Wifi lb-link model: wn155a "MTK7601 chipset" driver (150Mbps)
Go to solution Solved by Igor,
After connecting the wireless adapter we run the following command:
lsusb
the output is
Bus 004 Device 003: ID 148f:7601 Ralink Technology, Corp.
Trying to install armbian driver  (Linux nanopim1 3.4.113-sun8i #18 SMP PREEMPT  armv7l GNU/Linux) for lb-link model: wn155a "MTK7601 chipset" wireless adapter (150Mbps) using the following commands:
sudo apt-get install linux-headers-generic build-essential git
sudo apt-get install git
git clone https://github.com/flexiti/mt7601.git
cd mt7601
make clean
make
sudo make install
sudo mkdir -p /etc/Wireless/RT2870STA/
sudo cp RT2870STA.dat /etc/Wireless/RT2870STA/
sudo modprobe mt7601Usta
the output of the last command is
modprobe: ERROR: could not insert 'mt7601Usta': Exec format error
what should we do?
is MT7601U the same as MTK7601? or do we need another driver?
  • Solution
wrong. this way
https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver
what should we do?
This module works on kernel 4.19.y ... Better use that one. You can also try with hints from this script https://github.com/armbian/build/blob/sunxi-4.18/packages/extras/mt7601.sh
