armbian bug on the PPA
dragonlost
I wanted to update my tinkerboard and my nanopi m4.
I tested the following versions:
- Armbian_5.98_Nanopim4_Ubuntu_bionic_default_4.4.192_desktop
- Armbian_5.95_Tinkerboard_Ubuntu_bionic_default_4.4.190_desktop
with most of the ppa that I add I have the same error:
404 Not found [IP: 2001:67c:1560:8008::15 80]
E: The repository 'http://ppa.launchpad.net/mutlaqja/libgphoto2/ubuntu focal release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default
N: See apt-secure(8) manpage for repository creation and user configuration details.
bug for PPA :
http://ppa.launchpad.net/nilarimogard/webupd8
http://ppa.launchpad.net/pch/phd2
not this bug for this PPA :
http://ppa.launchpad.net/mutlaqja/ppa
I do not understand, because all these PPA worked very well before and still works very well on a raspberry and a computer amd64 actually
I tested the version: Armbian_5.90_Nanopim4_Ubuntu_bionic_default_4.4.179_desktop
If I do "sudo apt update" then "sudo apt upgrade" I pass in 4.4.192 and I have the same error.
By cons, if I freeze the kernel, and I made an update / upgrade, I can add without problem all the PPA.
I tried on the basic version in 4.4.192 to pass in 4.4.179 but I still have the bug with some PPA.
If I switch to 5.3.0-rc4 5.99.191102 no have error for PPA.
I just have to test version 4.4.190
all this test is just for nanopim4 because she most faster board
Hello.
after a lot of tests:
For nanopi-m4:
the latest PPA bug-free version is: 4.4.190
For the tinkerboard:
The latest PPA bug-free version of is: 4.4.182
I do not understand where this bug comes from but I test 2 ppa totally different:
ppa:pch/phd2
ppa:mutlaqja/libgphoto2
Hello @Igor
I have finally understood the problem. From version 4.4.192 on nanopi and 4.4.190 on tinkerboard. When adding a PPA this one is automatically added with the sources for "focal" (20.04LTS) instead of "bionic" (18.04LTS).
PPA which does not work, is not compatible with "focal", that is why.
8 minutes ago, dragonlost said:
3rd party script ?
Anything that is not coded by us is 3rd party - all packages & scripts that come unchanged from Debian/Ubuntu repositories. This is simply not possible to cover bug fixing after 1000+ peoples code.
I am trying to install WireGuard on Armbian_19.11.3.346_Tinkerboard_bionic_legacy_4.4.199_desktop
according to the setup instructions site https://www.wireguard.com/install/
the following commands gave this output:
1
aws@tinkerboard:~/Desktop$ sudo add-apt-repository ppa:wireguard/wireguard
 WireGuard is a novel VPN that runs inside the Linux Kernel. This is the Ubuntu packaging for WireGuard. More info may be found at its website, listed below.
More info: https://www.wireguard.com/
Packages: wireguard wireguard-tools wireguard-dkms
Install with: $ apt install wireguard
For help, please contact <email address hidden>
 More info: https://launchpad.net/~wireguard/+archive/ubuntu/wireguard
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Ign:1 http://ppa.launchpad.net/wireguard/wireguard/ubuntu focal InRelease
Hit:2 http://ports.ubuntu.com bionic InRelease
Hit:4 http://ports.ubuntu.com bionic-security InRelease
Err:5 http://ppa.launchpad.net/wireguard/wireguard/ubuntu focal Release
  404  Not Found [IP: 91.189.95.83 80]
Hit:6 http://ports.ubuntu.com bionic-updates InRelease
Hit:7 http://ports.ubuntu.com bionic-backports InRelease
Hit:3 https://apt.armbian.com bionic InRelease
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/wireguard/wireguard/ubuntu focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
2 aws@tinkerboard:~/Desktop$ sudo apt-get install wireguard
Building dependency tree
E: Unable to locate package wireguard
I tried to read and follow the posts on this thread https://forum.armbian.com/topic/4861-wireguard-on-armbian-tinkerboard/
however I could not get it installed.
would you please help ?
If you are unable to fix things with information in this post, start with a clean image - it has been fixed. WG works out of the box with latest module and tools.
