WarHawk_AVG
5787 profile views
  1. diagnostics listing of Orange Pi Zero 2W http://ix.io/4Lwr Not sure if this helps..but the stock build is lacking...plus I am getting 1.0 cpu usage at idle Orange Pi 1.0.0 user-built System too busy for benchmarking: 16:33:21 up 25 min, 3 users, load average: 1.15, 1.03, 0.92 System too busy for benchmarking: 16:33:26 up 25 min, 3 users, load average: 1.14, 1.03, 0.92 System too busy for benchmarking: 16:33:31 up 25 min, 3 users, load average: 1.13, 1.03, 0.93 System too busy for benchmarking: 16:33:36 up 25 min, 3 users, load average: 1.12, 1.03, 0.93 System too busy for benchmarking: 16:33:41 up 25 min, 3 users, load average: 1.11, 1.03, 0.93 Wish there was an official Armbian build...it usually seems much more "complete"
  2. I never got a chance to try a self build image...however After updating I decided to give it a whirl...I have a 1TB USB->SSD adapter (yeah, way overkill!!!!), and a 64GB USB drive... The 1TB drive has a 1/2 dozen docker containers running on em (the OPiPC isn't a powerhouse by any stretch...but by golly it's running...and has been running like a BOSS!!!! Thanks Armbian devs!) Gave it a whirl one last time...even did it remotely! (was worried I would bork it and get locked out...but it came right up!) warhawk@orangepipc:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 931.5G 0 disk └─sda1 8:1 0 931.5G 0 part /home/warhawk/hdd sdb 8:16 1 57.6G 0 disk └─sdb1 8:17 1 57.6G 0 part /var/log.hdd / mmcblk0 179:0 0 14.8G 0 disk └─mmcblk0p1 179:1 0 14.7G 0 part /boot /media/mmcboot zram0 254:0 0 499M 0 disk [SWAP] zram1 254:1 0 50M 0 disk /var/log zram2 254:2 0 0B 0 disk [Yeah, I have log2ram and zram-tools installed so it shows the mount point as /var/log.hdd and /] Worked like a boss...it did however blow out the /etc/fstab entry mounting the /dev/sda1 to /home/warhawk/hdd link...but was a VERY easy fix! warhawk@orangepipc:~$ cat /etc/fstab # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=705b28eb-7ba5-481e-ac44-cb93d2cfd612 /media/mmcboot ext4 defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=3c82ef17-f148-4cd5-afb5-efa861ad05ef / btrfs defaults,noatime,commit=600,compress=lzo,x-gvfs-hide 0 2 UUID=7e6a8eab-cf51-4649-9526-dd8adfeb63e4 /home/warhawk/hdd ext4 defaults,noatime,commit=600,x-gvfs-hine 0 0 I even found an older version of geekbench built for older ARM and ran it...nope..not a power house https://browser.geekbench.com/v5/cpu/compare/21830053?baseline=21830053 Even got an ARMv7 version of netdata working in a docker and even though it is a wee bit heavy on system resources, it's running it Odd thing is...the OPiPC has been more resilient than my daggum RPi4B 8GB...for some reason it either locks up or burns out the stupid POE hats I put on it...but the OPiPC keeps chugging! Kudo's to you and the dev team! OUTSTANDING job!!!!!!!! N_A - Geekbench.pdf
  3. I have tried several times to install the SD card root partition to a USB I have plugged in It fails to boot after it says it has completed I run it headless
