Ravi Terala
  1. What is the best way to report this bug so maintainers can take a look?
  2. I installed an old build and held these packages back. apt update is not breaking the OS. linux-dtb-current-rockchip64/bookworm 24.8.0-trunk.332 arm64 [actualizable desde: 24.8.0-trunk.139] linux-image-current-rockchip64/bookworm 24.8.0-trunk.332 arm64 [actualizable desde: 24.8.0-trunk.139] linux-u-boot-rk3318-box-current/bookworm 24.8.0-trunk.332 arm64 [actualizable desde: 24.8.0-trunk.139] One of these packages must be breaking initramfs.
  3. Hello there, I upgraded the newest kernel (`linux-image-current-rockchip64 arm64 24.8.0-trunk.332`) today. Something went wrong and it is failing to find the rootfs and drops in to initramfs shell. Attached are the update logs and login images. How do I fix this? Thanks apt-update.txt
  4. RK3588 is a very power CPU and is very capable of running desktop loads. Rock5 ITX form factor is excellent for hosting couple of cheap HDD/SSDs in a awesome looking case like RAIJINTEK PAEAN MINI, that's functional and looks awesome. It makes an excellent pair with Joshua Riek's Ubuntu distro for a fully functional desktop + NAS combo. I want to build one!
  5. I guess the board might have been fried. No power shows up on any where.
  6. @Jaybyrd, @Werner I tried the maskrom process and nothing is detected. I tested all the pins using a multimeter and no voltage is detected on any of the pins. Is this board now completely dead? Any way to revive this?
  7. I wasn't using PD, was using the plain old 5V 4A power supply I was using earlier. The board was already powered up with the 5V-4A power supply when I connected the USB-C multi-port dongle. Is there a way to diagnose what went wrong? Is the board totally dead?
  8. My Orange Pi 5 appears to be completely dead. No lights turn on when the power is connected and the SD card is freshly imaged as well. This started happening when I connected a USB-C multi-port dongle with a connected PD power supply to it. Is it possible to revive this?
