Younes_Thabet Posted July 18, 2019 Posted July 18, 2019 I have orange pi one with Armbian Xenial desktop legacy kernel 3.4.y which have a script.bin file in /boot directory and doesn't have /boot/dtb directory ...but when i installed Armbian Bionic mainline based kernel 4.19.y, I found the .dtb files but not the script.bin ....now i don't know how to configure both touch screen and the pwm pin! is the .dtb file (sun8i-h3-orangepi-one.dtb) is the same as script.bin or orangepione.bin ? if so, how to configure it? because i am used to convert the script.bin to .fex to configure it and then back to .bin.
martinayotte Posted July 18, 2019 Posted July 18, 2019 This is one of the major differences between Legacy and Mainline images. There is no way to convert between both !
Younes_Thabet Posted July 18, 2019 Author Posted July 18, 2019 On 7/18/2019 at 2:57 PM, martinayotte said: This is one of the major differences between Legacy and Mainline images. Expand thank you for the answer, sir. I want to remap the uart0 to be pwm on the PA05 according to https://github.com/iboguslavsky/pwm-sunxi-opi0 , i used to do this using script.bin in /boot...now i don't know how to do that!? could you please show me the file to configure pwm?
jernej Posted July 18, 2019 Posted July 18, 2019 On 7/18/2019 at 2:29 PM, Younes_Thabet said: is the .dtb file (sun8i-h3-orangepi-one.dtb) is the same as script.bin or orangepione.bin ? Expand They are different solutions for the same problem, so no, they are not the same. script.bin is Allwinner invention, whereas DTs is universal way in Linux for multiple platforms. On 7/18/2019 at 2:29 PM, Younes_Thabet said: if so, how to configure it? because i am used to convert the script.bin to .fex to configure it and then back to .bin. Expand You can use same workflow for dtb too, just with different tools and different syntax. However, it's easier to use DT overlays. I'm not the right person to ask questions about DT overlays, but I'm sure you can find enough info in Armbian documentation and forum.
martinayotte Posted July 18, 2019 Posted July 18, 2019 On 7/18/2019 at 3:29 PM, Younes_Thabet said: pwm on the PA05 according Expand There is already an DT overlay present in Armbian build, check here : /boot/dtb/overlay/sun8i-h3-pwm.dtbo To activate it, you need to edit /boot/armbianEnv.txt and add a line with "overlays=pwm", save and reboot ... More info here : https://docs.armbian.com/User-Guide_Allwinner_overlays/ and here : /boot/dtb/overlay/README.sun8i-h3-overlays
Younes_Thabet Posted July 18, 2019 Author Posted July 18, 2019 thanks again for the quick answer @martinayotte, i see from your answer that i don't need to modify a .dtb file but just add lines to armbianEnv.txt ... so i did add the "overlays=pwm" to armbianEnv and rebooted but when i use the PA05 pin i got a noisy signal, maybe i need to disactivate uart0 first, idk! I sure need to read more about overlays.
martinayotte Posted July 18, 2019 Posted July 18, 2019 On 7/18/2019 at 4:31 PM, Younes_Thabet said: so i did add the "overlays=pwm" to armbianEnv and rebooted but when i use the PA05 pin i got a noisy signal, maybe i need to disactivate uart0 first, idk! Expand Strange ... I didn't tried myself, but in the /boot/dtb/overlay/README.sun8i-h3-overlays, it is mentioned the following : Quote ### pwm Activates hardware PWM controller PWM pin: PA5 Pin PA5 is used as UART0 RX by default, so if this overlay is activated, UART0 and kernel console on ttyS0 will be disabled Expand When you said "noisy signal", did you attached a scope on it ? Did you do the following to provide settings or to show existing settings ? echo 0 > /sys/class/pwm/pwmchip0/export ll /sys/class/pwm/pwmchip0/pwm0/ cat /sys/class/pwm/pwmchip0/pwm0/duty_cycle
Younes_Thabet Posted July 21, 2019 Author Posted July 21, 2019 Yes, i used the oscilloscope to see the signal... it was working all the time i just had a bad connectivity that's all.. Thank you sir for your support.
