ScottP
  1. I ran into this issue a while back, I just downgraded back to the 5.10 kernel as it was a production server and I didn't have time to troubleshoot it. Are the current builds in the repo no fixed? I want to upgrade again to get the newer NPU driver to try out some LLMs on it Edit: I installed the latest image: linux-image-vendor-rk35xx 24.11.2 and it appears that this issue is resolved. Many thanks!
  2. The other issue with the vendor kernels is that the DTB seems to contain every rockchip dtb known - hundreds of them not just rk35xx - the default 256MB boot partition fills up as there is no room to have two kernel/overlay versions
  3. Same - this kernel seems to limit number of processes - fork failed, resource temporarily unavailable. Show your user limit: ulimit -u Show what limits other processes has: grep process /proc/*/limits
  4. I installed this kernel on a Rock 5B. Although the above fixed the issue for the original poster the failure of configure stage is not addressed. I think there is something wrong with this kernel. On my Home Assistant server some containers were failing to start and the errors pointed towards some resource/limits issue even for processes running as root. The errors were something like - fork failed, resource temporarily not available. I think update-initramfs ran into this issue producing the errors in the post. I don't have any logs since it has hard to do anything at this point, commands failing when trying to diagnose. I rolled back to 5.10 manually to get my server up and running. I think the maximum number of processes was being limited artificially low despite nothing being in /etc/security/limits* - I did see for not root users this limited to around 2k processes via ulimit -u - cant remember the exact number. If anyone is running this kernel you can check the limits for various processes - user and root alike by looking at /proc/<PID>/limits On my rolled back 5.10 legacy kernel this is 61790
  5. I Enabled overlay for USB0. Had to comment out g_serial too otherwise get hangs and usb disconnects. Odd decision to make the only USB port this board has into client mode instead of host so g_serial can be used as another console?
  6. ScottP
    Bananapi M7
    I'd use this for AI, the NPU is well supported now and having plenty of RAM opens up more possibilities
