Jeffrey Walton Posted April 21, 2019 Posted April 21, 2019 I'm using Armbian's Ubuntu Bionic image on a Libre Computer AML-S905X-CC (LePotato). It appears the chromedirver package is not available: Package chromedriver is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'chromedriver' has no installation candidate My use case is, I need to file an online complaint with a regulatory agency. The complaint is filed via a Python script, and Python uses Selenium to operate the web browser and populate the four page form. Please provide chromedriver (Chromium) and geckodriver (Firefox/Iceweasel) for the platform. ----- Note that the web drivers can be tricky on ARM. I've got a working script that uses Python and Selenium on Fedora 29, x86_64. I need to port to low cost ARM hardware. To date I have not been successful with getting things working with Chromium/Chromedriver or Firefox/Geckodriver on ARM. I've even tried to build Geckodriver from Rust/Cargo sources. One of the sore spots in building chromedriver and geckodriver is, the projects use that damn abandonware model. You have to start at Chromium or Firefox provided by the platform, and then use an old version of the driver that matches the web browser. The old version of the driver will be unsupported because they only support bleeding edge, so you have to work around past problems that never got fixed. ----- $ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.04.2 LTS Release: 18.04 Codename: bionic
Igor Posted April 21, 2019 Posted April 21, 2019 8 hours ago, Jeffrey Walton said: Please provide chromedriver (Chromium) and geckodriver (Firefox/Iceweasel) for the platform. If its missing, talk to Ubuntu to pack this for you or do some research if its packed and provided in some non-standard repository. Or just clone and compile:https://github.com/bayandin/chromedriver
Jeffrey Walton Posted April 29, 2019 Author Posted April 29, 2019 On 4/21/2019 at 4:36 AM, Igor said: If its missing, talk to Ubuntu to pack this for you or do some research if its packed and provided in some non-standard repository. Or just clone and compile:https://github.com/bayandin/chromedriver Bugs get reported to the platform provider first.
Igor Posted April 29, 2019 Posted April 29, 2019 2 hours ago, Jeffrey Walton said: Bugs get reported to the platform provider first. You did and I gave you advice what would IMHO be best to do. Please don't expect anyone will invest hours or weeks of their private time to solve a problem you have with a software which has absolutely nothing to do with Armbian. If you can't do it, check perhaps here https://www.debian.org/consultants/ or proceed as advised. Armbian is amateur based. We fix only problems we made and when we find time. Sometimes it takes days, sometimes years. Excerpt from licence under which Armbian is provided:https://github.com/armbian/build/blob/master/LICENSE NO WARRANTY 11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
Jeffrey Walton Posted April 29, 2019 Author Posted April 29, 2019 15 hours ago, Igor said: You did and I gave you advice what would IMHO be best to do. Please don't expect anyone will invest hours or weeks of their private time to solve a problem you have with a software which has absolutely nothing to do with Armbian... Armbian provided the software.
Igor Posted April 30, 2019 Posted April 30, 2019 8 hours ago, Jeffrey Walton said: Armbian provided the software. What you want is perhaps possible with a commercial support contract. But since we are very low on people, this seems unrealistic.
pzw Posted May 6, 2019 Posted May 6, 2019 On 4/29/2019 at 4:35 PM, Jeffrey Walton said: Armbian provided the software Wait.... The tone of your message, and the lack of used words, indicate that you do not get the concept of free open source software. You haven't paid a dime for it but expect, and basically insist judging from your messages, that you get support. I think @Igor was very clear, and friendly, in pointing you in the direction how to solve the issue. If you expect more, find a commercial distribution which runs on your hardware, which has the option to buy commercial support.
sfx2000 Posted May 27, 2019 Posted May 27, 2019 On 4/20/2019 at 5:10 PM, Jeffrey Walton said: 'm using Armbian's Ubuntu Bionic image on a Libre Computer AML-S905X-CC (LePotato). It appears the chromedirver package is not available: It's not available in the Ubuntu AMD64 repos either... As suggested, you'll have to sync up to the git src and build it yourself (or find a local freelancer if needed) - as this project chases a moving bus with dependencies on the version of Chrome itself (which is constantly changing), this would be a bit maintenance intensive...
Dliryc Posted August 10, 2020 Posted August 10, 2020 (edited) Hello, So it's possible to develop selenium for Armbian if we pay someone skilled enough for ? I mean it's technically possible to do it ? Just asking, because I really need it. But no idea which price it could be. I know it works on raspeberry pi. Or did someone make geckodriver work ? Thanks. Edited August 10, 2020 by Dliryc
