greg396
28 -
https://forum.armbian.com/topic/30074-helios64-armbian-2308-bookworm-issues-solved/page/11/#findComment-224260 wow, that's a bummer... how can I check if this happens also to my configuration?
I backuped the boot dir. So I don't need booting from Sd-card, armbian-install will format emmc and copy from where the boot dir? Afterward it moves the system to emmc. If I am running armbian-config there's a message "Warning: The current OS (bookworm) is not supported or not listed" it's the latest version "Armbian 21.02.1 stable 6.12.32-current-rockchip64 (Debian bookworm)" apt-get install armbian-config armbian-config is already the newest version (25.8.0-trunk.330.0708.120916) I can't see any option to install/update system
Dear Werner, I am booting without a sd-card and can use armbian-install with just an option transfering system from ssd to emmc and emmc won't be formatted? Which option should I chose? boot frm emmc / system on emmc? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb Armbian Installer support those storage scenarios: boot from SD, system on SATA / USB boot from eMMC / NAND, system on eMMC/NAND boot from eMMC / NAND, system on SATA / USB / NVME Boot from SPI - system on SATA, USB or NVMe Install/Update the bootloader on SD/eMMC Install/Update the bootloader on special eMMC partition Install/Update the bootloader on SPI Flash Install system to UEFI disk thank you for clarification!
Actual booting from eMMC and system including OMV from Sata SSD. Running boot & system from eMMC should be possible now and I would like to transfer system from SSD to eMMC without losing my config and starting from scratch again. That way I'll have a sdd beside the hdd for OMV. How can I manually transfer the system including OMV from SSD to eMMC and what configuration files need to be altered?
I could solve the instability problems and I am using the 2.5Gbit port now without having errors and with full speed! changing the swich Flow Control On for 2.5Gbit devices ethtool -K <LAN-device> sg off sudo ip link set dev <LAN device> mtu 9000 using the actual dtb file posted above cp rk3399-kobol-helios64.dtb /boot/dtb/rockchip/ update-initramfs -u nano /etc/default/cpufrequtils ENABLE=true MIN_SPEED=600000 MAX_SPEED=1800000 GOVERNOR=ondemand nano /etc/rc.local for cpufreqpolicy in 0 4 ; do echo 1 > policy${cpufreqpolicy}/ondemand/io_is_busy echo 25 > policy${cpufreqpolicy}/ondemand/up_threshold echo 10 > policy${cpufreqpolicy}/ondemand/sampling_down_factor echo $(cat policy${cpufreqpolicy}/cpuinfo_transition_latency) > policy${cpufreqpolicy}/ondemand/sampling_rate done for i in $(awk -F":" "/ahci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 10 > /proc/irq/$i/smp_affinity done for i in $(awk -F":" "/xhci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 20 > /proc/irq/$i/smp_affinity done exit 0 nano /usr/local/bin/make_nas_processes_faster.sh #!/bin/sh -e for i in `pgrep "iperf3|smb"` ; do ionice -c1 -p $i ; taskset -c -p 4 $i; done # >/dev/null 2>&1 running as a service
Is there a way to copy the system from sda1 [M2-Sata SSD (2280)] to emmc (uboot) from the running system without losing the configuration? If it's possible, how can I do this including configuring the changes? What is the maximum size for the M2-Sata SSD (2280)? https://wiki.kobol.io/helios64/m2/
tested sd card: No difference iperf3 from client to Helios around 20mb/s I tested another local 2.5Gbit transfer client (arch arm) - server (armbian) 2.34Gbit/s (292mbit/s) and reverse 326mbit/s (40mb/s) Maybe a setup problem with the switch or with arm-arch client drivers Nevertheless thank you for your help! ;)
I switched back to actual kernel 6.12.22 and if I need to transfer from NAS to Client I'll just use another LAN-cable with 1Gbit and have around 100mb/s And you are right, installing a new image would be the best. But configering OMV again and can't use a simple settings-backup is a nightmare for me I upgraded from Debian11 to 12 (Bullseye) and the upgrading process worked without issues, but maybe that upgrading could bring up the speed issue. sudo ethtool -i end1 Cannot get driver information: No such device In /lib/firmware/rtl_nic/ are all firmware versions... Is ther anything I need to fix?
After shutdown client, Nas, switch I tested the NAS with the downgraded kernel 6.6.87. Using the dtb for 6.6 from here https://forum.armbian.com/applications/core/interface/file/attachment.php?id=13745&key=de08de7cf5b1684faa2f41605ea19a5f Including your optimizations here /etc/rc.local -> done No difference! Speed from NAS to client remains at 200Mbit/s! :( armbian-hardware-optimization is disabled on your system -> how do i do this? make_nas_processes_faster.sh "if iperf3 tests are performed or if helios64 is mounted as a remote drive I call the following script that assigns a big core and a preferred" -> I copied the script to /usr/local/bin/make_nas_processes_faster.sh but how should it'll be started? ./make_nas_processes_faster.sh pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. Anything I can try?
Dear ebin-dev, I downgraded, got an error concerning linux-headers-current-rockchip64, could solve it with sudo apt --fix-broken install, but hesitating to reboot if I am not shure if the downgrade was 100% sucessful Is there any possibility to check before reboot if anything is well and system will reboot sucessful? sudo dpkg -i linux-* dpkg: warning: downgrading linux-dtb-current-rockchip64 from 25.2.3 to 24.11.0-trunk (Reading database ... 52529 files and directories currently installed.) Preparing to unpack linux-dtb-current-rockchip64_24.11.0-trunk_arm64__6.6.87-S8146-D0531-P5324-C702eH5c21-HK01ba-Vc222-B59f0-R448a.deb ... Armbian 'linux-dtb-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' starting. Armbian 'linux-dtb-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' finishing. Unpacking linux-dtb-current-rockchip64 (24.11.0-trunk) over (25.2.3) ... Selecting previously unselected package linux-headers-current-rockchip64. Preparing to unpack linux-headers-current-rockchip64_24.11.0-trunk_arm64__6.6.87-S8146-D0531-P5324-C702eH5c21-HK01ba-Vc222-B59f0-R448a.deb ... Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' starting. Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' finishing. Unpacking linux-headers-current-rockchip64 (24.11.0-trunk) ... dpkg: warning: downgrading linux-image-current-rockchip64 from 25.2.3 to 24.11.0-trunk Preparing to unpack linux-image-current-rockchip64_24.11.0-trunk_arm64__6.6.87-S8146-D0531-P5324-C702eH5c21-HK01ba-Vc222-B59f0-R448a.deb ... Armbian 'linux-image-current-rockchip64' for '6.12.22-current-rockchip64': 'prerm' starting. Armbian 'linux-image-current-rockchip64' for '6.12.22-current-rockchip64': 'prerm' finishing. Armbian 'linux-image-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' starting. ls: cannot access '/var/lib/initramfs-tools': No such file or directory Armbian 'linux-image-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' finishing. Unpacking linux-image-current-rockchip64 (24.11.0-trunk) over (25.2.3) ... Armbian 'linux-image-current-rockchip64' for '6.12.22-current-rockchip64': 'postrm' starting. Armbian 'linux-image-current-rockchip64' for '6.12.22-current-rockchip64': 'postrm' finishing. Setting up linux-dtb-current-rockchip64 (24.11.0-trunk) ... Armbian 'linux-dtb-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' starting. Armbian: DTB: symlinking /boot/dtb to /boot/dtb-6.6.87-current-rockchip64... 'dtb' -> 'dtb-6.6.87-current-rockchip64' Armbian 'linux-dtb-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' finishing. dpkg: dependency problems prevent configuration of linux-headers-current-rockchip64: linux-headers-current-rockchip64 depends on libelf-dev; however: Package libelf-dev is not installed. dpkg: error processing package linux-headers-current-rockchip64 (--install): dependency problems - leaving unconfigured Setting up linux-image-current-rockchip64 (24.11.0-trunk) ... Armbian 'linux-image-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' starting. update-initramfs: Generating /boot/initrd.img-6.6.87-current-rockchip64 update-initramfs: Converting to u-boot format Armbian: update last-installed kernel symlink to 'Image'... '/boot/Image' -> 'vmlinuz-6.6.87-current-rockchip64' Armbian: Debian compat: linux-update-symlinks install 6.6.87-current-rockchip64 boot/vmlinuz-6.6.87-current-rockchip64 I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.6.87-current-rockchip64 I: /initrd.img.old is now a symlink to boot/initrd.img-6.6.87-current-rockchip64 I: /vmlinuz is now a symlink to boot/vmlinuz-6.6.87-current-rockchip64 I: /initrd.img is now a symlink to boot/initrd.img-6.6.87-current-rockchip64 Armbian 'linux-image-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' finishing. Errors were encountered while processing: linux-headers-current-rockchip64 sudo apt --fix-broken install Reading package lists... Done Building dependency tree... Done Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: libelf-dev zlib1g-dev The following NEW packages will be installed: libelf-dev zlib1g-dev 0 upgraded, 2 newly installed, 0 to remove and 3 not upgraded. 1 not fully installed or removed. Need to get 987 kB of archives. After this operation, 1716 kB of additional disk space will be used. Do you want to continue? [Y/n] Y Get:1 http://deb.debian.org/debian bookworm/main arm64 zlib1g-dev arm64 1:1.2.13.dfsg-1 [913 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 libelf-dev arm64 0.188-2.1 [73.8 kB] Fetched 987 kB in 0s (2258 kB/s) Selecting previously unselected package zlib1g-dev:arm64. (Reading database ... 78145 files and directories currently installed.) Preparing to unpack .../zlib1g-dev_1%3a1.2.13.dfsg-1_arm64.deb ... Unpacking zlib1g-dev:arm64 (1:1.2.13.dfsg-1) ... Selecting previously unselected package libelf-dev:arm64. Preparing to unpack .../libelf-dev_0.188-2.1_arm64.deb ... Unpacking libelf-dev:arm64 (0.188-2.1) ... Setting up zlib1g-dev:arm64 (1:1.2.13.dfsg-1) ... Setting up libelf-dev:arm64 (0.188-2.1) ... Setting up linux-headers-current-rockchip64 (24.11.0-trunk) ... Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' starting. Compiling kernel-headers tools (6.6.87-current-rockchip64) using 6 CPUs - please wait ... HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/confdata.o HOSTCC scripts/kconfig/expr.o LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/menu.o HOSTCC scripts/kconfig/parser.tab.o HOSTCC scripts/kconfig/preprocess.o HOSTCC scripts/kconfig/symbol.o HOSTCC scripts/kconfig/util.o HOSTLD scripts/kconfig/conf # # configuration written to .config # SYNC include/config/auto.conf.cmd HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.[ch] HOSTCC scripts/dtc/libfdt/fdt.o HOSTCC scripts/dtc/libfdt/fdt_ro.o HOSTCC scripts/dtc/libfdt/fdt_wip.o HOSTCC scripts/dtc/libfdt/fdt_sw.o HOSTCC scripts/dtc/libfdt/fdt_rw.o HOSTCC scripts/dtc/libfdt/fdt_strerror.o HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o HOSTCC scripts/dtc/libfdt/fdt_addresses.o HOSTCC scripts/dtc/libfdt/fdt_overlay.o HOSTCC scripts/dtc/fdtoverlay.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/fdtoverlay HOSTLD scripts/dtc/dtc HOSTCC scripts/kallsyms HOSTCC scripts/sorttable HOSTCC scripts/asn1_compiler HOSTCC scripts/insert-sys-cert HOSTCC scripts/selinux/genheaders/genheaders HOSTCC scripts/selinux/mdp/mdp CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/devicetable-offsets.s MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/sumversion.o HOSTCC scripts/mod/symsearch.o UPD scripts/mod/devicetable-offsets.h HOSTCC scripts/mod/file2alias.o HOSTLD scripts/mod/modpost MODPOST scripts/mod/Module.symvers Done compiling kernel-headers tools (6.6.87-current-rockchip64). Done compiling kernel-headers tools (6.6.87-current-rockchip64). Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' finishing. Processing triggers for man-db (2.11.2-2) ... sudo dpkg -i linux-headers-current-rockchip64_24.11.0-trunk_arm64__6.6.87-S8146-D0531-P5324-C702eH5c21-HK01ba-Vc222-B59f0-R448a.deb (Reading database ... 78194 files and directories currently installed.) Preparing to unpack linux-headers-current-rockchip64_24.11.0-trunk_arm64__6.6.87-S8146-D0531-P5324-C702eH5c21-HK01ba-Vc222-B59f0-R448a.deb ... Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'prerm' starting. Cleaning directory /usr/src/linux-headers-6.6.87-current-rockchip64 ... Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'prerm' finishing. Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' starting. Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'preinst' finishing. Unpacking linux-headers-current-rockchip64 (24.11.0-trunk) over (24.11.0-trunk) ... Setting up linux-headers-current-rockchip64 (24.11.0-trunk) ... Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' starting. Compiling kernel-headers tools (6.6.87-current-rockchip64) using 6 CPUs - please wait ... HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/confdata.o HOSTCC scripts/kconfig/expr.o LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/menu.o HOSTCC scripts/kconfig/parser.tab.o HOSTCC scripts/kconfig/preprocess.o HOSTCC scripts/kconfig/symbol.o HOSTCC scripts/kconfig/util.o HOSTLD scripts/kconfig/conf # # configuration written to .config # SYNC include/config/auto.conf.cmd HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.[ch] HOSTCC scripts/dtc/libfdt/fdt.o HOSTCC scripts/dtc/libfdt/fdt_ro.o HOSTCC scripts/dtc/libfdt/fdt_wip.o HOSTCC scripts/dtc/libfdt/fdt_sw.o HOSTCC scripts/dtc/libfdt/fdt_rw.o HOSTCC scripts/dtc/libfdt/fdt_strerror.o HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o HOSTCC scripts/dtc/libfdt/fdt_addresses.o HOSTCC scripts/dtc/libfdt/fdt_overlay.o HOSTCC scripts/dtc/fdtoverlay.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/fdtoverlay HOSTLD scripts/dtc/dtc HOSTCC scripts/kallsyms HOSTCC scripts/sorttable HOSTCC scripts/asn1_compiler HOSTCC scripts/insert-sys-cert HOSTCC scripts/selinux/genheaders/genheaders HOSTCC scripts/selinux/mdp/mdp CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/devicetable-offsets.s MKELF scripts/mod/elfconfig.h UPD scripts/mod/devicetable-offsets.h HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/sumversion.o HOSTCC scripts/mod/symsearch.o HOSTCC scripts/mod/file2alias.o HOSTLD scripts/mod/modpost MODPOST scripts/mod/Module.symvers Done compiling kernel-headers tools (6.6.87-current-rockchip64). Done compiling kernel-headers tools (6.6.87-current-rockchip64). Armbian 'linux-headers-current-rockchip64' for '6.6.87-current-rockchip64': 'postinst' finishing. sudo cp rk3399-kobol-helios64.dtb /boot/dtb/rockchip/ sudo update-initramfs -u
Dear ebin-dev, the rtl_nic firmware from your link are already in /lib/firmware/rtl_nic - anything I should do? the modified dtb for 6.12 are installed already in march - without any changes. Your suggestion should be to downgrade the kernel, but how can I downgrade from actual kernel 6.12.x to your recommended deb-package 6.6.87 without getting into trouble and how I should disable kernel updates?
Today I did also the hardware fix for the 2.5Gbit Port & I can confirm nothing changed concerning the speed: Helios64 -> client around 200Mbit/s Client -> Helios64 2.35Gbit/s but unstable connection compared to 1Gbit Port, the transfer drops The switch monitoring indicates now 1 error. My Conclusion for 2.5Gbit Port: Not usable at all!
If I transfer from Helios64 2.5Gbit Port to a client 2.5Gbit port I'll got a very slow transfer rate (Helios -> client around 200Mbit/s), vice versa full speed, switch is 2.5Gbit (Rj45 ethernet Cat7 cable).Testet with iperf. The switch monitoring indicates always 2 errors. I know about the Hardware issue of Lan-Port2, but it only effect 1Gbit transfer. Nevertheless in the Network are also mixed with 1Gbit clients. Is there anything I'll can try to get full 2.5Gbit speed?
Hello thank you for your efforts, it's very kind from you! I bought an adapter and a Molex PicoBlade with two red and black wire and soldered that to the adapter. The fan works well, but it's only active if the cpu temperature gets up I think 50 degrees Celsius blue (PWM) to (1) and black (GND) to (2) to the two-pin connector It's safer to change this to Yellow +5V -> fan 5V pin1 (Black - GND -> fan pin2) And the fan wouldn't be active all the time and only if the cpu temperature raises to 50 degrees?
I think the easiest way should be just using an external NVMe-Drive and cloning the USB-drive from a X64-PC/Laptop. The other way could be to flash a different boatloader with UEFI-support, but I couldn't find any stable U-Boot.
