webbbn Posted April 26, 2019 Posted April 26, 2019 I am trying to get composite video fully working on an Orange Pi Zero Plus 2. I installed the legacy kernel image, and I've been able to turn on composite out, but I just get a blank screen on boot and there is no /dev/fb0. Is there anything else I have to do to enable the framebuffer. This is the (I believe) relevant portions of the script.fex file: [boot_disp] advert_disp = 0 auto_hpd = 1 output_type = 4 hdmi_channel = 0 hdmi_mode = 4 cvbs_channel = 1 cvbs_mode = 11 output_full = 1 hdmi_mode_check = 1 [disp_init] disp_init = 1 disp_mode = 1 screen0_output_type = 3 screen0_output_mode = 5 screen1_output_type = 2 screen1_output_mode = 14 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 1 fb1_framebuffer_num = 2 fb1_format = 10 fb1_pixel_sequence = 0 fb1_scaler_mode_enable = 1 [hdmi_para] hdmi_used = 0 hdpc_enable = 0 [tv_para] tv_used = 1 tv_dac_used = 1 tv_dac_src0 = 0 these are some possible relevant lines from boot. [ 0.000000] Kernel command line: root=UUID=ab03f9a3-0ba3-4236-8857-33f3229b7a85 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 monitor=composite-ntsc panic=10 consoleblank=0 loglevel=1 ubootpart=75ceecdb-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=96M cgroup_enable=memory swapaccount=1 [ 0.614087] [DISP]disp_module_init [ 0.614413] cmdline,init_disp= [ 0.614448] cmdline,disp= [ 0.615200] [DISP]disp_module_init finish [ 1.029299] cmdline,disp= [ 1.029629] [DISP] disp_init_tv,line:539:screen 0 do not support TV TYPE! [ 1.029647] [DISP] bsp_disp_tv_register,line:998:'ptv is null [ 1.029710] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr1<-->device1, type=2, mode=14
webbbn Posted April 26, 2019 Author Posted April 26, 2019 I should add that this is the H3 version of the board.
webbbn Posted April 27, 2019 Author Posted April 27, 2019 I finally got it working. I don't know what the problem was, but I switched back to the default config and started from there again. This is a diff between the original script.fex and the one that enables composite video out: 314c314 < disp_mode = 1 --- > disp_mode = 0 317,318c317,318 < screen1_output_type = 2 < screen1_output_mode = 14 --- > screen1_output_type = 3 > screen1_output_mode = 5 327c327 < hdmi_used = 0 --- > hdmi_used = 1 331c331 < tv_used = 1 --- > tv_used = 0 419c419 < tvout_used = 1 --- > tvout_used = 0
Igor Posted April 28, 2019 Posted April 28, 2019 14 hours ago, webbbn said: This is a diff between the original script.fex and the one that enables composite video out: If you care that this is not lost, send file with a name orangepizeroplus2-h3-tvout.fex here https://github.com/armbian/build/tree/master/config/fex
