dhlii Posted May 1, 2016 Posted May 1, 2016 Ununtu 14.04 in a VirtualBox VM Latestes Armbian ./compile.sh BOARD=orangepiplus KERNEL_ONLY=no PROGRESS_DISPLAY=plain RELEASE=wheezy KERNEL_CONFIGURE=yes KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=no BUILD_DESKTOP=no ..... [ o.k. ] Installing packages for [ Armbian ] Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package f3 [ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:245 ] [ error ] Installation of Armbian packages failed [ o.k. ] Process terminated [ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:539 ] [ error ] debootstrap-ng was interrupted [ o.k. ] Process terminated make: *** [all] Error 255 What am I actually missing ? I used to be able to build prior to 5.10 Anyway to pull a prior version ? Are they tagged or branched using git ?
zador.blood.stained Posted May 1, 2016 Posted May 1, 2016 @dhlii It must be a random error due to local mirror chosen by httpredir.debian.org or due to packages list download failing, it should work (Edit: tested and it does work) even without Igor's fix.
dhlii Posted May 2, 2016 Author Posted May 2, 2016 Still not working for me. Below is the current error Armbian 5.11 building for a cubox-i Though I get the same for an OrangePiPlus [ o.k. ] Creating board support package [ cubox-i ] [ o.k. ] Fingerprinting [ Armbian 5.11 Cubox-i Debian wheezy default Linux ] [ o.k. ] Building package [ linux-wheezy-root-cubox-i ] [ o.k. ] Starting build process for [ cubox-i wheezy ] [ o.k. ] Extracting wheezy-ng-armhf.dbd...9ec.tgz [ 0 days old ] wheezy-ng-armhf.dbd...9ec.tgz: 51.2MB [11.9MB/s] [=========================================================================================>] 100% mount: mount point /usr/src/amp/output/cache/sdcard/proc does not exist mount: mount point /usr/src/amp/output/cache/sdcard/sys does not exist mount: mount point /usr/src/amp/output/cache/sdcard/dev does not exist mount: mount point /usr/src/amp/output/cache/sdcard/dev does not exist mount: mount point /usr/src/amp/output/cache/sdcard/dev/pts does not exist [ o.k. ] Applying distribution specific tweaks for [ wheezy ] /usr/src/amp/lib/distributions.sh: line 23: /usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/71-no-recommends: No such file or directory cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/50unattended-upgrades’: No such file or directory cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/02periodic’: No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/50unattended-upgrades: No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/apt/apt.conf.d/50unattended-upgrades: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory rm: cannot remove ‘/usr/src/amp/output/cache/sdcard/tmp/ramlog_2.0.0_all.deb’: Not a directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/default/ramlog: No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/init.d/rsyslog: No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/init.d/rsyslog: No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/default/console-setup: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory touch: cannot touch ‘/usr/src/amp/output/cache/sdcard/root/.not_logged_in_yet’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory cp: failed to access ‘/usr/src/amp/output/cache/sdcard/tmp/’: Not a directory chroot: failed to run command ‘/bin/bash’: No such file or directory [ o.k. ] Installing packages [ linux-image-cubox ] /usr/src/amp/lib/boards.sh: line 186: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory /usr/src/amp/lib/boards.sh: line 187: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory /usr/src/amp/lib/boards.sh: line 188: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory /usr/src/amp/lib/boards.sh: line 189: /usr/src/amp/output/cache/sdcard/etc/default/cpufrequtils: No such file or directory rm: cannot remove ‘/usr/src/amp/output/cache/sdcard/etc/resolv.conf’: No such file or directory cp: target ‘/usr/src/amp/output/cache/sdcard/etc/network/’ is not a directory ln: failed to create symbolic link ‘/usr/src/amp/output/cache/sdcard/etc/network/interfaces’: No such file or directory mount: mount point /usr/src/amp/output/cache/sdcard/tmp is not a directory chroot: failed to run command ‘/bin/bash’: No such file or directory [ o.k. ] Installing u-boot [ linux-u-boot-cubox-i ] chroot: failed to run command ‘/bin/bash’: No such file or directory [ o.k. ] Installing headers [ linux-headers-cubox ] chroot: failed to run command ‘/bin/bash’: No such file or directory cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/boot/boot.bmp’: No such file or directory checkdir: cannot create extraction directory: /usr/src/amp/output/cache/sdcard/lib/firmware No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/lirc/hardware.conf: No such file or directory sed: can't read /usr/src/amp/output/cache/sdcard/etc/lirc/hardware.conf: No such file or directory cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/etc/lirc/lircd.conf’: No such file or directory cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/usr/local/bin/brcm_patchram_plus’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory [ o.k. ] Install board support package [ cubox-i ] chroot: failed to run command ‘/bin/bash’: No such file or directory chroot: failed to run command ‘/bin/bash’: No such file or directory [ o.k. ] Creating boot scripts [ cubox-i ] cp: cannot create regular file ‘/usr/src/amp/output/cache/sdcard/boot/boot.cmd’: No such file or directory umount: /usr/src/amp/output/cache/sdcard/tmp: not mounted [ o.k. ] Installing extra applications and drivers [ o.k. ] Building deb [ hostapd ] [ o.k. ] Downloading sources [ hostapd ] /usr/src/amp/lib/extras/hostapd.sh: line 103: cd: /usr/src/amp/output/cache/sdcard/tmp/hostap: Not a directory cat: /usr/src/amp/output/cache/sdcard/tmp/hostap/src/common/version.h: Not a directory [ o.k. ] Compiling [ v ] cp: failed to access ‘/usr/src/amp/output/cache/sdcard/tmp/hostap/src/drivers/’: Not a directory cp: failed to access ‘/usr/src/amp/output/cache/sdcard/tmp/hostap/hostapd/.config’: Not a directory cat: /usr/src/amp/output/cache/sdcard/tmp/hostap/hostapd/main.c: Not a directory [ error ] Not built [ hostapd ] [ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:516 ] [ error ] debootstrap-ng was interrupted [ o.k. ] Process terminated make: *** [all] Error 255
zador.blood.stained Posted May 2, 2016 Posted May 2, 2016 wheezy-ng-armhf.dbd...9ec.tgz: 51.2MB cache file size is too small, please delete output/cache/rootfs/ directory and try again. Also please set EXTERNAL="no" in compile.sh
dhlii Posted May 2, 2016 Author Posted May 2, 2016 Still no go. Running in an Ubuntu 14.04 VM This worked under something like 5.07 Free space on VM after failure Filesystem 1K-blocks Used Available Use% Mounted on udev 368144 4 368140 1% /dev tmpfs 75884 476 75408 1% /run /dev/sda1 7350760 4841688 2112632 70% / none 4 0 4 0% /sys/fs/cgroup none 5120 0 5120 0% /run/lock none 379400 0 379400 0% /run/shm none 102400 0 102400 0% /run/user Command Line ./compile.sh BOARD=cubox-i KERNEL_ONLY=no PROGRESS_DISPLAY=plain RELEASE=wheezy KERNEL_CONFIGURE=yes KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=no BUILD_DESKTOP=no BRANCH=default EXTERNAL=no .... [ o.k. ] Installing packages for [ Armbian ] Reading package lists... Building dependency tree... Reading state information... Package acpid is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package rfkill is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package libbluetooth3 is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package bash-completion is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source However the following packages replace it: bash Package bluez is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package psmisc is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package lsof is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package bc is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package ca-certificates is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package pkg-config is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package build-essential is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package parted is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package cmake is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package vim is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package makedev is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package bridge-utils is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package less is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package rsync is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package fping is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package initramfs-tools is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package libtool is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package hdparm is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package ncurses-term is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package automake is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package dosfstools is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package fake-hwclock is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package dialog is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package console-common is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package console-setup is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package usbutils is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package pciutils is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package kbd is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'automake' has no installation candidate E: Package 'bash-completion' has no installation candidate E: Package 'bc' has no installation candidate E: Package 'bridge-utils' has no installation candidate E: Package 'build-essential' has no installation candidate E: Package 'cmake' has no installation candidate E: Unable to locate package cpufrequtils E: Unable to locate package device-tree-compiler E: Package 'dosfstools' has no installation candidate E: Unable to locate package figlet E: Unable to locate package fbset E: Package 'fping' has no installation candidate E: Unable to locate package haveged E: Package 'hdparm' has no installation candidate E: Unable to locate package ifenslave-2.6 E: Couldn't find any package by regex 'ifenslave-2.6' E: Unable to locate package iw E: Package 'libtool' has no installation candidate E: Unable to locate package libwrap0-dev E: Unable to locate package lirc E: Package 'lsof' has no installation candidate E: Package 'fake-hwclock' has no installation candidate E: Unable to locate package libusb-dev E: Package 'psmisc' has no installation candidate E: Package 'parted' has no installation candidate E: Package 'pkg-config' has no installation candidate E: Unable to locate package pv E: Package 'rfkill' has no installation candidate E: Package 'rsync' has no installation candidate E: Package 'dialog' has no installation candidate E: Unable to locate package crda E: Unable to locate package wireless-regdb E: Package 'ncurses-term' has no installation candidate E: Unable to locate package sysfsutils E: Unable to locate package toilet E: Unable to locate package u-boot-tools E: Package 'usbutils' has no installation candidate E: Unable to locate package vlan E: Unable to locate package wireless-tools E: Unable to locate package libnl-3-dev E: Package 'console-setup' has no installation candidate E: Unable to locate package console-data E: Package 'console-common' has no installation candidate E: Unable to locate package unicode-data E: Unable to locate package libmtp-runtime E: Package 'initramfs-tools' has no installation candidate E: Package 'ca-certificates' has no installation candidate E: Package 'less' has no installation candidate E: Package 'makedev' has no installation candidate E: Package 'kbd' has no installation candidate E: Package 'acpid' has no installation candidate E: Unable to locate package libnl-genl-3-dev E: Unable to locate package alsa-utils E: Unable to locate package btrfs-tools E: Package 'bluez' has no installation candidate E: Unable to locate package hddtemp E: Unable to locate package i2c-tools E: Unable to locate package iperf E: Unable to locate package ir-keytable E: Unable to locate package iotop E: Unable to locate package iozone3 E: Unable to locate package weather-util E: Unable to locate package weather-util-data E: Unable to locate package stress E: Unable to locate package dvb-apps E: Unable to locate package sysbench E: Unable to locate package libbluetooth-dev E: Package 'libbluetooth3' has no installation candidate E: Package 'vim' has no installation candidate E: Package 'pciutils' has no installation candidate E: Unable to locate package evtest E: Unable to locate package htop E: Unable to locate package mtp-tools E: Unable to locate package python-smbus E: Unable to locate package libproc-processtable-perl E: Unable to locate package w-scan E: Unable to locate package f3 [ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:225 ] [ error ] Installation of Armbian packages failed [ o.k. ] Process terminated [ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:516 ] [ error ] debootstrap-ng was interrupted [ o.k. ] Process terminated make: *** [all] Error 255
zador.blood.stained Posted May 3, 2016 Posted May 3, 2016 Still it is a problem with downloading package lists. In case this is caused by apt-cacher-ng or debian mirror selection I'll add options to bypass apt-cacher-ng and to use preselected mirror for debootstrap process later.
dhlii Posted May 3, 2016 Author Posted May 3, 2016 If you can point me in the general direction I can look at that my self. While I have not delved very deep in Armbian yet, I am capable of dealing with scripts and embedded development.
zador.blood.stained Posted May 3, 2016 Posted May 3, 2016 Then try commenting out this line do disable apt-cacher for main packages installation procedure: https://github.com/igorpecovnik/lib/blob/master/debootstrap-ng.sh#L140 Also you can try changing mirrors in sources.list files for your target distribution: https://github.com/igorpecovnik/lib/tree/master/config/apt
dhlii Posted May 3, 2016 Author Posted May 3, 2016 Thank you. One of those two changes appears to have solved my problem. Additionally With the following change to a lxc linux container profile, I was able to build Armbian for a cubox-i under Debian Jessie in an ubuntu 14.04 lxc container. That is alot easier and less taxing of the computer than a virtual box VM. lxc.aa_profile = unconfined lxc.cgroup.devices.allow = b 7:* rwm lxc.cgroup.devices.allow = c 10:237 rwm ~
