16. Wifi works flawlessly with recent image. Includes Link Quality and Signal Level
  17. @wanasta orange pi zero 3 (and zero 2w) has on board wifi, have you tried them 1st? usb wifi dongles normally if the drivers are built into the kernel, plug them in and check dmesg if they are detected
  18. Attempting Armbian install onto an S905. Hardware specs at https://specdevice.com/showspec.php?id=6653-4ac9-1101-570d0033c587 Kernel begins to boot but gets errors and never completes dropping into initramfs shell. Was able to capture the dtb blob from the Android kernel and decompiled it. Enough differences to the dtb files in the Armbian distribution that I cannot figure out how to create a dtb file that will work. Have looked for other files on the internet but haven't come across something similar yet. Booting gets stuck in a loop of: meson-gx-mmc d0072000.mmc: no support for card's volts mmc0: error -22 whilst initialising SDIO card. mmc0: Card stuck being busy! __mmc_poll_for_busy Any feedback or guidance appreciated.
  19. Description systemctl reload-or-restart ssh prevents botching job if sshd is started by socket How Has This Been Tested? Quite harmless change which broadens systemctl tolerance towards services, no negative impacts expected Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] My changes generate no new warnings View the full article
  20. Description systemd-resolved is installed and enabled by default - unfortunately a static /etc/resolv.conf nameserver 1.0.0.1 set up during debootstrap phase is preventing systemd-resolved to do its job Removing the file after chroot has been finalized in post-tweaks.sh enables systemd-resolved to symlink /etc/resolv.conf to /run/systemd/resolved/stub-resolv.conf on first boot How Has This Been Tested? [x] Rebuilt an booted an Orangepi5-plus debian trixie image from trunk Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] My changes generate no new warnings View the full article
  21. Yesterday
  22. I have a tp link wn722n wifi adapter on the rtl8188eus chipset and I need to build a driver for the monitoring meter, but I don’t have the kernel headers, how and where can I download and install them?
  23. It works, thanks @ag123, good work ! For some reason the Armbian Image is far slower than the Orange Pi Debian image in UI mode. I am guessing its maybe because the Armbian Image comes only with Gnome which is probably heavier UI framework to run.
  24. Which SoCs and on which branch can have extensions enabled? 4l2loopback-dkms mesa-oibaf here: https://github.com/armbian/os/blob/main/userpatches/targets-release-standard-support.yaml#L40-L95 Mapping config: https://github.com/armbian/os/blob/main/userpatches/targets-extensions.map
  25. Yes, that's right, I can ignore it when I have a working w1-gpio on OZPI v3, but it would be nice to see how to fix it so that it works correctly. But what's strange to me is that I have to use the gpio name in lower case and not in upper case as it was always described in the w1-gpio examples. I tried to use the name with gpiod, i.e. "gpio74", instead of names like PC10, but it didn't work, so it occurred to me to try writing the name in lower case "pc10" instead of capital letters as usual, and I found that it worked, but I think it's not normal since capital letters have been used so far, I will check on OZP v1 whether it will work if I change to lowercase letters Thank you for exchanging ideas and tips on solving the problem
