djjerdog Posted October 25, 2019 Share Posted October 25, 2019 Trying to setup a build environment using vagrant, keep getting the following error. I've deleted everything and started over several times but keep getting stuck here. Any ideas what I'm doing wrong? vagrant@ubuntu-bionic:/vagrant$ sudo ./compile.sh [ o.k. ] Using config file [ /vagrant/userpatches/config-example.conf ] [ o.k. ] Preparing [ host ] [ o.k. ] Build host OS release [ bionic ] [ o.k. ] Syncing clock [ host ] [ o.k. ] Checking for external GCC compilers [ .... ] downloading using torrent network [ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz ] [ error ] ERROR in function download_and_verify [ general.sh:995 ] [ error ] verification failed [ o.k. ] Process terminated Link to comment Share on other sites More sharing options...
belfastraven Posted October 25, 2019 Share Posted October 25, 2019 I'm not sure exactly how you got to the point of this failure, which I think is some kind of "key" problem, but to test, I just deleted my armbian-builder box, and the build directory, recloned the build directory .i.e. git clone --depth 1 https://github.com/armbian/build cd 'd into build i.e. cd build and ran ./compile.sh vagrant This worked; it created the box and downloaded all the compilers properly... It seems that the "new" compile.sh from about three weeks ago actually does a lot more for one than the old methodolgy. (I believe it will even install vagrant and virtualbox if they are not there) You will be given the option to halt the box when your particular compile is finished. I think you can then get back into it by issuing the vagrant up vagrant ssh command s from the /build/userpatches directory. I'd be happy to change the doc to match what is actually going on if I understood whether I have a correct understanding of things, myself. :-) Link to comment Share on other sites More sharing options...
djjerdog Posted October 26, 2019 Author Share Posted October 26, 2019 Thanks @belfastraven for testing! I wasn't aware of using the "vagrant" switch, I was setting up vagrant manually following these instructions. https://docs.armbian.com/Developer-Guide_Using-Vagrant/ I still must be missing something though, I tried repeating your steps and received this. I'm using macOS (Catalina), I'm assuming this method is meant to be done on linux side? | => sudo ./compile.sh vagrant ./compile.sh: line 16: realpath: command not found ./compile.sh: line 77: systemd-detect-virt: command not found ./compile.sh: line 180: realpath: command not found [\e[0;32m .... ] Config file does not exist [\e[0;33m userpatches/config-vagrant.conf ] ________________________________________________________________________________ Link to comment Share on other sites More sharing options...
Igor Posted October 26, 2019 Share Posted October 26, 2019 4 hours ago, djjerdog said: I'm using macOS Automatic install only works on Debian based systems. Here you have to install Vagrant or Docker manually. And this new install was not tested on MacOS so I have no idea ... someone with Mac should check this. Bugs are possible. Link to comment Share on other sites More sharing options...
djjerdog Posted October 26, 2019 Author Share Posted October 26, 2019 Thanks for the info. I switched to Docker and the compiler is running now. 1 Link to comment Share on other sites More sharing options...
Raylynn Knight Posted November 11, 2019 Share Posted November 11, 2019 Perhaps the documentation should be update to prevent hours of frustration for those of us trying to use Vagrant on MacOS! This all used to work just fine on MacOS until recently. Link to comment Share on other sites More sharing options...
Igor Posted November 11, 2019 Share Posted November 11, 2019 4 hours ago, Raylynn Knight said: Perhaps the documentation should be update to prevent hours of frustration Still waiting for a MAC/Vagrant user that would write what shell be done and send a pull request to the documentation. Link to comment Share on other sites More sharing options...
