I've try to upgrade my pi to newest version of the system yesterday, but FAILED for both apt-get upgrade or by download and write the newest image. Here is my working log:
1. apt-upgrade from armbian 5.14 image
    - error message indicate there's error during the apt-get update process
    - reboot, the boot screen shows no bootup message, than begin the TFTP startup process
    - wait until TFTP timeout, the system halt.
2. download and write the newest **Armbian_5.20_Bananapipro_Ubuntu_xenial_4.7.3.7z**
    - can be startup with the boot screen, both power led and disk io led (green led) work as expected
    - system halt after a few second, the power led goes off
    - can power on the pi by long press the power button, but as same as the first boot, powered off a few seconds after power on
    - the message goes too fast, can't see what exact stage it reach
Right now, I've to go back to the last working image (Armbian_5.14_Bananapipro_Ubuntu_xenial_4.6.2).
I would also like to understand what is going on, but it actually can be some hardware problem after all. If things are on the edge and our new build draw just a little more power it can crash on boot. I know this explanation might sound stupid but I would check cables / PSU. They are responsible for most (strange) problems.
Banana Pro powered through the DC-IN Micro USB jack (not OTG), no peripherals connected, only network. The '/etc/init.d/brcm40183-patch' issue is present but everything else is working smoothly (running legacy kernel but this shouldn't matter if booting stops already in u-boot):
macbookpro-tk:~ tk$ slogin 192.168.83.89
tk@192.168.83.89's password:
 ____                                  ____  _   ____
| __ )  __ _ _ __   __ _ _ __   __ _  |  _ \(_) |  _ \ _ __ ___
|  _ \ / _` | '_ \ / _` | '_ \ / _` | | |_) | | | |_) | '__/ _ \
| |_) | (_| | | | | (_| | | | | (_| | |  __/| | |  __/| | | (_) |
|____/ \__,_|_| |_|\__,_|_| |_|\__,_| |_|   |_| |_|   |_|  \___/
Welcome to ARMBIAN Ubuntu 16.04.1 LTS 3.4.112-sun7i
System load:   0.00            Up time:       14 hours
IP:            192.168.83.89
CPU temp:      37°C
Usage of /:    20% of 7.2G
[ 18 updates to install: apt-get upgrade ]
Last login: Sat Sep 17 17:34:58 2016 from 192.168.83.91
sudo -tk@bananapipro:~$ sudo -s
[sudo] password for tk:
root@bananapipro:~# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=bananapipro
BOARD_NAME="Banana Pi Pro"
VERSION=5.16
LINUXFAMILY=sun7i
BRANCH=default
ARCH=arm
root@bananapipro:~# apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  libnl-route-3-200
Use 'sudo apt autoremove' to remove it.
The following packages have been kept back:
  vim vim-common vim-runtime vim-tiny
The following packages will be upgraded:
  armbian-firmware armbian-tools-xenial libnss-myhostname libpam-systemd
  libsystemd0 libudev1 linux-headers-sun7i linux-image-sun7i
  linux-u-boot-bananapipro-default linux-xenial-root-bananapipro systemd
  systemd-sysv udev
13 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Need to get 0 B/140 MB of archives.
After this operation, 21.5 kB of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 45578 files and directories currently installed.)
Preparing to unpack .../systemd-sysv_229-4ubuntu8_armhf.deb ...
Unpacking systemd-sysv (229-4ubuntu8) over (229-4ubuntu7) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up systemd-sysv (229-4ubuntu8) ...
Preparing to unpack .../libpam-systemd_229-4ubuntu8_armhf.deb ...
Unpacking libpam-systemd:armhf (229-4ubuntu8) over (229-4ubuntu7) ...
Preparing to unpack .../libsystemd0_229-4ubuntu8_armhf.deb ...
Unpacking libsystemd0:armhf (229-4ubuntu8) over (229-4ubuntu7) ...
Processing triggers for libc-bin (2.23-0ubuntu3) ...
Setting up libsystemd0:armhf (229-4ubuntu8) ...
Preparing to unpack .../libnss-myhostname_229-4ubuntu8_armhf.deb ...
Unpacking libnss-myhostname:armhf (229-4ubuntu8) over (229-4ubuntu7) ...
Preparing to unpack .../systemd_229-4ubuntu8_armhf.deb ...
Unpacking systemd (229-4ubuntu8) over (229-4ubuntu7) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for dbus (1.10.6-1ubuntu3) ...
Setting up systemd (229-4ubuntu8) ...
addgroup: The group `systemd-journal' already exists as a system group. Exiting.
Preparing to unpack .../udev_229-4ubuntu8_armhf.deb ...
Unpacking udev (229-4ubuntu8) over (229-4ubuntu7) ...
Preparing to unpack .../libudev1_229-4ubuntu8_armhf.deb ...
Unpacking libudev1:armhf (229-4ubuntu8) over (229-4ubuntu7) ...
Processing triggers for systemd (229-4ubuntu8) ...
Setting up libudev1:armhf (229-4ubuntu8) ...
Preparing to unpack .../armbian-firmware_5.20_armhf.deb ...
Unpacking armbian-firmware (5.20) over (5.14) ...
Preparing to unpack .../armbian-tools-xenial_5.20_armhf.deb ...
Unpacking armbian-tools-xenial (5.20) over (5.14) ...
dpkg: error processing archive /var/cache/apt/archives/armbian-tools-xenial_5.20_armhf.deb (--unpack):
 trying to overwrite '/etc/init.d/brcm40183-patch', which is also in package linux-xenial-root-bananapipro 5.16
Preparing to unpack .../linux-headers-sun7i_5.20_armhf.deb ...
Unpacking linux-headers-sun7i (5.20) over (5.17) ...
Preparing to unpack .../linux-image-sun7i_5.20_armhf.deb ...
Unpacking linux-image-sun7i (5.20) over (5.17) ...
Preparing to unpack .../linux-u-boot-bananapipro-default_5.20_armhf.deb ...
Unpacking linux-u-boot-bananapipro-default (5.20) over (5.16) ...
Preparing to unpack .../linux-xenial-root-bananapipro_5.20_armhf.deb ...
Unpacking linux-xenial-root-bananapipro (5.20) over (5.16) ...
Processing triggers for initramfs-tools (0.122ubuntu8.1) ...
update-initramfs: Generating /boot/initrd.img-3.4.112-sun7i
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@bananapipro:~# apt-get install -f
  libnl-route-3-200
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
8 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up udev (229-4ubuntu8) ...
addgroup: The group `input' already exists as a system group. Exiting.
update-initramfs: deferring update (trigger activated)
Setting up libpam-systemd:armhf (229-4ubuntu8) ...
Setting up armbian-firmware (5.20) ...
Setting up linux-headers-sun7i (5.20) ...
Compiling headers - please wait ...
Setting up linux-image-sun7i (5.20) ...
Setting up linux-u-boot-bananapipro-default (5.20) ...
Setting up linux-xenial-root-bananapipro (5.20) ...
Setting up libnss-myhostname:armhf (229-4ubuntu8) ...
root@bananapipro:~# reboot
Connection to 192.168.83.89 closed by remote host.
Connection to 192.168.83.89 closed.
 ____                                  ____  _   ____
System load:   0.91            Up time:       56 sec
Memory usage:  2 % of 984Mb  IP:            192.168.83.89
CPU temp:      40°C
[ 6 updates to install: apt-get upgrade ]
Last login: Sun Sep 18 07:42:05 2016 from 192.168.83.91
tk@bananapipro:~$ sudo armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/bEUa
Please post the URL in the Armbian forum where you've been asked for.
I would also suspect powering problems, especially when/if the wrong Micro USB jack is used (OTG instead of DC-IN) or an average cable is used (the cable here is 20cm long and 20AWG rated).
Edit: I was wrong, am currently using the 2nd best method (5.5/2.1 barrel to Micro USB adapter) since i did some storage tests some days ago and it's known that Micro USB cabling is not reliable enough for this:
Edit 2: Upgrading my vanilla installation on BPi Pro to latest also worked flawlessly (except of the /etc/init.d/brcm40183-patch 'issue'):  http://sprunge.us/iYKc
Here it looks like this when idle:
root@bananapro:~# cat /sys/power/axp_pmu/ac/voltage
5193500
And when running cpuburn-a7:
5105100
Edit 3: Powering through USB OTG also works with vanilla image. But it still looks like this here (5.2V idle and nearly no voltage drops under load since I avoid bad cabling):
tk@bananapro:~$ cat /sys/power/axp_pmu/vbus/voltage
5205400
OK, confirmed to be the cabling problem. I've test not under 10 cables these days and finally got 3 of them worked.  But I'm still can't understand why the cabel which can worked with the old image can't work now. Anyway, thanks everyone.
