Igor Posted April 12, 2016 Posted April 12, 2016 I prepared new kernel based on recent H3 Allwinner code. Code was found here: https://github.com/friendlyarm/h3_lichee than it was cleaned and moved to my repository: https://github.com/igorpecovnik/linux -b sun8i On the top there are additional 100+ patches. I am still working on patches so they are not online yet, but you can try first build and compare to old kernel. Download deb package (dpkg -i linux-image-sun8i_5.07_armhf.deb) Patches regarding thermal, video mode changing and camera are missing. They need further inspection and adjustments. 1
Igor Posted April 13, 2016 Author Posted April 13, 2016 With CMA enabled: http://mirror.igorpecovnik.com/test/CMA-linux-image-sun8i_5.07_armhf.deb Build tools also updated, I have done few tests and encounter no problems. 1
Igor Posted April 13, 2016 Author Posted April 13, 2016 M2+ is OK? I already prepare a download page. What do you think about unresolved patches? - MALI R4 looks like a lot of work - camera is out, we are getting new patch - thermal and videomode - this part is very different in new kernel and again, some more work. BTW, why do we need those pathches?
tkaiser Posted April 13, 2016 Posted April 13, 2016 On 4/13/2016 at 11:36 AM, Igor said: - MALI R4 looks like a lot of work - camera is out, we are getting new patch - thermal and videomode - this part is very different in new kernel and again, some more work. BTW, why do we need those pathches? Mali R4 isn't worth the efforts since we would need at least 4.1 to get OpenGLES acceleration in Chromium which might make a huge difference (not with 4.0 and I have no idea where to get Mali.so 4.1 or above). Regarding camera I hope @lex joins in, integrates sun4i_csi from sun7i, adds phelum's basic patches and then his adjustments on top. Videomode is not interesting any more (just a hack to provide videomodes as part of kernel cmdline in boot.cmd) and thermal patch I even forgot why I (re-)added it. Ah, it was a bugfix since the critical ths trip point was ignored: https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sun8i-default/unresolved/02-0005-h3-thermal.patch#L69 M2+ should just plain work since it's essentially a downclocked Orange Pi Plus/PC. And ATM I refuse to look into WiFi/BT stuff since it's AP6212 and should work with sun7i drivers or we wait until SinoVoip finishes their attemps to get WiFi/BT working (they rely on some BSP code that's completely different! But maybe since their documentation links already to FriendlyARM they simply took the drivers from there that are alreay present in our new sun8i sources?)
Igor Posted April 13, 2016 Author Posted April 13, 2016 OK, thanks for update. Wifi drivers are (almost?) the same as seen on Cubietruck / Banana PRO. But they are not working out of the box since kernel source structure is not exactly the same as on A20. I already try to adjust but failed.
tkaiser Posted April 13, 2016 Posted April 13, 2016 On 4/13/2016 at 12:44 PM, Igor said: Wifi drivers are (almost?) the same as seen on Cubietruck / Banana PRO. But they are not working out of the box since kernel source structure is not exactly the same as on A20. I already try to adjust but failed. Me too. And I didn't want to simply take their last commit since it seems to disable the Orange's 8189 WiFi.
tkaiser Posted April 13, 2016 Posted April 13, 2016 Tested the Banana Pi M2+ desktop image: http://sprunge.us/eAgG h3disp and sun8i-corekeeper.sh are missing (I don't understand why this switch didn't work?) and it seems throttling settings or lets better say thermal readouts differ somewhat (not necessarily higher but they seem to be smoothed somehow). Old kernel: New kernel: So with the old kernel the board would be a little bit faster but that's nothing to be concered of and maybe just a calibration issue (not in the mood to repeat every test 3 times as usual)
Igor Posted April 13, 2016 Author Posted April 13, 2016 Quote h3disp and sun8i-corekeeper.sh are missing (I don't understand why this switch didn't work?) and it seems throttling settings or lets better say thermal readouts differ somewhat (not necessarily higher but they seem to be smoothed somehow). My mistake / disabled in (my) config. I put mine under stress test ... let's wait and see. I hope we get rid of kswap bug, speed decrease, if any, is not an issue.
lampra Posted April 13, 2016 Posted April 13, 2016 I have noticed that when using the Armbian_5.05_Orangepih3_Debian_jessie_3.4.110 on orangepi pc or after updating the kernel from this topic, shutdown -r and reboot does not work, it shuts down the machine. Sometimes init 6 reboots the machine but not always. PS: During the installation of the CMA enabled .deb it complained about not finding the led and after boot, green and red leds are off.
tkaiser Posted April 15, 2016 Posted April 15, 2016 Hmm... maybe we should really remove every bit of code for M2+? They again start to violate the GPL, provide their new kernel release with fixed WiFi drivers only as binary and do not update the sources?
jernej Posted April 20, 2016 Posted April 20, 2016 On 4/13/2016 at 11:36 AM, Igor said: M2+ is OK? I already prepare a download page. What do you think about unresolved patches? - MALI R4 looks like a lot of work - camera is out, we are getting new patch - thermal and videomode - this part is very different in new kernel and again, some more work. BTW, why do we need those pathches? Why would MALI R4 driver need a lot of work? I'm using driver r4p0 from kernel source located in modules/mali and it works without a change. Only thing needed would be a proper section in fex file.
Igor Posted April 20, 2016 Author Posted April 20, 2016 Thanks for the tip. I didn't even notice that's already in the source
jernej Posted April 20, 2016 Posted April 20, 2016 No problem. It is in very inconvenient place. I already considered cloning your repo and putting drivers from modules/ folder in the right place, so separate driver builds would not be needed anymore. Actually, the only other driver worth considering would be NAND driver, but since it is only in binary blob form and not many H3 boards include NAND chips, it can be dropped.
Igor Posted April 20, 2016 Author Posted April 20, 2016 Quote I already considered cloning your repo and putting drivers from modules/ folder in the right place, If you find time, do it. I won't work on this soon.
Igor Posted April 21, 2016 Author Posted April 21, 2016 What about latest R6? https://github.com/dan-and/linux-sunxi/issues/26#issuecomment-212779770 We could also try to update @A20.
jernej Posted April 23, 2016 Posted April 23, 2016 Seems to be a no-go, at least for legal reasons, if not technical.
dony71 Posted May 17, 2016 Posted May 17, 2016 On 4/15/2016 at 6:32 AM, tkaiser said: Hmm... maybe we should really remove every bit of code for M2+? They again start to violate the GPL, provide their new kernel release with fixed WiFi drivers only as binary and do not update the sources? source is there now https://github.com/BPI-SINOVOIP/BPI-M2P-bsp/tree/master/linux-sunxi/drivers/net/wireless/bcmdhd
Igor Posted May 18, 2016 Author Posted May 18, 2016 It was added to our kernel a week ago and update will be pushed out withing days. https://github.com/igorpecovnik/lib/commit/28d4b146092a052c3d5349b796b4872fa9bf4c89
