Mathias Posted July 3, 2019 Posted July 3, 2019 Hi! On my RockPro64, I usually run Armbian with Ayufan's 5.1 kernel (it runs very well and after manually compiling the dtb file most of the error messages at startup are gone). I've tried a few days ago to run Armbian's dev kernel (5.0), and both the sdcard and my usb3 attached ssd could not be detected. The network was also missing. I have pasted the output of armbianmonitor -U here. Mathias
Igor Posted July 3, 2019 Posted July 3, 2019 On 7/3/2019 at 11:34 AM, Mathias said: I usually run Armbian with Ayufan's 5.1 kernel Expand Ours is the same, just stable repository is not updated since this is expensive manual work and kernel is not worth that troubles. Change to auto made beta repository and it should be pretty much the same support as from Ayufan.
