A5X MAX+ box can't enter armbian, ask for help
Hey guys,
I bought the A5X MAX+ and the specification is rk3328, 4GB, 1GIB, usb3, android7.
I tried to burn the blewing roms on my USB flash drive and SD card:
Armbian_5.76_Rk3328-tv_Debian_stretch_default_4.4.154_20190306.IMG
Armbian_5.96_Rk3328-tv_Debian_buster_default_4.4.154_desktop_20190911.IMG
Armbian_5.96_Rk3328-tv_Ubuntu_bionic_default_4.4.154_20190911.img
And I tried to input the text "rk3328-a5x.dtb, rk3328-a5x-1500.dtb, rk3328-a5x-mx10.dtb, rk3328-evb.dtb" in "/extlinux/extlinux.conf",  the system entered android instead of armbian which i really wanted.
I followed the steps as belows:
1. Burn the SD card or USB flash drive;
2, edit: / extlinux / extlinux.conf
3. Insert the SD card or USB flash drive into the TV box;
4. Powered TV box;
The final result is that the system cannot enter armbian, but android.
Could you guys help me check where the problem is?
15 hours ago, JamesX said:
1. Burn the SD card or  AND  USB flash drive;
3. Insert the SD card or AND  USB flash drive into the TV box;
6 hours ago, balbes150 said:
I inserted the  USB flash drive and SD card (see picture), then plugged in the TV box power, the system still enters the Android system. I don't know which step is missing.
wasn't the a5x max+ the box, which cannot boot from sd, as the sd-card is connected to the wrong emmc port for that? - you may search the rk3328 tv box thread for how to flash it via usb connection
best wishes - hexdump
https://forum.armbian.com/topic/8082-armbian-for-tv-box-rk3328/?do=findComment&comment=81283
I tried the rom of this friend above and directly brushed in A5X MAX +. After the brushing is successful, the device has no response.
  • Werner locked this topic
