Seasalt Posted April 5, 2016 Posted April 5, 2016 If I put a USB stick in I can see it in Nautilus(yes I installed nautilus) but when I click on the name of the USB , I get.. " Unable to access “USBNAME" Not authorized to perform operation (polkit authority not available and caller is not uid 0)" Everything else is working. I have Samba, SSH, x11vnc, NAS, HEVC x265 Video, all working happily.I can live without USB but I thought it would be important to give the Armbian developers feedback. I have looked for an answer and I do not see any one else having this problem. Once again I just love this Armbian / OPi.pc combination. Seasalt
tkaiser Posted April 5, 2016 Posted April 5, 2016 I just threw the error message (+ "nautilus") into Google and ended up here for example: http://ubuntuforums.org/showthread.php?t=2240690
svkatielee Posted April 6, 2016 Posted April 6, 2016 I am having the same USB automount errors. orangepipc -5.05 on Samsung Evo 32Gb w/ factory orange pi power supply I can mount OK with sudo mount so that's not a problem. I chased Policykit configuration for a day, no change. Then I chased polkit-1 another day (apt-get install polkit-1), got it to finally say $ pkaction --verbose --action-id org.freedesktop.udisks2.filesystem-mount description: Mount a filesystem message: Authentication is required to mount the filesystem vendor: The udisks Project vendor_url: http://udisks.freedesktop.org/ icon: drive-removable-media implicit any: yes implicit inactive: yes implicit active: yes But still No Authority to mount USB stick. I then removed all the policy kit config files that I messed with and STILL get the above yes answers, but no authority. Therefore armbian must not be using either form of polkit for authentication. Maybe its SELinux?? Edit: or not. not commands for SELinux installed. I'll keep chasing it, but I'm running out of ideas.
martinayotte Posted April 6, 2016 Posted April 6, 2016 Could it be simply because of /etc/group membership ?
svkatielee Posted April 6, 2016 Posted April 6, 2016 Could it be simply because of /etc/group membership ? I think not. larryl@orangepione:~$ groups larryl dialout sudo audio video plugdev netdev Does your USB stick automatically mount (or thru thunar) when pluged in? If this is my (and Seasalt's) personal problem, I'll live with it. I assumed it was widespread and that I would be helping to figure it out. I have orangepione, 5.05 image on 32Gb Samsung EVO, sudo apt-get update, upgraade added Cyphers to sshd, apt-get install tightvncserver xtightvncviewer, No other packages loaded. Before on the Opc PC, I installed gvfs policykit-1 and later removed policykit-1 thinking that was the problem, but not installed this time.
svkatielee Posted April 7, 2016 Posted April 7, 2016 I found Igor's Mar 12 commit, https://github.com/igorpecovnik/lib/commit/bf66a46085bdd8d6abc6149c710e0c0532dc882bAutomount/eject of USB, fix reboot/shutdown on desktop (Jessie)So I followed it:sudo apt-get -y install gvfs policykit-1 policykit-1-gnome ejectedited /boot/boot.cmd to change "cgroup-enable" to "cgroup_enable"sudo mkdir -p /etc/polkit-1/localauthority/50-local.d/added plugdev.pkla and power.pkla to itplugdev.pkla [Allow Automount] Identity=unix-group:plugdev Action=org.freedesktop.udisks2.filesystem-mount;org.freedesktop.udisks2.filesystem-mount-system;org.freedeskt op.udisks2.filesystem-mount-other-seat;org.freedesktop.udisks2.filesystem-unmount-others;org.freedesktop.udis ks2.eject-media;org.freedesktop.udisks2.eject-media-system;org.freedesktop.udisks2.power-off-drive* ResultAny=yes ResultInactive=yes ResultActive=yes power.pkla [Allow Desktopstuff] Identity=unix-group:sudo Action=org.freedesktop.login1.reboot;org.freedesktop.login1.reboot-multiple-session;org.freedesktop.login1.po wer-off;org.freedesktop.login1.power-off-multiple-sessions;org.freedesktop.login1.suspend;org.freedesktop.log in1.suspend-multiple-sessions;org.freedesktop.login1.hibernate;org.freedesktop.login1.hibernate-multiple-sess ions ResultAny=yes ResultInactive=yes ResultActive=yes I still get an error window saying I do not have permission to eject, however the USB stick is indeed unmounted. So fixed. Thank you for your comments. Larry
