thanh_tan Posted June 24, 2019 Posted June 24, 2019 Armbianmonitor: http://ix.io/1MF4 Hello, I just use the Zero Plus 2 H3 with extension, using Armbian 5.83 but failed to get the combo to play the sound I use the command aplay -l but return no sound card found How to install driver for sound in this board?
MacBreaker Posted June 24, 2019 Posted June 24, 2019 Try... armbian-config -> System -> Hardware and select "analog-codec" After a reboot, it should work. Markus
