Upcoming Events
Volunteering positions
Single board computer maintainer
Position: Board maintainerNumber of places: 64Applicants: 69
Chat | Social Media
#armbian at
irc.libera.chat or irc.oftc.net
Matrix or Discord
Mastodon | 𝕏 -
Popular Now
Activity Stream
740
Orange Pi Zero 3
Connect to the orange pi's serial port with a usb-serial from your laptop. Make sure you connect the TX with the RX, and viceversa. The speed is 115200. You will see booting messages, before the login prompt. If nothing works, re-write the img to the microSD. -
2887
@Benedito Portela be aware this looks like a eMCP (emmc and RAM in one chip) , do you try running from a usb drive -
2887
please tell us do have try setup LED-config in rk322x-config tool -
740
Orange Pi Zero 3
How do I check the logs if I'm not able to login? This is where it's stuck at. -
18
Orange pi zero 3 SPI cs pin
Thank you! I will try it tomorrow. What is spi1_cs0_pin and spi1_cs1_pin equal to, in Orange Pi Zero 2W, and in Opiz3? Is it defined in the spi-spidev dtso, or in the main opiz3/opiz2w dts? I need to have it correctly in the main DTS, because the LCD driver doesn't use spidev (and it would conflict). cs0 matches the pin position in raspberry pi: pin 24.... so it would make sense if cs1 is pin 26. Reference. This is the patch that changes the opiz3/2w DTS https://forum.armbian.com/topic/50418-dont-use-kernel-61216-on-sunxi64/page/2/#findComment-216934
Member Statistics
