SecureXperts Posted April 22, 2019 Posted April 22, 2019 I have the following hat http://wiki.seeedstudio.com/Raspberry_Pi_Relay_Board_v1.0 my image detects the i2c interfaces and mounts them in /dev as i2c-0 i2c-1 i2c-3 i2c-4, I can scan the different i2c interfaces as folloging interface i2cdetect -y 1 root@rockpi:~# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: UU 11 -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- I have set 0x20 address on my relay Board but cannot see the interface. Has anyone a hint what configuration settings i need to change Many Thanks Roman
pavelectric Posted April 22, 2019 Posted April 22, 2019 1 minute ago, SecureXperts said: root@rockpi:~# i2cdetect -y 1 So check on the other bus ... root@rockpi:~# i2cdetect -y 2
SecureXperts Posted April 22, 2019 Author Posted April 22, 2019 2 minutes ago, pavelectric said: So check on the other bus ... root@rockpi:~# i2cdetect -y 2 Hi pavelectric The /dev/i2c-2 is not available on my Image. Do in need to load some Kernel modules for that? Thanks
martinayotte Posted April 22, 2019 Posted April 22, 2019 31 minutes ago, SecureXperts said: my image detects the i2c interfaces The I2C present on Header pins 3 and 5 is the I2C7. To get I2C7 appearing as /dev/i2c-7, it requires to load the rockchip-i2c7.dtbo overlay which is present in /boot/dtb/rockchip/overlay. To do that, add the "overlays=i2c-7" into the /boot/armbianEnv.txt and reboot.
SecureXperts Posted April 23, 2019 Author Posted April 23, 2019 10 hours ago, martinayotte said: The I2C present on Header pins 3 and 5 is the I2C7. To get I2C7 appearing as /dev/i2c-7, it requires to load the rockchip-i2c7.dtbo overlay which is present in /boot/dtb/rockchip/overlay. To do that, add the "overlays=i2c-7" into the /boot/armbianEnv.txt and reboot. Hi martinayotte, thanks a lot for your input. Indeed i2c7 was not loaded. ;-) To add this overlay the good command is overlays=i2c7 without dash. Now all my HATs communicating over this bus is working like a charm!
