It is possible to drag backlight control slider to far left position and this completely dims the screen's backlight. This might cause a lot of trouble, if backlight levels get saved by systemd service, as it will persist across reboots and will require you to shine a flashlight on a screen to actually see something and turn backlight back on.
This feature is under development - its low level panel/pwm driver problem. Since development is mainly amateur based and since there are at least three different panels on Pinebooks ... things go slow.
