Ununtu 14.04 in a VirtualBox VM
Latestes Armbian
./compile.sh BOARD=orangepiplus KERNEL_ONLY=no PROGRESS_DISPLAY=plain RELEASE=wheezy KERNEL_CONFIGURE=yes KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=no BUILD_DESKTOP=no
[ o.k. ] Installing packages for [ Armbian ]
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package f3
[ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:245 ]
[ error ] Installation of Armbian packages failed
[ o.k. ] Process terminated
[ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:539 ]
[ error ] debootstrap-ng was interrupted
make: *** [all] Error 255
What am I actually missing ?
I used to be able to build prior to 5.10
Anyway to pull a prior version ? Are they tagged or branched using git ?
Still not working for me. Below is the current error Armbian 5.11 building for a cubox-i Though I get the same for an OrangePiPlus
[ o.k. ] Creating board support package [ cubox-i ]
[ o.k. ] Fingerprinting [ Armbian 5.11 Cubox-i Debian wheezy default Linux ]
[ o.k. ] Building package [ linux-wheezy-root-cubox-i ]
[ o.k. ] Starting build process for [ cubox-i wheezy ]
[ o.k. ] Extracting wheezy-ng-armhf.dbd...9ec.tgz [ 0 days old ]
wheezy-ng-armhf.dbd...9ec.tgz: 51.2MB [11.9MB/s] [=========================================================================================>] 100%
mount: mount point /usr/src/amp/output/cache/sdcard/proc does not exist
mount: mount point /usr/src/amp/output/cache/sdcard/sys does not exist
mount: mount point /usr/src/amp/output/cache/sdcard/dev does not exist
mount: mount point /usr/src/amp/output/cache/sdcard/dev/pts does not exist
[ o.k. ] Applying distribution specific tweaks for [ wheezy ]
/usr/src/amp/lib/distributions.sh: line 23: /usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/71-no-recommends: No such file or directory
cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/50unattended-upgrades’: No such file or directory
cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/02periodic’: No such file or directory
sed: can't read /usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/50unattended-upgrades: No such file or directory
chroot: failed to run command ‘/bin/bash’: No such file or directory
rm: cannot remove ‘/usr/src/amp/output/cache/sdcard/tmp/ramlog_2.0.0_all.deb’: Not a directory
sed: can't read /usr/src/amp/output/cache/sdcard/etc/default/ramlog: No such file or directory
sed: can't read /usr/src/amp/output/cache/sdcard/etc/init.d/rsyslog: No such file or directory
sed: can't read /usr/src/amp/output/cache/sdcard/etc/default/console-setup: No such file or directory
touch: cannot touch ‘/usr/src/amp/output/cache/sdcard/root/.not_logged_in_yet’: No such file or directory
cp: failed to access ‘/usr/src/amp/output/cache/sdcard/tmp/’: Not a directory
[ o.k. ] Installing packages [ linux-image-cubox ]
/usr/src/amp/lib/boards.sh: line 186: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory
/usr/src/amp/lib/boards.sh: line 187: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory
/usr/src/amp/lib/boards.sh: line 188: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory
/usr/src/amp/lib/boards.sh: line 189: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory
rm: cannot remove ‘/usr/src/amp/output/cache/sdcard/etc/resolv.conf’: No such file or directory
cp: target ‘/usr/src/amp/output/cache/sdcard/etc/network/’ is not a directory
ln: failed to create symbolic link ‘/usr/src/amp/output/cache/sdcard/etc/network/interfaces’: No such file or directory
mount: mount point /usr/src/amp/output/cache/sdcard/tmp is not a directory
[ o.k. ] Installing u-boot [ linux-u-boot-cubox-i ]
[ o.k. ] Installing headers [ linux-headers-cubox ]
cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/boot/boot.bmp’: No such file or directory
checkdir:  cannot create extraction directory: /usr/src/amp/output/cache/sdcard/lib/firmware
sed: can't read /usr/src/amp/output/cache/sdcard/etc/lirc/hardware.conf: No such file or directory
cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/etc/lirc/lircd.conf’: No such file or directory
cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/usr/local/bin/brcm_patchram_plus’: No such file or directory
[ o.k. ] Install board support package [ cubox-i ]
[ o.k. ] Creating boot scripts [ cubox-i ]
cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/boot/boot.cmd’: No such file or directory
umount: /usr/src/amp/output/cache/sdcard/tmp: not mounted
[ o.k. ] Installing extra applications and drivers
[ o.k. ] Building deb [ hostapd ]
[ o.k. ] Downloading sources [ hostapd ]
/usr/src/amp/lib/extras/hostapd.sh: line 103: cd: /usr/src/amp/output/cache/sdcard/tmp/hostap: Not a directory
cat: /usr/src/amp/output/cache/sdcard/tmp/hostap/src/common/version.h: Not a directory
[ o.k. ] Compiling [ v ]
cp: failed to access ‘/usr/src/amp/output/cache/sdcard/tmp/hostap/src/drivers/’: Not a directory
cp: failed to access ‘/usr/src/amp/output/cache/sdcard/tmp/hostap/hostapd/.config’: Not a directory
cat: /usr/src/amp/output/cache/sdcard/tmp/hostap/hostapd/main.c: Not a directory
[ error ] Not built [ hostapd ]
[ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:516 ]
Still no go.
Running in an Ubuntu 14.04 VM
This worked under something like 5.07
Free space on VM after failure
Filesystem     1K-blocks    Used Available Use% Mounted on
udev              368144       4    368140   1% /dev
tmpfs              75884     476     75408   1% /run
/dev/sda1        7350760 4841688   2112632  70% /
none                   4       0         4   0% /sys/fs/cgroup
none                5120       0      5120   0% /run/lock
none              379400       0    379400   0% /run/shm
none              102400       0    102400   0% /run/user
Command Line
./compile.sh BOARD=cubox-i KERNEL_ONLY=no PROGRESS_DISPLAY=plain RELEASE=wheezy KERNEL_CONFIGURE=yes KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=no BUILD_DESKTOP=no BRANCH=default EXTERNAL=no
Package acpid is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package rfkill is not available, but is referred to by another package.
Package libbluetooth3 is not available, but is referred to by another package.
Package bash-completion is not available, but is referred to by another package.
However the following packages replace it:
  bash
Package bluez is not available, but is referred to by another package.
Package psmisc is not available, but is referred to by another package.
Package lsof is not available, but is referred to by another package.
Package bc is not available, but is referred to by another package.
Package ca-certificates is not available, but is referred to by another package.
Package pkg-config is not available, but is referred to by another package.
Package build-essential is not available, but is referred to by another package.
Package parted is not available, but is referred to by another package.
Package cmake is not available, but is referred to by another package.
Package vim is not available, but is referred to by another package.
Package makedev is not available, but is referred to by another package.
Package bridge-utils is not available, but is referred to by another package.
Package less is not available, but is referred to by another package.
Package rsync is not available, but is referred to by another package.
Package fping is not available, but is referred to by another package.
Package initramfs-tools is not available, but is referred to by another package.
Package libtool is not available, but is referred to by another package.
Package hdparm is not available, but is referred to by another package.
Package ncurses-term is not available, but is referred to by another package.
Package automake is not available, but is referred to by another package.
Package dosfstools is not available, but is referred to by another package.
Package fake-hwclock is not available, but is referred to by another package.
Package dialog is not available, but is referred to by another package.
Package console-common is not available, but is referred to by another package.
Package console-setup is not available, but is referred to by another package.
Package usbutils is not available, but is referred to by another package.
Package pciutils is not available, but is referred to by another package.
Package kbd is not available, but is referred to by another package.
E: Package 'automake' has no installation candidate
E: Package 'bash-completion' has no installation candidate
E: Package 'bc' has no installation candidate
E: Package 'bridge-utils' has no installation candidate
E: Package 'build-essential' has no installation candidate
E: Package 'cmake' has no installation candidate
E: Unable to locate package cpufrequtils
E: Unable to locate package device-tree-compiler
E: Package 'dosfstools' has no installation candidate
E: Unable to locate package figlet
E: Unable to locate package fbset
E: Package 'fping' has no installation candidate
E: Unable to locate package haveged
E: Package 'hdparm' has no installation candidate
E: Unable to locate package ifenslave-2.6
E: Couldn't find any package by regex 'ifenslave-2.6'
E: Unable to locate package iw
E: Package 'libtool' has no installation candidate
E: Unable to locate package libwrap0-dev
E: Unable to locate package lirc
E: Package 'lsof' has no installation candidate
E: Package 'fake-hwclock' has no installation candidate
E: Unable to locate package libusb-dev
E: Package 'psmisc' has no installation candidate
E: Package 'parted' has no installation candidate
E: Package 'pkg-config' has no installation candidate
E: Unable to locate package pv
E: Package 'rfkill' has no installation candidate
E: Package 'rsync' has no installation candidate
E: Package 'dialog' has no installation candidate
E: Unable to locate package crda
E: Unable to locate package wireless-regdb
E: Package 'ncurses-term' has no installation candidate
E: Unable to locate package sysfsutils
E: Unable to locate package toilet
E: Unable to locate package u-boot-tools
E: Package 'usbutils' has no installation candidate
E: Unable to locate package vlan
E: Unable to locate package wireless-tools
E: Unable to locate package libnl-3-dev
E: Package 'console-setup' has no installation candidate
E: Unable to locate package console-data
E: Package 'console-common' has no installation candidate
E: Unable to locate package unicode-data
E: Unable to locate package libmtp-runtime
E: Package 'initramfs-tools' has no installation candidate
E: Package 'ca-certificates' has no installation candidate
E: Package 'less' has no installation candidate
E: Package 'makedev' has no installation candidate
E: Package 'kbd' has no installation candidate
E: Package 'acpid' has no installation candidate
E: Unable to locate package libnl-genl-3-dev
E: Unable to locate package alsa-utils
E: Unable to locate package btrfs-tools
E: Package 'bluez' has no installation candidate
E: Unable to locate package hddtemp
E: Unable to locate package i2c-tools
E: Unable to locate package iperf
E: Unable to locate package ir-keytable
E: Unable to locate package iotop
E: Unable to locate package iozone3
E: Unable to locate package weather-util
E: Unable to locate package weather-util-data
E: Unable to locate package stress
E: Unable to locate package dvb-apps
E: Unable to locate package sysbench
E: Unable to locate package libbluetooth-dev
E: Package 'libbluetooth3' has no installation candidate
E: Package 'vim' has no installation candidate
E: Package 'pciutils' has no installation candidate
E: Unable to locate package evtest
E: Unable to locate package htop
E: Unable to locate package mtp-tools
E: Unable to locate package python-smbus
E: Unable to locate package libproc-processtable-perl
E: Unable to locate package w-scan
[ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:225 ]
Still it is a problem with downloading package lists. In case this is caused by apt-cacher-ng or debian mirror selection I'll add options to bypass apt-cacher-ng and to use preselected mirror for debootstrap process later.
If you can point me in the general direction I can look at that my self.
While I have not delved very deep in Armbian yet, I am capable of dealing with scripts and embedded development.
Thank you.
One of those two changes appears to have solved my problem.
Additionally
With the following change to a lxc linux container profile, I was able to build Armbian for a cubox-i under Debian Jessie in an ubuntu 14.04 lxc container.
That is alot easier and less taxing of the computer than a virtual box VM.
lxc.aa_profile = unconfined
lxc.cgroup.devices.allow = b 7:* rwm
lxc.cgroup.devices.allow = c 10:237 rwm
I failed, too.
Ubuntu 16.04 VM
