Nanopi M4: HTop recognizes all cores as little cores
I'm using Nanopi M4 installed Armbian Buster.
It works like charm but I found a strange behavior of the system.
In htop all cores are displayed as little core. but when I checked actual clocks in /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq big cores are doing well (up to 1.8GHz).
htop result:
lscpu results:
Architecture:        aarch64
Byte Order:          Little Endian
CPU(s):              6
On-line CPU(s) list: 0-5
Thread(s) per core:  1
Core(s) per socket:  3
Socket(s):           2
Vendor ID:           ARM
Model:               4
Model name:          Cortex-A53
Stepping:            r0p4
CPU max MHz:         1800.0000
CPU min MHz:         408.0000
BogoMIPS:            48.00
Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32
CPU SOCKET CORE ONLINE MAXMHZ    MINMHZ
0   0      0    yes    1416.0000 408.0000
1   0      1    yes    1416.0000 408.0000
2   0      2    yes    1416.0000 408.0000
3   0      3    yes    1416.0000 408.0000
4   1      4    yes    1800.0000 408.0000
5   1      5    yes    1800.0000 408.0000
Is this result normal?
Hi.
What version of Armbian are you running?
Also please give the result of sudo armbianmonitor -a
I'm using Armbian 5.90 Bionic on the M4, and for me it's noted right in HTop. CPU 5&6 are big.
It could be a bug in HTop, or somewhere else. I don't think this hinders functionality. You could run a 7zip benchmark to see if it performs normal.
You should get a score like this with Buster.
7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,6 CPUs LE)
LE
CPU Freq:  1735  1793  1795  1796  1792  1797  1797  1796  1797
RAM size:    1926 MB,  # CPU hardware threads:   6
RAM usage:   1323 MB,  # Benchmark threads:      6
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       4590   491    910   4466  |      94490   533   1513   8058
23:       4320   491    897   4402  |      92071   532   1497   7967
24:       4389   533    885   4719  |      89315   530   1479   7839
25:       4115   532    883   4699  |      86785   531   1455   7723
Avr:             512    894   4571  |              531   1486   7897
Tot:             522   1190   6234
I have a NanoPi Neo4 running "Debian Buster with Armbian Linux 4.4.190-rk3399" and I don't see this problem.
I see this in htop:
  On 9/23/2019 at 10:34 AM, NicoD said:
Hi.
Expand
using Armbian 5.95 Buster with kernel 4.4.190-rk3399.
I cannot find -a option for armbianmonitor.. but when I run 7zip benchmark with -z option, the result is similar to yours. It seems the cpu performance is ok.
Do you have any idea what problem caused this?
Expand
No idea. I'll see if I can recreate this with Buster 5.95.
I don't think it's a problem in the meaning of "problem". Just a small bug in either htop or Buster.
I rarely use htop. So others will know more about that.
Have the same issue with my XU4.
I have a workaround for this. Remove all files in /home/[username]/.config/htop and replace it with the files from /root/.config/htop
Then all cores are labeled with "big." and ".LITTLE" as usual. But as soon as you change the configuration (for example toggle "Tree" with F5), everything is broken again.
A deeper inspection shows, that it has something to do with the file /home/[username]/.config/htop/htoprc.
The config parameter "right_meters" is set incorrectly.
For my XU4 the proper params are:
right_meters=Hostname Tasks LoadAverage Uptime CpuFreq(1) CpuFreq(2) CpuFreq(3) CpuFreq(4) CpuFreq(5) CpuFreq(6) CpuFreq(7) CpuFreq(8)
HTOP shows the wrong labels when the params are:
right_meters=Hostname Tasks LoadAverage Uptime CpuFreq CpuFreq CpuFreq CpuFreq CpuFreq CpuFreq CpuFreq CpuFreq
Expand
Agree with you. I'll see the htop source code. Thanks!
Expand
You're right. my htoprc file is same as yours. when I delete and recreate the file it works properly. It might be bug in Armbian customized htop.
Try this:
hit F2, select each label on the Right column and delete all CpuFreq (meter). Then add the available meters again. Exit htop and check again.
There is a meter called CpuFreq and CpuFreq1,CpuFreq2,... (cpu count). I think the correct meters should be CpuFreq1,2,3...8 and not CpuFreq.
