dragonlost Posted November 11, 2019 Posted November 11, 2019 I wanted to update my tinkerboard and my nanopi m4. I tested the following versions: - Armbian_5.98_Nanopim4_Ubuntu_bionic_default_4.4.192_desktop - Armbian_5.95_Tinkerboard_Ubuntu_bionic_default_4.4.190_desktop - Armbian_5.95_Tinkerboard_Ubuntu_bionic_default_4.4.190 with most of the ppa that I add I have the same error: 404 Not found [IP: 2001:67c:1560:8008::15 80] E: The repository 'http://ppa.launchpad.net/mutlaqja/libgphoto2/ubuntu focal release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default N: See apt-secure(8) manpage for repository creation and user configuration details. bug for PPA : http://ppa.launchpad.net/mutlaqja/libgphoto2 http://ppa.launchpad.net/nilarimogard/webupd8 http://ppa.launchpad.net/pch/phd2 not this bug for this PPA : http://ppa.launchpad.net/mutlaqja/ppa I do not understand, because all these PPA worked very well before and still works very well on a raspberry and a computer amd64 actually
dragonlost Posted November 11, 2019 Author Posted November 11, 2019 after sudo dpkg-reconfigure ca-certificates, problem not solve
Igor Posted November 11, 2019 Posted November 11, 2019 Is 3rd party software which you are trying to use on Armbian build for arm/arm64 ? If not, its normal that it fails.
dragonlost Posted November 11, 2019 Author Posted November 11, 2019 Yes, all this software is build for armhf/aarch64 my projet : https://github.com/Patrick-81/NAFABox everything worked fine until now
Igor Posted November 11, 2019 Posted November 11, 2019 What is your system time when you try to install packages?
dragonlost Posted November 11, 2019 Author Posted November 11, 2019 28 minutes ago, Igor said: What is your system time when you try to install packages? for all test my board is synchronize with internet time. I tested the same PPA on a raspberry Pi 4 on xubuntu and everything is very well done.
dragonlost Posted November 11, 2019 Author Posted November 11, 2019 1 hour ago, dragonlost said: for all test my board is synchronize with internet time. I tested the same PPA on a raspberry Pi 4 on xubuntu and everything is very well done. Apart from this problem no major problem. On armbian
Igor Posted November 11, 2019 Posted November 11, 2019 1 hour ago, dragonlost said: on xubuntu Do you use the same version of Ubuntu?
Igor Posted November 11, 2019 Posted November 11, 2019 There are changes http://ppa.launchpad.net/mutlaqja/libgphoto2/ubuntu/dists/bionic/ dated few days ago. Your problems started then?
dragonlost Posted November 11, 2019 Author Posted November 11, 2019 I tested the version: Armbian_5.90_Nanopim4_Ubuntu_bionic_default_4.4.179_desktop If I do "sudo apt update" then "sudo apt upgrade" I pass in 4.4.192 and I have the same error. By cons, if I freeze the kernel, and I made an update / upgrade, I can add without problem all the PPA. I tried on the basic version in 4.4.192 to pass in 4.4.179 but I still have the bug with some PPA.
dragonlost Posted November 11, 2019 Author Posted November 11, 2019 I tested the version: Armbian_5.90_Nanopim4_Ubuntu_bionic_default_4.4.179_desktop If I switch to 5.3.0-rc4 5.99.191102 no have error for PPA. I just have to test version 4.4.190 all this test is just for nanopim4 because she most faster board
dragonlost Posted November 12, 2019 Author Posted November 12, 2019 No bug on 4.4.190. Ppa bug is just for 4.4.192 on nanopi-m4 I will test on the tinkerboard.
dragonlost Posted November 12, 2019 Author Posted November 12, 2019 On 11/11/2019 at 5:55 PM, Igor said: There are changes http://ppa.launchpad.net/mutlaqja/libgphoto2/ubuntu/dists/bionic/ dated few days ago. Your problems started then? My last test is on june 2019 (on 4.4.190) for nanopi-m4 and tinkerboard.
dragonlost Posted November 16, 2019 Author Posted November 16, 2019 Hello. after a lot of tests: For nanopi-m4: the latest PPA bug-free version is: 4.4.190 For the tinkerboard: The latest PPA bug-free version of is: 4.4.182 I do not understand where this bug comes from but I test 2 ppa totally different: ppa:pch/phd2 ppa:mutlaqja/libgphoto2
dragonlost Posted December 14, 2019 Author Posted December 14, 2019 Hello @Igor I have finally understood the problem. From version 4.4.192 on nanopi and 4.4.190 on tinkerboard. When adding a PPA this one is automatically added with the sources for "focal" (20.04LTS) instead of "bionic" (18.04LTS). PPA which does not work, is not compatible with "focal", that is why.
dragonlost Posted December 14, 2019 Author Posted December 14, 2019 is same for 19.11.3 4.4.192 Nanopi Just need test last image for tinkerboard
dragonlost Posted December 14, 2019 Author Posted December 14, 2019 for example : (for phd2 ppa, but same for all other new ppa) : on /etc/apt/sources.list.d/pch-ubuntu-phd2-focal.list : deb http://ppa.launchpad.net/pch/phd2/ubuntu focal main All default source for armbian and ubuntu is on "bionic" (18.04lts)
Igor Posted December 14, 2019 Posted December 14, 2019 If this is a bug in 3rd party script you are wasting time. I can't fix it.
Igor Posted December 14, 2019 Posted December 14, 2019 8 minutes ago, dragonlost said: 3rd party script ? Anything that is not coded by us is 3rd party - all packages & scripts that come unchanged from Debian/Ubuntu repositories. This is simply not possible to cover bug fixing after 1000+ peoples code.
AwsTaha Posted December 30, 2019 Posted December 30, 2019 I am trying to install WireGuard on Armbian_19.11.3.346_Tinkerboard_bionic_legacy_4.4.199_desktop according to the setup instructions site https://www.wireguard.com/install/ the following commands gave this output: 1 aws@tinkerboard:~/Desktop$ sudo add-apt-repository ppa:wireguard/wireguard WireGuard is a novel VPN that runs inside the Linux Kernel. This is the Ubuntu packaging for WireGuard. More info may be found at its website, listed below. More info: https://www.wireguard.com/ Packages: wireguard wireguard-tools wireguard-dkms Install with: $ apt install wireguard For help, please contact <email address hidden> More info: https://launchpad.net/~wireguard/+archive/ubuntu/wireguard Press [ENTER] to continue or Ctrl-c to cancel adding it. Ign:1 http://ppa.launchpad.net/wireguard/wireguard/ubuntu focal InRelease Hit:2 http://ports.ubuntu.com bionic InRelease Hit:4 http://ports.ubuntu.com bionic-security InRelease Err:5 http://ppa.launchpad.net/wireguard/wireguard/ubuntu focal Release 404 Not Found [IP: 91.189.95.83 80] Hit:6 http://ports.ubuntu.com bionic-updates InRelease Hit:7 http://ports.ubuntu.com bionic-backports InRelease Hit:3 https://apt.armbian.com bionic InRelease Reading package lists... DoneE: The repository 'http://ppa.launchpad.net/wireguard/wireguard/ubuntu focal Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. 2 aws@tinkerboard:~/Desktop$ sudo apt-get install wireguard Reading package lists... Done Building dependency tree Reading state information... DoneE: Unable to locate package wireguard I tried to read and follow the posts on this thread https://forum.armbian.com/topic/4861-wireguard-on-armbian-tinkerboard/ however I could not get it installed. would you please help ?
Igor Posted December 30, 2019 Posted December 30, 2019 2 hours ago, AwsTaha said: would you please help ? If you are unable to fix things with information in this post, start with a clean image - it has been fixed. WG works out of the box with latest module and tools.
