Maybe I missed something, it's been a few weeks since I needed to install an image.  cubox with hdmi does not boot.  There is no serial port, so I can not even try to figure it out.  Also it never requests an ip address from the router.  Tried with trusty legacy and vanilla.  Used the link specifically labeled cubox-i  http://www.armbian.com/cubox-i/
You don't get anything at boot? Stock u-boot, which we use, prompts Solidrun logo. If you got nothing, than this means uboot is not loaded. We are doing major images rebuild very soon and I'll double check if problem is on our side.
btw. my Cubox has serial port - via micro usb. Isn't this default on all?
I'm also having trouble with the latest image on my Cubox-i4pro. My
Cubox is booting, but it can't output 1920x1080 on HDMI on my 1080p
display. I can adjust the bootcmd to output 1366x768. This works OK.
The network and wifi come up just fine. The display also works
perfectly fine on another computer.
Anyone else having similar issues?
This is a first gen cubox, half did not have a serial port. I would need a pinout to connect to what might be a serial port.  I could not find an archive image from months/years ago to try.
And yes, nothing at all, no hdmi signal.
Discovered it already had a serial device built-in.  What a nifty device.
elcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb  7 2016, 13:37:27.
Port /dev/ttyUSB1, 21:04:50
Press CTRL-A Z for help on special keys
T T CuBox
 ** LOADER **
U-Boot 2009.08 (Sep 20 2012 - 02:30:22) Marvell version: 5.4.4 NQ SR1
BootROM:
       Version on chip: 2.33
       Status: OK
       Retries #: 0
Board: CuBox
SoC:   88AP510 (A1)
CPU:   Marvell Sheeva (Rev 5)
       CPU @ 800Mhz, L2 @ 400Mhz
       DDR3 @ 400Mhz, TClock @ 166Mhz
PEX 0: interface detected no Link.
PEX 1: interface detected no Link.
DRAM:   1 GB
       CS 0: base 0x00000000 size 512 MB
       CS 1: base 0x20000000 size 512 MB
       Addresses 60M - 0M are saved for the U-Boot usage.
SF: Detected M25P32 with page size 64 kB, total  4 MB
Streaming disabled
L2 Cache Prefetch disabled
L2 Cache ECC disabled
Modifying CPU/CORE/DDR power rails to 1.0(-2.5%) / 1.0(-5%) / 1.5(-5%)
USB 0: Host Mode
USB 1: Host Mode
Setting VPU power OFF.
Setting GPU power ON.
MMC:   MV_SDHCI: 0, MV_SDHCI: 1
Net:   egiga0 [PRIME]
Hit any key to stop autoboot:  0
===> Executing ext4load usb 0:1 0x02000000 /boot.scr
(Re)start USB...
USB:   Register 10011 NbrPorts 1
USB EHCI 1.00
scanning bus for devices... 2 USB Device(s) found
Waiting for storage device(s) to settle before scanning...
       scanning bus for storage devices... 0 Storage Device(s) found
** Bad partition 1 **
===> Executing ext4load usb 1:1 0x02000000 /boot.scr
===> Executing fatload usb 0:1 0x02000000 /boot.scr
** Can't read from device 0 **
** Unable to use usb 0:1 for fatload **
===> Executing fatload usb 1:1 0x02000000 /boot.scr
** Can't read from device 1 **
** Unable to use usb 1:1 for fatload **
===> Executing ext4load usb 0:1 0x02000000 /boot/boot.scr
===> Executing ext4load usb 1:1 0x02000000 /boot/boot.scr
===> Executing fatload usb 0:1 0x02000000 /boot/boot.scr
===> Executing fatload usb 1:1 0x02000000 /boot/boot.scr
===> Executing ext4load usb 0:2 0x02000000 /boot.scr
** Bad partition 2 **
===> Executing ext4load usb 1:2 0x02000000 /boot.scr
===> Executing fatload usb 0:2 0x02000000 /boot.scr
** Unable to use usb 0:2 for fatload **
===> Executing fatload usb 1:2 0x02000000 /boot.scr
** Unable to use usb 1:2 for fatload **
===> Executing ext4load usb 0:2 0x02000000 /boot/boot.scr
===> Executing ext4load usb 1:2 0x02000000 /boot/boot.scr
===> Executing fatload usb 0:2 0x02000000 /boot/boot.scr
===> Executing fatload usb 1:2 0x02000000 /boot/boot.scr
===> Executing ext4load mmc 0:1 0x02000000 /boot.scr
Device: MV_SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 31914983424
Bus Width: 4-bit
Loading file "/boot.scr" from mmc device 0:1 mmcda1
** File not found /boot.scr
===> Executing fatload mmc 0:1 0x02000000 /boot.scr
reading /boot.scr
** Unable to read "/boot.scr" from mmc 0:1 **
===> Executing ext4load mmc 0:1 0x02000000 /boot/boot.scr
Loading file "/boot/boot.scr" from mmc device 0:1 mmcda1
747 bytes read
## Executing script at 02000000
## Error: "autodetectfdt" not defined
** No boot file defined **
usage: fatload <interface> <dev[:part]> <addr> <filename> [bytes]
Loading file "/boot/zImage" from mmc device 0:1 (mmcda1)
** File not found /boot/zImage
reading zImage
** Unable to read "zImage" from mmc 0:1 **
Loading file "zImage" from mmc device 0:1 mmcda1
** File not found zImage
Unknown command 'bootz' - try 'help'
===> Executing fatload mmc 0:1 0x02000000 /boot/boot.scr
reading /boot/boot.scr
** Unable to read "/boot/boot.scr" from mmc 0:1 **
===> Executing ext4load mmc 0:2 0x02000000 /boot.scr
===> Executing fatload mmc 0:2 0x02000000 /boot.scr
** Partition 2 not valid on device 0 **
** Unable to use mmc 0:2 for fatload **
===> Executing ext4load mmc 0:2 0x02000000 /boot/boot.scr
===> Executing fatload mmc 0:2 0x02000000 /boot/boot.scr
===> Executing ext4load ide 0:1 0x02000000 /boot.scr
Reset IDE:
Marvell Serial ATA Adapter
Integrated Sata device found
===> Executing fatload ide 0:1 0x02000000 /boot.scr
Error No HD connection
** Unable to use ide 0:1 for fatload **
===> Executing ext4load ide 0:1 0x02000000 /boot/boot.scr
===> Executing fatload ide 0:1 0x02000000 /boot/boot.scr
===> Executing ext4load ide 0:2 0x02000000 /boot.scr
===> Executing fatload ide 0:2 0x02000000 /boot.scr
** Unable to use ide 0:2 for fatload **
===> Executing ext4load ide 0:2 0x02000000 /boot/boot.scr
===> Executing fatload ide 0:2 0x02000000 /boot/boot.scr
Using egiga0 device
TFTP from server 192.168.15.100; our IP address is 192.168.15.223
Filename 'boot.scr'.
Load address: 0x2000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
Using egiga0 device
Loading: T T T T T
Ahaa, you are using old 1st generation Marvel based Cubox. This won't work, sorry ... we cover only Freescale imx6 based models. I don't have any of those boards. Perhaps you could try to build mainline uboot with kernel 4.4+ for this? No idea if it's supported.
For anyone who searches this thread.   Here is the most up to date bootable image I could find.
uname -a
Linux alarm 3.5.7-14-ARCH #1 PREEMPT Mon Jun 30 13:06:45 MDT 2014 armv7l GNU/Linux
https://archlinuxarm.org/about/downloads
Here is the only ubuntu I could find.  I would not recommend as it is no longer supported.
https://www.solid-run.com/download/pub/solidrun/cubox/distros/ubuntu/cubox-ubuntu-core-12.10-core-armhf-r1.tar.xz
uname -a
digging out this old thread  for anyone who will use the frist generation CuBox (Armada 510 CPU)-  like I found my today in a old box :)
Here is something newer than the 3.5.7 above:
https://docs.kali.org/kali-on-arm/install-kali-arm-on-a-cubox
https://images.offensive-security.com/arm-images/kali-2017.3-cubox.img.xz
Linux kali 3.6.9 #1 PREEMPT Wed Nov 15 13:40:13 CST 2017 armv7l GNU/Linux
or GeexBox (Kodi 16.1 compiled in Dec 2017) for CuBox:
http://download.geexbox.org/snapshots/geexbox-kodi-armada5xx-cubox/
http://download.geexbox.org/snapshots/geexbox-kodi-armada5xx-cubox/20171202/binaries.cubox/geexbox-devel-20171202-r8599994.cubox.img.xz
