Ali-leb Posted August 3, 2019 Posted August 3, 2019 first i was able to boot my nanopi from SD card and i was able to access it through SSH. then i was trying to boot my nanopi from EMMC but it was not booting. I already installed a different OS which is specialized for Eflasher (nanopi-neo-core_eflasher_friendlycore-xenial_4.14_armhf_20190522 ) . then i followed the steps carefully: http://wiki.friendlyarm.com/wiki/index. ... i_NEO_Core note : i was using commands since there is no HDMI. I typed : eflasher then i choose 1 and typed yes and waited until the OS was installed successfully and finally i powered off the nanopi, removed the SD card as mentioned, tried to power it on but i could not access it again through SSH anymore. I would if someone could help find the problem. or if someone would post the detailed steps to boot the nanopi NEO CORE from emmc using commands lines not HDMI. thanks in advance
Igor Posted August 3, 2019 Posted August 3, 2019 2 hours ago, Ali-leb said: detailed steps to boot the nanopi NEO CORE from emmc Download whatever you like:https://www.armbian.com/nanopi-neo/ Use manual: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb 2 hours ago, Ali-leb said: nanopi-neo-core_eflasher_friendlycore-xenial_4.14_armhf_20190522 No support for that. 1
X79133000 Posted August 4, 2019 Posted August 4, 2019 On 8/3/2019 at 8:03 AM, Igor said: Download whatever you like:https://www.armbian.com/nanopi-neo/ Use manual: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb No support for that. Trying to get the NanoPi Neo Air boot from EMMC, Did the following steps: 1- nand-sata-install 2- boot from eMMC / NAND, system on eMMC/NAND 3- Shutdown, and remove sd card, and reboot. 4- Get stuck in uboot. Any helps appreciated. Thanks This is what I get during boot: U-Boot SPL 2019.04-armbian (Jul 16 2019 - 00:07:29 +0200) DRAM: 512 MiB Trying to boot from MMC2 U-Boot 2019.04-armbian (Jul 16 2019 - 00:07:29 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: FriendlyARM NanoPi NEO Air DRAM: 512 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from EXT4... MMC: no card present In: serial Out: serial Err: serial Net: No ethernet found. starting USB... No controllers found Autoboot in 1 seconds, press <Space> to stop Card did not respond to voltage select! MMC: no card present starting USB... No controllers found USB is stopped. Please issue 'usb start' first. starting USB... No controllers found No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found starting USB... No controllers found No ethernet found. No ethernet found. =>
Igor Posted August 4, 2019 Posted August 4, 2019 46 minutes ago, X79133000 said: Any helps appreciated. Thanks This is what I get during boot: I can only confirm that something is wrong and I checked patches - they seems alright. It used to work in the past ... so something has been changed. Workaround is by using older builds - install and then update -> dl.armbian.com or wait until this is not resolved.
X79133000 Posted August 4, 2019 Posted August 4, 2019 Thank you, The older version worked. (Armbian_5.37_Nanopiair_Ubuntu_xenial_default_3.4.113) Will be waiting for the latest version with bug fixed.
Ali-leb Posted August 5, 2019 Author Posted August 5, 2019 On 8/3/2019 at 4:03 PM, Igor said: THANK YOU IT WORKED JUST SO FINE !!! Quote
Igor Posted August 5, 2019 Posted August 5, 2019 https://github.com/armbian/build/pull/1492 + Images on the download pages has been updated.
