0
Icenowy
Orange Pi PC2 image has pre-generated SSH host key
Recently I borrowed my Orange Pi PC2 to a friend, and he fails to set up SSH connection w/ it.
After debugging w/ HDMI monitor, I found ssh_host_ecdsa_key, ssh_host_ed25519_key and ssh_host_rsa_key are preloaded to the Orange Pi PC2 image, which prevented SSH from working.
Even if it doesn't prevent working of SSHD, it's also a severe security hole -- that means all Armbian installation with the same image will uses the same host key and they're vulnerable to MITM attack.
I think these files should be purged when generating image, and regenerated when first powerup. It's what AOSC OS images do.
Share this post
Link to post
Share on other sites
But they are (should be) regenerated. https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-firstrun#L61-L67
I'll check if we made some bug ... Thanks.
Until you don't login to the system, security hole (root/1234) is wide open, but still better than setting fixed password or automated login.
Share this post
Link to post
0
