Good evening,
as uboot doesn't get updated automatically since a few versions back, I ran the uboot install script manually today - so far everything worked, uboot got copied to the boot sector.
After rebooting though it seems that uboot is not working / properly compiled. It runs normally until the point where it would boot linux, then stops saying it can't find the various commands (bootz, help, echo etc).
It dropped me to the uboot shell. I tried a few commands (help, reset etc) and all just gave a "command not found" failure.
After restoring the 5.75 uboot from some backup it works again.
Is there some known problem in the current uboot? Otherwise we should probably tell users not to upgrade atm.
I will provide uboot serial output tomorrow, no time today.
Greetings,
count-doku
To prevent such problems.
It seem broken. No idea what is wrong  ....
No need. I just remove it from the repository. (rebuilding will take several minutes)
Ok I suspected that, and I was not criticizing it. It is a good solution. Just wanted to explain why I even updated ;)
Will it help if I do some test (different versions) and post logs?
Great. I assume if you remove latest version the old 5.75 will be available still?
I saw logs but time is the critical component.
Yes.
